[RSB 5 PATCH 1/3] sb/execute: Fix incremental decoder with --dry-run
chrisj at rtems.org
chrisj at rtems.org
Fri Sep 30 07:15:13 UTC 2022
Closes #4734
source-builder/sb/execute.py | 7 +++++--
1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/source-builder/sb/execute.py b/source-builder/sb/execute.py
index f470aba..e3809ec 100755
--- a/source-builder/sb/execute.py
+++ b/source-builder/sb/execute.py
@@ -182,7 +182,10 @@ class execute(object):
if trace_threads:
print('execute:_readthread: start')
- decoder = codecs.getincrementaldecoder(sys.stdout.encoding)()
+ if sys.stdout.encoding is not None:
+ decoder = codecs.getincrementaldecoder(sys.stdout.encoding)()
+ else:
+ decoder = None
count = 0
line = ''
try:
@@ -202,7 +205,7 @@ class execute(object):
_output_line(line + '\n', exe, prefix, out, count)
break
# str and bytes are the same type in Python2
- if type(data) is not str and type(data) is bytes:
+ if decoder is not None and type(data) is not str and type(data) is bytes:
data = decoder.decode(data)
last_ch = data[-1]
sd = (line + data).split('\n')
2.37.1
