[RSB 5 PATCH 2/3] sb/set-bulder: Fix installing builds when a single buildset
chrisj at rtems.org
chrisj at rtems.org
Fri Sep 30 07:15:14 UTC 2022
- Always stage a build
- Install if installable and outter most buildset instance
Closes #4731
source-builder/sb/setbuilder.py | 15 +++++++--------
1 file changed, 7 insertions(+), 8 deletions(-)
diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
index db9446f..41f5589 100644
--- a/source-builder/sb/setbuilder.py
+++ b/source-builder/sb/setbuilder.py
@@ -227,7 +227,7 @@ class buildset:
return self.install_mode() == 'installing'
def installable(self):
- return not self.opts.no_install() or self.staging()
+ return not self.opts.no_install() and self.installing()
def staging(self):
return not self.installing()
@@ -436,7 +436,7 @@ class buildset:
# If installing switch to staging. Not sure if this is still
# needed.
- if self.installing():
+ if nesting_count > 1 and self.installing():
self.macros['install_mode'] = 'staging'
try:
@@ -538,10 +538,10 @@ class buildset:
# Installing or staging ...
- log.trace('_bset: %2d: %s: deps:%r no-install:%r' % \
+ log.trace('_bset: %2d: mode: %s: deps:%r no-install:%r' % \
(nesting_count, self.install_mode(),
deps is None, self.opts.no_install()))
- log.trace('_bset: %2d: %s: builds: %s' % \
+ log.trace('_bset: %2d: mode: %s: builds: %s' % \
', '.join([b.name() for b in builds])))
if deps is None and not have_errors:
@@ -551,10 +551,9 @@ class buildset:
if b.installable():
prefix = b.config.expand('%{_prefix}')
buildroot = path.join(b.config.expand('%{buildroot}'), prefix)
- if self.staging():
- prefix = b.config.expand('%{stagingroot}')
+ self.install('staging', b.name(), buildroot, b.config.expand('%{stagingroot}'))
if self.installable():
- self.install(self.install_mode(), b.name(), buildroot, prefix)
+ self.install('installing', b.name(), buildroot, prefix)
# Sizes ...
@@ -610,7 +609,7 @@ class buildset:
# If builds have been staged install into the final prefix.
- if not have_errors:
+ if self.installing() and not have_errors:
stagingroot = macro_expand(self.macros, '%{stagingroot}')
have_stagingroot = path.exists(stagingroot)
do_install = not self.opts.no_install()
2.37.1
