[PATCH 03/13] sptls02: Fix alignment check
Sebastian Huber
Fri Sep 30 09:21:26 UTC 2022
testsuites/sptests/sptls02/init.cc | 8 ++++++--
1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/testsuites/sptests/sptls02/init.cc b/testsuites/sptests/sptls02/init.cc
index e4791cffd6..39fc2a2a24 100644
--- a/testsuites/sptests/sptls02/init.cc
+++ b/testsuites/sptests/sptls02/init.cc
@@ -169,10 +169,14 @@ static void checkTLSValues()
rtems_test_assert(extern_int == 7);
rtems_test_assert(i123 == 123);
rtems_test_assert(a256 == 256);
- rtems_test_assert((a256 & 255) == 0);
+ uintptr_t addr = reinterpret_cast<uintptr_t>(&a256);
+ RTEMS_OBFUSCATE_VARIABLE(addr);
+ rtems_test_assert((addr % 256) == 0);
rtems_test_assert(i0 == 0);
rtems_test_assert(a512 == 0);
- rtems_test_assert((a512 & 511) == 0);
+ addr = reinterpret_cast<uintptr_t>(&a512);
+ rtems_test_assert((addr % 512) == 0);
rtems_test_assert(f456(false) == 456);
rtems_test_assert(f0(false) == 0);
rtems_test_assert(C::c789() == 789);
2.35.3
