[PATCH 04/13] score: Require power of two CPU_STACK_MINIMUM_SIZE
Fri Sep 30 09:21:27 UTC 2022
For most CPU ports this was already the case.  This makes it possible to use
the size as an object alignment using RTEMS_ALIGNED().
 cpukit/score/cpu/aarch64/include/rtems/score/cpu.h | 2 +-
 cpukit/score/cpu/moxie/include/rtems/score/cpu.h   | 2 +-
 cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h  | 3 ++-
 cpukit/score/src/percpuasm.c                       | 7 ++++++-
 4 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
index 399e0fc802..aa4f90f1a8 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
@@ -102,7 +102,7 @@
 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
-#define CPU_STACK_MINIMUM_SIZE (1024 * 10)
+#define CPU_STACK_MINIMUM_SIZE (1024 * 8)
 /* This could be either 4 or 8, depending on the ABI in use.
  * Could also use __LP64__ or __ILP32__ */
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
index b94d47ab31..cc1900a852 100644
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
@@ -228,7 +228,7 @@ typedef struct {
  *  XXX
-#define CPU_STACK_MINIMUM_SIZE          (1536)
+#define CPU_STACK_MINIMUM_SIZE          (2048)
  * Size of a pointer.
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
index 962fc486fc..9ef6f43eb9 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
@@ -554,7 +554,8 @@ extern Context_Control_fp _CPU_Null_fp_context;
  * @addtogroup RTEMSScoreCPUExampleContext
  * Should be large enough to run all RTEMS tests.  This ensures
- * that a "reasonable" small application should not have any problems.
+ * that a "reasonable" small application should not have any problems.  The
+ * size shall be a power of two.
  * Port Specific Information:
diff --git a/cpukit/score/src/percpuasm.c b/cpukit/score/src/percpuasm.c
index 6e5a727b76..4bd92be37d 100644
--- a/cpukit/score/src/percpuasm.c
+++ b/cpukit/score/src/percpuasm.c
@@ -44,7 +44,7 @@
 #define PER_CPU_IS_POWER_OF_TWO( value ) \
-  ( ( ( ( value ) - 1 ) & ( value ) ) == 0 )
+  ( ( value ) > 1 && ( ( ( value ) - 1 ) & ( value ) ) == 0 )
  * The minimum alignment of two is due to the Heap Handler which uses the
@@ -72,6 +72,11 @@ RTEMS_STATIC_ASSERT(
   CPU_STACK_ALIGNMENT
+RTEMS_STATIC_ASSERT(
+  PER_CPU_IS_POWER_OF_TWO( CPU_STACK_MINIMUM_SIZE ),
+  CPU_STACK_MINIMUM_SIZE
   sizeof(void *) == CPU_SIZEOF_POINTER,
   CPU_SIZEOF_POINTER
2.35.3
