[PATCH 06/13] config: Add rtems_malloc_task_stack_for_idle()
Sebastian Huber
Fri Sep 30 09:21:29 UTC 2022
Update #4524.
cpukit/doxygen/appl-config.h | 13 +++++
cpukit/include/rtems/rtems/config.h | 29 +++++++++-
cpukit/include/rtems/score/interr.h | 1 +
cpukit/sapi/src/interrtext.c | 3 +-
cpukit/sapi/src/malloctaskstackforidle.c | 59 +++++++++++++++++++++
spec/build/cpukit/librtemscpu.yml | 1 +
spec/build/testsuites/sptests/grp.yml | 2 +
spec/build/testsuites/sptests/spfatal36.yml | 19 +++++++
testsuites/sptests/spfatal36/init.c | 52 ++++++++++++++++++
testsuites/sptests/spfatal36/spfatal36.doc | 11 ++++
testsuites/sptests/spinternalerror02/init.c | 2 +-
testsuites/sptests/sptls04/init.c | 2 +
12 files changed, 191 insertions(+), 3 deletions(-)
create mode 100644 cpukit/sapi/src/malloctaskstackforidle.c
create mode 100644 spec/build/testsuites/sptests/spfatal36.yml
create mode 100644 testsuites/sptests/spfatal36/init.c
create mode 100644 testsuites/sptests/spfatal36/spfatal36.doc
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index aa6dbae648..ee647dc961 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -4842,6 +4842,19 @@
* configuration options. It is assumed that any memory allocated for the
* stack of an IDLE task will not be from the RTEMS Workspace or the memory
* statically allocated by default.
+ * For applications with a thread-local storage size which is completely
+ * unknown at the time the application configuration is defined, RTEMS provides
+ * an IDLE task stack allocator which uses rtems_malloc(). The size of the
+ * allocated thread storage area is the sum of stack size defined by the
+ * #CONFIGURE_IDLE_TASK_STACK_SIZE configuration option and the actual
+ * thread-local storage size of the application. Define this configuration
+ * option to ``rtems_malloc_task_stack_for_idle`` to use this allocator. If
+ * the memory allocation fails, then the system terminates with the
+ * INTERNAL_ERROR_CORE fatal source and the
+ * INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK fatal code during system
+ * initialization.
+ * @endparblock
#define CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE
diff --git a/cpukit/include/rtems/rtems/config.h b/cpukit/include/rtems/rtems/config.h
index 3d813c55b6..7c7f1e3aa3 100644
--- a/cpukit/include/rtems/rtems/config.h
+++ b/cpukit/include/rtems/rtems/config.h
@@ -10,7 +10,7 @@
- * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2020, 2022 embedded brains GmbH (http://www.embedded-brains.de)
* Copyright (C) 1989, 2008 On-Line Applications Research Corporation (OAR)
@@ -58,6 +58,7 @@
#define _RTEMS_RTEMS_CONFIG_H
#include <stdbool.h>
+#include <stddef.h>
#include <stdint.h>
@@ -328,6 +329,32 @@ uint32_t rtems_configuration_get_maximum_tasks( void );
uint32_t rtems_configuration_get_maximum_timers( void );
+/* Generated from spec:/rtems/config/if/malloc-task-stack-for-idle */
+ * @ingroup RTEMSAPIConfig
+ * @brief Allocates a thread storage area for an IDLE task using
+ * rtems_malloc().
+ * @param unused is an unused parameter.
+ * @param[in,out] size is the pointer to an size_t object. At function entry,
+ * the object contains the size of the thread storage area not accounting for
+ * the thread-local storage size. When the directive call is successful, the
+ * size of the allocated thread storage area will be stored in this object.
+ * The thread storage size is determined by the #CONFIGURE_IDLE_TASK_STACK_SIZE
+ * application configuration option and the actual thread-local storage size of
+ * the application. The memory is allocated using rtems_malloc().
+ * @return Returns the begin address of the allocated thread storage area.
+ * @par Notes
+ * See #CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE.
+void *rtems_malloc_task_stack_for_idle( uint32_t unused, size_t *size );
#ifdef __cplusplus
#endif
diff --git a/cpukit/include/rtems/score/interr.h b/cpukit/include/rtems/score/interr.h
index ae4966d6d8..6e6926ab61 100644
--- a/cpukit/include/rtems/score/interr.h
+++ b/cpukit/include/rtems/score/interr.h
@@ -229,6 +229,7 @@ typedef enum {
INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA = 40,
INTERNAL_ERROR_TOO_LARGE_TLS_SIZE = 41,
INTERNAL_ERROR_RTEMS_INIT_TASK_CONSTRUCT_FAILED = 42,
+ INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK = 43
} Internal_errors_Core_list;
typedef CPU_Uint32ptr Internal_errors_t;
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index 383cc5bc0a..005cdc4508 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -83,7 +83,8 @@ static const char *const internal_error_text[] = {
"INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL",
"INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA",
"INTERNAL_ERROR_TOO_LARGE_TLS_SIZE",
- "INTERNAL_ERROR_RTEMS_INIT_TASK_CONSTRUCT_FAILED"
+ "INTERNAL_ERROR_RTEMS_INIT_TASK_CONSTRUCT_FAILED",
+ "INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK"
const char *rtems_internal_error_text( rtems_fatal_code error )
diff --git a/cpukit/sapi/src/malloctaskstackforidle.c b/cpukit/sapi/src/malloctaskstackforidle.c
new file mode 100644
index 0000000000..c136a6ad4b
--- /dev/null
+++ b/cpukit/sapi/src/malloctaskstackforidle.c
@@ -0,0 +1,59 @@
+ * @file
+ * @brief This source file contains the implementation of
+ * rtems_malloc_task_stack_for_idle().
+ * Copyright (C) 2022 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/config.h>
+#include <rtems/malloc.h>
+#include <rtems/score/interr.h>
+#include <rtems/score/tls.h>
+ void *area;
+ (void) unused;
+ *size += _TLS_Get_allocation_size();
+ area = rtems_malloc( *size );
+ if ( area == NULL ) {
+ _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK );
+ return area;
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index f034f3fadf..57c97d9213 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1363,6 +1363,7 @@ source:
- cpukit/sapi/src/ioregisterdriver.c
- cpukit/sapi/src/iounregisterdriver.c
- cpukit/sapi/src/iowrite.c
+- cpukit/sapi/src/malloctaskstackforidle.c
- cpukit/sapi/src/panic.c
- cpukit/sapi/src/profilingiterate.c
- cpukit/sapi/src/profilingreportxml.c
diff --git a/spec/build/testsuites/sptests/grp.yml b/spec/build/testsuites/sptests/grp.yml
index c8f70ed13b..b14eefb145 100644
--- a/spec/build/testsuites/sptests/grp.yml
+++ b/spec/build/testsuites/sptests/grp.yml
@@ -258,6 +258,8 @@ links:
uid: spfatal34
- role: build-dependency
uid: spfatal35
+- role: build-dependency
+ uid: spfatal36
uid: spfifo01
diff --git a/spec/build/testsuites/sptests/spfatal36.yml b/spec/build/testsuites/sptests/spfatal36.yml
index 0000000000..9e623e3511
--- /dev/null
+++ b/spec/build/testsuites/sptests/spfatal36.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2022 embedded brains GmbH
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spfatal36/init.c
+stlib: []
+target: testsuites/sptests/spfatal36.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/sptests/spfatal36/init.c b/testsuites/sptests/spfatal36/init.c
index 0000000000..78a9bc9082
--- /dev/null
+++ b/testsuites/sptests/spfatal36/init.c
@@ -0,0 +1,52 @@
+ * are met:
+#endif
+#include "../spfatal_support/spfatal.h"
+#define FATAL_ERROR_TEST_NAME "36"
+#define FATAL_ERROR_DESCRIPTION "failure in idle task stack allocation"
+#define FATAL_ERROR_EXPECTED_SOURCE INTERNAL_ERROR_CORE
+#define FATAL_ERROR_EXPECTED_ERROR \
+#define CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE rtems_malloc_task_stack_for_idle
+#define CONFIGURE_IDLE_TASK_STACK_SIZE ( SIZE_MAX - RTEMS_MINIMUM_STACK_SIZE )
+static void force_error( void )
+ RTEMS_UNREACHABLE();
+#include "../spfatal_support/spfatalimpl.h"
diff --git a/testsuites/sptests/spfatal36/spfatal36.doc b/testsuites/sptests/spfatal36/spfatal36.doc
index 0000000000..bf4a0d492d
--- /dev/null
+++ b/testsuites/sptests/spfatal36/spfatal36.doc
@@ -0,0 +1,11 @@
+This file describes the concepts tested by this test set.
+test set name: spfatal36
+directives:
+ - rtems_malloc_task_stack_for_idle()
+concepts:
+ - Provoke a memory allocation failure in the directive.
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index 08aeabd3a7..e139547ca5 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -49,7 +49,7 @@ static void test_internal_error_text(void)
} while ( text != text_last );
rtems_test_assert(
- error - 3 == INTERNAL_ERROR_RTEMS_INIT_TASK_CONSTRUCT_FAILED
+ error - 3 == INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK
diff --git a/testsuites/sptests/sptls04/init.c b/testsuites/sptests/sptls04/init.c
index 79ab5a5a9a..7239092185 100644
--- a/testsuites/sptests/sptls04/init.c
+++ b/testsuites/sptests/sptls04/init.c
@@ -63,6 +63,8 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
#define CONFIGURE_MAXIMUM_TASKS 1
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
2.35.3
