[PATCH 06/13] config: Add rtems_malloc_task_stack_for_idle()
Chris Johns
chrisj at rtems.org
Fri Sep 30 21:39:04 UTC 2022
On 30/9/2022 7:21 pm, Sebastian Huber wrote:
> Update #4524.
> cpukit/doxygen/appl-config.h | 13 +++++
> cpukit/include/rtems/rtems/config.h | 29 +++++++++-
> cpukit/include/rtems/score/interr.h | 1 +
> cpukit/sapi/src/interrtext.c | 3 +-
> cpukit/sapi/src/malloctaskstackforidle.c | 59 +++++++++++++++++++++
> spec/build/cpukit/librtemscpu.yml | 1 +
> spec/build/testsuites/sptests/grp.yml | 2 +
> spec/build/testsuites/sptests/spfatal36.yml | 19 +++++++
> testsuites/sptests/spfatal36/init.c | 52 ++++++++++++++++++
> testsuites/sptests/spfatal36/spfatal36.doc | 11 ++++
> testsuites/sptests/spinternalerror02/init.c | 2 +-
> testsuites/sptests/sptls04/init.c | 2 +
> 12 files changed, 191 insertions(+), 3 deletions(-)
> create mode 100644 cpukit/sapi/src/malloctaskstackforidle.c
> create mode 100644 spec/build/testsuites/sptests/spfatal36.yml
> create mode 100644 testsuites/sptests/spfatal36/init.c
> create mode 100644 testsuites/sptests/spfatal36/spfatal36.doc
> diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
> index aa6dbae648..ee647dc961 100644
> --- a/cpukit/doxygen/appl-config.h
> +++ b/cpukit/doxygen/appl-config.h
> @@ -4842,6 +4842,19 @@
> * configuration options. It is assumed that any memory allocated for the
> * stack of an IDLE task will not be from the RTEMS Workspace or the memory
> * statically allocated by default.
> + * For applications with a thread-local storage size which is completely
> + * unknown at the time the application configuration is defined, RTEMS provides
> + * an IDLE task stack allocator which uses rtems_malloc().
I thought the TLS size was static and set by the linker? Has this changed?
I am confused about the relationship between an unknown TLS size and IDLE task?
And the relationship of the TLS size and stack size?
> * * The size of the
> + * allocated thread storage area is the sum of stack size defined by the
> + * #CONFIGURE_IDLE_TASK_STACK_SIZE configuration option and the actual
> + * thread-local storage size of the application.
The label CONFIGURE_IDLE_TASK_STACK_SIZE provides no insight into it being
effected by the TLS size.
> * * Define this configuration
> + * option to ``rtems_malloc_task_stack_for_idle`` to use this allocator. If
> + * the memory allocation fails, then the system terminates with the
> + * INTERNAL_ERROR_CORE fatal source and the
> + * INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK fatal code during system
> + * initialization.
> + * @endparblock
I am confused about the how and why I would use this change?
Thanks
