[PATCH v2] docs/user: add docs for riscv/kendrytek210 BSP variant
Alan Cudmore alan.cudmore at gmail.com
Sat Apr 1 22:13:33 UTC 2023
Interesting - I get the same error when I run ticker on renode now. I just
tried it on a board and it works.
It also still passes the renode-test that I run, which includes ticker
ticker along with a dozen other tests. I'll look into why this does not
work right now.
Thanks,
Alan
On Sat, Apr 1, 2023 at 5:32 PM Hesham Almatary <heshamelmatary at gmail.com>
wrote:
> Thanks Alan! It Looks good to me. I'd appreciate your help with
> running on the simulator. I followed your documentation in this patch,
> but ticker seems to fatal error as follows:
> "*** FATAL ***
> fatal source: 6 (RTEMS_FATAL_SOURCE_BSP)
> CPU: 0
> fatal code: 3342 (0x00000d0e)
> RTEMS version: 6.0.0.4021b87e002a094fb0d8ddd099cb8483d6986c8b
> RTEMS tools: 12.2.1 20221121 (RTEMS 6, RSB
> 65f83cf973d6f1f8974ea1818e653753b83eaea8-modified, Newlib b9898fc)
> executing thread ID: 0x09010001
> executing thread name: IDLE"
> This is the log from Renode:
> 22:28:53.3268 [INFO] Loaded monitor commands from:
> /home/hesham/Downloads/renode_portable/scripts/monitor.py
> 22:28:58.0077 [INFO] Including script:
> /home/hesham/Downloads/renode_portable/scripts/single-node/kendryte_k210.resc
> 22:28:58.0181 [INFO] System bus created.
> 22:28:58.8437 [INFO] sysbus: Loading segment of 68760 bytes length at
> 0x80000000.
> 22:28:58.8568 [INFO] sysbus: Loading segment of 4096 bytes length at
> 0x80010C98.
> 22:28:58.8571 [INFO] sysbus: Loading segment of 6217728 bytes length
> at 0x80012000.
> 22:28:58.8783 [INFO] cpu1: Setting PC value to 0x80000000.
> 22:28:58.8793 [INFO] cpu2: Setting PC value to 0x80000000.
> 22:28:58.9003 [INFO] machine-0: Machine started.
> 22:28:58.9704 [WARNING] plic: Unhandled write to offset 0x200000, value
> 0x0.
> 22:28:58.9790 [WARNING] sysbus: [cpu1: 0x80009FE0] (tag:
> 'SYSCTL/clk_sel0') ReadDoubleWord from non existing peripheral at
> 0x50440020, returning 0x00000000.
> On Sat, 1 Apr 2023 at 21:22, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> > Hi Hesham,
> > I applied your suggestions and sent a v3 patch.
> > Thanks for the review,
> > Alan
> > On Sat, Apr 1, 2023 at 1:43 PM Hesham Almatary <heshamelmatary at gmail.com>
> wrote:
> >> On Fri, 31 Mar 2023 at 17:15, Alan Cudmore <alan.cudmore at gmail.com>
> wrote:
> >> > This patch adds the documentation for building and running RTEMS on
> the Kendryte K210
> >> > RISC-V SoC. The generic riscv introducion was re-arranged to list the
> multilib variants
> >> > then the specific hardware targets. In addition a couple of errors
> were fixed for the
> >> > generic QEMU commands.
> >> > V2 corrected a typo, expanded K210 Console UART parameters, and
> addded a hyperlink
> >> > to renode.io install instructions.
> >> > Closes #4876
> >> >  user/bsps/bsps-riscv.rst | 116
> >> >  1 file changed, 103 insertions(+), 13 deletions(-)
> >> > diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
> >> > index 41f369f..af79e6e 100644
> >> > --- a/user/bsps/bsps-riscv.rst
> >> > +++ b/user/bsps/bsps-riscv.rst
> >> > @@ -8,7 +8,7 @@ riscv (RISC-V)
> >> >  riscv
> >> > -This BSP offers 12 variants:
> >> > +**This BSP offers 10 variants, each corresponding to a GCC
> multilib:**
> >> We should probably remove the number as it changes and what we have in
> >> RTEMS might not be an exact match. i.e., "This BSP corresponds to
> >> multilib variants, with different RISC-V standard extensions" or
> >> something.
> >> >  * rv32i
> >> > @@ -30,23 +30,22 @@ This BSP offers 12 variants:
> >> >  * rv64imafdc
> >> > -* frdme310arty
> >> > -* mpfs64imafdc
> >> > -Each rv* variant corresponds to a GCC multilib.  A particular
> variant reflects an
> >> > -ISA with ABI and code model choice. All rv64 BSPs have medany code
> model by
> >> > +Each variant reflects an ISA with ABI and code model choice. All
> rv64 BSPs have medany code model by
> >> >  default, while rv32 BSPs are medlow. The reason is that RV32 medlow
> can access
> >> >  the entire 32-bit address space, while RV64 medlow can only access
> addresses
> >> >  below 0x80000000. With RV64 medany, it's possible to perform
> accesses above
> >> > -0x80000000.
> >> > +0x80000000. The BSP must be started in machine mode.
> >> > +The reference platform for the rv* variants is the QEMU `virt`
> machine.
> >> QEMU and Spike.
> >> > +**The BSP also provides the following 3 variants for specific
> hardware targets:**
> >> > -The BSP must be started im machine mode.
> >> > +* frdme310arty - The reference platform for this variant is the Arty
> FPGA board with the Sifive Freedom E310 reference design.
> >> > -The reference platform for this BSP is the QEMU `virt` machine.
> >> > +* mpfs64imafdc - The reference platform for this variant is the
> Microchip PolarFire SoC Icicle Kit.
> >> > +* kendrytek210 - The reference platform for this variant is the
> Kendryte K210 SoC on the Sipeed MAiX Bit or MAiXDuino board.
> >> > -The reference platform for the mpfs64imafdc BSP variant is the
> Microchip
> >> > -PolarFire SoC Icicle Kit.
> >> >  Build Configuration Options
> >> > @@ -90,6 +89,9 @@ configuration INI file. The ``waf`` defaults can be
> used to inspect the values.
> >> >       The maximum number of NS16550 devices supported by the console
> driver (2
> >> >       by default).
> >> > +``RISCV_ENABLE_SIFIVE_UART_SUPPORT``
> >> > +     Enable the Sifive console UART (disabled by default)
> >> np: SiFive.
> >> >  ``RISCV_RAM_REGION_BEGIN``
> >> >       The begin of the RAM region for linker command file (default is
> 0x80000000).
> >> > @@ -104,6 +106,10 @@ configuration INI file. The ``waf`` defaults can
> be used to inspect the values.
> >> >       Enables support Microchip PolarFire SoC if defined to a non-zero
> >> >       value, otherwise it is disabled (disabled by default).
> >> > +``RISCV_ENABLE_KENDRYTE_K210_SUPPORT``
> >> > +     Enables support for the Kendtryte K210 SoC if defined to a
> non-zero
> >> > +     value, otherwise it is disabled (disabled by default).
> >> >  ``RISCV_BOOT_HARTID``
> >> >       The boot hartid (processor number) of risc-v cpu by default 0.
> >> > @@ -131,7 +137,7 @@ The console driver supports devices compatible to
> >> >  * "ns16750" (see ``RISCV_CONSOLE_MAX_NS16550_DEVICES`` BSP option).
> >> > -* "sifive,uart0" (see ``RISCV_ENABLE_FRDME310ARTY_SUPPORT`` BSP
> option).
> >> > +* "sifive,uart0" (see ``RISCV_ENABLE_SIFIVE_UART_SUPPORT`` BSP
> option). This console driver is used by the frdme310arty and kendrytek210
> BSP variants.
> >> >  They are initialized according to the device tree.  The console
> driver does not
> >> >  configure the pins or peripheral clocks.  The console device is
> selected
> >> > @@ -145,11 +151,13 @@ and spike machines. For instance, to run the
> ``rv64imafdc`` BSP with the
> >> >  following "config.ini" file.
> >> >  .. code-block:: none
> >> >      [riscv/rv64imafdc]
> >> >  Run the following QEMU command.
> >> >  .. code-block:: shell
> >> >      $ qemu-system-riscv64 -M virt -nographic -bios $RTEMS_EXE
> >> >      $ qemu-system-riscv64 -M spike -nographic -bios $RTEMS_EXE
> >> > @@ -160,11 +168,13 @@ For instance, to run the ``rv64imafdc`` BSP
> with the following
> >> >  "config.ini" file.
> >> >      [riscv/rv64imafdc]
> >> >  Run the following Spike command.
> >> >      $ spike --isa=rv64imafdc $RTEMS_EXE
> >> >  Unlike QEMU, Spike supports enabling/disabling a subset of the
> imafdc extensions
> >> > @@ -277,6 +287,86 @@ Serial terminal UART1 displays the SMP example
> messages
> >> >      *** END OF TEST SMP 1 ***
> >> > +Kendryte K210
> >> > +The Kendryte K210 SoC is a dual core 64-bit RISC-V SoC with an AI
> NPU,
> >> > +built in SRAM, and a variety of peripherals. Currently just the
> console UART, interrupt controller, and timer are supported.
> >> > +The device tree blob is embedded in the ``kendrytek210`` BSP variant
> by default.
> >> > +When the kendrytek210 BSP variant is selected,
> ``BSP_DTB_IS_SUPPORTED`` enabled and the DTB header path
> >> > +``BSP_DTB_HEADER_PATH`` is set to bsp/kendryte-k210-dtb.h.
> >> > +The ``kendrytek210`` BSP variant has been tested on the following
> simulator and boards:
> >> > +* Renode.io simulator using the Kendrtye k210 model
> >> > +* Sipeed MAix BiT board
> >> > +* Sipeed MaixDuino board
> >> > +**Building the Kendryte K210 BSP**
> >> > +Configuration file ``config.ini``:
> >> > +.. code-block:: none
> >> > +    [riscv/kendrytek210]
> >> > +    RTEMS_SMP = True
> >> > +Build RTEMS:
> >> > +.. code-block:: shell
> >> > +    $ ./waf configure --prefix=$HOME/rtems-start/rtems/6
> >> > +    $ ./waf
> >> > +**Flash an executable to the Sipeed MAix BiT or MAixDuino board**
> >> > +Binary images can be flashed to the Sipeed boards through the USB
> port using the kflash.py utility available from the python pip utility.
> >> > +    $ riscv-rtems6-objcopy -Obinary ticker.exe ticker.bin
> >> > +    $ kflash.py --uart /dev/ttyUSB0 ticker.bin
> >> > +After the image is flashed, the RTEMS image will automatically boot.
> It will also run when the board is reset or powered through the USB cable.
> The USB port provides the power and console UART. Plug the USB cable into a
> host PC and bring up a terminal emulator at 115200 baud, 8 data bits, 1
> stop bit, no parity, and no flow control. On Linux the UART device is often
> ``/dev/ttyUSB0``.
> >> > +**Run a RTEMS application on the Renode.io simulator**
> >> > +RTEMS executables compiled with the kendrytek210 BSP can run on the
> renode.io simulator using the built-in K210 model. The simulator
> currently supports the console UART, interrupt controller, and timer.
> >> > +To install renode.io please refer to the `installation instructions
> <https://github.com/renode/renode#installation>`_. Once installed make a
> local copy of the ``kendryte_k210.resc`` script from the
> ``renode/scripts/single-node`` directory to a local directory where it can
> be edited. Edit the script and change the line that loads the Linux image
> to load a RTEMS elf image instead. The default extension for the RTEMS
> sample ELF images is ``.exe``.
> >> > +Change this line in the kendryte_k210.resc file:
> >> > +    sysbus LoadELF @
> https://dl.antmicro.com/projects/renode/kendryte-k210--vmlinux-s_2206416-2c1f2b2c2f2fc0c48a7b12a3f3c65809b81f452e
> >> > +To this:
> >> > +    sysbus LoadELF @ticker.exe
> >> > +After editing the script, start renode and load the
> kendryte_k210.resc script to start the emulation.
> >> > +    (monitor) s @kendryte_k210.resc
> >> > +You should see a renode UART window and the RTEMS ticker example
> output.
> >> > +**Generating the Device Tree Header**
> >> > +The kendrytek210 BSP uses a built in device tree blob. If additional
> peripheral support is added to the BSP, the device tree may need to be
> updated. After editing the device tree source, compile it to a device tree
> blob with the following command:
> >> > +    $ dtc -O dtb -b 0 -o kendryte-k210.dtb kendryte-k210.dts
> >> > +The dtb file can then be converted to a C array using the
> rtems-bin2c tool. The data for the device tree binary can then replace the
> existing device tree binary data in the ``kendryte-k210-dtb.h`` header file.
> >> >  noel
> >> > 2.25.1
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
> >> Regards,
> >> Hesham
> Regards,
> Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230401/6623b879/attachment-0001.htm>
