[PATCH v2] docs/user: add docs for riscv/kendrytek210 BSP variant
Alan Cudmore alan.cudmore at gmail.com
Sun Apr 2 00:17:56 UTC 2023
Hi Hesham,
I found a difference between the .resc file I use to run single tests and
the .resc file that the renode-test uses.
The resc file where ticker.exe fails has this extra statement:
$ex='machine SetSerialExecution True'
If I comment that out, ticker runs on Renode.
I couldn't find that in the documentation, so I'm going to have to search
the renode code to see what it does. I'm pretty sure I used to run
ticker.exe by itself without commenting out that line.
It's odd because a number of other examples work with the statement like
smp08.exe, unlimited.exe, hello.exe.
For reference, my renode-test setup for the K210 is here:
https://github.com/alanc98/k210-rtems-test
Note that if you run this, the rki test will fail unless you remove the
last test or build an RKI image for the k210:
https://github.com/alanc98/rki2/tree/rtems6
Alan
On Sat, Apr 1, 2023 at 6:13 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
> Interesting - I get the same error when I run ticker on renode now. I just
> tried it on a board and it works.
> It also still passes the renode-test that I run, which includes ticker
> ticker along with a dozen other tests. I'll look into why this does not
> work right now.
> Thanks,
> Alan
> On Sat, Apr 1, 2023 at 5:32 PM Hesham Almatary <heshamelmatary at gmail.com>
> wrote:
>> Thanks Alan! It Looks good to me. I'd appreciate your help with
>> running on the simulator. I followed your documentation in this patch,
>> but ticker seems to fatal error as follows:
>> "*** FATAL ***
>> fatal source: 6 (RTEMS_FATAL_SOURCE_BSP)
>> CPU: 0
>> fatal code: 3342 (0x00000d0e)
>> RTEMS version: 6.0.0.4021b87e002a094fb0d8ddd099cb8483d6986c8b
>> RTEMS tools: 12.2.1 20221121 (RTEMS 6, RSB
>> 65f83cf973d6f1f8974ea1818e653753b83eaea8-modified, Newlib b9898fc)
>> executing thread ID: 0x09010001
>> executing thread name: IDLE"
>> This is the log from Renode:
>> 22:28:53.3268 [INFO] Loaded monitor commands from:
>> /home/hesham/Downloads/renode_portable/scripts/monitor.py
>> 22:28:58.0077 [INFO] Including script:
>> /home/hesham/Downloads/renode_portable/scripts/single-node/kendryte_k210.resc
>> 22:28:58.0181 [INFO] System bus created.
>> 22:28:58.8437 [INFO] sysbus: Loading segment of 68760 bytes length at
>> 0x80000000.
>> 22:28:58.8568 [INFO] sysbus: Loading segment of 4096 bytes length at
>> 0x80010C98.
>> 22:28:58.8571 [INFO] sysbus: Loading segment of 6217728 bytes length
>> at 0x80012000.
>> 22:28:58.8783 [INFO] cpu1: Setting PC value to 0x80000000.
>> 22:28:58.8793 [INFO] cpu2: Setting PC value to 0x80000000.
>> 22:28:58.9003 [INFO] machine-0: Machine started.
>> 22:28:58.9704 [WARNING] plic: Unhandled write to offset 0x200000, value
>> 0x0.
>> 22:28:58.9790 [WARNING] sysbus: [cpu1: 0x80009FE0] (tag:
>> 'SYSCTL/clk_sel0') ReadDoubleWord from non existing peripheral at
>> 0x50440020, returning 0x00000000.
>> On Sat, 1 Apr 2023 at 21:22, Alan Cudmore <alan.cudmore at gmail.com> wrote:
>> > Hi Hesham,
>> > I applied your suggestions and sent a v3 patch.
>> > Thanks for the review,
>> > Alan
>> > On Sat, Apr 1, 2023 at 1:43 PM Hesham Almatary <
>> heshamelmatary at gmail.com> wrote:
>> >> On Fri, 31 Mar 2023 at 17:15, Alan Cudmore <alan.cudmore at gmail.com>
>> wrote:
>> >> > This patch adds the documentation for building and running RTEMS on
>> the Kendryte K210
>> >> > RISC-V SoC. The generic riscv introducion was re-arranged to list
>> the multilib variants
>> >> > then the specific hardware targets. In addition a couple of errors
>> were fixed for the
>> >> > generic QEMU commands.
>> >> > V2 corrected a typo, expanded K210 Console UART parameters, and
>> addded a hyperlink
>> >> > to renode.io install instructions.
>> >> > Closes #4876
>> >> >  user/bsps/bsps-riscv.rst | 116
>> >> >  1 file changed, 103 insertions(+), 13 deletions(-)
>> >> > diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
>> >> > index 41f369f..af79e6e 100644
>> >> > --- a/user/bsps/bsps-riscv.rst
>> >> > +++ b/user/bsps/bsps-riscv.rst
>> >> > @@ -8,7 +8,7 @@ riscv (RISC-V)
>> >> >  riscv
>> >> > -This BSP offers 12 variants:
>> >> > +**This BSP offers 10 variants, each corresponding to a GCC
>> multilib:**
>> >> We should probably remove the number as it changes and what we have in
>> >> RTEMS might not be an exact match. i.e., "This BSP corresponds to
>> >> multilib variants, with different RISC-V standard extensions" or
>> >> something.
>> >> >  * rv32i
>> >> > @@ -30,23 +30,22 @@ This BSP offers 12 variants:
>> >> >  * rv64imafdc
>> >> > -* frdme310arty
>> >> > -* mpfs64imafdc
>> >> > -Each rv* variant corresponds to a GCC multilib.  A particular
>> variant reflects an
>> >> > -ISA with ABI and code model choice. All rv64 BSPs have medany code
>> model by
>> >> > +Each variant reflects an ISA with ABI and code model choice. All
>> rv64 BSPs have medany code model by
>> >> >  default, while rv32 BSPs are medlow. The reason is that RV32 medlow
>> can access
>> >> >  the entire 32-bit address space, while RV64 medlow can only access
>> addresses
>> >> >  below 0x80000000. With RV64 medany, it's possible to perform
>> accesses above
>> >> > -0x80000000.
>> >> > +0x80000000. The BSP must be started in machine mode.
>> >> > +The reference platform for the rv* variants is the QEMU `virt`
>> machine.
>> >> QEMU and Spike.
>> >> > +**The BSP also provides the following 3 variants for specific
>> hardware targets:**
>> >> > -The BSP must be started im machine mode.
>> >> > +* frdme310arty - The reference platform for this variant is the
>> Arty FPGA board with the Sifive Freedom E310 reference design.
>> >> > -The reference platform for this BSP is the QEMU `virt` machine.
>> >> > +* mpfs64imafdc - The reference platform for this variant is the
>> Microchip PolarFire SoC Icicle Kit.
>> >> > +* kendrytek210 - The reference platform for this variant is the
>> Kendryte K210 SoC on the Sipeed MAiX Bit or MAiXDuino board.
>> >> > -The reference platform for the mpfs64imafdc BSP variant is the
>> Microchip
>> >> > -PolarFire SoC Icicle Kit.
>> >> >  Build Configuration Options
>> >> > @@ -90,6 +89,9 @@ configuration INI file. The ``waf`` defaults can
>> be used to inspect the values.
>> >> >       The maximum number of NS16550 devices supported by the console
>> driver (2
>> >> >       by default).
>> >> > +``RISCV_ENABLE_SIFIVE_UART_SUPPORT``
>> >> > +     Enable the Sifive console UART (disabled by default)
>> >> np: SiFive.
>> >> >  ``RISCV_RAM_REGION_BEGIN``
>> >> >       The begin of the RAM region for linker command file (default
>> is 0x80000000).
>> >> > @@ -104,6 +106,10 @@ configuration INI file. The ``waf`` defaults
>> can be used to inspect the values.
>> >> >       Enables support Microchip PolarFire SoC if defined to a
>> non-zero
>> >> >       value, otherwise it is disabled (disabled by default).
>> >> > +``RISCV_ENABLE_KENDRYTE_K210_SUPPORT``
>> >> > +     Enables support for the Kendtryte K210 SoC if defined to a
>> non-zero
>> >> > +     value, otherwise it is disabled (disabled by default).
>> >> >  ``RISCV_BOOT_HARTID``
>> >> >       The boot hartid (processor number) of risc-v cpu by default 0.
>> >> > @@ -131,7 +137,7 @@ The console driver supports devices compatible to
>> >> >  * "ns16750" (see ``RISCV_CONSOLE_MAX_NS16550_DEVICES`` BSP option).
>> >> > -* "sifive,uart0" (see ``RISCV_ENABLE_FRDME310ARTY_SUPPORT`` BSP
>> option).
>> >> > +* "sifive,uart0" (see ``RISCV_ENABLE_SIFIVE_UART_SUPPORT`` BSP
>> option). This console driver is used by the frdme310arty and kendrytek210
>> BSP variants.
>> >> >  They are initialized according to the device tree.  The console
>> driver does not
>> >> >  configure the pins or peripheral clocks.  The console device is
>> selected
>> >> > @@ -145,11 +151,13 @@ and spike machines. For instance, to run the
>> ``rv64imafdc`` BSP with the
>> >> >  following "config.ini" file.
>> >> >  .. code-block:: none
>> >> >      [riscv/rv64imafdc]
>> >> >  Run the following QEMU command.
>> >> >  .. code-block:: shell
>> >> >      $ qemu-system-riscv64 -M virt -nographic -bios $RTEMS_EXE
>> >> >      $ qemu-system-riscv64 -M spike -nographic -bios $RTEMS_EXE
>> >> > @@ -160,11 +168,13 @@ For instance, to run the ``rv64imafdc`` BSP
>> with the following
>> >> >  "config.ini" file.
>> >> >      [riscv/rv64imafdc]
>> >> >  Run the following Spike command.
>> >> >      $ spike --isa=rv64imafdc $RTEMS_EXE
>> >> >  Unlike QEMU, Spike supports enabling/disabling a subset of the
>> imafdc extensions
>> >> > @@ -277,6 +287,86 @@ Serial terminal UART1 displays the SMP example
>> messages
>> >> >      *** END OF TEST SMP 1 ***
>> >> > +Kendryte K210
>> >> > +The Kendryte K210 SoC is a dual core 64-bit RISC-V SoC with an AI
>> NPU,
>> >> > +built in SRAM, and a variety of peripherals. Currently just the
>> console UART, interrupt controller, and timer are supported.
>> >> > +The device tree blob is embedded in the ``kendrytek210`` BSP
>> variant by default.
>> >> > +When the kendrytek210 BSP variant is selected,
>> ``BSP_DTB_IS_SUPPORTED`` enabled and the DTB header path
>> >> > +``BSP_DTB_HEADER_PATH`` is set to bsp/kendryte-k210-dtb.h.
>> >> > +The ``kendrytek210`` BSP variant has been tested on the following
>> simulator and boards:
>> >> > +* Renode.io simulator using the Kendrtye k210 model
>> >> > +* Sipeed MAix BiT board
>> >> > +* Sipeed MaixDuino board
>> >> > +**Building the Kendryte K210 BSP**
>> >> > +Configuration file ``config.ini``:
>> >> > +.. code-block:: none
>> >> > +    [riscv/kendrytek210]
>> >> > +    RTEMS_SMP = True
>> >> > +Build RTEMS:
>> >> > +.. code-block:: shell
>> >> > +    $ ./waf configure --prefix=$HOME/rtems-start/rtems/6
>> >> > +    $ ./waf
>> >> > +**Flash an executable to the Sipeed MAix BiT or MAixDuino board**
>> >> > +Binary images can be flashed to the Sipeed boards through the USB
>> port using the kflash.py utility available from the python pip utility.
>> >> > +    $ riscv-rtems6-objcopy -Obinary ticker.exe ticker.bin
>> >> > +    $ kflash.py --uart /dev/ttyUSB0 ticker.bin
>> >> > +After the image is flashed, the RTEMS image will automatically
>> boot. It will also run when the board is reset or powered through the USB
>> cable. The USB port provides the power and console UART. Plug the USB cable
>> into a host PC and bring up a terminal emulator at 115200 baud, 8 data
>> bits, 1 stop bit, no parity, and no flow control. On Linux the UART device
>> is often ``/dev/ttyUSB0``.
>> >> > +**Run a RTEMS application on the Renode.io simulator**
>> >> > +RTEMS executables compiled with the kendrytek210 BSP can run on the
>> renode.io simulator using the built-in K210 model. The simulator
>> currently supports the console UART, interrupt controller, and timer.
>> >> > +To install renode.io please refer to the `installation
>> instructions <https://github.com/renode/renode#installation>`_. Once
>> installed make a local copy of the ``kendryte_k210.resc`` script from the
>> ``renode/scripts/single-node`` directory to a local directory where it can
>> be edited. Edit the script and change the line that loads the Linux image
>> to load a RTEMS elf image instead. The default extension for the RTEMS
>> sample ELF images is ``.exe``.
>> >> > +Change this line in the kendryte_k210.resc file:
>> >> > +    sysbus LoadELF @
>> https://dl.antmicro.com/projects/renode/kendryte-k210--vmlinux-s_2206416-2c1f2b2c2f2fc0c48a7b12a3f3c65809b81f452e
>> >> > +To this:
>> >> > +    sysbus LoadELF @ticker.exe
>> >> > +After editing the script, start renode and load the
>> kendryte_k210.resc script to start the emulation.
>> >> > +    (monitor) s @kendryte_k210.resc
>> >> > +You should see a renode UART window and the RTEMS ticker example
>> output.
>> >> > +**Generating the Device Tree Header**
>> >> > +The kendrytek210 BSP uses a built in device tree blob. If
>> additional peripheral support is added to the BSP, the device tree may need
>> to be updated. After editing the device tree source, compile it to a device
>> tree blob with the following command:
>> >> > +    $ dtc -O dtb -b 0 -o kendryte-k210.dtb kendryte-k210.dts
>> >> > +The dtb file can then be converted to a C array using the
>> rtems-bin2c tool. The data for the device tree binary can then replace the
>> existing device tree binary data in the ``kendryte-k210-dtb.h`` header file.
>> >> >  noel
>> >> > 2.25.1
>> >> > _______________________________________________
>> >> > devel mailing list
>> >> > devel at rtems.org
>> >> > http://lists.rtems.org/mailman/listinfo/devel
>> >> Regards,
>> >> Hesham
>> Regards,
>> Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230401/5295c4df/attachment-0001.htm>
