[lwip 3/6] tms570: Use new pin configuration API
Sebastian Huber
Tue Apr 4 14:55:13 UTC 2023
uLan/ports/driver/tms570_emac/tms570_netif.c | 55 +++++++++-----------
1 file changed, 25 insertions(+), 30 deletions(-)
diff --git a/uLan/ports/driver/tms570_emac/tms570_netif.c b/uLan/ports/driver/tms570_emac/tms570_netif.c
index c27f6d5..46e025a 100644
--- a/uLan/ports/driver/tms570_emac/tms570_netif.c
+++ b/uLan/ports/driver/tms570_emac/tms570_netif.c
@@ -78,10 +78,6 @@
/* take in account oversized frames */
#define MAX_TRANSFER_UNIT 1500
-#ifndef TMS570_MMR_SELECT_GMII_SEL
- #define TMS570_MMR_SELECT_GMII_SEL TMS570_BALL_XX_GMII_SEL
-#endif
#ifndef TMS570_BALL_K19_MII_RXCLK
#define TMS570_BALL_K19_MII_RXCLK TMS570_BALL_K19_MII_RX_CLK
#endif
@@ -333,35 +329,34 @@ tms570_eth_init_find_PHY(struct tms570_netif_state *nf_state)
return ERR_OK;
+static const uint32_t tms570_eth_pin_config[] = {
+ TMS570_MMR_SELECT_MII_MODE,
+ TMS570_BALL_V5_MDCLK,
+ TMS570_BALL_G3_MDIO,
+ TMS570_BALL_H19_MII_TXEN,
+ TMS570_BALL_E18_MII_TXD_3,
+ TMS570_BALL_R2_MII_TXD_2,
+ TMS570_BALL_J19_MII_TXD_1,
+ TMS570_BALL_J18_MII_TXD_0,
+ TMS570_BALL_D19_MII_TX_CLK,
+ TMS570_BALL_H18_MII_RXD_3,
+ TMS570_BALL_G19_MII_RXD_2,
+ TMS570_BALL_A14_MII_RXD_1,
+ TMS570_BALL_P1_MII_RXD_0,
+ TMS570_BALL_K19_MII_RXCLK,
+ TMS570_BALL_N19_MII_RX_ER,
+ TMS570_BALL_B11_MII_RX_DV,
+ TMS570_BALL_B4_MII_CRS,
+ TMS570_BALL_F3_MII_COL
static void
tms570_eth_init_set_pinmux(void)
-#if defined(__rtems__)
- TMS570_IOMM.KICK_REG0 = 0x83E70B13U;
- TMS570_IOMM.KICK_REG1 = 0x95A4F1E0U;
- tms570_bsp_pin_set_function(TMS570_BALL_V5_MDCLK, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_G3_MDIO, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_H19_MII_TXEN, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_E18_MII_TXD_3, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_R2_MII_TXD_2, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_J19_MII_TXD_1, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_J18_MII_TXD_0, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_D19_MII_TX_CLK, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_H18_MII_RXD_3, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_G19_MII_RXD_2, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_A14_MII_RXD_1, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_P1_MII_RXD_0, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_K19_MII_RXCLK, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_N19_MII_RX_ER, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_B11_MII_RX_DV, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_B4_MII_CRS, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_set_function(TMS570_BALL_F3_MII_COL, TMS570_PIN_FNC_AUTO);
- tms570_bsp_pin_clear_function(TMS570_MMR_SELECT_GMII_SEL, TMS570_PIN_FNC_AUTO);
- TMS570_IOMM.KICK_REG0 = 0;
- TMS570_IOMM.KICK_REG1 = 0;
-#endif /*__rtems__*/
+ tms570_pin_config_prepare();
+ tms570_pin_config_array_apply(tms570_eth_pin_config,
+ RTEMS_ARRAY_SIZE(tms570_eth_pin_config));
+ tms570_pin_config_complete();
static err_t
2.35.3
