[lwip 4/6] tms570: Add EMACUse100Mbps()
Sebastian Huber
Tue Apr 4 14:55:14 UTC 2023
uLan/ports/driver/tms570_emac/ti_drv_emac.h | 19 +++++++++++++++++++
uLan/ports/driver/tms570_emac/tms570_netif.c | 6 ++++++
2 files changed, 25 insertions(+)
diff --git a/uLan/ports/driver/tms570_emac/ti_drv_emac.h b/uLan/ports/driver/tms570_emac/ti_drv_emac.h
index 54f22c8..a829edd 100644
--- a/uLan/ports/driver/tms570_emac/ti_drv_emac.h
+++ b/uLan/ports/driver/tms570_emac/ti_drv_emac.h
@@ -163,6 +163,25 @@ EMACDuplexSet(volatile tms570_emacm_t *emacBase, int duplexMode)
+ * \brief This API sets the RMII interface speeed for MAC.
+ * \param emacBase Base address of the EMAC Module registers.
+ * \param use100Mbps indicates if the RMII interface speed shall be 100 Mbps.
+ * \return None
+static inline void
+EMACUse100Mbps(volatile tms570_emacm_t *emacBase, bool use100Mbps)
+ if (use100Mbps) {
+ emacBase->MACCONTROL |= TMS570_EMACM_MACCONTROL_RMIISPEED;
+ } else {
+ emacBase->MACCONTROL &= ~TMS570_EMACM_MACCONTROL_RMIISPEED;
* \brief API to enable the transmit in the TX Control Register
* After the transmit is enabled, any write to TXHDP of
diff --git a/uLan/ports/driver/tms570_emac/tms570_netif.c b/uLan/ports/driver/tms570_emac/tms570_netif.c
index 46e025a..b484a42 100644
--- a/uLan/ports/driver/tms570_emac/tms570_netif.c
+++ b/uLan/ports/driver/tms570_emac/tms570_netif.c
@@ -468,6 +468,12 @@ tms570_eth_init_hw_post_init(struct tms570_netif_state *nf_state)
return UNKN_DUPLEX_MODE;
+ if (regContent & (PHY_100BASETX_m | PHY_100BASETXDUPL_m)) {
+ EMACUse100Mbps(nf_state->emac_base, true);
+ } else {
+ EMACUse100Mbps(nf_state->emac_base, false);
/* enable hostpend interrupts in emac module */
nf_state->emac_base->MACINTMASKSET |= TMS570_EMACM_MACINTMASKSET_HOSTMASK;
2.35.3
