[lwip 5/6] tms570: Add endianess support
Sebastian Huber
Tue Apr 4 14:55:15 UTC 2023
uLan/ports/driver/tms570_emac/tms570_netif.c | 135 +++++++++++--------
1 file changed, 81 insertions(+), 54 deletions(-)
diff --git a/uLan/ports/driver/tms570_emac/tms570_netif.c b/uLan/ports/driver/tms570_emac/tms570_netif.c
index b484a42..4149bcb 100644
--- a/uLan/ports/driver/tms570_emac/tms570_netif.c
+++ b/uLan/ports/driver/tms570_emac/tms570_netif.c
@@ -148,6 +148,30 @@ static void tms570_eth_init_netif_fill(struct netif *netif);
static void tms570_eth_init_buffer_descriptors(struct tms570_netif_state *nf_state);
static void tms570_eth_init_set_pinmux();
+static inline uint32_t tms570_eth_swap(uint32_t word)
+#if TMS570_VARIANT == 4357
+ return __builtin_bswap32(word);
+#else
+ return word;
+#endif
+static inline uint8_t *tms570_eth_swap_bufptr(volatile void *p)
+ return (uint8_t *)tms570_eth_swap((uint32_t)p);
+static inline struct emac_tx_bd *tms570_eth_swap_txp(volatile struct emac_tx_bd *p)
+ return (struct emac_tx_bd *)tms570_eth_swap((uint32_t)p);
+static inline struct emac_rx_bd *tms570_eth_swap_rxp(volatile struct emac_rx_bd *p)
+ return (struct emac_rx_bd *)tms570_eth_swap((uint32_t)p);
/***** initializing functions **********************************************/
@@ -518,8 +542,10 @@ tms570_eth_init_buffer_descriptors(struct tms570_netif_state *nf_state)
* Initialize the Descriptor Memory For TX and RX
* Only Channel 0 is supported for both TX and RX
- txch->inactive_head = (volatile struct emac_tx_bd *)nf_state->emac_ctrl_ram;
- txch->inactive_tail = NULL;
+ /* Initialize all the TX buffer Descriptors */
+ curr_txbd = (volatile struct emac_tx_bd *)nf_state->emac_ctrl_ram;
+ txch->inactive_head = curr_txbd;
txch->active_head = NULL;
txch->active_tail = NULL;
@@ -531,38 +557,40 @@ tms570_eth_init_buffer_descriptors(struct tms570_netif_state *nf_state)
tms570_eth_debug_printf("pocet bd %d\n", num_bd);
#endif
- curr_txbd = txch->inactive_head;
- /* Initialize all the TX buffer Descriptors */
while (num_bd > 0) {
- curr_txbd->next = curr_txbd + 1;
+ volatile struct emac_tx_bd *next_txbd = curr_txbd + 1;
+ curr_txbd->next = tms570_eth_swap_txp(next_txbd);
curr_txbd->flags_pktlen = 0;
- txch->inactive_tail = curr_txbd;
- curr_txbd = curr_txbd->next;
- num_bd--;
+ curr_txbd = next_txbd;
+ --num_bd;
+ --curr_txbd;
curr_txbd->next = NULL;
+ txch->inactive_tail = curr_txbd;
/* Initialize the descriptors for the RX channel */
- rxch->inactive_head = ((volatile struct emac_rx_bd *)curr_txbd)+2;
+ curr_rxbd = (volatile struct emac_rx_bd *)(curr_txbd + 1);
+ rxch->inactive_head = curr_rxbd;
+ rxch->active_tail = NULL;
+ rxch->active_head = NULL;
rxch->freed_pbuf_len = MAX_RX_PBUF_ALLOC*PBUF_LEN_MAX;
- rxch->inactive_head->flags_pktlen = EMAC_DSC_FLAG_OWNER;
- rxch->inactive_head->next = rxch->inactive_head + 1;
- curr_rxbd = rxch->inactive_head;
num_bd = ((SIZE_EMAC_CTRL_RAM >> 1) / sizeof(struct emac_rx_bd))-1;
- curr_rxbd = curr_rxbd->next;
- curr_rxbd->next = curr_rxbd + 1;
- curr_rxbd->flags_pktlen = EMAC_DSC_FLAG_OWNER;
+ volatile struct emac_rx_bd *next_rxbd = curr_rxbd + 1;
+ curr_rxbd->next = tms570_eth_swap_rxp(next_rxbd);
+ curr_rxbd->flags_pktlen = tms570_eth_swap(EMAC_DSC_FLAG_OWNER);
curr_rxbd->pbuf = NULL;
- num_bd--;
+ curr_rxbd = next_rxbd;
+ --num_bd;
+ --curr_rxbd;
curr_rxbd->next = NULL;
rxch->inactive_tail = curr_rxbd;
- rxch->active_tail = NULL;
- rxch->active_head = NULL;
#if TMS570_NETIF_DEBUG
tms570_eth_debug_show_rx(nf_state);
tms570_eth_debug_show_tx(nf_state);
@@ -648,8 +676,8 @@ tms570_eth_send_raw(struct netif *netif, struct pbuf *pbuf)
/* First 'part' of packet flags */
- curr_bd->flags_pktlen = pktlen | EMAC_DSC_FLAG_SOP |
- EMAC_DSC_FLAG_OWNER;
+ curr_bd->flags_pktlen = tms570_eth_swap(pktlen | EMAC_DSC_FLAG_SOP |
+ EMAC_DSC_FLAG_OWNER);
/* Copy pbuf information into TX BDs --
* remember that the pbuf for a single packet might be chained!
@@ -658,8 +686,8 @@ tms570_eth_send_raw(struct netif *netif, struct pbuf *pbuf)
if (curr_bd == NULL)
goto error_out_of_descriptors;
- curr_bd->bufptr = (uint8_t *)(q->payload);
- curr_bd->bufoff_len = (q->len) & 0xFFFF;
+ curr_bd->bufptr = tms570_eth_swap_bufptr(q->payload);
+ curr_bd->bufoff_len = tms570_eth_swap(q->len & 0xFFFF);
/* This is an extra field that is not par of the in-HW BD.
* This is used when freeing the pbuf after the TX processing
@@ -667,7 +695,7 @@ tms570_eth_send_raw(struct netif *netif, struct pbuf *pbuf)
curr_bd->pbuf = pbuf;
packet_tail = curr_bd;
- curr_bd = curr_bd->next;
+ curr_bd = tms570_eth_swap_txp(curr_bd->next);
if (padlen) {
@@ -679,14 +707,14 @@ tms570_eth_send_raw(struct netif *netif, struct pbuf *pbuf)
* of given frame as padding
curr_bd->bufptr = packet_head->bufptr;
- curr_bd->bufoff_len = padlen;
+ curr_bd->bufoff_len = tms570_eth_swap(padlen);
/* Indicate the end of the packet */
packet_tail->next = NULL;
- packet_tail->flags_pktlen |= EMAC_DSC_FLAG_EOP;
+ packet_tail->flags_pktlen |= tms570_eth_swap(EMAC_DSC_FLAG_EOP);
txch->inactive_head = curr_bd;
@@ -702,7 +730,7 @@ tms570_eth_send_raw(struct netif *netif, struct pbuf *pbuf)
* end of the chain, the EOQ will be set. In that case,
* the HDP shall be written again.
- txch->active_tail->next = packet_head;
+ txch->active_tail->next = tms570_eth_swap_txp(packet_head);
curr_bd = txch->active_tail;
/* We were too slow and the EMAC already read the
@@ -710,7 +738,7 @@ tms570_eth_send_raw(struct netif *netif, struct pbuf *pbuf)
* case the transmission stopped and we need to write the
* pointer to newly added BDs to the TX HDP
- if (curr_bd->flags_pktlen & EMAC_DSC_FLAG_EOQ) {
+ if (tms570_eth_swap(curr_bd->flags_pktlen) & EMAC_DSC_FLAG_EOQ) {
tms570_eth_hw_set_TX_HDP(nf_state, packet_head);
@@ -768,8 +796,7 @@ tms570_eth_process_irq_rx(void *arg)
/* For each valid frame */
- while ((curr_bd->flags_pktlen & EMAC_DSC_FLAG_SOP) &&
- !(curr_bd->flags_pktlen & EMAC_DSC_FLAG_OWNER)) {
+ while ((tms570_eth_swap(curr_bd->flags_pktlen) & (EMAC_DSC_FLAG_SOP | EMAC_DSC_FLAG_OWNER)) == EMAC_DSC_FLAG_SOP) {
unsigned int total_rx_len;
unsigned int processed_rx_len = 0;
int corrupt_fl = 0;
@@ -777,7 +804,7 @@ tms570_eth_process_irq_rx(void *arg)
sys_arch_data_sync_barier();
pbuf = curr_bd->pbuf;
- total_rx_len = curr_bd->flags_pktlen & 0xFFFF;
+ total_rx_len = tms570_eth_swap(curr_bd->flags_pktlen) & 0xFFFF;
tms570_eth_debug_printf("recieve packet. L = %d ", total_rx_len);
/* The received frame might be fragmented into muliple
* pieces -- each one referenced by a separate BD.
@@ -798,9 +825,9 @@ tms570_eth_process_irq_rx(void *arg)
tms570_eth_debug_printf("A - 0x%08x ", q);
/* This is the size of the "received data" not the PBUF */
q->tot_len = total_rx_len - processed_rx_len;
- q->len = curr_bd->bufoff_len & 0xFFFF;
+ q->len = tms570_eth_swap(curr_bd->bufoff_len) & 0xFFFF;
- if (curr_bd->flags_pktlen & EMAC_DSC_FLAG_EOP)
+ if (tms570_eth_swap(curr_bd->flags_pktlen) & EMAC_DSC_FLAG_EOP)
break;
* If we are executing here, it means this
@@ -814,7 +841,7 @@ tms570_eth_process_irq_rx(void *arg)
corrupt_fl = 1;
break;
+ curr_bd = tms570_eth_swap_rxp(curr_bd->next);
q->next = curr_bd->pbuf;
processed_rx_len += q->len;
@@ -825,10 +852,10 @@ tms570_eth_process_irq_rx(void *arg)
if (rxch->inactive_tail == NULL) {
rxch->inactive_head = rxch->active_head;
} else {
- rxch->inactive_tail->next = rxch->active_head;
+ rxch->inactive_tail->next = tms570_eth_swap_rxp(rxch->active_head);
rxch->inactive_tail = curr_bd;
- rxch->active_head = curr_bd->next;
+ rxch->active_head = tms570_eth_swap_rxp(curr_bd->next);
if (curr_bd->next == NULL)
rxch->inactive_tail->next = NULL;
@@ -883,20 +910,20 @@ tms570_eth_process_irq_tx(void *arg)
/* Traverse the list of BDs used for transmission --
* stop on the first unused
- while ((curr_bd != NULL) && (curr_bd->flags_pktlen & EMAC_DSC_FLAG_SOP)) {
+ while ((curr_bd != NULL) && (tms570_eth_swap(curr_bd->flags_pktlen) & EMAC_DSC_FLAG_SOP)) {
/* Make sure the transmission is over */
- if (curr_bd->flags_pktlen & EMAC_DSC_FLAG_OWNER) {
+ if (tms570_eth_swap(curr_bd->flags_pktlen) & EMAC_DSC_FLAG_OWNER) {
tms570_eth_debug_printf("TXthread ownership not transfered!!!!\n");
break;
/* Find the last chunk of the packet */
- while (!(curr_bd->flags_pktlen & EMAC_DSC_FLAG_EOP))
+ while (!(tms570_eth_swap(curr_bd->flags_pktlen) & EMAC_DSC_FLAG_EOP))
/* Remove flags for the transmitted BDs */
- start_of_packet_bd->flags_pktlen &= (~EMAC_DSC_FLAG_SOP);
- curr_bd->flags_pktlen &= (~EMAC_DSC_FLAG_EOP);
+ start_of_packet_bd->flags_pktlen &= tms570_eth_swap(~EMAC_DSC_FLAG_SOP);
+ curr_bd->flags_pktlen &= tms570_eth_swap(~EMAC_DSC_FLAG_EOP);
* Return processed BDs to inactive list
@@ -904,14 +931,14 @@ tms570_eth_process_irq_tx(void *arg)
if (txch->inactive_tail == NULL) {
txch->inactive_head = start_of_packet_bd;
} else {
- txch->inactive_tail->next = start_of_packet_bd;
+ txch->inactive_tail->next = tms570_eth_swap_txp(start_of_packet_bd);
txch->inactive_tail = curr_bd;
* Remove BDs from active list
- txch->active_head = curr_bd->next;
+ txch->active_head = tms570_eth_swap_txp(curr_bd->next);
if (curr_bd->next == NULL) {
@@ -1072,9 +1099,9 @@ tms570_eth_rx_pbuf_refill(struct tms570_netif_state *nf_state, int single_fl)
} else {
q = new_pbuf;
for (;; ) {
- curr_bd->bufptr = (uint8_t *)q->payload;
- curr_bd->bufoff_len = q->len;
- curr_bd->flags_pktlen = EMAC_DSC_FLAG_OWNER;
+ curr_bd->bufoff_len = tms570_eth_swap(q->len);
+ curr_bd->flags_pktlen = tms570_eth_swap(EMAC_DSC_FLAG_OWNER);
curr_bd->pbuf = q;
rxch->freed_pbuf_len -= q->len;
q = q->next;
@@ -1084,7 +1111,7 @@ tms570_eth_rx_pbuf_refill(struct tms570_netif_state *nf_state, int single_fl)
rxch->inactive_tail = NULL;
break;
if (q != NULL)
@@ -1092,7 +1119,7 @@ tms570_eth_rx_pbuf_refill(struct tms570_netif_state *nf_state, int single_fl)
/* Add the newly allocated BDs to the
* end of the list
- rxch->inactive_head = curr_bd->next;
+ rxch->inactive_head = tms570_eth_swap_rxp(curr_bd->next);
curr_bd->next = NULL;
@@ -1102,9 +1129,9 @@ tms570_eth_rx_pbuf_refill(struct tms570_netif_state *nf_state, int single_fl)
rxch->active_tail = curr_bd;
tms570_eth_hw_set_RX_HDP(nf_state, rxch->active_head);
} else {
- rxch->active_tail->next = curr_head;
+ rxch->active_tail->next = tms570_eth_swap_rxp(curr_head);
- if ((rxch->active_tail->flags_pktlen & EMAC_DSC_FLAG_EOQ) != 0)
+ if ((tms570_eth_swap(rxch->active_tail->flags_pktlen) & EMAC_DSC_FLAG_EOQ) != 0)
@@ -1192,7 +1219,7 @@ tms570_eth_debug_show_BD_chain_rx(volatile struct emac_rx_bd *curr_bd,
while (curr_bd != NULL) {
tms570_eth_debug_printf("%d ", tms570_eth_debug_get_BD_num(curr_bd, nf_state));
count++;
tms570_eth_debug_printf(" count = %d\n", count);
@@ -1206,7 +1233,7 @@ tms570_eth_debug_show_BD_chain_tx(volatile struct emac_tx_bd *curr_bd,
count++;
2.35.3
