[PATCH 3/8] rtems/gcc: Do not build GMP in GCC, use the staged build
chrisj at rtems.org
chrisj at rtems.org
Wed Apr 5 01:30:57 UTC 2023
- Do not build GMP when building GCC. GMP is now built
as a package for GDB. Building as a separate package
lets use control how it is built.
Updates #4892
source-builder/config/gcc-common-1.cfg | 29 +++++++-------------------
1 file changed, 8 insertions(+), 21 deletions(-)
diff --git a/source-builder/config/gcc-common-1.cfg b/source-builder/config/gcc-common-1.cfg
index 933202a..42c8a7b 100644
--- a/source-builder/config/gcc-common-1.cfg
+++ b/source-builder/config/gcc-common-1.cfg
@@ -58,9 +58,6 @@ URL: http://gcc.gnu.org/
%if %{!defined mpc_url}
%define mpc_url https://gcc.gnu.org/pub/gcc/infrastructure
%endif
-%if %{!defined gmp_url}
- %define gmp_url https://gcc.gnu.org/pub/gcc/infrastructure
-%endif
%if %{!defined mpfr_url}
%define mpfr_url https://gcc.gnu.org/pub/gcc/infrastructure
%endif
@@ -75,7 +72,6 @@ URL: http://gcc.gnu.org/
%source set isl %{isl_url}/isl-%{isl_version}.tar.bz2
%endif
%source set mpc %{mpc_url}/mpc-%{mpc_version}.tar.gz
-%source set gmp %{gmp_url}/gmp-%{gmp_version}.tar.bz2
%source set mpfr %{mpfr_url}/mpfr-%{mpfr_version}.tar.bz2
@@ -128,15 +124,6 @@ URL: http://gcc.gnu.org/
%{__ln_s} $PWD/${source_dir_isl} ${source_dir_gcc}/isl
%endif
- # MPFR
- source_dir_mpfr="mpfr-%{mpfr_version}"
- %source setup mpfr -q -D -n mpfr-%{mpfr_version}
- %patch setup mpfr -p1
- cd ${build_top}
- # Build MPFR one-tree style
- %{__rmfile} ${source_dir_gcc}/mpfr
- %{__ln_s} $PWD/${source_dir_mpfr} ${source_dir_gcc}/mpfr
# MPC
source_dir_mpc="mpc-%{mpc_version}"
%source setup mpc -q -D -n mpc-%{mpc_version}
@@ -146,14 +133,14 @@ URL: http://gcc.gnu.org/
%{__rmfile} ${source_dir_gcc}/mpc
%{__ln_s} $PWD/${source_dir_mpc} ${source_dir_gcc}/mpc
- # GMP
- source_dir_gmp="gmp-%{gmp_version}"
- %source setup gmp -q -D -n gmp-%{gmp_version}
- %patch setup gmp -p1
+ # MPFR
+ source_dir_mpfr="mpfr-%{mpfr_version}"
+ %source setup mpfr -q -D -n mpfr-%{mpfr_version}
+ %patch setup mpfr -p1
cd ${build_top}
- # Build GMP one-tree style
- %{__rmfile} ${source_dir_gcc}/gmp
- %{__ln_s} $PWD/${source_dir_gmp} ${source_dir_gcc}/gmp
+ # Build MPFR one-tree style
+ %{__rmfile} ${source_dir_gcc}/mpfr
+ %{__ln_s} $PWD/${source_dir_mpfr} ${source_dir_gcc}/mpfr
echo "%{gcc_version_message}" > ${source_dir_gcc}/gcc/DEV-PHASE
@@ -232,7 +219,7 @@ URL: http://gcc.gnu.org/
cp ../${source_dir_gcc}/gcc/gsyslimits.h gcc/include/syslimits.h
fi
- %{__make} %{?_smp_mflags} all
+ %{__make} -w %{?_smp_mflags} all
cd ${build_top}
2.37.1
