[PATCH 4/8] devel/gmp: Disable assemble builds on MacOS AARCH64
chrisj at rtems.org
chrisj at rtems.org
Wed Apr 5 01:30:58 UTC 2023
Updates #4892
source-builder/config/gmp.cfg | 12 +++++++++++-
1 file changed, 11 insertions(+), 1 deletion(-)
diff --git a/source-builder/config/gmp.cfg b/source-builder/config/gmp.cfg
index ffd3b20..4e8d674 100644
--- a/source-builder/config/gmp.cfg
+++ b/source-builder/config/gmp.cfg
@@ -19,6 +19,15 @@ URL: https://gmplib.org/
%source set gmp https://gcc.gnu.org/pub/gcc/infrastructure/gmp-%{gmp_version}.tar.bz2
+%define gmp_extra_options %{nil}
+# Do not use assembler if MacOS AARCH64
+%if %{_host_os} == darwin && %{_host_arch} == arm64
+ %define gmp_extra_options %{gmp_extra_options} --disable-assembly
+%endif
# Prepare the source code.
@@ -44,7 +53,8 @@ URL: https://gmplib.org/
--exec-prefix=%{_exec_prefix} \
--includedir=%{_includedir} --libdir=%{_libdir} \
--mandir=%{_mandir} --infodir=%{_infodir} \
- --disable-shared
+ --disable-shared \
+ %{gmp_extra_options}
%{__make} %{?_smp_mflags} all
2.37.1
