[PATCH 6/8] devel/mpfr: Add MPFR as a package
chrisj at rtems.org chrisj at rtems.org
Wed Apr 5 01:31:00 UTC 2023
- This is a place holder incase we stop building MPFR in
  GCC.
Updates #4892
 bare/config/devel/mpfr-4.2.0.cfg | 18 ++++++++++
 source-builder/config/mpfr.cfg   | 62 ++++++++++++++++++++++++++++++++
 2 files changed, 80 insertions(+)
 create mode 100644 bare/config/devel/mpfr-4.2.0.cfg
 create mode 100644 source-builder/config/mpfr.cfg
diff --git a/bare/config/devel/mpfr-4.2.0.cfg b/bare/config/devel/mpfr-4.2.0.cfg
new file mode 100644
index 0000000..77e9ffd
--- /dev/null
+++ b/bare/config/devel/mpfr-4.2.0.cfg
@@ -0,0 +1,18 @@
+# MPFR 4.2.0
+%if %{release} == %{nil}
+%define release 1
+%endif
+%include %{_configdir}/base.cfg
+%define mpfr_version 4.2.0
+%hash sha512 mpfr-%{mpfr_version}.tar.bz2 \
+        yyqTFLlONKTqSc4mGYAulCDJguVSWKS8Qj+AJ0BjJkaj1CDn/PNzsZYYOFuLK0Eqv6En6PRzBThjQkysIziTwA==
+# The MPFR build instructions.
+%include %{_configdir}/mpfr.cfg
diff --git a/source-builder/config/mpfr.cfg b/source-builder/config/mpfr.cfg
index 0000000..6d64c1a
--- /dev/null
+++ b/source-builder/config/mpfr.cfg
@@ -0,0 +1,62 @@
+# The GNU Multiple-precision Floating-point computations with correct Rounding (MPFR)
+# This configuration file configure's, make's and install's GMP.
+%define release 1
+%endif
+Name:      mpfr-%{mpfr_version}-%{_host}-%{release}
+Summary:   The GNU Multiple-precision Floating-point computations with correct Rounding Library (MPFR)
+           v%{mpfr_version} for target %{_target} on host %{_host}
+Version:   %{mpfr_version}
+Release:   %{release}
+URL: 	   https://www.mpfr.org/
+# Source
+%source set mpfr https://www.mpfr.org/mpfr-%{mpfr_version}/mpfr-%{mpfr_version}.tar.bz2
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  %source setup mpfr -q -n mpfr-%{mpfr_version}
+  %patch setup mpfr -p1
+  cd ${build_top}
+%build
+  build_top=$(pwd)
+  cd mpfr-%{mpfr_version}
+  %{host_build_flags}
+  ./configure \
+    --build=%{_build} --host=%{_host} \
+    --verbose \
+    --prefix=%{_prefix} --bindir=%{_bindir} \
+    --exec-prefix=%{_exec_prefix} \
+    --includedir=%{_includedir} --libdir=%{_libdir} \
+    --mandir=%{_mandir} --infodir=%{_infodir} \
+    --disable-shared
+  %{__make} %{?_smp_mflags} all
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  rm -rf $SB_BUILD_ROOT
+  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  cd ${build_top}
2.37.1
