[PATCH 7/8] rtems/mipsstx39: Update to GDB 13.1 and stage build GMP
chrisj at rtems.org
chrisj at rtems.org
Wed Apr 5 01:31:01 UTC 2023
- Use a build set file to stage GMP as recent GDB
versions require GMP.
Update #4892
rtems/config/6/rtems-mips.bset | 2 +-
rtems/config/tools/rtems-mipstx39-gdb-11.2.cfg | 3 ---
rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg | 11 -----------
rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg | 11 -----------
rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg | 11 -----------
rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg | 11 -----------
rtems/config/tools/rtems-mipstx39-gdb-8.0.1-1.cfg | 3 ---
rtems/config/tools/rtems-mipstx39-gdb-head.cfg | 3 ---
rtems/config/tools/rtems-mipstx39-gdb.bset | 7 +++++++
9 files changed, 8 insertions(+), 54 deletions(-)
delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-11.2.cfg
delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg
delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg
delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg
delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg
delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-8.0.1-1.cfg
delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-head.cfg
create mode 100644 rtems/config/tools/rtems-mipstx39-gdb.bset
diff --git a/rtems/config/6/rtems-mips.bset b/rtems/config/6/rtems-mips.bset
index 370e5ea..6289172 100644
--- a/rtems/config/6/rtems-mips.bset
+++ b/rtems/config/6/rtems-mips.bset
@@ -3,4 +3,4 @@
%define gdb-sim-options --enable-sim-hardware
%define win32-gdb-disable-sim
%include 6/rtems-default.bset
-tools/rtems-mipstx39-gdb-head
+tools/rtems-mipstx39-gdb
diff --git a/rtems/config/tools/rtems-mipstx39-gdb-11.2.cfg b/rtems/config/tools/rtems-mipstx39-gdb-11.2.cfg
deleted file mode 100644
index 7707519..0000000
--- a/rtems/config/tools/rtems-mipstx39-gdb-11.2.cfg
+++ /dev/null
@@ -1,3 +0,0 @@
-%undefine _target
-%define _target mipstx39-rtems%{rtems_version}
-%include tools/rtems-gdb-11.2.cfg
diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg b/rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg
index 3c0bed5..0000000
--- a/rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg
+++ /dev/null
@@ -1,11 +0,0 @@
-# MIPS STX39 GDB 7.5.1.
-%undefine _target
-# The gdb build instructions for RTEMS 7.5.1.
-%include tools/rtems-gdb-7.5.1-1.cfg
diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg b/rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg
index 836c0bb..0000000
--- a/rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg
+++ /dev/null
@@ -1,11 +0,0 @@
-# MIPS STX39 GDB 7.6.
-%undefine _target
-# The gdb build instructions for RTEMS 7.6.
-%include tools/rtems-gdb-7.6-1.cfg
diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg b/rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg
index 0e65b5e..0000000
--- a/rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg
+++ /dev/null
@@ -1,11 +0,0 @@
-# MIPS STX39 GDB 7.7.
-%undefine _target
-# The gdb build instructions for RTEMS 7.7.
-%include tools/rtems-gdb-7.7-1.cfg
diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg b/rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg
index 5777b5f..0000000
--- a/rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg
+++ /dev/null
@@ -1,11 +0,0 @@
-# MIPS TX39 GDB 7.9.
-%undefine _target
-# The gdb 7.9 build instructions for RTEMS.
-%include tools/rtems-gdb-7.9-1.cfg
diff --git a/rtems/config/tools/rtems-mipstx39-gdb-8.0.1-1.cfg b/rtems/config/tools/rtems-mipstx39-gdb-8.0.1-1.cfg
index 05b270b..0000000
--- a/rtems/config/tools/rtems-mipstx39-gdb-8.0.1-1.cfg
+++ /dev/null
@@ -1,3 +0,0 @@
-%undefine _target
-%include tools/rtems-gdb-8.0.1-1.cfg
diff --git a/rtems/config/tools/rtems-mipstx39-gdb-head.cfg b/rtems/config/tools/rtems-mipstx39-gdb-head.cfg
index d90ea33..0000000
--- a/rtems/config/tools/rtems-mipstx39-gdb-head.cfg
+++ /dev/null
@@ -1,3 +0,0 @@
-%undefine _target
-%include tools/rtems-gdb-head.cfg
diff --git a/rtems/config/tools/rtems-mipstx39-gdb.bset b/rtems/config/tools/rtems-mipstx39-gdb.bset
new file mode 100644
index 0000000..392e24d
--- /dev/null
+++ b/rtems/config/tools/rtems-mipstx39-gdb.bset
@@ -0,0 +1,7 @@
+%define release 1
+%define rtems_arch mips
+%define gdb-sim-options --enable-sim-hardware
+%define win32-gdb-disable-sim
+%define _target mipstx39-rtems%{rtems_version}
+devel/gmp-6.2.1
+tools/rtems-gdb-13.1
2.37.1
