[PATCH 7/8] rtems/mipsstx39: Update to GDB 13.1 and stage build GMP
Joel Sherrill
joel at rtems.org
Wed Apr 5 17:27:08 UTC 2023
This is separate because mipstx39 is not a full toolchain but we have to
built this target to get the jmr3904 simulator. It should normally be in
sync with the other gdb configurations.
This looks ok.
On Tue, Apr 4, 2023 at 8:31 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chris at contemporary.net.au>
> - Use a build set file to stage GMP as recent GDB
> versions require GMP.
> Update #4892
> rtems/config/6/rtems-mips.bset | 2 +-
> rtems/config/tools/rtems-mipstx39-gdb-11.2.cfg | 3 ---
> rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg | 11 -----------
> rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg | 11 -----------
> rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg | 11 -----------
> rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg | 11 -----------
> rtems/config/tools/rtems-mipstx39-gdb-8.0.1-1.cfg | 3 ---
> rtems/config/tools/rtems-mipstx39-gdb-head.cfg | 3 ---
> rtems/config/tools/rtems-mipstx39-gdb.bset | 7 +++++++
> 9 files changed, 8 insertions(+), 54 deletions(-)
> delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-11.2.cfg
> delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg
> delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg
> delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg
> delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg
> delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-8.0.1-1.cfg
> delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-head.cfg
> create mode 100644 rtems/config/tools/rtems-mipstx39-gdb.bset
> diff --git a/rtems/config/6/rtems-mips.bset
> b/rtems/config/6/rtems-mips.bset
> index 370e5ea..6289172 100644
> --- a/rtems/config/6/rtems-mips.bset
> +++ b/rtems/config/6/rtems-mips.bset
> @@ -3,4 +3,4 @@
> %define gdb-sim-options --enable-sim-hardware
> %define win32-gdb-disable-sim
> %include 6/rtems-default.bset
> -tools/rtems-mipstx39-gdb-head
> +tools/rtems-mipstx39-gdb
> diff --git a/rtems/config/tools/rtems-mipstx39-gdb-11.2.cfg
> b/rtems/config/tools/rtems-mipstx39-gdb-11.2.cfg
> deleted file mode 100644
> index 7707519..0000000
> --- a/rtems/config/tools/rtems-mipstx39-gdb-11.2.cfg
> +++ /dev/null
> @@ -1,3 +0,0 @@
> -%undefine _target
> -%define _target mipstx39-rtems%{rtems_version}
> -%include tools/rtems-gdb-11.2.cfg
> diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg
> b/rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg
> index 3c0bed5..0000000
> --- a/rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg
> +++ /dev/null
> @@ -1,11 +0,0 @@
> -# MIPS STX39 GDB 7.5.1.
> -%undefine _target
> -# The gdb build instructions for RTEMS 7.5.1.
> -%include tools/rtems-gdb-7.5.1-1.cfg
> diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg
> b/rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg
> index 836c0bb..0000000
> --- a/rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg
> +++ /dev/null
> @@ -1,11 +0,0 @@
> -# MIPS STX39 GDB 7.6.
> -%undefine _target
> -# The gdb build instructions for RTEMS 7.6.
> -%include tools/rtems-gdb-7.6-1.cfg
> diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg
> b/rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg
> index 0e65b5e..0000000
> --- a/rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg
> +++ /dev/null
> @@ -1,11 +0,0 @@
> -# MIPS STX39 GDB 7.7.
> -%undefine _target
> -# The gdb build instructions for RTEMS 7.7.
> -%include tools/rtems-gdb-7.7-1.cfg
> diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg
> b/rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg
> index 5777b5f..0000000
> --- a/rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg
> +++ /dev/null
> @@ -1,11 +0,0 @@
> -# MIPS TX39 GDB 7.9.
> -%undefine _target
> -# The gdb 7.9 build instructions for RTEMS.
> -%include tools/rtems-gdb-7.9-1.cfg
> diff --git a/rtems/config/tools/rtems-mipstx39-gdb-8.0.1-1.cfg
> b/rtems/config/tools/rtems-mipstx39-gdb-8.0.1-1.cfg
> index 05b270b..0000000
> --- a/rtems/config/tools/rtems-mipstx39-gdb-8.0.1-1.cfg
> +++ /dev/null
> @@ -1,3 +0,0 @@
> -%undefine _target
> -%include tools/rtems-gdb-8.0.1-1.cfg
> diff --git a/rtems/config/tools/rtems-mipstx39-gdb-head.cfg
> b/rtems/config/tools/rtems-mipstx39-gdb-head.cfg
> index d90ea33..0000000
> --- a/rtems/config/tools/rtems-mipstx39-gdb-head.cfg
> +++ /dev/null
> @@ -1,3 +0,0 @@
> -%undefine _target
> -%include tools/rtems-gdb-head.cfg
> diff --git a/rtems/config/tools/rtems-mipstx39-gdb.bset
> b/rtems/config/tools/rtems-mipstx39-gdb.bset
> new file mode 100644
> index 0000000..392e24d
> --- /dev/null
> +++ b/rtems/config/tools/rtems-mipstx39-gdb.bset
> @@ -0,0 +1,7 @@
> +%define release 1
> +%define rtems_arch mips
> +%define gdb-sim-options --enable-sim-hardware
> +%define win32-gdb-disable-sim
> +%define _target mipstx39-rtems%{rtems_version}
> +devel/gmp-6.2.1
> +tools/rtems-gdb-13.1
> 2.37.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230405/af574a36/attachment.htm>
