[PATCH v3 3/3] bsps/microblaze: Fix UART transmit interrupt
Alex White
alex.white at oarcorp.com
Mon Apr 10 03:47:59 UTC 2023
From: "Maldonado, Sergio E. (GSFC-580.0)" <sergio.e.maldonado at nasa.gov>
bsps/microblaze/include/dev/serial/uartlite.h | 2 ++
bsps/microblaze/shared/dev/serial/uartlite.c | 22 ++++++++++++++-----
2 files changed, 19 insertions(+), 5 deletions(-)
diff --git a/bsps/microblaze/include/dev/serial/uartlite.h b/bsps/microblaze/include/dev/serial/uartlite.h
index 009f416508..f58ae92ef8 100644
--- a/bsps/microblaze/include/dev/serial/uartlite.h
+++ b/bsps/microblaze/include/dev/serial/uartlite.h
@@ -51,7 +51,9 @@ typedef struct {
uint32_t initial_baud;
uint32_t enabled;
#ifdef BSP_MICROBLAZE_FPGA_CONSOLE_INTERRUPTS
+ struct rtems_termios_tty *tty;
bool transmitting;
+ size_t tx_queued;
uint32_t irq;
#endif
} uart_lite_context;
diff --git a/bsps/microblaze/shared/dev/serial/uartlite.c b/bsps/microblaze/shared/dev/serial/uartlite.c
index e2007ee24a..611c339371 100644
--- a/bsps/microblaze/shared/dev/serial/uartlite.c
+++ b/bsps/microblaze/shared/dev/serial/uartlite.c
@@ -48,8 +48,11 @@ static void microblaze_uart_interrupt( void *arg )
rtems_termios_enqueue_raw_characters( tty, &c, 1 );
- while ( ctx->transmitting && !XUartLite_IsTransmitEmpty( ctx->address ) ) {
- rtems_termios_dequeue_characters( tty, 1 );
+ if ( ctx->transmitting && XUartLite_IsTransmitEmpty( ctx->address ) ) {
+ size_t sent = ctx->tx_queued;
+ ctx->transmitting = false;
+ ctx->tx_queued = 0;
+ rtems_termios_dequeue_characters( tty, sent );
#endif
@@ -81,6 +84,8 @@ static bool uart_first_open(
if ( sc != RTEMS_SUCCESSFUL ) {
return false;
+ ctx->tty = tty;
#endif
return true;
@@ -120,10 +125,17 @@ static void uart_write(
if ( n > 0 ) {
+ size_t remaining = n;
+ const char *p = &s[0];
+ while (!XUartLite_IsTransmitFull( ctx->address ) && remaining > 0) {
+ XUartLite_SendByte( ctx->address, *p );
+ p++;
+ remaining--;
ctx->transmitting = true;
- XUartLite_SendByte( ctx->address, s[0] );
- } else {
- ctx->transmitting = false;
+ ctx->tx_queued = n - remaining;
#else
size_t i = 0;
2.34.1
