[PATCH v3 2/3] bsps/microblaze: Add support for multiple UARTs
Alex White
alex.white at oarcorp.com
Mon Apr 10 03:47:58 UTC 2023
From: "Maldonado, Sergio E. (GSFC-580.0)" <sergio.e.maldonado at nasa.gov>
bsps/microblaze/include/dev/serial/uartlite.h | 2 +
.../microblaze_fpga/console/console-io.c | 205 ++++++++++++++++--
bsps/microblaze/shared/dev/serial/uartlite.c | 8 +-
.../bsps/microblaze/microblaze_fpga/grp.yml | 10 +
.../bsps/microblaze/microblaze_fpga/obj.yml | 1 -
.../microblaze_fpga/optconsoleuart.yml | 21 ++
.../microblaze_fpga/optmaxuarts.yml | 21 ++
.../microblaze/microblaze_fpga/optuartirq.yml | 20 ++
.../microblaze/microblaze_fpga/optuseuart.yml | 17 ++
9 files changed, 275 insertions(+), 30 deletions(-)
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optconsoleuart.yml
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optmaxuarts.yml
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optuartirq.yml
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optuseuart.yml
diff --git a/bsps/microblaze/include/dev/serial/uartlite.h b/bsps/microblaze/include/dev/serial/uartlite.h
index 2fda3796b3..009f416508 100644
--- a/bsps/microblaze/include/dev/serial/uartlite.h
+++ b/bsps/microblaze/include/dev/serial/uartlite.h
@@ -49,8 +49,10 @@ typedef struct {
rtems_termios_device_context base;
uintptr_t address;
uint32_t initial_baud;
+ uint32_t enabled;
#ifdef BSP_MICROBLAZE_FPGA_CONSOLE_INTERRUPTS
bool transmitting;
+ uint32_t irq;
#endif
} uart_lite_context;
diff --git a/bsps/microblaze/microblaze_fpga/console/console-io.c b/bsps/microblaze/microblaze_fpga/console/console-io.c
index 81c4e73690..c4de3800cc 100644
--- a/bsps/microblaze/microblaze_fpga/console/console-io.c
+++ b/bsps/microblaze/microblaze_fpga/console/console-io.c
@@ -34,39 +34,200 @@
* POSSIBILITY OF SUCH DAMAGE.
-#include <bsp/console-termios.h>
-#include <bsp/microblaze-fdt-support.h>
-#include <dev/serial/uartlite.h>
+#include <unistd.h>
+#include <string.h>
+#include <stdio.h>
+#include <sys/param.h>
+#include <bsp/console-termios.h>
+#include <bsp/fatal.h>
#include <bspopts.h>
+#include <dev/serial/uartlite.h>
-uart_lite_context microblaze_qemu_uart_context = {
- .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "UARTLITE" ),
- .initial_baud = 115200
-static bool fill_uart_base(rtems_termios_device_context *context)
- uint32_t mblaze_uart_base;
- mblaze_uart_base = try_get_prop_from_device_tree(
- "xlnx,xps-uartlite-1.00.a",
- "reg",
- BSP_MICROBLAZE_FPGA_UART_BASE
+#ifdef BSP_MICROBLAZE_FPGA_USE_FDT
+#include <bsp/fdt.h>
+#include <libfdt.h>
+#endif
- microblaze_qemu_uart_context.address = mblaze_uart_base;
+#include <rtems/console.h>
- return true;
+#ifndef BSP_MICROBLAZE_FPGA_USE_FDT
+static uart_lite_context uart_lite_instances[] = {
+ .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "UARTLITE" ),
+ .initial_baud = 115200,
+ .address = BSP_MICROBLAZE_FPGA_UART_BASE,
+#if BSP_MICROBLAZE_FPGA_USE_UART
+ .enabled = 1,
+#endif
+#ifdef BSP_MICROBLAZE_FPGA_CONSOLE_INTERRUPTS
+ .irq = BSP_MICROBLAZE_FPGA_UART_IRQ
+#endif
const console_device console_device_table[] = {
.device_file = "/dev/ttyS0",
- .probe = fill_uart_base,
.handler = µblaze_uart_fns,
- .context = µblaze_qemu_uart_context.base
+ .context = &uart_lite_instances[0].base
const size_t console_device_count = RTEMS_ARRAY_SIZE( console_device_table );
+#else
+static uart_lite_context uart_lite_instances[BSP_MICROBLAZE_FPGA_MAX_UARTS];
+console_device *dynamic_console_device_table;
+size_t dynamic_console_device_count;
+/* Override the console_device_table and console_device_count */
+#define console_device_table dynamic_console_device_table
+#define console_device_count dynamic_console_device_count
+#endif /* BSP_MICROBLAZE_FPGA_USE_FDT */
+static int microblaze_fpga_get_stdout_node(const void *fdt)
+ int node;
+ int len;
+ int offset;
+ const char *console;
+ const char *q;
+ node = fdt_path_offset( fdt, "/chosen" );
+ if ( node < 0 ) {
+ return 0;
+ console = fdt_getprop( fdt, node, "stdout-path", NULL );
+ if ( console == NULL ) {
+ return 0;
+ q = strchr(console, ':');
+ if ( !q ) {
+ return 0;
+ len = q - console;
+ /* Get the node specified by stdout-path */
+ offset = fdt_path_offset_namelen( fdt, console, len );
+ if (offset < 0) {
+ return 0;
+ return offset;
+static void initialize_uart_arrays(uint32_t max_uarts) {
+ dynamic_console_device_table = calloc(max_uarts, sizeof(console_device));
+ dynamic_console_device_count = max_uarts;
+ for (uint32_t i = 0; i < max_uarts; i++) {
+ rtems_termios_device_context_initialize(&uart_lite_instances[i].base, "UARTLITE");
+ uart_lite_instances[i].initial_baud = 115200;
+ dynamic_console_device_table[i].device_file = malloc(11);
+ snprintf((char *)console_device_table[i].device_file, 11, "/dev/ttyS%u", i);
+ dynamic_console_device_table[i].handler = µblaze_uart_fns;
+ dynamic_console_device_table[i].context = &uart_lite_instances[i].base;
+#endif
+rtems_device_driver console_initialize(
+ rtems_device_major_number major,
+ rtems_device_minor_number minor,
+ void *arg
+ uint32_t port;
+ uint32_t stdout_port = BSP_MICROBLAZE_FPGA_CONSOLE_UART;
+ initialize_uart_arrays(BSP_MICROBLAZE_FPGA_MAX_UARTS);
+ const char compatible[] = "xlnx,xps-uartlite-1.00.a";
+ const void *fdt = bsp_fdt_get();
+ int len;
+ int stdout_node = microblaze_fpga_get_stdout_node(fdt);
+ int node = fdt_node_offset_by_compatible( fdt, -1, compatible);
+ while ( node != -FDT_ERR_NOTFOUND ) {
+ const uint32_t *prop;
+ const void *status;
+ uint32_t disabled = 0;
+ port = console_device_count;
+ /* check if node device status has been set to disabled */
+ status = fdt_getprop( fdt, node, "status", &len );
+ if ( status != NULL ) {
+ if ( strncmp( status, "disabled", MIN( 9, len) ) == 0 ) {
+ disabled = 1;
+ if ( !disabled ) {
+ /* use port number property as the device table index */
+ prop = fdt_getprop( fdt, node, "port-number", NULL );
+ if ( prop != NULL ) {
+ port = fdt32_to_cpu( prop[0] );
+ if ( port < console_device_count ) {
+ prop = fdt_getprop( fdt, node, "reg", NULL );
+ uint32_t address = fdt32_to_cpu( prop[0] );
+ uart_lite_instances[ port ].address = address;
+ uart_lite_instances[ port ].enabled = 1;
+ if ( node == stdout_node ) {
+ stdout_port = port;
+ prop = fdt_getprop( fdt, node, "interrupts", NULL );
+ uint32_t irq = fdt32_to_cpu( prop[0] );
+ uart_lite_instances[ port ].irq = irq;
+#endif
+ node = fdt_node_offset_by_compatible( fdt, node, compatible );
+ if ( disabled || ( port >= console_device_count ) )
+ continue;
+ rtems_termios_initialize();
+ for ( port = 0; port < console_device_count; port++ ) {
+ const console_device *ctx = &console_device_table[ port ];
+ rtems_status_code sc;
+ if ( !uart_lite_instances[ port ].enabled )
+ continue;
+ sc = rtems_termios_device_install(
+ ctx->device_file,
+ ctx->handler,
+ ctx->flow,
+ ctx->context
+ if ( sc != RTEMS_SUCCESSFUL ) {
+ bsp_fatal( BSP_FATAL_CONSOLE_INSTALL_0 );
+ if ( port == stdout_port ) {
+ if ( link( ctx->device_file, CONSOLE_DEVICE_NAME ) != 0 ) {
+ bsp_fatal( BSP_FATAL_CONSOLE_INSTALL_1 );
+ return RTEMS_SUCCESSFUL;
diff --git a/bsps/microblaze/shared/dev/serial/uartlite.c b/bsps/microblaze/shared/dev/serial/uartlite.c
index 953c630759..e2007ee24a 100644
--- a/bsps/microblaze/shared/dev/serial/uartlite.c
+++ b/bsps/microblaze/shared/dev/serial/uartlite.c
@@ -71,14 +71,8 @@ static bool uart_first_open(
XUartLite_EnableIntr( ctx->address );
- uint32_t uart_irq_num = try_get_prop_from_device_tree(
- "interrupts",
- 1
sc = rtems_interrupt_handler_install(
- uart_irq_num,
+ ctx->irq,
"UART",
RTEMS_INTERRUPT_SHARED,
microblaze_uart_interrupt,
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/grp.yml b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
index aa88821458..4f854de2cd 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
@@ -54,6 +54,8 @@ links:
uid: opticachesize
- role: build-dependency
uid: optintcbaseaddress
+- role: build-dependency
+ uid: optmaxuarts
uid: optramlen
@@ -66,6 +68,14 @@ links:
uid: opttimerfrequency
uid: optuartlitebaseaddress
+ uid: optuseuart
+ uid: optuartirq
+ uid: optuartirq
+ uid: optconsoleuart
uid: optusefdt
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
index 67afbb7c7e..52ba596768 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
@@ -47,7 +47,6 @@ source:
- bsps/shared/dev/cpucounter/cpucounterfrequency.c
- bsps/shared/dev/cpucounter/cpucounterread.c
- bsps/shared/dev/getentropy/getentropy-cpucounter.c
-- bsps/shared/dev/serial/console-termios-init.c
- bsps/shared/dev/serial/console-termios.c
- bsps/shared/irq/irq-default-handler.c
- bsps/shared/start/bspfatal-default.c
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optconsoleuart.yml b/spec/build/bsps/microblaze/microblaze_fpga/optconsoleuart.yml
new file mode 100644
index 0000000000..8cc8e18062
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optconsoleuart.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+actions:
+- get-integer: null
+- assert-uint32: null
+- env-assign: null
+- format-and-define: null
+build-type: option
+copyrights:
+- Copyright (C) 2023 On-Line Applications Research Corporation (OAR)
+default:
+- enabled-by: true
+ value: 0
+default-by-variant: []
+description: |
+ default uart console device port number
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_MICROBLAZE_FPGA_CONSOLE_UART
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optmaxuarts.yml b/spec/build/bsps/microblaze/microblaze_fpga/optmaxuarts.yml
index 0000000000..3b639a5922
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optmaxuarts.yml
@@ -0,0 +1,21 @@
+actions:
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+ value: 1
+description: |
+ maximum number of UART devices
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_MICROBLAZE_FPGA_MAX_UARTS
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optuartirq.yml b/spec/build/bsps/microblaze/microblaze_fpga/optuartirq.yml
index 0000000000..054388bf8a
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optuartirq.yml
@@ -0,0 +1,20 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+ value: 3
+description: |
+ irq number of the AXI UART Lite
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_MICROBLAZE_FPGA_UART_IRQ
+type: build
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optuseuart.yml b/spec/build/bsps/microblaze/microblaze_fpga/optuseuart.yml
index 0000000000..c3ddd11b78
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optuseuart.yml
@@ -0,0 +1,17 @@
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+ value: true
+description: |
+ define if UART is used
+enabled-by: true
+links: []
+name: BSP_MICROBLAZE_FPGA_USE_UART
+type: build
2.34.1
