[PATCH 1/2] bsps/motorola_powerpc: Change defines from BSP names to avoid clash
Joel Sherrill
joel at rtems.org
Tue Apr 11 12:44:15 UTC 2023
On Tue, Apr 11, 2023, 12:00 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Change mvme2100 to mot_pcc_mvme2100 to avoid clashing with the
> RTEMS_BSP value for the BSP. You cannot have a define that is the
> BSP name.
> bsps/mips/include/bsp/i8259.h | 4 ++--
> bsps/powerpc/motorola_powerpc/include/bsp.h | 6 +++---
> bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h | 2 +-
> bsps/powerpc/motorola_powerpc/include/bsp/irq.h | 2 +-
> bsps/powerpc/motorola_powerpc/start/bspreset.c | 2 +-
> bsps/powerpc/motorola_powerpc/start/bspstart.c | 10 +++++-----
> bsps/powerpc/motorola_powerpc/start/motorola.c | 2 +-
> bsps/powerpc/shared/irq/irq_init.c | 6 +++---
> bsps/powerpc/shared/pci/detect_raven_bridge.c | 2 +-
> bsps/powerpc/shared/rtc/todcfg.c | 6 +++---
> .../bsps/powerpc/motorola_powerpc/optmvme2100.yml | 2 +-
> .../bsps/powerpc/motorola_powerpc/optmvme2307.yml | 2 +-
> .../bsps/powerpc/motorola_powerpc/optmvme2700.yml | 2 +-
> 13 files changed, 24 insertions(+), 24 deletions(-)
> diff --git a/bsps/mips/include/bsp/i8259.h b/bsps/mips/include/bsp/i8259.h
> index 1a947829b0..29e3853874 100644
> --- a/bsps/mips/include/bsp/i8259.h
> +++ b/bsps/mips/include/bsp/i8259.h
> @@ -37,7 +37,7 @@
This patch looks ok except for this if 1. It appears it was already there
but you touched it. Any explanation? Can the if 1 be removed?
> -#if 1
> +#if 1
> #define ISA8259_M_ELCR 0x4d0
> #define ISA8259_S_ELCR 0x4d1
> #endif
> @@ -169,7 +169,7 @@ extern "C" {
> -#if defined(mvme2100)
> +#if defined(mot_ppc_mvme2100)
> #define BSP_DEC21143_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 1)
> #define BSP_PMC_PCMIP_TYPE1_SLOT0_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 2)
> #define BSP_PCMIP_TYPE1_SLOT1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 3)
> diff --git a/bsps/powerpc/motorola_powerpc/include/bsp.h
> b/bsps/powerpc/motorola_powerpc/include/bsp.h
> index db0995fa5c..d44bcd5cff 100644
> --- a/bsps/powerpc/motorola_powerpc/include/bsp.h
> +++ b/bsps/powerpc/motorola_powerpc/include/bsp.h
> @@ -89,7 +89,7 @@ extern "C" {
> /* fundamental addresses for BSP (CHRPxxx and PREPxxx are from
> libcpu/io.h) */
> #define _IO_BASE CHRP_ISA_IO_BASE
> #define _ISA_MEM_BASE CHRP_ISA_MEM_BASE
> /* address of our ram on the PCI bus */
> @@ -154,7 +154,7 @@ extern "C" {
> * find out what it is which is VERY different from other Motorola
> boards.
> #define BSP_UART_IOBASE_COM1 ((_IO_BASE)+0x01e10000)
> /* #define BSP_UART_IOBASE_COM1 (0xffe10000) */
> #define BSP_OPEN_PIC_BASE_OFFSET 0x40000
> #define BSP_VGA_IOBASE ((_IO_BASE)+0x3c0)
> #endif
> -#if defined(mvme2300) || defined(mvme2307) || defined(mvme2700)
> +#if defined(mvme2300) || defined(mot_ppc_mvme2307) ||
> defined(mot_ppc_mvme2700)
> #define MVME_HAS_DEC21140
> #endif
> #endif
> diff --git a/bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h
> b/bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h
> index 9b355819f1..9e57730d60 100644
> --- a/bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h
> +++ b/bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h
> @@ -66,7 +66,7 @@
> * available and unused!
> #define _VME_A32_WIN0_ON_PCI 0x90000000
> #define _VME_A24_ON_PCI 0x9f000000
> #define _VME_A16_ON_PCI 0x9fff0000
> diff --git a/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
> b/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
> index fea2859c3e..74bda323eb 100644
> --- a/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
> +++ b/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
> @@ -133,7 +133,7 @@ extern "C" {
> #define BSP_PCI_ISA_BRIDGE_IRQ (BSP_PCI_IRQ0)
> #endif
> diff --git a/bsps/powerpc/motorola_powerpc/start/bspreset.c
> b/bsps/powerpc/motorola_powerpc/start/bspreset.c
> index 0931badae4..d0af42284f 100644
> --- a/bsps/powerpc/motorola_powerpc/start/bspreset.c
> +++ b/bsps/powerpc/motorola_powerpc/start/bspreset.c
> @@ -16,7 +16,7 @@ void bsp_reset(void)
> CPU_print_stack();
> /* shutdown and reboot */
> *(unsigned char*)0xffe00000 |= 0x80;
> #else
> /* Memory-mapped Port 92 PIB device access
> diff --git a/bsps/powerpc/motorola_powerpc/start/bspstart.c
> b/bsps/powerpc/motorola_powerpc/start/bspstart.c
> index a781297565..894cf9d73d 100644
> --- a/bsps/powerpc/motorola_powerpc/start/bspstart.c
> +++ b/bsps/powerpc/motorola_powerpc/start/bspstart.c
> @@ -109,7 +109,7 @@ char *save_boot_params(
> return loaderParam;
> unsigned int EUMBBAR;
> @@ -130,7 +130,7 @@ uint32_t _CPU_Counter_frequency(void)
> static void bsp_early( void )
> -#if !defined(mvme2100)
> +#if !defined(mot_ppc_mvme2100)
> unsigned l2cr;
> #endif
> prep_t boardManufacturer;
> @@ -149,7 +149,7 @@ static void bsp_early( void )
> * Init MMU block address translation to enable hardware access
> * PC legacy IO space used for inb/outb and all PC compatible hardware
> @@ -173,7 +173,7 @@ static void bsp_early( void )
> setdbat(3, 0xb0000000, 0xb0000000, 0x10000000, IO_PAGE);
> #endif
> /* Need 0xfec00000 mapped for this */
> EUMBBAR = get_eumbbar();
> #endif
> @@ -200,7 +200,7 @@ static void bsp_early( void )
> #endif
> * Enable L2 Cache. Note that the set_L2CR(L2CR) codes checks for
> * relevant CPU type (mpc750)...
> diff --git a/bsps/powerpc/motorola_powerpc/start/motorola.c
> b/bsps/powerpc/motorola_powerpc/start/motorola.c
> index 25b1d3aa3c..58c711f07b 100644
> --- a/bsps/powerpc/motorola_powerpc/start/motorola.c
> +++ b/bsps/powerpc/motorola_powerpc/start/motorola.c
> @@ -368,7 +368,7 @@ motorolaBoard getMotorolaBoard(void)
> * NOTE: Every path must set currentBoard.
> currentBoard = (motorolaBoard) MVME_2100;
> #else
> unsigned char cpu_type;
> diff --git a/bsps/powerpc/shared/irq/irq_init.c
> b/bsps/powerpc/shared/irq/irq_init.c
> index 233c659b85..ecbff9bb19 100644
> --- a/bsps/powerpc/shared/irq/irq_init.c
> +++ b/bsps/powerpc/shared/irq/irq_init.c
> @@ -98,7 +98,7 @@ static rtems_irq_prio irqPrioTable[BSP_IRQ_NUMBER]={
> #if BSP_PCI_IRQ_NUMBER > 0
> static unsigned char mvme2100_openpic_initpolarities[16] = {
> 0, /* Not used - should be disabled */
> 0, /* DEC21143 Controller */
> @@ -276,7 +276,7 @@ loop_exit:
> void BSP_rtems_irq_mng_init(unsigned cpuId)
> -#if BSP_ISA_IRQ_NUMBER > 0 && !defined(mvme2100)
> +#if BSP_ISA_IRQ_NUMBER > 0 && !defined(mot_ppc_mvme2100)
> int known_cpi_isa_bridge = 0;
> #endif
> int i;
> @@ -285,7 +285,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
> * First initialize the Interrupt management hardware
> #ifdef TRACE_IRQ_INIT
> printk("Going to initialize EPIC interrupt controller (openpic
> compliant)\n");
> #endif
> diff --git a/bsps/powerpc/shared/pci/detect_raven_bridge.c
> b/bsps/powerpc/shared/pci/detect_raven_bridge.c
> index 0a1c04a2e2..a3f03e0acd 100644
> --- a/bsps/powerpc/shared/pci/detect_raven_bridge.c
> +++ b/bsps/powerpc/shared/pci/detect_raven_bridge.c
> @@ -30,7 +30,7 @@
> extern const pci_config_access_functions pci_direct_functions;
> extern const pci_config_access_functions pci_indirect_functions;
> /* FIXME - this should really be in a separate file - the 2100 doesn't
> * have a raven chip so there is no point having 2100 code here
> diff --git a/bsps/powerpc/shared/rtc/todcfg.c
> b/bsps/powerpc/shared/rtc/todcfg.c
> index 17ef18d5b5..95d75216a2 100644
> --- a/bsps/powerpc/shared/rtc/todcfg.c
> +++ b/bsps/powerpc/shared/rtc/todcfg.c
> @@ -11,7 +11,7 @@
> #include <libchip/m48t08.h>
> /* Forward function declaration */
> uint32_t mvmertc_get_register( uintptr_t, uint8_t );
> void mvmertc_set_register( uintptr_t, uint8_t, uint32_t );
> #endif
> @@ -24,7 +24,7 @@ rtc_tbl RTC_Table[] = {
> &m48t08_fns, /* pDeviceFns */
> rtc_probe, /* deviceProbe */
> NULL, /* pDeviceParams */
> 0xFFE81ff8, /* ulCtrlPort1 */
> 0x00, /* ulDataPort */
> m48t08_get_register, /* getRegister */
> @@ -44,7 +44,7 @@ rtc_tbl RTC_Table[] = {
> size_t RTC_Count = NUM_RTCS;
> #include <rtems/bspIo.h>
> uintptr_t base,
> diff --git a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml
> b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml
> index 5214a4c0fe..11aee65314 100644
> --- a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml
> +++ b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml
> @@ -14,5 +14,5 @@ description: |
> Defined for MVME2100 -- undefined for others
> enabled-by: true
> links: []
> -name: mvme2100
> +name: mot_ppc_mvme2100
> type: build
> diff --git a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
> b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
> index da417b9c9b..351b8e2d72 100644
> --- a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
> +++ b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
> Defined for MVME2307 -- undefined for others
> enabled-by: true
> links: []
> -name: mvme2307
> +name: mot_ppc_mvme2307
> type: build
> diff --git a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
> b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
> index 5b968bd1f0..5df50c6858 100644
> --- a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
> +++ b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
> Defined for MVME2700 -- undefined for others
> enabled-by: true
> links: []
> -name: mvme2700
> +name: mot_ppc_mvme2700
> type: build
> 2.37.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230411/913340cc/attachment-0001.htm>
