[PATCH 1/2] bsps/motorola_powerpc: Change defines from BSP names to avoid clash
Chris Johns
chrisj at rtems.org
Tue Apr 11 22:31:45 UTC 2023
On 11/4/2023 10:44 pm, Joel Sherrill wrote:
> On Tue, Apr 11, 2023, 12:00 AM <chrisj at rtems.org <mailto:chrisj at rtems.org>> wrote:
> From: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>
> - Change mvme2100 to mot_pcc_mvme2100 to avoid clashing with the
> RTEMS_BSP value for the BSP. You cannot have a define that is the
> BSP name.
> bsps/mips/include/bsp/i8259.h | 4 ++--
> bsps/powerpc/motorola_powerpc/include/bsp.h | 6 +++---
> bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h | 2 +-
> bsps/powerpc/motorola_powerpc/include/bsp/irq.h | 2 +-
> bsps/powerpc/motorola_powerpc/start/bspreset.c | 2 +-
> bsps/powerpc/motorola_powerpc/start/bspstart.c | 10 +++++-----
> bsps/powerpc/motorola_powerpc/start/motorola.c | 2 +-
> bsps/powerpc/shared/irq/irq_init.c | 6 +++---
> bsps/powerpc/shared/pci/detect_raven_bridge.c | 2 +-
> bsps/powerpc/shared/rtc/todcfg.c | 6 +++---
> .../bsps/powerpc/motorola_powerpc/optmvme2100.yml | 2 +-
> .../bsps/powerpc/motorola_powerpc/optmvme2307.yml | 2 +-
> .../bsps/powerpc/motorola_powerpc/optmvme2700.yml | 2 +-
> 13 files changed, 24 insertions(+), 24 deletions(-)
> diff --git a/bsps/mips/include/bsp/i8259.h b/bsps/mips/include/bsp/i8259.h
> index 1a947829b0..29e3853874 100644
> --- a/bsps/mips/include/bsp/i8259.h
> +++ b/bsps/mips/include/bsp/i8259.h
> @@ -37,7 +37,7 @@
> This patch looks ok except for this if 1. It appears it was already there but
> you touched it. Any explanation? Can the if 1 be removed?
It is a whitespace change and I decided to leave this in to clean it up. The
MIPS BSP as copied a header and I fixed the define to make sure all places have
been updated however any MIPS user should consider this common header being
shared but that is outside the scope of this change.
Is this OK?
> -#if 1
> +#if 1
> #define ISA8259_M_ELCR 0x4d0
> #define ISA8259_S_ELCR 0x4d1
> #endif
> @@ -169,7 +169,7 @@ extern "C" {
> -#if defined(mvme2100)
> +#if defined(mot_ppc_mvme2100)
> #define BSP_DEC21143_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 1)
> #define BSP_PMC_PCMIP_TYPE1_SLOT0_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 2)
> #define BSP_PCMIP_TYPE1_SLOT1_IRQ (BSP_PCI_IRQ_LOWEST_OFFSET + 3)
> diff --git a/bsps/powerpc/motorola_powerpc/include/bsp.h
> b/bsps/powerpc/motorola_powerpc/include/bsp.h
> index db0995fa5c..d44bcd5cff 100644
> --- a/bsps/powerpc/motorola_powerpc/include/bsp.h
> +++ b/bsps/powerpc/motorola_powerpc/include/bsp.h
> @@ -89,7 +89,7 @@ extern "C" {
> /* fundamental addresses for BSP (CHRPxxx and PREPxxx are from libcpu/io.h) */
> #define _IO_BASE CHRP_ISA_IO_BASE
> #define _ISA_MEM_BASE CHRP_ISA_MEM_BASE
> /* address of our ram on the PCI bus */
> @@ -154,7 +154,7 @@ extern "C" {
> * find out what it is which is VERY different from other Motorola boards.
> #define BSP_UART_IOBASE_COM1 ((_IO_BASE)+0x01e10000)
> /* #define BSP_UART_IOBASE_COM1 (0xffe10000) */
> #define BSP_OPEN_PIC_BASE_OFFSET 0x40000
> #define BSP_VGA_IOBASE ((_IO_BASE)+0x3c0)
> #endif
> -#if defined(mvme2300) || defined(mvme2307) || defined(mvme2700)
> +#if defined(mvme2300) || defined(mot_ppc_mvme2307) || defined(mot_ppc_mvme2700)
> #define MVME_HAS_DEC21140
> #endif
> #endif
> diff --git a/bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h
> b/bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h
> index 9b355819f1..9e57730d60 100644
> --- a/bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h
> +++ b/bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h
> @@ -66,7 +66,7 @@
> * available and unused!
> #define _VME_A32_WIN0_ON_PCI 0x90000000
> #define _VME_A24_ON_PCI 0x9f000000
> #define _VME_A16_ON_PCI 0x9fff0000
> diff --git a/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
> b/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
> index fea2859c3e..74bda323eb 100644
> --- a/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
> +++ b/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
> @@ -133,7 +133,7 @@ extern "C" {
> #define BSP_PCI_ISA_BRIDGE_IRQ (BSP_PCI_IRQ0)
> #endif
> diff --git a/bsps/powerpc/motorola_powerpc/start/bspreset.c
> b/bsps/powerpc/motorola_powerpc/start/bspreset.c
> index 0931badae4..d0af42284f 100644
> --- a/bsps/powerpc/motorola_powerpc/start/bspreset.c
> +++ b/bsps/powerpc/motorola_powerpc/start/bspreset.c
> @@ -16,7 +16,7 @@ void bsp_reset(void)
> CPU_print_stack();
> /* shutdown and reboot */
> *(unsigned char*)0xffe00000 |= 0x80;
> #else
> /* Memory-mapped Port 92 PIB device access
> diff --git a/bsps/powerpc/motorola_powerpc/start/bspstart.c
> b/bsps/powerpc/motorola_powerpc/start/bspstart.c
> index a781297565..894cf9d73d 100644
> --- a/bsps/powerpc/motorola_powerpc/start/bspstart.c
> +++ b/bsps/powerpc/motorola_powerpc/start/bspstart.c
> @@ -109,7 +109,7 @@ char *save_boot_params(
> return loaderParam;
> unsigned int EUMBBAR;
> @@ -130,7 +130,7 @@ uint32_t _CPU_Counter_frequency(void)
> static void bsp_early( void )
> -#if !defined(mvme2100)
> +#if !defined(mot_ppc_mvme2100)
> unsigned l2cr;
> #endif
> prep_t boardManufacturer;
> @@ -149,7 +149,7 @@ static void bsp_early( void )
> * Init MMU block address translation to enable hardware access
> * PC legacy IO space used for inb/outb and all PC compatible hardware
> @@ -173,7 +173,7 @@ static void bsp_early( void )
> setdbat(3, 0xb0000000, 0xb0000000, 0x10000000, IO_PAGE);
> #endif
> /* Need 0xfec00000 mapped for this */
> EUMBBAR = get_eumbbar();
> #endif
> @@ -200,7 +200,7 @@ static void bsp_early( void )
> #endif
> * Enable L2 Cache. Note that the set_L2CR(L2CR) codes checks for
> * relevant CPU type (mpc750)...
> diff --git a/bsps/powerpc/motorola_powerpc/start/motorola.c
> b/bsps/powerpc/motorola_powerpc/start/motorola.c
> index 25b1d3aa3c..58c711f07b 100644
> --- a/bsps/powerpc/motorola_powerpc/start/motorola.c
> +++ b/bsps/powerpc/motorola_powerpc/start/motorola.c
> @@ -368,7 +368,7 @@ motorolaBoard getMotorolaBoard(void)
> * NOTE: Every path must set currentBoard.
> currentBoard = (motorolaBoard) MVME_2100;
> #else
> unsigned char cpu_type;
> diff --git a/bsps/powerpc/shared/irq/irq_init.c
> b/bsps/powerpc/shared/irq/irq_init.c
> index 233c659b85..ecbff9bb19 100644
> --- a/bsps/powerpc/shared/irq/irq_init.c
> +++ b/bsps/powerpc/shared/irq/irq_init.c
> @@ -98,7 +98,7 @@ static rtems_irq_prio irqPrioTable[BSP_IRQ_NUMBER]={
> #if BSP_PCI_IRQ_NUMBER > 0
> static unsigned char mvme2100_openpic_initpolarities[16] = {
> 0, /* Not used - should be disabled */
> 0, /* DEC21143 Controller */
> @@ -276,7 +276,7 @@ loop_exit:
> void BSP_rtems_irq_mng_init(unsigned cpuId)
> -#if BSP_ISA_IRQ_NUMBER > 0 && !defined(mvme2100)
> +#if BSP_ISA_IRQ_NUMBER > 0 && !defined(mot_ppc_mvme2100)
> int known_cpi_isa_bridge = 0;
> #endif
> int i;
> @@ -285,7 +285,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
> * First initialize the Interrupt management hardware
> #ifdef TRACE_IRQ_INIT
> printk("Going to initialize EPIC interrupt controller (openpic
> compliant)\n");
> #endif
> diff --git a/bsps/powerpc/shared/pci/detect_raven_bridge.c
> b/bsps/powerpc/shared/pci/detect_raven_bridge.c
> index 0a1c04a2e2..a3f03e0acd 100644
> --- a/bsps/powerpc/shared/pci/detect_raven_bridge.c
> +++ b/bsps/powerpc/shared/pci/detect_raven_bridge.c
> @@ -30,7 +30,7 @@
> extern const pci_config_access_functions pci_direct_functions;
> extern const pci_config_access_functions pci_indirect_functions;
> /* FIXME - this should really be in a separate file - the 2100 doesn't
> * have a raven chip so there is no point having 2100 code here
> diff --git a/bsps/powerpc/shared/rtc/todcfg.c b/bsps/powerpc/shared/rtc/todcfg.c
> index 17ef18d5b5..95d75216a2 100644
> --- a/bsps/powerpc/shared/rtc/todcfg.c
> +++ b/bsps/powerpc/shared/rtc/todcfg.c
> @@ -11,7 +11,7 @@
> #include <libchip/m48t08.h>
> /* Forward function declaration */
> uint32_t mvmertc_get_register( uintptr_t, uint8_t );
> void mvmertc_set_register( uintptr_t, uint8_t, uint32_t );
> #endif
> @@ -24,7 +24,7 @@ rtc_tbl RTC_Table[] = {
> &m48t08_fns, /* pDeviceFns */
> rtc_probe, /* deviceProbe */
> NULL, /* pDeviceParams */
> 0xFFE81ff8, /* ulCtrlPort1 */
> 0x00, /* ulDataPort */
> m48t08_get_register, /* getRegister */
> @@ -44,7 +44,7 @@ rtc_tbl RTC_Table[] = {
> size_t RTC_Count = NUM_RTCS;
> #include <rtems/bspIo.h>
> uintptr_t base,
> diff --git a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml
> b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml
> index 5214a4c0fe..11aee65314 100644
> --- a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml
> +++ b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml
> @@ -14,5 +14,5 @@ description: |
> Defined for MVME2100 -- undefined for others
> enabled-by: true
> links: []
> -name: mvme2100
> +name: mot_ppc_mvme2100
> type: build
> diff --git a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
> b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
> index da417b9c9b..351b8e2d72 100644
> --- a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
> +++ b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
> Defined for MVME2307 -- undefined for others
> enabled-by: true
> links: []
> -name: mvme2307
> +name: mot_ppc_mvme2307
> type: build
> diff --git a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
> b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
> index 5b968bd1f0..5df50c6858 100644
> --- a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
> +++ b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
> Defined for MVME2700 -- undefined for others
> enabled-by: true
> links: []
> -name: mvme2700
> +name: mot_ppc_mvme2700
> type: build
> 2.37.1
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
> <http://lists.rtems.org/mailman/listinfo/devel>
