[PATCH v2] docs/user: add docs for riscv/kendrytek210 BSP variant
Alan Cudmore
alan.cudmore at gmail.com
Tue Apr 11 19:54:29 UTC 2023
Sorry, meant to reply to the list too.. I think you pushed v2 of my patch.
I was up to v6 that fixed a bunch of issues.
What is the best way to fix this? Rewind, or I can submit a new patch based
on this.
Thanks, Alan
On Tue, Apr 11, 2023, 2:29 PM Joel Sherrill <joel at rtems.org> wrote:
> Pushed. Thanks.
> Please check that it looks good to you.
> --joel
> On Fri, Mar 31, 2023 at 11:15 AM Alan Cudmore <alan.cudmore at gmail.com>
> wrote:
>> This patch adds the documentation for building and running RTEMS on the
>> Kendryte K210
>> RISC-V SoC. The generic riscv introducion was re-arranged to list the
>> multilib variants
>> then the specific hardware targets. In addition a couple of errors were
>> fixed for the
>> generic QEMU commands.
>> V2 corrected a typo, expanded K210 Console UART parameters, and addded a
>> hyperlink
>> to renode.io install instructions.
>> Closes #4876
>> user/bsps/bsps-riscv.rst | 116 ++++++++++++++++++++++++++++++++++-----
>> 1 file changed, 103 insertions(+), 13 deletions(-)
>> diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
>> index 41f369f..af79e6e 100644
>> --- a/user/bsps/bsps-riscv.rst
>> +++ b/user/bsps/bsps-riscv.rst
>> @@ -8,7 +8,7 @@ riscv (RISC-V)
>> riscv
>> -This BSP offers 12 variants:
>> +**This BSP offers 10 variants, each corresponding to a GCC multilib:**
>> * rv32i
>> @@ -30,23 +30,22 @@ This BSP offers 12 variants:
>> * rv64imafdc
>> -* frdme310arty
>> -* mpfs64imafdc
>> -Each rv* variant corresponds to a GCC multilib. A particular variant
>> reflects an
>> -ISA with ABI and code model choice. All rv64 BSPs have medany code model
>> by
>> +Each variant reflects an ISA with ABI and code model choice. All rv64
>> BSPs have medany code model by
>> default, while rv32 BSPs are medlow. The reason is that RV32 medlow can
>> access
>> the entire 32-bit address space, while RV64 medlow can only access
>> addresses
>> below 0x80000000. With RV64 medany, it's possible to perform accesses
>> above
>> -0x80000000.
>> +0x80000000. The BSP must be started in machine mode.
>> +The reference platform for the rv* variants is the QEMU `virt` machine.
>> +**The BSP also provides the following 3 variants for specific hardware
>> targets:**
>> -The BSP must be started im machine mode.
>> +* frdme310arty - The reference platform for this variant is the Arty
>> FPGA board with the Sifive Freedom E310 reference design.
>> -The reference platform for this BSP is the QEMU `virt` machine.
>> +* mpfs64imafdc - The reference platform for this variant is the
>> Microchip PolarFire SoC Icicle Kit.
>> +* kendrytek210 - The reference platform for this variant is the Kendryte
>> K210 SoC on the Sipeed MAiX Bit or MAiXDuino board.
>> -The reference platform for the mpfs64imafdc BSP variant is the Microchip
>> -PolarFire SoC Icicle Kit.
>> Build Configuration Options
>> @@ -90,6 +89,9 @@ configuration INI file. The ``waf`` defaults can be
>> used to inspect the values.
>> The maximum number of NS16550 devices supported by the console
>> driver (2
>> by default).
>> +``RISCV_ENABLE_SIFIVE_UART_SUPPORT``
>> + Enable the Sifive console UART (disabled by default)
>> ``RISCV_RAM_REGION_BEGIN``
>> The begin of the RAM region for linker command file (default is
>> 0x80000000).
>> @@ -104,6 +106,10 @@ configuration INI file. The ``waf`` defaults can be
>> Enables support Microchip PolarFire SoC if defined to a non-zero
>> value, otherwise it is disabled (disabled by default).
>> +``RISCV_ENABLE_KENDRYTE_K210_SUPPORT``
>> + Enables support for the Kendtryte K210 SoC if defined to a non-zero
>> + value, otherwise it is disabled (disabled by default).
>> ``RISCV_BOOT_HARTID``
>> The boot hartid (processor number) of risc-v cpu by default 0.
>> @@ -131,7 +137,7 @@ The console driver supports devices compatible to
>> * "ns16750" (see ``RISCV_CONSOLE_MAX_NS16550_DEVICES`` BSP option).
>> -* "sifive,uart0" (see ``RISCV_ENABLE_FRDME310ARTY_SUPPORT`` BSP option).
>> +* "sifive,uart0" (see ``RISCV_ENABLE_SIFIVE_UART_SUPPORT`` BSP option).
>> This console driver is used by the frdme310arty and kendrytek210 BSP
>> variants.
>> They are initialized according to the device tree. The console driver
>> does not
>> configure the pins or peripheral clocks. The console device is selected
>> @@ -145,11 +151,13 @@ and spike machines. For instance, to run the
>> ``rv64imafdc`` BSP with the
>> following "config.ini" file.
>> .. code-block:: none
>> [riscv/rv64imafdc]
>> Run the following QEMU command.
>> .. code-block:: shell
>> $ qemu-system-riscv64 -M virt -nographic -bios $RTEMS_EXE
>> $ qemu-system-riscv64 -M spike -nographic -bios $RTEMS_EXE
>> @@ -160,11 +168,13 @@ For instance, to run the ``rv64imafdc`` BSP with
>> the following
>> "config.ini" file.
>> [riscv/rv64imafdc]
>> Run the following Spike command.
>> $ spike --isa=rv64imafdc $RTEMS_EXE
>> Unlike QEMU, Spike supports enabling/disabling a subset of the imafdc
>> extensions
>> @@ -277,6 +287,86 @@ Serial terminal UART1 displays the SMP example
>> messages
>> *** END OF TEST SMP 1 ***
>> +Kendryte K210
>> +The Kendryte K210 SoC is a dual core 64-bit RISC-V SoC with an AI NPU,
>> +built in SRAM, and a variety of peripherals. Currently just the console
>> UART, interrupt controller, and timer are supported.
>> +The device tree blob is embedded in the ``kendrytek210`` BSP variant by
>> default.
>> +When the kendrytek210 BSP variant is selected, ``BSP_DTB_IS_SUPPORTED``
>> enabled and the DTB header path
>> +``BSP_DTB_HEADER_PATH`` is set to bsp/kendryte-k210-dtb.h.
>> +The ``kendrytek210`` BSP variant has been tested on the following
>> simulator and boards:
>> +* Renode.io simulator using the Kendrtye k210 model
>> +* Sipeed MAix BiT board
>> +* Sipeed MaixDuino board
>> +**Building the Kendryte K210 BSP**
>> +Configuration file ``config.ini``:
>> +.. code-block:: none
>> + [riscv/kendrytek210]
>> + RTEMS_SMP = True
>> +Build RTEMS:
>> +.. code-block:: shell
>> + $ ./waf configure --prefix=$HOME/rtems-start/rtems/6
>> + $ ./waf
>> +**Flash an executable to the Sipeed MAix BiT or MAixDuino board**
>> +Binary images can be flashed to the Sipeed boards through the USB port
>> using the kflash.py utility available from the python pip utility.
>> + $ riscv-rtems6-objcopy -Obinary ticker.exe ticker.bin
>> + $ kflash.py --uart /dev/ttyUSB0 ticker.bin
>> +After the image is flashed, the RTEMS image will automatically boot. It
>> will also run when the board is reset or powered through the USB cable. The
>> USB port provides the power and console UART. Plug the USB cable into a
>> host PC and bring up a terminal emulator at 115200 baud, 8 data bits, 1
>> stop bit, no parity, and no flow control. On Linux the UART device is often
>> ``/dev/ttyUSB0``.
>> +**Run a RTEMS application on the Renode.io simulator**
>> +RTEMS executables compiled with the kendrytek210 BSP can run on the
>> renode.io simulator using the built-in K210 model. The simulator
>> currently supports the console UART, interrupt controller, and timer.
>> +To install renode.io please refer to the `installation instructions <
>> https://github.com/renode/renode#installation>`_. Once installed make a
>> local copy of the ``kendryte_k210.resc`` script from the
>> ``renode/scripts/single-node`` directory to a local directory where it can
>> be edited. Edit the script and change the line that loads the Linux image
>> to load a RTEMS elf image instead. The default extension for the RTEMS
>> sample ELF images is ``.exe``.
>> +Change this line in the kendryte_k210.resc file:
>> + sysbus LoadELF @
>> https://dl.antmicro.com/projects/renode/kendryte-k210--vmlinux-s_2206416-2c1f2b2c2f2fc0c48a7b12a3f3c65809b81f452e
>> +To this:
>> + sysbus LoadELF @ticker.exe
>> +After editing the script, start renode and load the kendryte_k210.resc
>> script to start the emulation.
>> + (monitor) s @kendryte_k210.resc
>> +You should see a renode UART window and the RTEMS ticker example output.
>> +**Generating the Device Tree Header**
>> +The kendrytek210 BSP uses a built in device tree blob. If additional
>> peripheral support is added to the BSP, the device tree may need to be
>> updated. After editing the device tree source, compile it to a device tree
>> blob with the following command:
>> + $ dtc -O dtb -b 0 -o kendryte-k210.dtb kendryte-k210.dts
>> +The dtb file can then be converted to a C array using the rtems-bin2c
>> tool. The data for the device tree binary can then replace the existing
>> device tree binary data in the ``kendryte-k210-dtb.h`` header file.
>> noel
>> 2.25.1
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230411/4ff89785/attachment.htm>
