[PATCH v2] docs/user: add docs for riscv/kendrytek210 BSP variant
Tue Apr 11 21:05:01 UTC 2023
Sorry. I didn't realise there were that many revisions and when I searched
my inbox I missed it
I reverted V2 and applied V6. Hopefully ok now
On Tue, Apr 11, 2023, 2:54 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
> Sorry, meant to reply to the list too.. I think you pushed v2 of my patch.
> I was up to v6 that fixed a bunch of issues.
> What is the best way to fix this? Rewind, or I can submit a new patch
> based on this.
> Thanks, Alan
> On Tue, Apr 11, 2023, 2:29 PM Joel Sherrill <joel at rtems.org> wrote:
>> Pushed. Thanks.
>> Please check that it looks good to you.
>> --joel
>> On Fri, Mar 31, 2023 at 11:15 AM Alan Cudmore <alan.cudmore at gmail.com>
>> wrote:
>>> This patch adds the documentation for building and running RTEMS on the
>>> Kendryte K210
>>> RISC-V SoC. The generic riscv introducion was re-arranged to list the
>>> multilib variants
>>> then the specific hardware targets. In addition a couple of errors were
>>> fixed for the
>>> generic QEMU commands.
>>> V2 corrected a typo, expanded K210 Console UART parameters, and addded a
>>> hyperlink
>>> to renode.io install instructions.
>>> Closes #4876
>>>  user/bsps/bsps-riscv.rst | 116 ++++++++++++++++++++++++++++++++++-----
>>>  1 file changed, 103 insertions(+), 13 deletions(-)
>>> diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
>>> index 41f369f..af79e6e 100644
>>> --- a/user/bsps/bsps-riscv.rst
>>> +++ b/user/bsps/bsps-riscv.rst
>>> @@ -8,7 +8,7 @@ riscv (RISC-V)
>>>  riscv
>>> -This BSP offers 12 variants:
>>> +**This BSP offers 10 variants, each corresponding to a GCC multilib:**
>>>  * rv32i
>>> @@ -30,23 +30,22 @@ This BSP offers 12 variants:
>>>  * rv64imafdc
>>> -* frdme310arty
>>> -* mpfs64imafdc
>>> -Each rv* variant corresponds to a GCC multilib.  A particular variant
>>> reflects an
>>> -ISA with ABI and code model choice. All rv64 BSPs have medany code
>>> model by
>>> +Each variant reflects an ISA with ABI and code model choice. All rv64
>>> BSPs have medany code model by
>>>  default, while rv32 BSPs are medlow. The reason is that RV32 medlow can
>>> access
>>>  the entire 32-bit address space, while RV64 medlow can only access
>>> addresses
>>>  below 0x80000000. With RV64 medany, it's possible to perform accesses
>>> above
>>> -0x80000000.
>>> +0x80000000. The BSP must be started in machine mode.
>>> +The reference platform for the rv* variants is the QEMU `virt` machine.
>>> +**The BSP also provides the following 3 variants for specific hardware
>>> targets:**
>>> -The BSP must be started im machine mode.
>>> +* frdme310arty - The reference platform for this variant is the Arty
>>> FPGA board with the Sifive Freedom E310 reference design.
>>> -The reference platform for this BSP is the QEMU `virt` machine.
>>> +* mpfs64imafdc - The reference platform for this variant is the
>>> Microchip PolarFire SoC Icicle Kit.
>>> +* kendrytek210 - The reference platform for this variant is the
>>> Kendryte K210 SoC on the Sipeed MAiX Bit or MAiXDuino board.
>>> -The reference platform for the mpfs64imafdc BSP variant is the Microchip
>>> -PolarFire SoC Icicle Kit.
>>>  Build Configuration Options
>>> @@ -90,6 +89,9 @@ configuration INI file. The ``waf`` defaults can be
>>> used to inspect the values.
>>>       The maximum number of NS16550 devices supported by the console
>>> driver (2
>>>       by default).
>>> +``RISCV_ENABLE_SIFIVE_UART_SUPPORT``
>>> +     Enable the Sifive console UART (disabled by default)
>>>  ``RISCV_RAM_REGION_BEGIN``
>>>       The begin of the RAM region for linker command file (default is
>>> 0x80000000).
>>> @@ -104,6 +106,10 @@ configuration INI file. The ``waf`` defaults can be
>>>       Enables support Microchip PolarFire SoC if defined to a non-zero
>>>       value, otherwise it is disabled (disabled by default).
>>> +``RISCV_ENABLE_KENDRYTE_K210_SUPPORT``
>>> +     Enables support for the Kendtryte K210 SoC if defined to a non-zero
>>> +     value, otherwise it is disabled (disabled by default).
>>>  ``RISCV_BOOT_HARTID``
>>>       The boot hartid (processor number) of risc-v cpu by default 0.
>>> @@ -131,7 +137,7 @@ The console driver supports devices compatible to
>>>  * "ns16750" (see ``RISCV_CONSOLE_MAX_NS16550_DEVICES`` BSP option).
>>> -* "sifive,uart0" (see ``RISCV_ENABLE_FRDME310ARTY_SUPPORT`` BSP option).
>>> +* "sifive,uart0" (see ``RISCV_ENABLE_SIFIVE_UART_SUPPORT`` BSP option).
>>> This console driver is used by the frdme310arty and kendrytek210 BSP
>>> variants.
>>>  They are initialized according to the device tree.  The console driver
>>> does not
>>>  configure the pins or peripheral clocks.  The console device is selected
>>> @@ -145,11 +151,13 @@ and spike machines. For instance, to run the
>>> ``rv64imafdc`` BSP with the
>>>  following "config.ini" file.
>>>  .. code-block:: none
>>>      [riscv/rv64imafdc]
>>>  Run the following QEMU command.
>>>  .. code-block:: shell
>>>      $ qemu-system-riscv64 -M virt -nographic -bios $RTEMS_EXE
>>>      $ qemu-system-riscv64 -M spike -nographic -bios $RTEMS_EXE
>>> @@ -160,11 +168,13 @@ For instance, to run the ``rv64imafdc`` BSP with
>>> the following
>>>  "config.ini" file.
>>>      [riscv/rv64imafdc]
>>>  Run the following Spike command.
>>>      $ spike --isa=rv64imafdc $RTEMS_EXE
>>>  Unlike QEMU, Spike supports enabling/disabling a subset of the imafdc
>>> extensions
>>> @@ -277,6 +287,86 @@ Serial terminal UART1 displays the SMP example
>>> messages
>>>      *** END OF TEST SMP 1 ***
>>> +Kendryte K210
>>> +The Kendryte K210 SoC is a dual core 64-bit RISC-V SoC with an AI NPU,
>>> +built in SRAM, and a variety of peripherals. Currently just the console
>>> UART, interrupt controller, and timer are supported.
>>> +The device tree blob is embedded in the ``kendrytek210`` BSP variant by
>>> default.
>>> +When the kendrytek210 BSP variant is selected, ``BSP_DTB_IS_SUPPORTED``
>>> enabled and the DTB header path
>>> +``BSP_DTB_HEADER_PATH`` is set to bsp/kendryte-k210-dtb.h.
>>> +The ``kendrytek210`` BSP variant has been tested on the following
>>> simulator and boards:
>>> +* Renode.io simulator using the Kendrtye k210 model
>>> +* Sipeed MAix BiT board
>>> +* Sipeed MaixDuino board
>>> +**Building the Kendryte K210 BSP**
>>> +Configuration file ``config.ini``:
>>> +.. code-block:: none
>>> +    [riscv/kendrytek210]
>>> +    RTEMS_SMP = True
>>> +Build RTEMS:
>>> +.. code-block:: shell
>>> +    $ ./waf configure --prefix=$HOME/rtems-start/rtems/6
>>> +    $ ./waf
>>> +**Flash an executable to the Sipeed MAix BiT or MAixDuino board**
>>> +Binary images can be flashed to the Sipeed boards through the USB port
>>> using the kflash.py utility available from the python pip utility.
>>> +    $ riscv-rtems6-objcopy -Obinary ticker.exe ticker.bin
>>> +    $ kflash.py --uart /dev/ttyUSB0 ticker.bin
>>> +After the image is flashed, the RTEMS image will automatically boot. It
>>> will also run when the board is reset or powered through the USB cable. The
>>> USB port provides the power and console UART. Plug the USB cable into a
>>> host PC and bring up a terminal emulator at 115200 baud, 8 data bits, 1
>>> stop bit, no parity, and no flow control. On Linux the UART device is often
>>> ``/dev/ttyUSB0``.
>>> +**Run a RTEMS application on the Renode.io simulator**
>>> +RTEMS executables compiled with the kendrytek210 BSP can run on the
>>> renode.io simulator using the built-in K210 model. The simulator
>>> currently supports the console UART, interrupt controller, and timer.
>>> +To install renode.io please refer to the `installation instructions <
>>> https://github.com/renode/renode#installation>`_. Once installed make a
>>> local copy of the ``kendryte_k210.resc`` script from the
>>> ``renode/scripts/single-node`` directory to a local directory where it can
>>> be edited. Edit the script and change the line that loads the Linux image
>>> to load a RTEMS elf image instead. The default extension for the RTEMS
>>> sample ELF images is ``.exe``.
>>> +Change this line in the kendryte_k210.resc file:
>>> +    sysbus LoadELF @
>>> https://dl.antmicro.com/projects/renode/kendryte-k210--vmlinux-s_2206416-2c1f2b2c2f2fc0c48a7b12a3f3c65809b81f452e
>>> +To this:
>>> +    sysbus LoadELF @ticker.exe
>>> +After editing the script, start renode and load the kendryte_k210.resc
>>> script to start the emulation.
>>> +    (monitor) s @kendryte_k210.resc
>>> +You should see a renode UART window and the RTEMS ticker example output.
>>> +**Generating the Device Tree Header**
>>> +The kendrytek210 BSP uses a built in device tree blob. If additional
>>> peripheral support is added to the BSP, the device tree may need to be
>>> updated. After editing the device tree source, compile it to a device tree
>>> blob with the following command:
>>> +    $ dtc -O dtb -b 0 -o kendryte-k210.dtb kendryte-k210.dts
>>> +The dtb file can then be converted to a C array using the rtems-bin2c
>>> tool. The data for the device tree binary can then replace the existing
>>> device tree binary data in the ``kendryte-k210-dtb.h`` header file.
>>>  noel
>>> 2.25.1
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230411/73bf13e1/attachment-0001.htm>
