[PATCH v2] docs/user: add docs for riscv/kendrytek210 BSP variant
Alan Cudmore
alan.cudmore at gmail.com
Tue Apr 11 21:21:05 UTC 2023
Looks good - I generated the HTML and PDF versions.
Thanks,
Alan
On Tue, Apr 11, 2023 at 5:05 PM Joel Sherrill <joel at rtems.org> wrote:
> Sorry. I didn't realise there were that many revisions and when I searched
> my inbox I missed it
> I reverted V2 and applied V6. Hopefully ok now
> On Tue, Apr 11, 2023, 2:54 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
>> Sorry, meant to reply to the list too.. I think you pushed v2 of my
>> patch. I was up to v6 that fixed a bunch of issues.
>> What is the best way to fix this? Rewind, or I can submit a new patch
>> based on this.
>> Thanks, Alan
>> On Tue, Apr 11, 2023, 2:29 PM Joel Sherrill <joel at rtems.org> wrote:
>>> Pushed. Thanks.
>>> Please check that it looks good to you.
>>> --joel
>>> On Fri, Mar 31, 2023 at 11:15 AM Alan Cudmore <alan.cudmore at gmail.com>
>>> wrote:
>>>> This patch adds the documentation for building and running RTEMS on the
>>>> Kendryte K210
>>>> RISC-V SoC. The generic riscv introducion was re-arranged to list the
>>>> multilib variants
>>>> then the specific hardware targets. In addition a couple of errors were
>>>> fixed for the
>>>> generic QEMU commands.
>>>> V2 corrected a typo, expanded K210 Console UART parameters, and addded
>>>> a hyperlink
>>>> to renode.io install instructions.
>>>> Closes #4876
>>>> user/bsps/bsps-riscv.rst | 116 ++++++++++++++++++++++++++++++++++-----
>>>> 1 file changed, 103 insertions(+), 13 deletions(-)
>>>> diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
>>>> index 41f369f..af79e6e 100644
>>>> --- a/user/bsps/bsps-riscv.rst
>>>> +++ b/user/bsps/bsps-riscv.rst
>>>> @@ -8,7 +8,7 @@ riscv (RISC-V)
>>>> riscv
>>>> -This BSP offers 12 variants:
>>>> +**This BSP offers 10 variants, each corresponding to a GCC multilib:**
>>>> * rv32i
>>>> @@ -30,23 +30,22 @@ This BSP offers 12 variants:
>>>> * rv64imafdc
>>>> -* frdme310arty
>>>> -* mpfs64imafdc
>>>> -Each rv* variant corresponds to a GCC multilib. A particular variant
>>>> reflects an
>>>> -ISA with ABI and code model choice. All rv64 BSPs have medany code
>>>> model by
>>>> +Each variant reflects an ISA with ABI and code model choice. All rv64
>>>> BSPs have medany code model by
>>>> default, while rv32 BSPs are medlow. The reason is that RV32 medlow
>>>> can access
>>>> the entire 32-bit address space, while RV64 medlow can only access
>>>> addresses
>>>> below 0x80000000. With RV64 medany, it's possible to perform accesses
>>>> above
>>>> -0x80000000.
>>>> +0x80000000. The BSP must be started in machine mode.
>>>> +The reference platform for the rv* variants is the QEMU `virt` machine.
>>>> +**The BSP also provides the following 3 variants for specific hardware
>>>> targets:**
>>>> -The BSP must be started im machine mode.
>>>> +* frdme310arty - The reference platform for this variant is the Arty
>>>> FPGA board with the Sifive Freedom E310 reference design.
>>>> -The reference platform for this BSP is the QEMU `virt` machine.
>>>> +* mpfs64imafdc - The reference platform for this variant is the
>>>> Microchip PolarFire SoC Icicle Kit.
>>>> +* kendrytek210 - The reference platform for this variant is the
>>>> Kendryte K210 SoC on the Sipeed MAiX Bit or MAiXDuino board.
>>>> -The reference platform for the mpfs64imafdc BSP variant is the
>>>> Microchip
>>>> -PolarFire SoC Icicle Kit.
>>>> Build Configuration Options
>>>> @@ -90,6 +89,9 @@ configuration INI file. The ``waf`` defaults can be
>>>> used to inspect the values.
>>>> The maximum number of NS16550 devices supported by the console
>>>> driver (2
>>>> by default).
>>>> +``RISCV_ENABLE_SIFIVE_UART_SUPPORT``
>>>> + Enable the Sifive console UART (disabled by default)
>>>> ``RISCV_RAM_REGION_BEGIN``
>>>> The begin of the RAM region for linker command file (default is
>>>> 0x80000000).
>>>> @@ -104,6 +106,10 @@ configuration INI file. The ``waf`` defaults can
>>>> be used to inspect the values.
>>>> Enables support Microchip PolarFire SoC if defined to a non-zero
>>>> value, otherwise it is disabled (disabled by default).
>>>> +``RISCV_ENABLE_KENDRYTE_K210_SUPPORT``
>>>> + Enables support for the Kendtryte K210 SoC if defined to a
>>>> non-zero
>>>> + value, otherwise it is disabled (disabled by default).
>>>> ``RISCV_BOOT_HARTID``
>>>> The boot hartid (processor number) of risc-v cpu by default 0.
>>>> @@ -131,7 +137,7 @@ The console driver supports devices compatible to
>>>> * "ns16750" (see ``RISCV_CONSOLE_MAX_NS16550_DEVICES`` BSP option).
>>>> -* "sifive,uart0" (see ``RISCV_ENABLE_FRDME310ARTY_SUPPORT`` BSP
>>>> option).
>>>> +* "sifive,uart0" (see ``RISCV_ENABLE_SIFIVE_UART_SUPPORT`` BSP
>>>> option). This console driver is used by the frdme310arty and kendrytek210
>>>> BSP variants.
>>>> They are initialized according to the device tree. The console driver
>>>> does not
>>>> configure the pins or peripheral clocks. The console device is
>>>> selected
>>>> @@ -145,11 +151,13 @@ and spike machines. For instance, to run the
>>>> ``rv64imafdc`` BSP with the
>>>> following "config.ini" file.
>>>> .. code-block:: none
>>>> [riscv/rv64imafdc]
>>>> Run the following QEMU command.
>>>> .. code-block:: shell
>>>> $ qemu-system-riscv64 -M virt -nographic -bios $RTEMS_EXE
>>>> $ qemu-system-riscv64 -M spike -nographic -bios $RTEMS_EXE
>>>> @@ -160,11 +168,13 @@ For instance, to run the ``rv64imafdc`` BSP with
>>>> the following
>>>> "config.ini" file.
>>>> [riscv/rv64imafdc]
>>>> Run the following Spike command.
>>>> $ spike --isa=rv64imafdc $RTEMS_EXE
>>>> Unlike QEMU, Spike supports enabling/disabling a subset of the imafdc
>>>> extensions
>>>> @@ -277,6 +287,86 @@ Serial terminal UART1 displays the SMP example
>>>> messages
>>>> *** END OF TEST SMP 1 ***
>>>> +Kendryte K210
>>>> +The Kendryte K210 SoC is a dual core 64-bit RISC-V SoC with an AI NPU,
>>>> +built in SRAM, and a variety of peripherals. Currently just the
>>>> console UART, interrupt controller, and timer are supported.
>>>> +The device tree blob is embedded in the ``kendrytek210`` BSP variant
>>>> by default.
>>>> +When the kendrytek210 BSP variant is selected,
>>>> ``BSP_DTB_IS_SUPPORTED`` enabled and the DTB header path
>>>> +``BSP_DTB_HEADER_PATH`` is set to bsp/kendryte-k210-dtb.h.
>>>> +The ``kendrytek210`` BSP variant has been tested on the following
>>>> simulator and boards:
>>>> +* Renode.io simulator using the Kendrtye k210 model
>>>> +* Sipeed MAix BiT board
>>>> +* Sipeed MaixDuino board
>>>> +**Building the Kendryte K210 BSP**
>>>> +Configuration file ``config.ini``:
>>>> +.. code-block:: none
>>>> + [riscv/kendrytek210]
>>>> + RTEMS_SMP = True
>>>> +Build RTEMS:
>>>> +.. code-block:: shell
>>>> + $ ./waf configure --prefix=$HOME/rtems-start/rtems/6
>>>> + $ ./waf
>>>> +**Flash an executable to the Sipeed MAix BiT or MAixDuino board**
>>>> +Binary images can be flashed to the Sipeed boards through the USB port
>>>> using the kflash.py utility available from the python pip utility.
>>>> + $ riscv-rtems6-objcopy -Obinary ticker.exe ticker.bin
>>>> + $ kflash.py --uart /dev/ttyUSB0 ticker.bin
>>>> +After the image is flashed, the RTEMS image will automatically boot.
>>>> It will also run when the board is reset or powered through the USB cable.
>>>> The USB port provides the power and console UART. Plug the USB cable into a
>>>> host PC and bring up a terminal emulator at 115200 baud, 8 data bits, 1
>>>> stop bit, no parity, and no flow control. On Linux the UART device is often
>>>> ``/dev/ttyUSB0``.
>>>> +**Run a RTEMS application on the Renode.io simulator**
>>>> +RTEMS executables compiled with the kendrytek210 BSP can run on the
>>>> renode.io simulator using the built-in K210 model. The simulator
>>>> currently supports the console UART, interrupt controller, and timer.
>>>> +To install renode.io please refer to the `installation instructions <
>>>> https://github.com/renode/renode#installation>`_. Once installed make
>>>> a local copy of the ``kendryte_k210.resc`` script from the
>>>> ``renode/scripts/single-node`` directory to a local directory where it can
>>>> be edited. Edit the script and change the line that loads the Linux image
>>>> to load a RTEMS elf image instead. The default extension for the RTEMS
>>>> sample ELF images is ``.exe``.
>>>> +Change this line in the kendryte_k210.resc file:
>>>> + sysbus LoadELF @
>>>> https://dl.antmicro.com/projects/renode/kendryte-k210--vmlinux-s_2206416-2c1f2b2c2f2fc0c48a7b12a3f3c65809b81f452e
>>>> +To this:
>>>> + sysbus LoadELF @ticker.exe
>>>> +After editing the script, start renode and load the kendryte_k210.resc
>>>> script to start the emulation.
>>>> + (monitor) s @kendryte_k210.resc
>>>> +You should see a renode UART window and the RTEMS ticker example
>>>> output.
>>>> +**Generating the Device Tree Header**
>>>> +The kendrytek210 BSP uses a built in device tree blob. If additional
>>>> peripheral support is added to the BSP, the device tree may need to be
>>>> updated. After editing the device tree source, compile it to a device tree
>>>> blob with the following command:
>>>> + $ dtc -O dtb -b 0 -o kendryte-k210.dtb kendryte-k210.dts
>>>> +The dtb file can then be converted to a C array using the rtems-bin2c
>>>> tool. The data for the device tree binary can then replace the existing
>>>> device tree binary data in the ``kendryte-k210-dtb.h`` header file.
>>>> noel
>>>> 2.25.1
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230411/d4503e3a/attachment.htm>
