[PATCH v2 1/2] bsps/motorola_powerpc: Change defines from BSP names to avoid clash
chrisj at rtems.org chrisj at rtems.org
Wed Apr 12 01:56:21 UTC 2023
- Change mvme2100 to mot_pcc_mvme2100 to avoid clashing with the
  RTEMS_BSP value for the BSP. You cannot have a define that is the
  BSP name or the RTEMS_BSP name will be the define.
 bsps/mips/include/bsp/i8259.h                          |  2 +-
 bsps/powerpc/motorola_powerpc/include/bsp.h            |  6 +++---
 bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h  |  2 +-
 bsps/powerpc/motorola_powerpc/include/bsp/irq.h        |  2 +-
 bsps/powerpc/motorola_powerpc/start/bspreset.c         |  2 +-
 bsps/powerpc/motorola_powerpc/start/bspstart.c         | 10 +++++-----
 bsps/powerpc/motorola_powerpc/start/motorola.c         |  2 +-
 bsps/powerpc/shared/irq/irq_init.c                     |  6 +++---
 bsps/powerpc/shared/pci/detect_raven_bridge.c          |  2 +-
 bsps/powerpc/shared/rtc/todcfg.c                       |  6 +++---
 .../bsps/powerpc/motorola_powerpc/optmvme2100.yml      |  2 +-
 .../bsps/powerpc/motorola_powerpc/optmvme2307.yml      |  2 +-
 .../bsps/powerpc/motorola_powerpc/optmvme2700.yml      |  2 +-
 13 files changed, 23 insertions(+), 23 deletions(-)
diff --git a/bsps/mips/include/bsp/i8259.h b/bsps/mips/include/bsp/i8259.h
index 1a947829b0..e833fd2d36 100644
--- a/bsps/mips/include/bsp/i8259.h
+++ b/bsps/mips/include/bsp/i8259.h
@@ -169,7 +169,7 @@ extern "C" {
-#if defined(mvme2100)
+#if defined(mot_ppc_mvme2100)
 #define BSP_DEC21143_IRQ                (BSP_PCI_IRQ_LOWEST_OFFSET + 1)
 #define BSP_PMC_PCMIP_TYPE1_SLOT0_IRQ   (BSP_PCI_IRQ_LOWEST_OFFSET + 2)
 #define BSP_PCMIP_TYPE1_SLOT1_IRQ       (BSP_PCI_IRQ_LOWEST_OFFSET + 3)
diff --git a/bsps/powerpc/motorola_powerpc/include/bsp.h b/bsps/powerpc/motorola_powerpc/include/bsp.h
index db0995fa5c..d44bcd5cff 100644
--- a/bsps/powerpc/motorola_powerpc/include/bsp.h
+++ b/bsps/powerpc/motorola_powerpc/include/bsp.h
@@ -89,7 +89,7 @@ extern "C" {
 /* fundamental addresses for BSP (CHRPxxx and PREPxxx are from libcpu/io.h) */
 #define	_IO_BASE		CHRP_ISA_IO_BASE
 #define	_ISA_MEM_BASE		CHRP_ISA_MEM_BASE
 /* address of our ram on the PCI bus   */
@@ -154,7 +154,7 @@ extern "C" {
  *  find out what it is which is VERY different from other Motorola boards.
 #define BSP_UART_IOBASE_COM1 ((_IO_BASE)+0x01e10000)
 /* #define BSP_UART_IOBASE_COM1     (0xffe10000) */
 #define BSP_OPEN_PIC_BASE_OFFSET 0x40000
 #define BSP_VGA_IOBASE       ((_IO_BASE)+0x3c0)
 #endif
-#if defined(mvme2300) || defined(mvme2307) || defined(mvme2700)
+#if defined(mvme2300) || defined(mot_ppc_mvme2307) || defined(mot_ppc_mvme2700)
 #define MVME_HAS_DEC21140
 #endif
 #endif
diff --git a/bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h b/bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h
index 9b355819f1..9e57730d60 100644
--- a/bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h
+++ b/bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h
@@ -66,7 +66,7 @@
  * available and unused!
 #define _VME_A32_WIN0_ON_PCI  0x90000000
 #define _VME_A24_ON_PCI      0x9f000000
 #define _VME_A16_ON_PCI      0x9fff0000
diff --git a/bsps/powerpc/motorola_powerpc/include/bsp/irq.h b/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
index fea2859c3e..74bda323eb 100644
--- a/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
+++ b/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
@@ -133,7 +133,7 @@ extern "C" {
 #define BSP_PCI_ISA_BRIDGE_IRQ		(BSP_PCI_IRQ0)
 #endif
diff --git a/bsps/powerpc/motorola_powerpc/start/bspreset.c b/bsps/powerpc/motorola_powerpc/start/bspreset.c
index 0931badae4..d0af42284f 100644
--- a/bsps/powerpc/motorola_powerpc/start/bspreset.c
+++ b/bsps/powerpc/motorola_powerpc/start/bspreset.c
@@ -16,7 +16,7 @@ void bsp_reset(void)
   CPU_print_stack();
   /* shutdown and reboot */
   *(unsigned char*)0xffe00000 |= 0x80;
 #else
    /* Memory-mapped Port 92 PIB device access
diff --git a/bsps/powerpc/motorola_powerpc/start/bspstart.c b/bsps/powerpc/motorola_powerpc/start/bspstart.c
index a781297565..894cf9d73d 100644
--- a/bsps/powerpc/motorola_powerpc/start/bspstart.c
+++ b/bsps/powerpc/motorola_powerpc/start/bspstart.c
@@ -109,7 +109,7 @@ char *save_boot_params(
   return loaderParam;
 unsigned int EUMBBAR;
@@ -130,7 +130,7 @@ uint32_t _CPU_Counter_frequency(void)
 static void bsp_early( void )
-#if !defined(mvme2100)
+#if !defined(mot_ppc_mvme2100)
   unsigned l2cr;
 #endif
   prep_t boardManufacturer;
@@ -149,7 +149,7 @@ static void bsp_early( void )
    * Init MMU block address translation to enable hardware access
    * PC legacy IO space used for inb/outb and all PC compatible hardware
@@ -173,7 +173,7 @@ static void bsp_early( void )
   setdbat(3, 0xb0000000, 0xb0000000, 0x10000000, IO_PAGE);
 #endif
   /* Need 0xfec00000 mapped for this */
   EUMBBAR = get_eumbbar();
 #endif
@@ -200,7 +200,7 @@ static void bsp_early( void )
 #endif
    * Enable L2 Cache. Note that the set_L2CR(L2CR) codes checks for
    * relevant CPU type (mpc750)...
diff --git a/bsps/powerpc/motorola_powerpc/start/motorola.c b/bsps/powerpc/motorola_powerpc/start/motorola.c
index 25b1d3aa3c..58c711f07b 100644
--- a/bsps/powerpc/motorola_powerpc/start/motorola.c
+++ b/bsps/powerpc/motorola_powerpc/start/motorola.c
@@ -368,7 +368,7 @@ motorolaBoard getMotorolaBoard(void)
  *  NOTE: Every path must set currentBoard.
   currentBoard = (motorolaBoard) MVME_2100;
 #else
   unsigned char  cpu_type;
diff --git a/bsps/powerpc/shared/irq/irq_init.c b/bsps/powerpc/shared/irq/irq_init.c
index 233c659b85..ecbff9bb19 100644
--- a/bsps/powerpc/shared/irq/irq_init.c
+++ b/bsps/powerpc/shared/irq/irq_init.c
@@ -98,7 +98,7 @@ static rtems_irq_prio irqPrioTable[BSP_IRQ_NUMBER]={
 #if BSP_PCI_IRQ_NUMBER > 0
 static unsigned char mvme2100_openpic_initpolarities[16] = {
     0,  /* Not used - should be disabled */
     0,	/* DEC21143 Controller */
@@ -276,7 +276,7 @@ loop_exit:
 void BSP_rtems_irq_mng_init(unsigned cpuId)
-#if BSP_ISA_IRQ_NUMBER > 0 && !defined(mvme2100)
+#if BSP_ISA_IRQ_NUMBER > 0 && !defined(mot_ppc_mvme2100)
   int known_cpi_isa_bridge = 0;
 #endif
   int i;
@@ -285,7 +285,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
    * First initialize the Interrupt management hardware
 #ifdef TRACE_IRQ_INIT
   printk("Going to initialize EPIC interrupt controller (openpic compliant)\n");
 #endif
diff --git a/bsps/powerpc/shared/pci/detect_raven_bridge.c b/bsps/powerpc/shared/pci/detect_raven_bridge.c
index 0a1c04a2e2..a3f03e0acd 100644
--- a/bsps/powerpc/shared/pci/detect_raven_bridge.c
+++ b/bsps/powerpc/shared/pci/detect_raven_bridge.c
@@ -30,7 +30,7 @@
 extern const pci_config_access_functions pci_direct_functions;
 extern const pci_config_access_functions pci_indirect_functions;
 /* FIXME - this should really be in a separate file - the 2100 doesn't
  *         have a raven chip so there is no point having 2100 code here
diff --git a/bsps/powerpc/shared/rtc/todcfg.c b/bsps/powerpc/shared/rtc/todcfg.c
index 17ef18d5b5..95d75216a2 100644
--- a/bsps/powerpc/shared/rtc/todcfg.c
+++ b/bsps/powerpc/shared/rtc/todcfg.c
@@ -11,7 +11,7 @@
 #include <libchip/m48t08.h>
 /* Forward function declaration */
 uint32_t mvmertc_get_register( uintptr_t, uint8_t );
 void mvmertc_set_register( uintptr_t, uint8_t, uint32_t );
 #endif
@@ -24,7 +24,7 @@ rtc_tbl RTC_Table[] = {
         &m48t08_fns,               /* pDeviceFns */
         rtc_probe,                 /* deviceProbe */
         NULL,                      /* pDeviceParams */
         0xFFE81ff8,                /* ulCtrlPort1 */
         0x00,                      /* ulDataPort */
         m48t08_get_register,       /* getRegister */
@@ -44,7 +44,7 @@ rtc_tbl RTC_Table[] = {
 size_t RTC_Count = NUM_RTCS;
 #include <rtems/bspIo.h>
   uintptr_t base,
diff --git a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml
index 5214a4c0fe..11aee65314 100644
--- a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml
+++ b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2100.yml
@@ -14,5 +14,5 @@ description: |
   Defined for MVME2100 -- undefined for others
 enabled-by: true
 links: []
-name: mvme2100
+name: mot_ppc_mvme2100
 type: build
diff --git a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
index da417b9c9b..351b8e2d72 100644
--- a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
+++ b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
   Defined for MVME2307 -- undefined for others
 enabled-by: true
 links: []
-name: mvme2307
+name: mot_ppc_mvme2307
 type: build
diff --git a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
index 5b968bd1f0..5df50c6858 100644
--- a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
+++ b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
   Defined for MVME2700 -- undefined for others
 enabled-by: true
 links: []
-name: mvme2700
+name: mot_ppc_mvme2700
 type: build
2.37.1
