[PATCH v2 2/2] bsps/powerpc: Fix warnings with PPC_SPECIAL_PURPOSE_REGISTER
chrisj at rtems.org chrisj at rtems.org
Wed Apr 12 01:56:22 UTC 2023
- This change avoids the GCC extension of blocks in expressions that
  ISO forbids and is warned about with the pedantic warnings option.
 bsps/powerpc/include/libcpu/powerpc-utility.h | 42 ++++++++++---------
 .../powerpc/shared/exceptions/ppc_exc_print.c | 25 ++++++-----
 2 files changed, 38 insertions(+), 29 deletions(-)
diff --git a/bsps/powerpc/include/libcpu/powerpc-utility.h b/bsps/powerpc/include/libcpu/powerpc-utility.h
index 922e5d2407..0f916ae9fa 100644
--- a/bsps/powerpc/include/libcpu/powerpc-utility.h
+++ b/bsps/powerpc/include/libcpu/powerpc-utility.h
@@ -574,18 +574,12 @@ static inline void ppc_set_decrementer_register(uint32_t dec)
  * @brief Returns the value of the Special Purpose Register with number @a spr.
- * @note This macro uses a GNU C extension.
-#define PPC_SPECIAL_PURPOSE_REGISTER(spr) \
-    uint32_t val; \
-    __asm__ volatile (\
-      "mfspr %0, " PPC_STRINGOF(spr) \
-      : "=r" (val) \
-    val;\
+#define PPC_SPECIAL_PURPOSE_REGISTER(spr, val) \
+  __asm__ volatile (\
+    "mfspr %0, " PPC_STRINGOF(spr) \
+    : "=r" (val) \
  * @brief Sets the Special Purpose Register with number @a spr to the value in
@@ -612,7 +606,7 @@ static inline void ppc_set_decrementer_register(uint32_t dec)
     uint32_t val; \
     uint32_t mybits = bits; \
     _ISR_Local_disable(level); \
-    val = PPC_SPECIAL_PURPOSE_REGISTER(spr); \
+    PPC_SPECIAL_PURPOSE_REGISTER(spr, val); \
     val |= mybits; \
     PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val); \
     _ISR_Local_enable(level); \
@@ -632,7 +626,7 @@ static inline void ppc_set_decrementer_register(uint32_t dec)
     uint32_t mymask = mask; \
     val &= ~mymask; \
     val |= mybits; \
@@ -651,7 +645,7 @@ static inline void ppc_set_decrementer_register(uint32_t dec)
     uint32_t val; \
     val &= ~mybits; \
@@ -790,7 +784,9 @@ static inline void ppc_set_time_base(uint32_t val)
 static inline uint32_t ppc_time_base_upper(void)
-  return PPC_SPECIAL_PURPOSE_REGISTER(TBRU);
+  uint32_t val;
+  PPC_SPECIAL_PURPOSE_REGISTER(TBRU, val);
+  return val;
 static inline void ppc_set_time_base_upper(uint32_t val)
@@ -810,12 +806,16 @@ static inline void ppc_set_time_base_64(uint64_t val)
 static inline uint32_t ppc_alternate_time_base(void)
-  return PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_ATBL);
+  uint32_t val;
+  PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_ATBL, val);
+  return val;
 static inline uint32_t ppc_alternate_time_base_upper(void)
-  return PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_ATBU);
+  uint32_t val;
+  PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_ATBU, val);
+  return val;
 static inline uint64_t ppc_alternate_time_base_64(void)
@@ -835,7 +835,9 @@ static inline uint64_t ppc_alternate_time_base_64(void)
 static inline uint32_t ppc_processor_id(void)
-  return PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_PIR);
+  uint32_t val;
+  PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_PIR, val);
+  return val;
 static inline void ppc_set_processor_id(uint32_t val)
@@ -845,7 +847,9 @@ static inline void ppc_set_processor_id(uint32_t val)
 static inline uint32_t ppc_fsl_system_version(void)
-  return PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_SVR);
+  uint32_t val;
+  PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_SVR, val);
+  return val;
 static inline uint32_t ppc_fsl_system_version_cid(uint32_t svr)
diff --git a/bsps/powerpc/shared/exceptions/ppc_exc_print.c b/bsps/powerpc/shared/exceptions/ppc_exc_print.c
index e4fcc73cb1..ff231beff9 100644
--- a/bsps/powerpc/shared/exceptions/ppc_exc_print.c
+++ b/bsps/powerpc/shared/exceptions/ppc_exc_print.c
@@ -42,18 +42,23 @@ typedef struct LRFrameRec_ {
 static uint32_t ppc_exc_get_DAR_dflt(void)
-  if (ppc_cpu_is_60x())
-    return PPC_SPECIAL_PURPOSE_REGISTER(PPC_DAR);
-  else
+  uint32_t val;
+  if (ppc_cpu_is_60x()) {
+    PPC_SPECIAL_PURPOSE_REGISTER(PPC_DAR, val);
+    return val;
+  } else {
     switch (ppc_cpu_is_bookE()) {
       default:
         break;
       case PPC_BOOKE_STD:
       case PPC_BOOKE_E500:
-        return PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_DEAR);
+        PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_DEAR, val);
+        return val;
       case PPC_BOOKE_405:
-        return PPC_SPECIAL_PURPOSE_REGISTER(PPC405_DEAR);
+        PPC_SPECIAL_PURPOSE_REGISTER(PPC405_DEAR, val);
+        return val;
   return 0xdeadbeef;
@@ -170,13 +175,13 @@ void _CPU_Exception_frame_print(const CPU_Exception_frame *excPtr)
     printk(" %s = 0x%08" PRIx32 "\n", reg, ppc_exc_get_DAR());
   if (ppc_cpu_is_bookE()) {
-    unsigned esr, mcsr;
+    uint32_t esr, mcsr;
     if (ppc_cpu_is_bookE() == PPC_BOOKE_405) {
-      esr  = PPC_SPECIAL_PURPOSE_REGISTER(PPC405_ESR);
-      mcsr = PPC_SPECIAL_PURPOSE_REGISTER(PPC405_MCSR);
+      PPC_SPECIAL_PURPOSE_REGISTER(PPC405_ESR, esr);
+      PPC_SPECIAL_PURPOSE_REGISTER(PPC405_MCSR, mcsr);
     } else {
-      esr  = PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_ESR);
-      mcsr = PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_MCSR);
+      PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_ESR, esr);
+      PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_MCSR, mcsr);
     printk("  ESR = 0x%08x\n", esr);
     printk(" MCSR = 0x%08x\n", mcsr);
2.37.1
