AW: [PATCH 00/18] Port PTPd to rtems-libbsd
Gabriel.Moyano at dlr.de Gabriel.Moyano at dlr.de
Thu Apr 13 06:46:23 UTC 2023
> On 12/4/2023 11:54 pm, Gabriel Moyano wrote:
> > These commits are for porting PTPd to rtems-libbsd and are based on the
> master branch.
> > This work is a joint effort with Chris Johns, which we started some time
> ago.
> > Originally, we wanted to port some of the commits to PTPd upstream but
> unfortunately the project is no longer maintained (our pull request has been
> open for more than a year).
> > For this reason, we decided to add PTPd files as contrib.
> > In fact, this is the first commit.
> > One important feature introduced to PTPd is the support for kqueue,
> which was done by Chris.
> > Also, a new test for running a PTPd instance was added to the test suit.
> > I'm happy to hear feedback from you.
> Thank for you for all the work I know has gone into getting this package
> together. It has been a journey. It is great to see the work reach this finished
> level ready to merge.
Thanks you too.
> Is this for the master, 6-freebsd-12 or both branches of libbsd?
It is for the master, once approved I'll create the one for 6-freebsd-12. I understand that there will be some changes needed.
