[PATCH] spec/bsp/makecustom: Make BSP include path a system include path
chrisj at rtems.org
chrisj at rtems.org
Wed Apr 12 22:20:04 UTC 2023
- Export the BSP include path as a system include path so the order
of options on an application compiler command line does not matter.
Closes #4896
spec/build/bsps/makecustom.yml | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/spec/build/bsps/makecustom.yml b/spec/build/bsps/makecustom.yml
index 139629b597..c00240595e 100644
--- a/spec/build/bsps/makecustom.yml
+++ b/spec/build/bsps/makecustom.yml
@@ -2,7 +2,7 @@ SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
build-type: config-file
content: |
include $$(RTEMS_ROOT)/make/custom/default.cfg
- CPU_DEFINES = -I$$(exec_prefix)/$$(RTEMS_BSP)/lib/include
+ CPU_DEFINES = -isystem $$(exec_prefix)/$$(RTEMS_BSP)/lib/include
CPU_CFLAGS = ${ABI_FLAGS}
CFLAGS_OPTIMIZE_V = ${OPTIMIZATION_FLAGS}
LDFLAGS = -B$$(exec_prefix)/$$(RTEMS_BSP)/lib ${PKGCONFIG_LDFLAGS}
2.37.1
