[PATCH] spec/bsp/makecustom: Make BSP include path a system include path
Will
nyphbl8d at gmail.com
Thu Apr 13 13:48:52 UTC 2023
This change is fine, but it also needs the packageconfig change to match.
The thread from October has the full patch (title was "[PATCH v2]
spec/pkgconfig: Allow builds to override headers"). This also needs a
change to libbsd to account for this alteration, IIRC.
Kinsey
On Wed, Apr 12, 2023 at 5:20 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Export the BSP include path as a system include path so the order
> of options on an application compiler command line does not matter.
> Closes #4896
> spec/build/bsps/makecustom.yml | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/spec/build/bsps/makecustom.yml
> b/spec/build/bsps/makecustom.yml
> index 139629b597..c00240595e 100644
> --- a/spec/build/bsps/makecustom.yml
> +++ b/spec/build/bsps/makecustom.yml
> @@ -2,7 +2,7 @@ SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> build-type: config-file
> content: |
> include $$(RTEMS_ROOT)/make/custom/default.cfg
> - CPU_DEFINES = -I$$(exec_prefix)/$$(RTEMS_BSP)/lib/include
> + CPU_DEFINES = -isystem $$(exec_prefix)/$$(RTEMS_BSP)/lib/include
> CPU_CFLAGS = ${ABI_FLAGS}
> CFLAGS_OPTIMIZE_V = ${OPTIMIZATION_FLAGS}
> LDFLAGS = -B$$(exec_prefix)/$$(RTEMS_BSP)/lib ${PKGCONFIG_LDFLAGS}
> 2.37.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230413/2e211bd8/attachment.htm>
