[rtems-source-builder PATCH] rtems: Add back gsed that was remove by mistake
chrisj at rtems.org chrisj at rtems.org
Fri Apr 14 22:56:45 UTC 2023
- Build GNU sed for hosts that it is not installed on for the MIPS
  tools.
 rtems/config/tools/rtems-default-tools.bset | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/rtems/config/tools/rtems-default-tools.bset b/rtems/config/tools/rtems-default-tools.bset
index 0291786..35c9235 100644
--- a/rtems/config/tools/rtems-default-tools.bset
+++ b/rtems/config/tools/rtems-default-tools.bset
@@ -6,7 +6,7 @@
 # available
 %define _internal_gsed_path %{_tmpinternal}
-%defineifnot with_rtems_gmp textproc/gsed-internal
+%defineifnot with_rtems_gsed textproc/gsed-internal
 # GNU tools need texinfo for makeinfo to build documentation
 %define _internal_texinfo_path %{_tmpinternal}
@@ -21,6 +21,7 @@
 %{with_rtems_dtc}
 %{with_rtems_expat}
 %{with_rtems_gmp}
+%{with_rtems_gsed}
 %{with_rtems_texinfo}
 %{with_rtems_gdb}
 %{with_rtems_binutils}
2.37.1
