FreeBSD libefi import -- how to proceed?
Sat Apr 15 00:25:18 UTC 2023
On Fri, Apr 14, 2023, 3:00 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Mar 28, 2023 at 4:27 AM Karel Gardas <karel at functional.vision>
> wrote:
> >    Folks,
> > I'm using FreeBSD's libefi on my hacked multiboot2 based amd64 BSP which
> > I'd like to push for review (at least).
> > Now, I'd like to prepare libefi for import but I'm still in doubts if to
> > do that in:
> > - as intact form as possible, import even files which will not be used
> > in foreseeable future or even ever
> It looks like a lot to import wholesale. usually within RTEMS itself
> we have been selective and prefer to avoid bringing in dead
> code/files.
I think this is a pretty solid guide to follow. Unless you find yourself
importing all but a handful anyway. Or there is a clear near term path to
needing it.
Avoid dead code but don't make it harder to maintain in the future.
I like a file named ORIGIN which identifies the source info/hash.
> > - as minimalistic as possible. Include only files really needed by
> > RTEMS. Where making compilation issues #ifdef __rtems__ as usual.
> This would be preferred I think, in rtems.git at least.
Hopefully you can just follow the rules that we use for libbsd.
> > What exactly I need to import is:
> > https://github.com/freebsd/freebsd-src/tree/main/stand/efi/include
> > https://github.com/freebsd/freebsd-src/tree/main/stand/efi/libefi
> > In 'include' I'd like to omit risc/arm/arm64 platform specific
> > subdirectories for now.
> > Anyway, plan is to put both those directories into
> > bsps/shared/freebsd/stand/efi to mimic perfectly location in FBSD tree
> > and to have them ready to be reusable later for arm64 and risc-v BSPs
> > consumption.
> I think it makes sense. The only issue to me is that usually the
> bootloader stuff is in start/ directory. You might put any
> rtems-flavored interfaces to use the efi services into shared/start
> perhaps.
Agreed on location. Keeping the FreeBSD source as intact as possible even
if it's a subset is critical. Leave architecture specific code under the
top shared/.../efi since that's what they did. Maintain source transparency
back to the original code.
When in doubt, ask yourself: when I revisit this in 5 years to try to
update it, will I know what happened? And answer that question with
whatever makes life easier for future Karel. :)
--joel
> > Thanks!
> > Karel
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230414/fe7d432a/attachment.htm>
