[PATCH 3/3] bsps/amd64: increase CPU alignment to 16
Karel Gardas
karel at functional.vision
Sun Apr 16 21:24:03 UTC 2023
AMD64 requires SSE support which operates on 128bit data values.
cpukit/score/cpu/x86_64/include/rtems/score/cpu.h | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
index 2671c607a7..b26fb4c8ad 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
@@ -144,7 +144,7 @@ typedef struct {
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
#define CPU_STACK_MINIMUM_SIZE (1024*4)
#define CPU_SIZEOF_POINTER 8
-#define CPU_ALIGNMENT 8
+#define CPU_ALIGNMENT 16
#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT 16
#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
2.25.1
