[PATCH 1/3] bsps/shared: import FreeBSD libefi library
Karel Gardas
karel at functional.vision
Fri Apr 21 21:16:09 UTC 2023
The library is imported in minimalist version just to support future
amd64efi BSP.
The FreeBSD tree commit id with imported libefi version is:
ce7b20e5129cf0f269951b313d336a9c7d54d790
bsps/shared/freebsd/stand/efi/include/README | 36 +
.../freebsd/stand/efi/include/amd64/efibind.h | 275 ++++
bsps/shared/freebsd/stand/efi/include/efi.h | 87 ++
.../shared/freebsd/stand/efi/include/efiapi.h | 1204 +++++++++++++++++
.../shared/freebsd/stand/efi/include/eficon.h | 527 ++++++++
.../freebsd/stand/efi/include/eficonsctl.h | 134 ++
.../shared/freebsd/stand/efi/include/efidef.h | 224 +++
.../freebsd/stand/efi/include/efidevp.h | 511 +++++++
.../shared/freebsd/stand/efi/include/efierr.h | 68 +
.../shared/freebsd/stand/efi/include/efigop.h | 121 ++
.../shared/freebsd/stand/efi/include/efilib.h | 172 +++
bsps/shared/freebsd/stand/efi/libefi/libefi.c | 63 +
bsps/shared/freebsd/stand/efi/libefi/wchar.c | 73 +
13 files changed, 3495 insertions(+)
create mode 100644 bsps/shared/freebsd/stand/efi/include/README
create mode 100644 bsps/shared/freebsd/stand/efi/include/amd64/efibind.h
create mode 100644 bsps/shared/freebsd/stand/efi/include/efi.h
create mode 100644 bsps/shared/freebsd/stand/efi/include/efiapi.h
create mode 100644 bsps/shared/freebsd/stand/efi/include/eficon.h
create mode 100644 bsps/shared/freebsd/stand/efi/include/eficonsctl.h
create mode 100644 bsps/shared/freebsd/stand/efi/include/efidef.h
create mode 100644 bsps/shared/freebsd/stand/efi/include/efidevp.h
create mode 100644 bsps/shared/freebsd/stand/efi/include/efierr.h
create mode 100644 bsps/shared/freebsd/stand/efi/include/efigop.h
create mode 100644 bsps/shared/freebsd/stand/efi/include/efilib.h
create mode 100644 bsps/shared/freebsd/stand/efi/libefi/libefi.c
create mode 100644 bsps/shared/freebsd/stand/efi/libefi/wchar.c
diff --git a/bsps/shared/freebsd/stand/efi/include/README b/bsps/shared/freebsd/stand/efi/include/README
new file mode 100644
index 0000000000..bf821fae7e
--- /dev/null
+++ b/bsps/shared/freebsd/stand/efi/include/README
@@ -0,0 +1,36 @@
+/* $FreeBSD$ */
+Files in this directory and subdirectories are subject to the following
+copyright unless superceded or supplemented by additional specific license
+terms found in the file headers of individual files.
+Copyright (c) 1998-2000 Intel Corporation
+Redistribution and use in source and binary forms, with or without
+modification, are permitted provided that the following conditions
+are met:
+Redistributions of source code must retain the above copyright
+notice, this list of conditions and the following disclaimer.
+Redistributions in binary form must reproduce the above copyright
+notice, this list of conditions and the following disclaimer in
+the documentation and/or other materials provided with the
+distribution.
+THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
+WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+DISCLAIMED. IN NO EVENT SHALL INTEL BE LIABLE FOR ANY DIRECT,
+INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
+(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
+SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
+STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
+OF THE POSSIBILITY OF SUCH DAMAGE. THE EFI SPECIFICATION AND ALL
+OTHER INFORMATION ON THIS WEB SITE ARE PROVIDED "AS IS" WITH NO
+WARRANTIES, AND ARE SUBJECT TO CHANGE WITHOUT NOTICE.
diff --git a/bsps/shared/freebsd/stand/efi/include/amd64/efibind.h b/bsps/shared/freebsd/stand/efi/include/amd64/efibind.h
index 0000000000..97b4a04865
--- /dev/null
+++ b/bsps/shared/freebsd/stand/efi/include/amd64/efibind.h
@@ -0,0 +1,275 @@
+/* $FreeBSD$ */
+Copyright (c) 1999 - 2003 Intel Corporation. All rights reserved
+This software and associated documentation (if any) is furnished
+under a license and may only be used or copied in accordance
+with the terms of the license. Except as permitted by such
+license, no part of this software or documentation may be
+reproduced, stored in a retrieval system, or transmitted in any
+form or by any means without the express written consent of
+Intel Corporation.
+Module Name:
+ efefind.h
+Abstract:
+ EFI to compile bindings
+Revision History
+#pragma pack()
+#ifdef __FreeBSD__
+#include <sys/stdint.h>
+#elif __rtems__
+#include <stdint.h>
+#else
+// Basic int types of various widths
+#if (__STDC_VERSION__ < 199901L )
+ // No ANSI C 1999/2000 stdint.h integer width declarations
+ #ifdef _MSC_EXTENSIONS
+ // Use Microsoft C compiler integer width declarations
+ typedef unsigned __int64 uint64_t;
+ typedef __int64 int64_t;
+ typedef unsigned __int32 uint32_t;
+ typedef __int32 int32_t;
+ typedef unsigned short uint16_t;
+ typedef short int16_t;
+ typedef unsigned char uint8_t;
+ typedef char int8_t;
+ #else
+ #ifdef UNIX_LP64
+ // Use LP64 programming model from C_FLAGS for integer width declarations
+ typedef unsigned long uint64_t;
+ typedef long int64_t;
+ typedef unsigned int uint32_t;
+ typedef int int32_t;
+ #else
+ // Assume P64 programming model from C_FLAGS for integer width declarations
+ typedef unsigned long long uint64_t;
+ typedef long long int64_t;
+ #endif
+ #endif
+#endif
+#endif /* __FreeBSD__ */
+// Basic EFI types of various widths
+#ifndef ACPI_THREAD_ID /* ACPI's definitions are fine */
+#define ACPI_USE_SYSTEM_INTTYPES 1 /* Tell ACPI we've defined types */
+typedef uint64_t UINT64;
+typedef int64_t INT64;
+#ifndef _BASETSD_H_
+ typedef uint32_t UINT32;
+ typedef int32_t INT32;
+#endif
+typedef uint16_t UINT16;
+typedef int16_t INT16;
+typedef uint8_t UINT8;
+typedef int8_t INT8;
+#endif
+#undef VOID
+#define VOID void
+typedef int64_t INTN;
+typedef uint64_t UINTN;
+#ifdef EFI_NT_EMULATOR
+ #define POST_CODE(_Data)
+#else
+ #ifdef EFI_DEBUG
+#define POST_CODE(_Data) __asm mov eax,(_Data) __asm out 0x80,al
+ #else
+ #endif
+#endif
+#define EFIERR(a) (0x8000000000000000 | a)
+#define EFI_ERROR_MASK 0x8000000000000000
+#define EFIERR_OEM(a) (0xc000000000000000 | a)
+#define BAD_POINTER 0xFBFBFBFBFBFBFBFB
+#define MAX_ADDRESS 0xFFFFFFFFFFFFFFFF
+#define BREAKPOINT() __asm { int 3 }
+// Pointers must be aligned to these address to function
+#define MIN_ALIGNMENT_SIZE 4
+#define ALIGN_VARIABLE(Value ,Adjustment) \
+ (UINTN)Adjustment = 0; \
+ if((UINTN)Value % MIN_ALIGNMENT_SIZE) \
+ (UINTN)Adjustment = MIN_ALIGNMENT_SIZE - ((UINTN)Value % MIN_ALIGNMENT_SIZE); \
+ Value = (UINTN)Value + (UINTN)Adjustment
+// Define macros to build data structure signatures from characters.
+#define EFI_SIGNATURE_16(A,B) ((A) | (B<<8))
+#define EFI_SIGNATURE_32(A,B,C,D) (EFI_SIGNATURE_16(A,B) | (EFI_SIGNATURE_16(C,D) << 16))
+#define EFI_SIGNATURE_64(A,B,C,D,E,F,G,H) (EFI_SIGNATURE_32(A,B,C,D) | ((UINT64)(EFI_SIGNATURE_32(E,F,G,H)) << 32))
+// EFIAPI - prototype calling convention for EFI function pointers
+// BOOTSERVICE - prototype for implementation of a boot service interface
+// RUNTIMESERVICE - prototype for implementation of a runtime service interface
+// RUNTIMEFUNCTION - prototype for implementation of a runtime function that is not a service
+// RUNTIME_CODE - pragma macro for declaring runtime code
+#ifdef __amd64__
+#define EFIAPI __attribute__((ms_abi))
+#endif
+#ifndef EFIAPI // Forces EFI calling conventions reguardless of compiler options
+ #define EFIAPI __cdecl // Force C calling convention for Microsoft C compiler
+ #else
+ #define EFIAPI // Substitute expresion to force C calling convention
+ #endif
+#endif
+#define BOOTSERVICE
+//#define RUNTIMESERVICE(proto,a) alloc_text("rtcode",a); proto a
+//#define RUNTIMEFUNCTION(proto,a) alloc_text("rtcode",a); proto a
+#define RUNTIMESERVICE
+#define RUNTIMEFUNCTION
+#define RUNTIME_CODE(a) alloc_text("rtcode", a)
+#define BEGIN_RUNTIME_DATA() data_seg("rtdata")
+#define END_RUNTIME_DATA() data_seg("")
+#define VOLATILE volatile
+#define MEMORY_FENCE()
+#ifdef EFI_NO_INTERFACE_DECL
+ #define EFI_FORWARD_DECLARATION(x)
+ #define EFI_INTERFACE_DECL(x)
+#else
+ #define EFI_FORWARD_DECLARATION(x) typedef struct _##x x
+ #define EFI_INTERFACE_DECL(x) typedef struct x
+#endif
+// To help ensure proper coding of integrated drivers, they are
+// compiled as DLLs. In NT they require a dll init entry pointer.
+// The macro puts a stub entry point into the DLL so it will load.
+#define EFI_DRIVER_ENTRY_POINT(InitFunction) \
+ EFI_STATUS \
+ InitFunction ( \
+ EFI_HANDLE ImageHandle, \
+ EFI_SYSTEM_TABLE *SystemTable \
+ UINTN \
+ __stdcall \
+ _DllMainCRTStartup ( \
+ UINTN Inst, \
+ UINTN reason_for_call, \
+ VOID *rserved \
+ return 1; \
+ int \
+ __declspec( dllexport ) \
+ __cdecl \
+ InitializeDriver ( \
+ void *ImageHandle, \
+ void *SystemTable \
+ return InitFunction(ImageHandle, SystemTable); \
+ #define LOAD_INTERNAL_DRIVER(_if, type, name, entry) \
+ (_if)->LoadInternal(type, name, NULL)
+#else // EFI_NT_EMULATOR
+// When building similar to FW, link everything together as
+// one big module.
+ #define EFI_DRIVER_ENTRY_POINT(InitFunction)
+ (_if)->LoadInternal(type, name, entry)
+#endif // EFI_FW_NT
+#ifdef __FreeBSD__
+#define INTERFACE_DECL(x) struct x
+#elif __rtems__
+#else
+// Some compilers don't support the forward reference construct:
+// typedef struct XXXXX
+// The following macro provide a workaround for such cases.
+#ifdef NO_INTERFACE_DECL
+#else
+#define INTERFACE_DECL(x) typedef struct x
+#endif
+#ifdef _MSC_EXTENSIONS
+#pragma warning ( disable : 4731 ) // Suppress warnings about modification of EBP
+#endif
diff --git a/bsps/shared/freebsd/stand/efi/include/efi.h b/bsps/shared/freebsd/stand/efi/include/efi.h
index 0000000000..5b4743d44b
--- /dev/null
+++ b/bsps/shared/freebsd/stand/efi/include/efi.h
@@ -0,0 +1,87 @@
+/* $FreeBSD$ */
+Copyright (c) 1999 - 2002 Intel Corporation. All rights reserved
+Intel Corporation.
+Module Name:
+ efi.h
+Abstract:
+ Public EFI header files
+Revision History
+// Build flags on input
+// EFI32
+// EFI_DEBUG - Enable debugging code
+// EFI_NT_EMULATOR - Building for running under NT
+#ifndef _EFI_INCLUDE_
+#define _EFI_INCLUDE_
+#define EFI_FIRMWARE_VENDOR L"INTEL"
+#define EFI_FIRMWARE_MAJOR_REVISION 14
+#define EFI_FIRMWARE_MINOR_REVISION 62
+#define EFI_FIRMWARE_REVISION ((EFI_FIRMWARE_MAJOR_REVISION <<16) | (EFI_FIRMWARE_MINOR_REVISION))
+#include "efibind.h"
+#include "efidef.h"
+#include "efidevp.h"
+#ifndef __rtems__
+#include "efipciio.h"
+#include "efiprot.h"
+#endif /* __rtems__ */
+#include "eficon.h"
+#include "eficonsctl.h"
+#ifndef __rtems__
+#include "efiser.h"
+#include "efi_nii.h"
+#include "efipxebc.h"
+#include "efinet.h"
+#include "efiapi.h"
+#ifndef __rtems__
+#include "efifs.h"
+#include "efierr.h"
+#include "efigop.h"
+#ifndef __rtems__
+#include "efiip.h"
+#include "efiudp.h"
+#include "efitcp.h"
+#include "efipoint.h"
+#include "efiuga.h"
+#include <sys/types.h>
+#ifdef __rtems__
+#include <stdbool.h>
+#endif
+ * Global variables
+extern EFI_LOADED_IMAGE *boot_img;
+extern bool boot_services_active;
+ * FreeBSD UUID
+#define FREEBSD_BOOT_VAR_GUID \
+ { 0xCFEE69AD, 0xA0DE, 0x47A9, {0x93, 0xA8, 0xF6, 0x31, 0x06, 0xF8, 0xAE, 0x99} }
+#endif
diff --git a/bsps/shared/freebsd/stand/efi/include/efiapi.h b/bsps/shared/freebsd/stand/efi/include/efiapi.h
index 0000000000..fb5c861b38
--- /dev/null
+++ b/bsps/shared/freebsd/stand/efi/include/efiapi.h
@@ -0,0 +1,1204 @@
+/* $FreeBSD$ */
+#ifndef _EFI_API_H
+#define _EFI_API_H
+Intel Corporation.
+Module Name:
+ efiapi.h
+Abstract:
+ Global EFI runtime & boot service interfaces
+Revision History
+// EFI Specification Revision
+#define EFI_SPECIFICATION_MAJOR_REVISION 1
+#define EFI_SPECIFICATION_MINOR_REVISION 10
+// Declare forward referenced data structures
+INTERFACE_DECL(_EFI_SYSTEM_TABLE);
+// EFI Memory
+typedef
+EFI_STATUS
+(EFIAPI *EFI_ALLOCATE_PAGES) (
+ IN EFI_ALLOCATE_TYPE Type,
+ IN EFI_MEMORY_TYPE MemoryType,
+ IN UINTN NoPages,
+ OUT EFI_PHYSICAL_ADDRESS *Memory
+typedef
+EFI_STATUS
+(EFIAPI *EFI_FREE_PAGES) (
+ IN EFI_PHYSICAL_ADDRESS Memory,
+ IN UINTN NoPages
+typedef
+EFI_STATUS
+(EFIAPI *EFI_GET_MEMORY_MAP) (
+ IN OUT UINTN *MemoryMapSize,
+ IN OUT EFI_MEMORY_DESCRIPTOR *MemoryMap,
+ OUT UINTN *MapKey,
+ OUT UINTN *DescriptorSize,
+ OUT UINT32 *DescriptorVersion
+#define NextMemoryDescriptor(Ptr,Size) ((EFI_MEMORY_DESCRIPTOR *) (((UINT8 *) Ptr) + Size))
+typedef
+EFI_STATUS
+(EFIAPI *EFI_ALLOCATE_POOL) (
+ IN EFI_MEMORY_TYPE PoolType,
+ IN UINTN Size,
+ OUT VOID **Buffer
+typedef
+EFI_STATUS
+(EFIAPI *EFI_FREE_POOL) (
+ IN VOID *Buffer
+typedef
+EFI_STATUS
+(EFIAPI *EFI_SET_VIRTUAL_ADDRESS_MAP) (
+ IN UINTN MemoryMapSize,
+ IN UINTN DescriptorSize,
+ IN UINT32 DescriptorVersion,
+ IN EFI_MEMORY_DESCRIPTOR *VirtualMap
+#define EFI_OPTIONAL_PTR 0x00000001
+#define EFI_INTERNAL_FNC 0x00000002 // Pointer to internal runtime fnc
+#define EFI_INTERNAL_PTR 0x00000004 // Pointer to internal runtime data
+typedef
+EFI_STATUS
+(EFIAPI *EFI_CONVERT_POINTER) (
+ IN UINTN DebugDisposition,
+ IN OUT VOID **Address
+// EFI Events
+#define EVT_TIMER 0x80000000
+#define EVT_RUNTIME 0x40000000
+#define EVT_RUNTIME_CONTEXT 0x20000000
+#define EVT_NOTIFY_WAIT 0x00000100
+#define EVT_NOTIFY_SIGNAL 0x00000200
+#define EVT_SIGNAL_EXIT_BOOT_SERVICES 0x00000201
+#define EVT_SIGNAL_VIRTUAL_ADDRESS_CHANGE 0x60000202
+#define EVT_EFI_SIGNAL_MASK 0x000000FF
+#define EVT_EFI_SIGNAL_MAX 2
+typedef
+VOID
+(EFIAPI *EFI_EVENT_NOTIFY) (
+ IN EFI_EVENT Event,
+ IN VOID *Context
+typedef
+EFI_STATUS
+(EFIAPI *EFI_CREATE_EVENT) (
+ IN UINT32 Type,
+ IN EFI_TPL NotifyTpl,
+ IN EFI_EVENT_NOTIFY NotifyFunction,
+ IN VOID *NotifyContext,
+ OUT EFI_EVENT *Event
+typedef enum {
+ TimerCancel,
+ TimerPeriodic,
+ TimerRelative,
+ TimerTypeMax
+} EFI_TIMER_DELAY;
+typedef
+EFI_STATUS
+(EFIAPI *EFI_SET_TIMER) (
+ IN EFI_TIMER_DELAY Type,
+ IN UINT64 TriggerTime
+typedef
+EFI_STATUS
+(EFIAPI *EFI_SIGNAL_EVENT) (
+typedef
+EFI_STATUS
+(EFIAPI *EFI_WAIT_FOR_EVENT) (
+ IN UINTN NumberOfEvents,
+ IN EFI_EVENT *Event,
+ OUT UINTN *Index
+typedef
+EFI_STATUS
+(EFIAPI *EFI_CLOSE_EVENT) (
+typedef
+EFI_STATUS
+(EFIAPI *EFI_CHECK_EVENT) (
+// Task priority level
+#define TPL_APPLICATION 4
+#define TPL_CALLBACK 8
+#define TPL_NOTIFY 16
+#define TPL_HIGH_LEVEL 31
+typedef
+EFI_TPL
+(EFIAPI *EFI_RAISE_TPL) (
+ IN EFI_TPL NewTpl
+typedef
+VOID
+(EFIAPI *EFI_RESTORE_TPL) (
+ IN EFI_TPL OldTpl
+// EFI platform varibles
+#define EFI_GLOBAL_VARIABLE \
+ { 0x8BE4DF61, 0x93CA, 0x11d2, {0xAA, 0x0D, 0x00, 0xE0, 0x98, 0x03, 0x2B, 0x8C} }
+// Variable attributes
+#define EFI_VARIABLE_NON_VOLATILE 0x00000001
+#define EFI_VARIABLE_BOOTSERVICE_ACCESS 0x00000002
+#define EFI_VARIABLE_RUNTIME_ACCESS 0x00000004
+#define EFI_VARIABLE_HARDWARE_ERROR_RECORD 0x00000008
+#define EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS 0x00000010
+#define EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS 0x00000020
+#define EFI_VARIABLE_APPEND_WRITE 0x00000040
+// Variable size limitation
+#define EFI_MAXIMUM_VARIABLE_SIZE 1024
+typedef
+EFI_STATUS
+(EFIAPI *EFI_GET_VARIABLE) (
+ IN CHAR16 *VariableName,
+ IN EFI_GUID *VendorGuid,
+ OUT UINT32 *Attributes OPTIONAL,
+ IN OUT UINTN *DataSize,
+ OUT VOID *Data
+typedef
+EFI_STATUS
+(EFIAPI *EFI_GET_NEXT_VARIABLE_NAME) (
+ IN OUT UINTN *VariableNameSize,
+ IN OUT CHAR16 *VariableName,
+ IN OUT EFI_GUID *VendorGuid
+typedef
+EFI_STATUS
+(EFIAPI *EFI_SET_VARIABLE) (
+ IN const CHAR16 *VariableName,
+ IN UINT32 Attributes,
+ IN UINTN DataSize,
+ IN VOID *Data
+// EFI Time
+typedef struct {
+ UINT32 Resolution; // 1e-6 parts per million
+ UINT32 Accuracy; // hertz
+ BOOLEAN SetsToZero; // Set clears sub-second time
+} EFI_TIME_CAPABILITIES;
+typedef
+EFI_STATUS
+(EFIAPI *EFI_GET_TIME) (
+ OUT EFI_TIME *Time,
+ OUT EFI_TIME_CAPABILITIES *Capabilities OPTIONAL
+typedef
+EFI_STATUS
+(EFIAPI *EFI_SET_TIME) (
+ IN EFI_TIME *Time
+typedef
+EFI_STATUS
+(EFIAPI *EFI_GET_WAKEUP_TIME) (
+ OUT BOOLEAN *Enabled,
+ OUT BOOLEAN *Pending,
+typedef
+EFI_STATUS
+(EFIAPI *EFI_SET_WAKEUP_TIME) (
+ IN BOOLEAN Enable,
+ IN EFI_TIME *Time OPTIONAL
+// Image functions
+// PE32+ Subsystem type for EFI images
+#if !defined(IMAGE_SUBSYSTEM_EFI_APPLICATION)
+#define IMAGE_SUBSYSTEM_EFI_APPLICATION 10
+#define IMAGE_SUBSYSTEM_EFI_BOOT_SERVICE_DRIVER 11
+#define IMAGE_SUBSYSTEM_EFI_RUNTIME_DRIVER 12
+#endif
+// PE32+ Machine type for EFI images
+#if !defined(EFI_IMAGE_MACHINE_IA32)
+#define EFI_IMAGE_MACHINE_IA32 0x014c
+#endif
+#if !defined(EFI_IMAGE_MACHINE_EBC)
+#define EFI_IMAGE_MACHINE_EBC 0x0EBC
+#endif
+// Image Entry prototype
+typedef
+EFI_STATUS
+(EFIAPI *EFI_IMAGE_ENTRY_POINT) (
+ IN EFI_HANDLE ImageHandle,
+ IN struct _EFI_SYSTEM_TABLE *SystemTable
+typedef
+EFI_STATUS
+(EFIAPI *EFI_IMAGE_LOAD) (
+ IN BOOLEAN BootPolicy,
+ IN EFI_HANDLE ParentImageHandle,
+ IN EFI_DEVICE_PATH *FilePath,
+ IN VOID *SourceBuffer OPTIONAL,
+ IN UINTN SourceSize,
+ OUT EFI_HANDLE *ImageHandle
+typedef
+EFI_STATUS
+(EFIAPI *EFI_IMAGE_START) (
+ OUT UINTN *ExitDataSize,
+ OUT CHAR16 **ExitData OPTIONAL
+typedef
+EFI_STATUS
+(EFIAPI *EFI_EXIT) (
+ IN EFI_STATUS ExitStatus,
+ IN UINTN ExitDataSize,
+ IN CHAR16 *ExitData OPTIONAL
+#ifndef __rtems__
+ __dead2
+#endif
+typedef
+EFI_STATUS
+(EFIAPI *EFI_IMAGE_UNLOAD) (
+// Image handle
+#define LOADED_IMAGE_PROTOCOL \
+ { 0x5B1B31A1, 0x9562, 0x11d2, {0x8E, 0x3F, 0x00, 0xA0, 0xC9, 0x69, 0x72, 0x3B} }
+#define EFI_LOADED_IMAGE_INFORMATION_REVISION 0x1000
+typedef struct {
+ UINT32 Revision;
+ EFI_HANDLE ParentHandle;
+ struct _EFI_SYSTEM_TABLE *SystemTable;
+ // Source location of image
+ EFI_HANDLE DeviceHandle;
+ EFI_DEVICE_PATH *FilePath;
+ VOID *Reserved;
+ // Images load options
+ UINT32 LoadOptionsSize;
+ VOID *LoadOptions;
+ // Location of where image was loaded
+ VOID *ImageBase;
+ UINT64 ImageSize;
+ EFI_MEMORY_TYPE ImageCodeType;
+ EFI_MEMORY_TYPE ImageDataType;
+ // If the driver image supports a dynamic unload request
+ EFI_IMAGE_UNLOAD Unload;
+} EFI_LOADED_IMAGE;
+typedef
+EFI_STATUS
+(EFIAPI *EFI_EXIT_BOOT_SERVICES) (
+ IN UINTN MapKey
+// Misc
+typedef
+EFI_STATUS
+(EFIAPI *EFI_STALL) (
+ IN UINTN Microseconds
+typedef
+EFI_STATUS
+(EFIAPI *EFI_SET_WATCHDOG_TIMER) (
+ IN UINTN Timeout,
+ IN UINT64 WatchdogCode,
+ IN CHAR16 *WatchdogData OPTIONAL
+typedef enum {
+ EfiResetCold,
+ EfiResetWarm,
+ EfiResetShutdown
+} EFI_RESET_TYPE;
+typedef
+VOID
+(EFIAPI *EFI_RESET_SYSTEM) (
+ IN EFI_RESET_TYPE ResetType,
+ IN EFI_STATUS ResetStatus,
+ IN CHAR16 *ResetData OPTIONAL
+#ifndef __rtems__
+ __dead2
+#endif
+typedef
+EFI_STATUS
+(EFIAPI *EFI_GET_NEXT_MONOTONIC_COUNT) (
+ OUT UINT64 *Count
+typedef
+EFI_STATUS
+(EFIAPI *EFI_GET_NEXT_HIGH_MONO_COUNT) (
+ OUT UINT32 *HighCount
+// Protocol handler functions
+typedef enum {
+ EFI_NATIVE_INTERFACE
+} EFI_INTERFACE_TYPE;
+typedef
+EFI_STATUS
+(EFIAPI *EFI_INSTALL_PROTOCOL_INTERFACE) (
+ IN OUT EFI_HANDLE *Handle,
+ IN EFI_GUID *Protocol,
+ IN EFI_INTERFACE_TYPE InterfaceType,
+ IN VOID *Interface
+typedef
+EFI_STATUS
+(EFIAPI *EFI_REINSTALL_PROTOCOL_INTERFACE) (
+ IN EFI_HANDLE Handle,
+ IN VOID *OldInterface,
+ IN VOID *NewInterface
+typedef
+EFI_STATUS
+(EFIAPI *EFI_UNINSTALL_PROTOCOL_INTERFACE) (
+typedef
+EFI_STATUS
+(EFIAPI *EFI_HANDLE_PROTOCOL) (
+ OUT VOID **Interface
+typedef
+EFI_STATUS
+(EFIAPI *EFI_REGISTER_PROTOCOL_NOTIFY) (
+ OUT VOID **Registration
+typedef enum {
+ AllHandles,
+ ByRegisterNotify,
+ ByProtocol
+} EFI_LOCATE_SEARCH_TYPE;
+typedef
+EFI_STATUS
+(EFIAPI *EFI_LOCATE_HANDLE) (
+ IN EFI_LOCATE_SEARCH_TYPE SearchType,
+ IN EFI_GUID *Protocol OPTIONAL,
+ IN VOID *SearchKey OPTIONAL,
+ IN OUT UINTN *BufferSize,
+ OUT EFI_HANDLE *Buffer
+typedef
+EFI_STATUS
+(EFIAPI *EFI_LOCATE_DEVICE_PATH) (
+ IN OUT EFI_DEVICE_PATH **DevicePath,
+ OUT EFI_HANDLE *Device
+typedef
+EFI_STATUS
+(EFIAPI *EFI_INSTALL_CONFIGURATION_TABLE) (
+ IN EFI_GUID *Guid,
+ IN VOID *Table
+typedef
+EFI_STATUS
+(EFIAPI *EFI_RESERVED_SERVICE) (
+ VOID
+typedef
+EFI_STATUS
+(EFIAPI *EFI_CONNECT_CONTROLLER) (
+ IN EFI_HANDLE ControllerHandle,
+ IN EFI_HANDLE *DriverImageHandle OPTIONAL,
+ IN EFI_DEVICE_PATH *RemainingDevicePath OPTIONAL,
+ IN BOOLEAN Recursive
+typedef
+EFI_STATUS
+(EFIAPI *EFI_DISCONNECT_CONTROLLER)(
+ IN EFI_HANDLE DriverImageHandle, OPTIONAL
+ IN EFI_HANDLE ChildHandle OPTIONAL
+#define EFI_OPEN_PROTOCOL_BY_HANDLE_PROTOCOL 0x00000001
+#define EFI_OPEN_PROTOCOL_GET_PROTOCOL 0x00000002
+#define EFI_OPEN_PROTOCOL_TEST_PROTOCOL 0x00000004
+#define EFI_OPEN_PROTOCOL_BY_CHILD_CONTROLLER 0x00000008
+#define EFI_OPEN_PROTOCOL_BY_DRIVER 0x00000010
+#define EFI_OPEN_PROTOCOL_EXCLUSIVE 0x00000020
+typedef
+EFI_STATUS
+(EFIAPI *EFI_OPEN_PROTOCOL) (
+ OUT VOID **Interface,
+ IN EFI_HANDLE ControllerHandle, OPTIONAL
+typedef
+EFI_STATUS
+(EFIAPI *EFI_CLOSE_PROTOCOL) (
+ IN EFI_HANDLE DeviceHandle
+typedef struct {
+ EFI_HANDLE AgentHandle;
+ EFI_HANDLE ControllerHandle;
+ UINT32 Attributes;
+ UINT32 OpenCount;
+} EFI_OPEN_PROTOCOL_INFORMATION_ENTRY;
+typedef
+EFI_STATUS
+(EFIAPI *EFI_OPEN_PROTOCOL_INFORMATION) (
+ IN EFI_HANDLE UserHandle,
+ IN EFI_OPEN_PROTOCOL_INFORMATION_ENTRY **EntryBuffer,
+ OUT UINTN *EntryCount
+typedef
+EFI_STATUS
+(EFIAPI *EFI_PROTOCOLS_PER_HANDLE) (
+ OUT EFI_GUID ***ProtocolBuffer,
+ OUT UINTN *ProtocolBufferCount
+typedef
+EFI_STATUS
+(EFIAPI *EFI_LOCATE_HANDLE_BUFFER) (
+ IN OUT UINTN *NumberHandles,
+ OUT EFI_HANDLE **Buffer
+typedef
+EFI_STATUS
+(EFIAPI *EFI_LOCATE_PROTOCOL) (
+ EFI_GUID *Protocol,
+ VOID *Registration, OPTIONAL
+ VOID **Interface
+typedef
+EFI_STATUS
+(EFIAPI *EFI_INSTALL_MULTIPLE_PROTOCOL_INTERFACES) (
+typedef
+EFI_STATUS
+(EFIAPI *EFI_UNINSTALL_MULTIPLE_PROTOCOL_INTERFACES) (
+typedef
+EFI_STATUS
+(EFIAPI *EFI_CALCULATE_CRC32) (
+ IN VOID *Data,
+ OUT UINT32 *Crc32
+typedef
+VOID
+(EFIAPI *EFI_COPY_MEM) (
+ IN VOID *Destination,
+ IN VOID *Source,
+ IN UINTN Length
+typedef
+VOID
+(EFIAPI *EFI_SET_MEM) (
+ IN VOID *Buffer,
+ IN UINTN Size,
+ IN UINT8 Value
+// Standard EFI table header
+typedef struct _EFI_TABLE_HEARDER {
+ UINT64 Signature;
+ UINT32 Revision;
+ UINT32 HeaderSize;
+ UINT32 CRC32;
+ UINT32 Reserved;
+} EFI_TABLE_HEADER;
+// EFI Runtime Serivces Table
+#define EFI_RUNTIME_SERVICES_SIGNATURE 0x56524553544e5552
+#define EFI_RUNTIME_SERVICES_REVISION ((EFI_SPECIFICATION_MAJOR_REVISION<<16) | (EFI_SPECIFICATION_MINOR_REVISION))
+typedef struct {
+ EFI_TABLE_HEADER Hdr;
+ // Time services
+ EFI_GET_TIME GetTime;
+ EFI_SET_TIME SetTime;
+ EFI_GET_WAKEUP_TIME GetWakeupTime;
+ EFI_SET_WAKEUP_TIME SetWakeupTime;
+ // Virtual memory services
+ EFI_SET_VIRTUAL_ADDRESS_MAP SetVirtualAddressMap;
+ EFI_CONVERT_POINTER ConvertPointer;
+ // Variable serviers
+ EFI_GET_VARIABLE GetVariable;
+ EFI_GET_NEXT_VARIABLE_NAME GetNextVariableName;
+ EFI_SET_VARIABLE SetVariable;
+ // Misc
+ EFI_GET_NEXT_HIGH_MONO_COUNT GetNextHighMonotonicCount;
+ EFI_RESET_SYSTEM ResetSystem;
+} EFI_RUNTIME_SERVICES;
+// EFI Boot Services Table
+#define EFI_BOOT_SERVICES_SIGNATURE 0x56524553544f4f42
+#define EFI_BOOT_SERVICES_REVISION ((EFI_SPECIFICATION_MAJOR_REVISION<<16) | (EFI_SPECIFICATION_MINOR_REVISION))
+typedef struct {
+ // Task priority functions
+ EFI_RAISE_TPL RaiseTPL;
+ EFI_RESTORE_TPL RestoreTPL;
+ // Memory functions
+ EFI_ALLOCATE_PAGES AllocatePages;
+ EFI_FREE_PAGES FreePages;
+ EFI_GET_MEMORY_MAP GetMemoryMap;
+ EFI_ALLOCATE_POOL AllocatePool;
+ EFI_FREE_POOL FreePool;
+ // Event & timer functions
+ EFI_CREATE_EVENT CreateEvent;
+ EFI_SET_TIMER SetTimer;
+ EFI_WAIT_FOR_EVENT WaitForEvent;
+ EFI_SIGNAL_EVENT SignalEvent;
+ EFI_CLOSE_EVENT CloseEvent;
+ EFI_CHECK_EVENT CheckEvent;
+ // Protocol handler functions
+ EFI_INSTALL_PROTOCOL_INTERFACE InstallProtocolInterface;
+ EFI_REINSTALL_PROTOCOL_INTERFACE ReinstallProtocolInterface;
+ EFI_UNINSTALL_PROTOCOL_INTERFACE UninstallProtocolInterface;
+ EFI_HANDLE_PROTOCOL HandleProtocol;
+ VOID *Reserved;
+ EFI_REGISTER_PROTOCOL_NOTIFY RegisterProtocolNotify;
+ EFI_LOCATE_HANDLE LocateHandle;
+ EFI_LOCATE_DEVICE_PATH LocateDevicePath;
+ EFI_INSTALL_CONFIGURATION_TABLE InstallConfigurationTable;
+ // Image functions
+ EFI_IMAGE_LOAD LoadImage;
+ EFI_IMAGE_START StartImage;
+ EFI_EXIT Exit;
+ EFI_IMAGE_UNLOAD UnloadImage;
+ EFI_EXIT_BOOT_SERVICES ExitBootServices;
+ // Misc functions
+ EFI_GET_NEXT_MONOTONIC_COUNT GetNextMonotonicCount;
+ EFI_STALL Stall;
+ EFI_SET_WATCHDOG_TIMER SetWatchdogTimer;
+ // DriverSupport Services
+ EFI_CONNECT_CONTROLLER ConnectController;
+ EFI_DISCONNECT_CONTROLLER DisconnectController;
+ // Open and Close Protocol Services
+ EFI_OPEN_PROTOCOL OpenProtocol;
+ EFI_CLOSE_PROTOCOL CloseProtocol;
+ EFI_OPEN_PROTOCOL_INFORMATION OpenProtocolInformation;
+ // Library Services to reduce size of drivers
+ EFI_PROTOCOLS_PER_HANDLE ProtocolsPerHandle;
+ EFI_LOCATE_HANDLE_BUFFER LocateHandleBuffer;
+ EFI_LOCATE_PROTOCOL LocateProtocol;
+ EFI_INSTALL_MULTIPLE_PROTOCOL_INTERFACES InstallMultipleProtocolInterfaces;
+ EFI_UNINSTALL_MULTIPLE_PROTOCOL_INTERFACES UninstallMultipleProtocolInterfaces;
+ // CRC32 services
+ EFI_CALCULATE_CRC32 CalculateCrc32;
+ // Memory Utility Services
+ EFI_COPY_MEM CopyMem;
+ EFI_SET_MEM SetMem;
+} EFI_BOOT_SERVICES;
+// EFI Configuration Table and GUID definitions
+#define MPS_TABLE_GUID \
+ { 0xeb9d2d2f, 0x2d88, 0x11d3, {0x9a, 0x16, 0x0, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define ACPI_TABLE_GUID \
+ { 0xeb9d2d30, 0x2d88, 0x11d3, {0x9a, 0x16, 0x0, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define ACPI_20_TABLE_GUID \
+ { 0x8868e871, 0xe4f1, 0x11d3, {0xbc, 0x22, 0x0, 0x80, 0xc7, 0x3c, 0x88, 0x81} }
+#define SMBIOS_TABLE_GUID \
+ { 0xeb9d2d31, 0x2d88, 0x11d3, {0x9a, 0x16, 0x0, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define SMBIOS3_TABLE_GUID \
+ { 0xf2fd1544, 0x9794, 0x4a2c, {0x99, 0x2e, 0xe5, 0xbb, 0xcf, 0x20, 0xe3, 0x94} }
+#define SAL_SYSTEM_TABLE_GUID \
+ { 0xeb9d2d32, 0x2d88, 0x11d3, {0x9a, 0x16, 0x0, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define FDT_TABLE_GUID \
+ { 0xb1b621d5, 0xf19c, 0x41a5, {0x83, 0x0b, 0xd9, 0x15, 0x2c, 0x69, 0xaa, 0xe0} }
+#define DXE_SERVICES_TABLE_GUID \
+ { 0x5ad34ba, 0x6f02, 0x4214, {0x95, 0x2e, 0x4d, 0xa0, 0x39, 0x8e, 0x2b, 0xb9} }
+#define HOB_LIST_TABLE_GUID \
+ { 0x7739f24c, 0x93d7, 0x11d4, {0x9a, 0x3a, 0x0, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define LZMA_DECOMPRESSION_GUID \
+ { 0xee4e5898, 0x3914, 0x4259, {0x9d, 0x6e, 0xdc, 0x7b, 0xd7, 0x94, 0x3, 0xcf} }
+#define ARM_MP_CORE_INFO_TABLE_GUID \
+ { 0xa4ee0728, 0xe5d7, 0x4ac5, {0xb2, 0x1e, 0x65, 0x8e, 0xd8, 0x57, 0xe8, 0x34} }
+#define ESRT_TABLE_GUID \
+ { 0xb122a263, 0x3661, 0x4f68, {0x99, 0x29, 0x78, 0xf8, 0xb0, 0xd6, 0x21, 0x80} }
+#define MEMORY_TYPE_INFORMATION_TABLE_GUID \
+ { 0x4c19049f, 0x4137, 0x4dd3, {0x9c, 0x10, 0x8b, 0x97, 0xa8, 0x3f, 0xfd, 0xfa} }
+#define DEBUG_IMAGE_INFO_TABLE_GUID \
+ { 0x49152e77, 0x1ada, 0x4764, {0xb7, 0xa2, 0x7a, 0xfe, 0xfe, 0xd9, 0x5e, 0x8b} }
+typedef struct _EFI_CONFIGURATION_TABLE {
+ EFI_GUID VendorGuid;
+ VOID *VendorTable;
+} EFI_CONFIGURATION_TABLE;
+// EFI System Table
+#define EFI_SYSTEM_TABLE_SIGNATURE 0x5453595320494249
+#define EFI_SYSTEM_TABLE_REVISION ((EFI_SPECIFICATION_MAJOR_REVISION<<16) | (EFI_SPECIFICATION_MINOR_REVISION))
+#define EFI_1_10_SYSTEM_TABLE_REVISION ((1<<16) | 10)
+#define EFI_1_02_SYSTEM_TABLE_REVISION ((1<<16) | 02)
+typedef struct _EFI_SYSTEM_TABLE {
+ CHAR16 *FirmwareVendor;
+ UINT32 FirmwareRevision;
+ EFI_HANDLE ConsoleInHandle;
+ SIMPLE_INPUT_INTERFACE *ConIn;
+ EFI_HANDLE ConsoleOutHandle;
+ SIMPLE_TEXT_OUTPUT_INTERFACE *ConOut;
+ EFI_HANDLE StandardErrorHandle;
+ SIMPLE_TEXT_OUTPUT_INTERFACE *StdErr;
+ EFI_RUNTIME_SERVICES *RuntimeServices;
+ EFI_BOOT_SERVICES *BootServices;
+ UINTN NumberOfTableEntries;
+ EFI_CONFIGURATION_TABLE *ConfigurationTable;
+} EFI_SYSTEM_TABLE;
+ * unlisted GUID's..
+#define EFI_EBC_INTERPRETER_PROTOCOL_GUID \
+{ 0x13AC6DD1, 0x73D0, 0x11D4, {0xB0, 0x6B, 0x00, 0xAA, 0x00, 0xBD, 0x6D, 0xE7} }
+#define EFI_DRIVER_CONFIGURATION2_PROTOCOL_GUID \
+{ 0xbfd7dc1d, 0x24f1, 0x40d9, {0x82, 0xe7, 0x2e, 0x09, 0xbb, 0x6b, 0x4e, 0xbe} }
+#define EFI_DRIVER_CONFIGURATION_PROTOCOL_GUID \
+{ 0x107a772b, 0xd5e1, 0x11d4, {0x9a, 0x46, 0x0, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define EFI_DRIVER_BINDING_PROTOCOL_GUID \
+ { 0x18A031AB, 0xB443, 0x4D1A, \
+ { 0xA5, 0xC0, 0x0C, 0x09, 0x26, 0x1E, 0x9F, 0x71 } \
+#define EFI_TAPE_IO_PROTOCOL_GUID \
+ { 0x1e93e633, 0xd65a, 0x459e, \
+ { 0xab, 0x84, 0x93, 0xd9, 0xec, 0x26, 0x6d, 0x18 } \
+#define EFI_SCSI_IO_PROTOCOL_GUID \
+ { 0x932f47e6, 0x2362, 0x4002, \
+ { 0x80, 0x3e, 0x3c, 0xd5, 0x4b, 0x13, 0x8f, 0x85 } \
+#define EFI_USB2_HC_PROTOCOL_GUID \
+ { 0x3e745226, 0x9818, 0x45b6, \
+ { 0xa2, 0xac, 0xd7, 0xcd, 0x0e, 0x8b, 0xa2, 0xbc } \
+#define EFI_DEBUG_SUPPORT_PROTOCOL_GUID \
+ { 0x2755590C, 0x6F3C, 0x42FA, \
+ { 0x9E, 0xA4, 0xA3, 0xBA, 0x54, 0x3C, 0xDA, 0x25 } \
+#define EFI_DEBUGPORT_PROTOCOL_GUID \
+ { 0xEBA4E8D2, 0x3858, 0x41EC, \
+ { 0xA2, 0x81, 0x26, 0x47, 0xBA, 0x96, 0x60, 0xD0 } \
+#define EFI_DECOMPRESS_PROTOCOL_GUID \
+ { 0xd8117cfe, 0x94a6, 0x11d4, \
+ { 0x9a, 0x3a, 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d } \
+#define EFI_ACPI_TABLE_PROTOCOL_GUID \
+ { 0xffe06bdd, 0x6107, 0x46a6, \
+ { 0x7b, 0xb2, 0x5a, 0x9c, 0x7e, 0xc5, 0x27, 0x5c} \
+#define EFI_HII_CONFIG_ROUTING_PROTOCOL_GUID \
+ { 0x587e72d7, 0xcc50, 0x4f79, \
+ { 0x82, 0x09, 0xca, 0x29, 0x1f, 0xc1, 0xa1, 0x0f } \
+#define EFI_HII_DATABASE_PROTOCOL_GUID \
+ { 0xef9fc172, 0xa1b2, 0x4693, \
+ { 0xb3, 0x27, 0x6d, 0x32, 0xfc, 0x41, 0x60, 0x42 } \
+#define EFI_HII_STRING_PROTOCOL_GUID \
+ { 0xfd96974, 0x23aa, 0x4cdc, \
+ { 0xb9, 0xcb, 0x98, 0xd1, 0x77, 0x50, 0x32, 0x2a } \
+#define EFI_HII_IMAGE_PROTOCOL_GUID \
+ { 0x31a6406a, 0x6bdf, 0x4e46, \
+ { 0xb2, 0xa2, 0xeb, 0xaa, 0x89, 0xc4, 0x9, 0x20 } \
+#define EFI_HII_FONT_PROTOCOL_GUID \
+ { 0xe9ca4775, 0x8657, 0x47fc, \
+ { 0x97, 0xe7, 0x7e, 0xd6, 0x5a, 0x8, 0x43, 0x24 } \
+#define EFI_HII_CONFIGURATION_ACCESS_PROTOCOL_GUID \
+ { 0x330d4706, 0xf2a0, 0x4e4f, \
+ { 0xa3, 0x69, 0xb6, 0x6f, 0xa8, 0xd5, 0x43, 0x85 } \
+#define EFI_COMPONENT_NAME_PROTOCOL_GUID \
+{ 0x107a772c, 0xd5e1, 0x11d4, {0x9a, 0x46, 0x0, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define EFI_COMPONENT_NAME2_PROTOCOL_GUID \
+ { 0x6a7a5cff, 0xe8d9, 0x4f70, \
+ { 0xba, 0xda, 0x75, 0xab, 0x30, 0x25, 0xce, 0x14} \
+#define EFI_USB_IO_PROTOCOL_GUID \
+ { 0x2B2F68D6, 0x0CD2, 0x44cf, \
+ { 0x8E, 0x8B, 0xBB, 0xA2, 0x0B, 0x1B, 0x5B, 0x75 } \
+#define EFI_HCDP_TABLE_GUID \
+ { 0xf951938d, 0x620b, 0x42ef, \
+ { 0x82, 0x79, 0xa8, 0x4b, 0x79, 0x61, 0x78, 0x98 } \
+#define EFI_DEVICE_TREE_GUID \
+ { 0xb1b621d5, 0xf19c, 0x41a5, \
+ { 0x83, 0x0b, 0xd9, 0x15, 0x2c, 0x69, 0xaa, 0xe0 } \
+#define EFI_VENDOR_APPLE_GUID \
+ { 0x2B0585EB, 0xD8B8, 0x49A9, \
+ { 0x8B, 0x8C, 0xE2, 0x1B, 0x01, 0xAE, 0xF2, 0xB7 } \
+#define EFI_CONSOLE_IN_DEVICE_GUID \
+{ 0xd3b36f2b, 0xd551, 0x11d4, {0x9a, 0x46, 0x0, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define EFI_CONSOLE_OUT_DEVICE_GUID \
+{ 0xd3b36f2c, 0xd551, 0x11d4, {0x9a, 0x46, 0x0, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define EFI_STANDARD_ERROR_DEVICE_GUID \
+{ 0xd3b36f2d, 0xd551, 0x11d4, {0x9a, 0x46, 0x0, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define EFI_UNICODE_COLLATION2_PROTOCOL_GUID \
+{ 0xa4c751fc, 0x23ae, 0x4c3e, {0x92, 0xe9, 0x49, 0x64, 0xcf, 0x63, 0xf3, 0x49} }
+#define EFI_FORM_BROWSER2_PROTOCOL_GUID \
+{ 0xb9d4c360, 0xbcfb, 0x4f9b, {0x92, 0x98, 0x53, 0xc1, 0x36, 0x98, 0x22, 0x58} }
+#define EFI_ARP_SERVICE_BINDING_PROTOCOL_GUID \
+{ 0xf44c00ee, 0x1f2c, 0x4a00, {0xaa, 0x9, 0x1c, 0x9f, 0x3e, 0x8, 0x0, 0xa3} }
+#define EFI_ARP_PROTOCOL_GUID \
+{ 0xf4b427bb, 0xba21, 0x4f16, {0xbc, 0x4e, 0x43, 0xe4, 0x16, 0xab, 0x61, 0x9c} }
+#define EFI_IP4_CONFIG_PROTOCOL_GUID \
+{ 0x3b95aa31, 0x3793, 0x434b, {0x86, 0x67, 0xc8, 0x07, 0x08, 0x92, 0xe0, 0x5e} }
+#define EFI_IP6_CONFIG_PROTOCOL_GUID \
+{ 0x937fe521, 0x95ae, 0x4d1a, {0x89, 0x29, 0x48, 0xbc, 0xd9, 0x0a, 0xd3, 0x1a} }
+#define EFI_MANAGED_NETWORK_SERVICE_BINDING_PROTOCOL_GUID \
+{ 0xf36ff770, 0xa7e1, 0x42cf, {0x9e, 0xd2, 0x56, 0xf0, 0xf2, 0x71, 0xf4, 0x4c} }
+#define EFI_MANAGED_NETWORK_PROTOCOL_GUID \
+{ 0x7ab33a91, 0xace5, 0x4326, {0xb5, 0x72, 0xe7, 0xee, 0x33, 0xd3, 0x9f, 0x16} }
+#define EFI_MTFTP4_SERVICE_BINDING_PROTOCOL_GUID \
+{ 0x2FE800BE, 0x8F01, 0x4aa6, {0x94, 0x6B, 0xD7, 0x13, 0x88, 0xE1, 0x83, 0x3F} }
+#define EFI_MTFTP4_PROTOCOL_GUID \
+{ 0x78247c57, 0x63db, 0x4708, {0x99, 0xc2, 0xa8, 0xb4, 0xa9, 0xa6, 0x1f, 0x6b} }
+#define EFI_MTFTP6_SERVICE_BINDING_PROTOCOL_GUID \
+{ 0xd9760ff3, 0x3cca, 0x4267, {0x80, 0xf9, 0x75, 0x27, 0xfa, 0xfa, 0x42, 0x23} }
+#define EFI_MTFTP6_PROTOCOL_GUID \
+{ 0xbf0a78ba, 0xec29, 0x49cf, {0xa1, 0xc9, 0x7a, 0xe5, 0x4e, 0xab, 0x6a, 0x51} }
+#define EFI_DHCP4_PROTOCOL_GUID \
+{ 0x8a219718, 0x4ef5, 0x4761, {0x91, 0xc8, 0xc0, 0xf0, 0x4b, 0xda, 0x9e, 0x56} }
+#define EFI_DHCP4_SERVICE_BINDING_PROTOCOL_GUID \
+{ 0x9d9a39d8, 0xbd42, 0x4a73, {0xa4, 0xd5, 0x8e, 0xe9, 0x4b, 0xe1, 0x13, 0x80} }
+#define EFI_DHCP6_SERVICE_BINDING_PROTOCOL_GUID \
+{ 0x9fb9a8a1, 0x2f4a, 0x43a6, {0x88, 0x9c, 0xd0, 0xf7, 0xb6, 0xc4, 0x7a, 0xd5} }
+#define EFI_DHCP6_PROTOCOL_GUID \
+{ 0x87c8bad7, 0x595, 0x4053, {0x82, 0x97, 0xde, 0xde, 0x39, 0x5f, 0x5d, 0x5b} }
+#define EFI_SCSI_PASS_THRU_PROTOCOL_GUID \
+{ 0xa59e8fcf, 0xbda0, 0x43bb, {0x90, 0xb1, 0xd3, 0x73, 0x2e, 0xca, 0xa8, 0x77} }
+#define EFI_EXT_SCSI_PASS_THRU_PROTOCOL_GUID \
+{ 0x143b7632, 0xb81b, 0x4cb7, {0xab, 0xd3, 0xb6, 0x25, 0xa5, 0xb9, 0xbf, 0xfe} }
+#define EFI_DISK_INFO_PROTOCOL_GUID \
+{ 0xd432a67f, 0x14dc, 0x484b, {0xb3, 0xbb, 0x3f, 0x2, 0x91, 0x84, 0x93, 0x27} }
+#define EFI_ISA_IO_PROTOCOL_GUID \
+{ 0x7ee2bd44, 0x3da0, 0x11d4, { 0x9a, 0x38, 0x0, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define EFI_VLAN_CONFIG_PROTOCOL_GUID \
+{ 0x9e23d768, 0xd2f3, 0x4366, {0x9f, 0xc3, 0x3a, 0x7a, 0xba, 0x86, 0x43, 0x74} }
+#define EFI_IDE_CONTROLLER_INIT_PROTOCOL_GUID \
+{ 0xa1e37052, 0x80d9, 0x4e65, {0xa3, 0x17, 0x3e, 0x9a, 0x55, 0xc4, 0x3e, 0xc9} }
+#define EFI_ISA_ACPI_PROTOCOL_GUID \
+{ 0x64a892dc, 0x5561, 0x4536, {0x92, 0xc7, 0x79, 0x9b, 0xfc, 0x18, 0x33, 0x55} }
+#define EFI_PCI_ENUMERATION_COMPLETE_GUID \
+{ 0x30cfe3e7, 0x3de1, 0x4586, {0xbe, 0x20, 0xde, 0xab, 0xa1, 0xb3, 0xb7, 0x93} }
+#define EFI_DRIVER_DIAGNOSTICS_PROTOCOL_GUID \
+{ 0x0784924f, 0xe296, 0x11d4, {0x9a, 0x49, 0x0, 0x90, 0x27, 0x3f, 0xc1, 0x4d } }
+#define EFI_DRIVER_DIAGNOSTICS2_PROTOCOL_GUID \
+{ 0x4d330321, 0x025f, 0x4aac, {0x90, 0xd8, 0x5e, 0xd9, 0x00, 0x17, 0x3b, 0x63} }
+#define EFI_CAPSULE_ARCH_PROTOCOL_GUID \
+{ 0x5053697e, 0x2cbc, 0x4819, {0x90, 0xd9, 0x05, 0x80, 0xde, 0xee, 0x57, 0x54} }
+#define EFI_MONOTONIC_COUNTER_ARCH_PROTOCOL_GUID \
+{0x1da97072, 0xbddc, 0x4b30, {0x99, 0xf1, 0x72, 0xa0, 0xb5, 0x6f, 0xff, 0x2a} }
+#define EFI_REALTIME_CLOCK_ARCH_PROTOCOL_GUID \
+{0x27cfac87, 0x46cc, 0x11d4, {0x9a, 0x38, 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define EFI_MP_SERVICES_PROTOCOL_GUID \
+{ 0x3fdda605, 0xa76e, 0x4f46, {0xad, 0x29, 0x12, 0xf4, 0x53, 0x1b, 0x3d, 0x08} }
+#define EFI_VARIABLE_ARCH_PROTOCOL_GUID \
+{ 0x1e5668e2, 0x8481, 0x11d4, {0xbc, 0xf1, 0x0, 0x80, 0xc7, 0x3c, 0x88, 0x81 } }
+#define EFI_VARIABLE_WRITE_ARCH_PROTOCOL_GUID \
+{ 0x6441f818, 0x6362, 0x4e44, {0xb5, 0x70, 0x7d, 0xba, 0x31, 0xdd, 0x24, 0x53} }
+#define EFI_WATCHDOG_TIMER_ARCH_PROTOCOL_GUID \
+#define EFI_ACPI_SUPPORT_PROTOCOL_GUID \
+#define EFI_BDS_ARCH_PROTOCOL_GUID \
+{ 0x665e3ff6, 0x46cc, 0x11d4, {0x9a, 0x38, 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define EFI_METRONOME_ARCH_PROTOCOL_GUID \
+{ 0x26baccb2, 0x6f42, 0x11d4, {0xbc, 0xe7, 0x0, 0x80, 0xc7, 0x3c, 0x88, 0x81 } }
+#define EFI_TIMER_ARCH_PROTOCOL_GUID \
+{ 0x26baccb3, 0x6f42, 0x11d4, {0xbc, 0xe7, 0x0, 0x80, 0xc7, 0x3c, 0x88, 0x81 } }
+#define EFI_DPC_PROTOCOL_GUID \
+{ 0x480f8ae9, 0xc46, 0x4aa9, { 0xbc, 0x89, 0xdb, 0x9f, 0xba, 0x61, 0x98, 0x6} }
+#define EFI_PRINT2_PROTOCOL_GUID \
+{ 0xf05976ef, 0x83f1, 0x4f3d, {0x86, 0x19, 0xf7, 0x59, 0x5d, 0x41, 0xe5, 0x38} }
+#define EFI_RESET_ARCH_PROTOCOL_GUID \
+{ 0x27cfac88, 0x46cc, 0x11d4, {0x9a, 0x38, 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define EFI_CPU_ARCH_PROTOCOL_GUID \
+{ 0x26baccb1, 0x6f42, 0x11d4, {0xbc, 0xe7, 0x0, 0x80, 0xc7, 0x3c, 0x88, 0x81 } }
+#define EFI_CPU_IO2_PROTOCOL_GUID \
+{ 0xad61f191, 0xae5f, 0x4c0e, {0xb9, 0xfa, 0xe8, 0x69, 0xd2, 0x88, 0xc6, 0x4f} }
+#define EFI_LEGACY_8259_PROTOCOL_GUID \
+{ 0x38321dba, 0x4fe0, 0x4e17, {0x8a, 0xec, 0x41, 0x30, 0x55, 0xea, 0xed, 0xc1} }
+#define EFI_SECURITY_ARCH_PROTOCOL_GUID \
+{ 0xa46423e3, 0x4617, 0x49f1, {0xb9, 0xff, 0xd1, 0xbf, 0xa9, 0x11, 0x58, 0x39} }
+#define EFI_SECURITY2_ARCH_PROTOCOL_GUID \
+{ 0x94ab2f58, 0x1438, 0x4ef1, {0x91, 0x52, 0x18, 0x94, 0x1a, 0x3a, 0x0e, 0x68} }
+#define EFI_RUNTIME_ARCH_PROTOCOL_GUID \
+{ 0xb7dfb4e1, 0x52f, 0x449f, {0x87, 0xbe, 0x98, 0x18, 0xfc, 0x91, 0xb7, 0x33} }
+#define EFI_STATUS_CODE_RUNTIME_PROTOCOL_GUID \
+{ 0xd2b2b828, 0x826, 0x48a7, {0xb3, 0xdf, 0x98, 0x3c, 0x0, 0x60, 0x24, 0xf0} }
+#define EFI_DATA_HUB_PROTOCOL_GUID \
+{ 0xae80d021, 0x618e, 0x11d4, {0xbc, 0xd7, 0x0, 0x80, 0xc7, 0x3c, 0x88, 0x81} }
+#define PCD_PROTOCOL_GUID \
+{ 0x11b34006, 0xd85b, 0x4d0a, { 0xa2, 0x90, 0xd5, 0xa5, 0x71, 0x31, 0xe, 0xf7} }
+#define EFI_PCD_PROTOCOL_GUID \
+{ 0x13a3f0f6, 0x264a, 0x3ef0, {0xf2, 0xe0, 0xde, 0xc5, 0x12, 0x34, 0x2f, 0x34} }
+#define EFI_FIRMWARE_VOLUME_BLOCK_PROTOCOL_GUID \
+{ 0x8f644fa9, 0xe850, 0x4db1, {0x9c, 0xe2, 0xb, 0x44, 0x69, 0x8e, 0x8d, 0xa4 } }
+#define EFI_FIRMWARE_VOLUME2_PROTOCOL_GUID \
+{ 0x220e73b6, 0x6bdb, 0x4413, { 0x84, 0x5, 0xb9, 0x74, 0xb1, 0x8, 0x61, 0x9a } }
+#define EFI_FIRMWARE_VOLUME_DISPATCH_PROTOCOL_GUID \
+{ 0x7aa35a69, 0x506c, 0x444f, {0xa7, 0xaf, 0x69, 0x4b, 0xf5, 0x6f, 0x71, 0xc8} }
+#define LZMA_COMPRESS_GUID \
+{ 0xee4e5898, 0x3914, 0x4259, {0x9d, 0x6e, 0xdc, 0x7b, 0xd7, 0x94, 0x03, 0xcf} }
+#endif
diff --git a/bsps/shared/freebsd/stand/efi/include/eficon.h b/bsps/shared/freebsd/stand/efi/include/eficon.h
index 0000000000..ba80114eb9
--- /dev/null
+++ b/bsps/shared/freebsd/stand/efi/include/eficon.h
@@ -0,0 +1,527 @@
+/* $FreeBSD$ */
+#ifndef _EFI_CON_H
+#define _EFI_CON_H
+Intel Corporation.
+Module Name:
+ eficon.h
+Abstract:
+ EFI console protocols
+Revision History
+// Text output protocol
+#define SIMPLE_TEXT_OUTPUT_PROTOCOL \
+ { 0x387477c2, 0x69c7, 0x11d2, {0x8e, 0x39, 0x0, 0xa0, 0xc9, 0x69, 0x72, 0x3b} }
+INTERFACE_DECL(_SIMPLE_TEXT_OUTPUT_INTERFACE);
+typedef
+EFI_STATUS
+(EFIAPI *EFI_TEXT_RESET) (
+ IN struct _SIMPLE_TEXT_OUTPUT_INTERFACE *This,
+ IN BOOLEAN ExtendedVerification
+typedef
+EFI_STATUS
+(EFIAPI *EFI_TEXT_OUTPUT_STRING) (
+ IN CHAR16 *String
+typedef
+EFI_STATUS
+(EFIAPI *EFI_TEXT_TEST_STRING) (
+ IN CHAR16 *String
+typedef
+EFI_STATUS
+(EFIAPI *EFI_TEXT_QUERY_MODE) (
+ IN UINTN ModeNumber,
+ OUT UINTN *Columns,
+ OUT UINTN *Rows
+typedef
+EFI_STATUS
+(EFIAPI *EFI_TEXT_SET_MODE) (
+typedef
+EFI_STATUS
+(EFIAPI *EFI_TEXT_SET_ATTRIBUTE) (
+ IN UINTN Attribute
+#define EFI_BLACK 0x00
+#define EFI_BLUE 0x01
+#define EFI_GREEN 0x02
+#define EFI_CYAN (EFI_BLUE | EFI_GREEN)
+#define EFI_RED 0x04
+#define EFI_MAGENTA (EFI_BLUE | EFI_RED)
+#define EFI_BROWN (EFI_GREEN | EFI_RED)
+#define EFI_LIGHTGRAY (EFI_BLUE | EFI_GREEN | EFI_RED)
+#define EFI_BRIGHT 0x08
+#define EFI_DARKGRAY (EFI_BRIGHT)
+#define EFI_LIGHTBLUE (EFI_BLUE | EFI_BRIGHT)
+#define EFI_LIGHTGREEN (EFI_GREEN | EFI_BRIGHT)
+#define EFI_LIGHTCYAN (EFI_CYAN | EFI_BRIGHT)
+#define EFI_LIGHTRED (EFI_RED | EFI_BRIGHT)
+#define EFI_LIGHTMAGENTA (EFI_MAGENTA | EFI_BRIGHT)
+#define EFI_YELLOW (EFI_BROWN | EFI_BRIGHT)
+#define EFI_WHITE (EFI_BLUE | EFI_GREEN | EFI_RED | EFI_BRIGHT)
+#define EFI_TEXT_ATTR(f,b) ((f) | ((b) << 4))
+#define EFI_BACKGROUND_BLACK 0x00
+#define EFI_BACKGROUND_BLUE 0x10
+#define EFI_BACKGROUND_GREEN 0x20
+#define EFI_BACKGROUND_CYAN (EFI_BACKGROUND_BLUE | EFI_BACKGROUND_GREEN)
+#define EFI_BACKGROUND_RED 0x40
+#define EFI_BACKGROUND_MAGENTA (EFI_BACKGROUND_BLUE | EFI_BACKGROUND_RED)
+#define EFI_BACKGROUND_BROWN (EFI_BACKGROUND_GREEN | EFI_BACKGROUND_RED)
+#define EFI_BACKGROUND_LIGHTGRAY (EFI_BACKGROUND_BLUE | EFI_BACKGROUND_GREEN | EFI_BACKGROUND_RED)
+typedef
+EFI_STATUS
+(EFIAPI *EFI_TEXT_CLEAR_SCREEN) (
+typedef
+EFI_STATUS
+(EFIAPI *EFI_TEXT_SET_CURSOR_POSITION) (
+ IN UINTN Column,
+ IN UINTN Row
+typedef
+EFI_STATUS
+(EFIAPI *EFI_TEXT_ENABLE_CURSOR) (
+ IN BOOLEAN Enable
+typedef struct {
+ INT32 MaxMode;
+ // current settings
+ INT32 Mode;
+ INT32 Attribute;
+ INT32 CursorColumn;
+ INT32 CursorRow;
+ BOOLEAN CursorVisible;
+} SIMPLE_TEXT_OUTPUT_MODE;
+typedef struct _SIMPLE_TEXT_OUTPUT_INTERFACE {
+ EFI_TEXT_RESET Reset;
+ EFI_TEXT_OUTPUT_STRING OutputString;
+ EFI_TEXT_TEST_STRING TestString;
+ EFI_TEXT_QUERY_MODE QueryMode;
+ EFI_TEXT_SET_MODE SetMode;
+ EFI_TEXT_SET_ATTRIBUTE SetAttribute;
+ EFI_TEXT_CLEAR_SCREEN ClearScreen;
+ EFI_TEXT_SET_CURSOR_POSITION SetCursorPosition;
+ EFI_TEXT_ENABLE_CURSOR EnableCursor;
+ // Current mode
+ SIMPLE_TEXT_OUTPUT_MODE *Mode;
+} SIMPLE_TEXT_OUTPUT_INTERFACE;
+// Define's for required EFI Unicode Box Draw character
+#define BOXDRAW_HORIZONTAL 0x2500
+#define BOXDRAW_VERTICAL 0x2502
+#define BOXDRAW_DOWN_RIGHT 0x250c
+#define BOXDRAW_DOWN_LEFT 0x2510
+#define BOXDRAW_UP_RIGHT 0x2514
+#define BOXDRAW_UP_LEFT 0x2518
+#define BOXDRAW_VERTICAL_RIGHT 0x251c
+#define BOXDRAW_VERTICAL_LEFT 0x2524
+#define BOXDRAW_DOWN_HORIZONTAL 0x252c
+#define BOXDRAW_UP_HORIZONTAL 0x2534
+#define BOXDRAW_VERTICAL_HORIZONTAL 0x253c
+#define BOXDRAW_DOUBLE_HORIZONTAL 0x2550
+#define BOXDRAW_DOUBLE_VERTICAL 0x2551
+#define BOXDRAW_DOWN_RIGHT_DOUBLE 0x2552
+#define BOXDRAW_DOWN_DOUBLE_RIGHT 0x2553
+#define BOXDRAW_DOUBLE_DOWN_RIGHT 0x2554
+#define BOXDRAW_DOWN_LEFT_DOUBLE 0x2555
+#define BOXDRAW_DOWN_DOUBLE_LEFT 0x2556
+#define BOXDRAW_DOUBLE_DOWN_LEFT 0x2557
+#define BOXDRAW_UP_RIGHT_DOUBLE 0x2558
+#define BOXDRAW_UP_DOUBLE_RIGHT 0x2559
+#define BOXDRAW_DOUBLE_UP_RIGHT 0x255a
+#define BOXDRAW_UP_LEFT_DOUBLE 0x255b
+#define BOXDRAW_UP_DOUBLE_LEFT 0x255c
+#define BOXDRAW_DOUBLE_UP_LEFT 0x255d
+#define BOXDRAW_VERTICAL_RIGHT_DOUBLE 0x255e
+#define BOXDRAW_VERTICAL_DOUBLE_RIGHT 0x255f
+#define BOXDRAW_DOUBLE_VERTICAL_RIGHT 0x2560
+#define BOXDRAW_VERTICAL_LEFT_DOUBLE 0x2561
+#define BOXDRAW_VERTICAL_DOUBLE_LEFT 0x2562
+#define BOXDRAW_DOUBLE_VERTICAL_LEFT 0x2563
+#define BOXDRAW_DOWN_HORIZONTAL_DOUBLE 0x2564
+#define BOXDRAW_DOWN_DOUBLE_HORIZONTAL 0x2565
+#define BOXDRAW_DOUBLE_DOWN_HORIZONTAL 0x2566
+#define BOXDRAW_UP_HORIZONTAL_DOUBLE 0x2567
+#define BOXDRAW_UP_DOUBLE_HORIZONTAL 0x2568
+#define BOXDRAW_DOUBLE_UP_HORIZONTAL 0x2569
+#define BOXDRAW_VERTICAL_HORIZONTAL_DOUBLE 0x256a
+#define BOXDRAW_VERTICAL_DOUBLE_HORIZONTAL 0x256b
+#define BOXDRAW_DOUBLE_VERTICAL_HORIZONTAL 0x256c
+// EFI Required Block Elements Code Chart
+#define BLOCKELEMENT_FULL_BLOCK 0x2588
+#define BLOCKELEMENT_LIGHT_SHADE 0x2591
+// EFI Required Geometric Shapes Code Chart
+#define GEOMETRICSHAPE_UP_TRIANGLE 0x25b2
+#define GEOMETRICSHAPE_RIGHT_TRIANGLE 0x25ba
+#define GEOMETRICSHAPE_DOWN_TRIANGLE 0x25bc
+#define GEOMETRICSHAPE_LEFT_TRIANGLE 0x25c4
+// EFI Required Arrow shapes
+#define ARROW_UP 0x2191
+#define ARROW_DOWN 0x2193
+// Text input protocol
+#define SIMPLE_TEXT_INPUT_PROTOCOL \
+ { 0x387477c1, 0x69c7, 0x11d2, {0x8e, 0x39, 0x0, 0xa0, 0xc9, 0x69, 0x72, 0x3b} }
+INTERFACE_DECL(_SIMPLE_INPUT_INTERFACE);
+typedef struct {
+ UINT16 ScanCode;
+ CHAR16 UnicodeChar;
+} EFI_INPUT_KEY;
+// Baseline unicode control chars
+#define CHAR_NULL 0x0000
+#define CHAR_BACKSPACE 0x0008
+#define CHAR_TAB 0x0009
+#define CHAR_LINEFEED 0x000A
+#define CHAR_CARRIAGE_RETURN 0x000D
+// Scan codes for base line keys
+#define SCAN_NULL 0x0000
+#define SCAN_UP 0x0001
+#define SCAN_DOWN 0x0002
+#define SCAN_RIGHT 0x0003
+#define SCAN_LEFT 0x0004
+#define SCAN_HOME 0x0005
+#define SCAN_END 0x0006
+#define SCAN_INSERT 0x0007
+#define SCAN_DELETE 0x0008
+#define SCAN_PAGE_UP 0x0009
+#define SCAN_PAGE_DOWN 0x000A
+#define SCAN_F1 0x000B
+#define SCAN_F2 0x000C
+#define SCAN_F3 0x000D
+#define SCAN_F4 0x000E
+#define SCAN_F5 0x000F
+#define SCAN_F6 0x0010
+#define SCAN_F7 0x0011
+#define SCAN_F8 0x0012
+#define SCAN_F9 0x0013
+#define SCAN_F10 0x0014
+#define SCAN_ESC 0x0017
+// EFI Scan code Ex
+#define SCAN_F11 0x0015
+#define SCAN_F12 0x0016
+#define SCAN_F13 0x0068
+#define SCAN_F14 0x0069
+#define SCAN_F15 0x006A
+#define SCAN_F16 0x006B
+#define SCAN_F17 0x006C
+#define SCAN_F18 0x006D
+#define SCAN_F19 0x006E
+#define SCAN_F20 0x006F
+#define SCAN_F21 0x0070
+#define SCAN_F22 0x0071
+#define SCAN_F23 0x0072
+#define SCAN_F24 0x0073
+#define SCAN_MUTE 0x007F
+#define SCAN_VOLUME_UP 0x0080
+#define SCAN_VOLUME_DOWN 0x0081
+#define SCAN_BRIGHTNESS_UP 0x0100
+#define SCAN_BRIGHTNESS_DOWN 0x0101
+#define SCAN_SUSPEND 0x0102
+#define SCAN_HIBERNATE 0x0103
+#define SCAN_TOGGLE_DISPLAY 0x0104
+#define SCAN_RECOVERY 0x0105
+#define SCAN_EJECT 0x0106
+typedef
+EFI_STATUS
+(EFIAPI *EFI_INPUT_RESET) (
+ IN struct _SIMPLE_INPUT_INTERFACE *This,
+typedef
+EFI_STATUS
+(EFIAPI *EFI_INPUT_READ_KEY) (
+ OUT EFI_INPUT_KEY *Key
+typedef struct _SIMPLE_INPUT_INTERFACE {
+ EFI_INPUT_RESET Reset;
+ EFI_INPUT_READ_KEY ReadKeyStroke;
+ EFI_EVENT WaitForKey;
+} SIMPLE_INPUT_INTERFACE;
+#define EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL_GUID \
+ {0xdd9e7534, 0x7762, 0x4698, {0x8c, 0x14, 0xf5, 0x85, \
+ 0x17, 0xa6, 0x25, 0xaa} }
+INTERFACE_DECL(_EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL);
+typedef UINT8 EFI_KEY_TOGGLE_STATE;
+// Any Shift or Toggle State that is valid should have
+// high order bit set.
+typedef struct EFI_KEY_STATE {
+ UINT32 KeyShiftState;
+ EFI_KEY_TOGGLE_STATE KeyToggleState;
+} EFI_KEY_STATE;
+typedef struct {
+ EFI_INPUT_KEY Key;
+ EFI_KEY_STATE KeyState;
+} EFI_KEY_DATA;
+// Shift state
+#define EFI_SHIFT_STATE_VALID 0x80000000
+#define EFI_RIGHT_SHIFT_PRESSED 0x00000001
+#define EFI_LEFT_SHIFT_PRESSED 0x00000002
+#define EFI_RIGHT_CONTROL_PRESSED 0x00000004
+#define EFI_LEFT_CONTROL_PRESSED 0x00000008
+#define EFI_RIGHT_ALT_PRESSED 0x00000010
+#define EFI_LEFT_ALT_PRESSED 0x00000020
+#define EFI_RIGHT_LOGO_PRESSED 0x00000040
+#define EFI_LEFT_LOGO_PRESSED 0x00000080
+#define EFI_MENU_KEY_PRESSED 0x00000100
+#define EFI_SYS_REQ_PRESSED 0x00000200
+// Toggle state
+#define EFI_TOGGLE_STATE_VALID 0x80
+#define EFI_KEY_STATE_EXPOSED 0x40
+#define EFI_SCROLL_LOCK_ACTIVE 0x01
+#define EFI_NUM_LOCK_ACTIVE 0x02
+#define EFI_CAPS_LOCK_ACTIVE 0x04
+// EFI Key Notfication Function
+typedef
+EFI_STATUS
+(EFIAPI *EFI_KEY_NOTIFY_FUNCTION) (
+ IN EFI_KEY_DATA *KeyData
+typedef
+EFI_STATUS
+(EFIAPI *EFI_INPUT_RESET_EX) (
+ IN struct _EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL *This,
+ Routine Description:
+ Reset the input device and optionaly run diagnostics
+ Arguments:
+ This - Protocol instance pointer.
+ ExtendedVerification - Driver may perform diagnostics on reset.
+ Returns:
+ EFI_SUCCESS - The device was reset.
+ EFI_DEVICE_ERROR - The device is not functioning properly and could
+ not be reset.
+typedef
+EFI_STATUS
+(EFIAPI *EFI_INPUT_READ_KEY_EX) (
+ OUT EFI_KEY_DATA *KeyData
+ Reads the next keystroke from the input device. The WaitForKey Event can
+ be used to test for existence of a keystroke via WaitForEvent () call.
+ Arguments:
+ KeyData - A pointer to a buffer that is filled in with the keystroke
+ state data for the key that was pressed.
+ Returns:
+ EFI_SUCCESS - The keystroke information was returned.
+ EFI_NOT_READY - There was no keystroke data availiable.
+ EFI_DEVICE_ERROR - The keystroke information was not returned due to
+ hardware errors.
+ EFI_INVALID_PARAMETER - KeyData is NULL.
+typedef
+EFI_STATUS
+(EFIAPI *EFI_SET_STATE) (
+ IN EFI_KEY_TOGGLE_STATE *KeyToggleState
+ Set certain state for the input device.
+ Arguments:
+ KeyToggleState - A pointer to the EFI_KEY_TOGGLE_STATE to set the
+ state for the input device.
+ Returns:
+ EFI_SUCCESS - The device state was set successfully.
+ EFI_DEVICE_ERROR - The device is not functioning correctly and could
+ not have the setting adjusted.
+ EFI_UNSUPPORTED - The device does not have the ability to set its state.
+ EFI_INVALID_PARAMETER - KeyToggleState is NULL.
+typedef
+EFI_STATUS
+(EFIAPI *EFI_REGISTER_KEYSTROKE_NOTIFY) (
+ IN EFI_KEY_DATA *KeyData,
+ IN EFI_KEY_NOTIFY_FUNCTION KeyNotificationFunction,
+ OUT EFI_HANDLE *NotifyHandle
+ Register a notification function for a particular keystroke for the input device.
+ Arguments:
+ information data for the key that was pressed.
+ KeyNotificationFunction - Points to the function to be called when the key
+ sequence is typed specified by KeyData.
+ NotifyHandle - Points to the unique handle assigned to the registered notification.
+ Returns:
+ EFI_SUCCESS - The notification function was registered successfully.
+ EFI_OUT_OF_RESOURCES - Unable to allocate resources for necesssary data structures.
+ EFI_INVALID_PARAMETER - KeyData or NotifyHandle is NULL.
+typedef
+EFI_STATUS
+(EFIAPI *EFI_UNREGISTER_KEYSTROKE_NOTIFY) (
+ IN EFI_HANDLE NotificationHandle
+ Remove a registered notification function from a particular keystroke.
+ Arguments:
+ NotificationHandle - The handle of the notification function being unregistered.
+ Returns:
+ EFI_SUCCESS - The notification function was unregistered successfully.
+ EFI_INVALID_PARAMETER - The NotificationHandle is invalid.
+ EFI_NOT_FOUND - Can not find the matching entry in database.
+typedef struct _EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL {
+ EFI_INPUT_RESET_EX Reset;
+ EFI_INPUT_READ_KEY_EX ReadKeyStrokeEx;
+ EFI_EVENT WaitForKeyEx;
+ EFI_SET_STATE SetState;
+ EFI_REGISTER_KEYSTROKE_NOTIFY RegisterKeyNotify;
+ EFI_UNREGISTER_KEYSTROKE_NOTIFY UnregisterKeyNotify;
+} EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL;
+#endif
diff --git a/bsps/shared/freebsd/stand/efi/include/eficonsctl.h b/bsps/shared/freebsd/stand/efi/include/eficonsctl.h
index 0000000000..68be3d69f4
--- /dev/null
+++ b/bsps/shared/freebsd/stand/efi/include/eficonsctl.h
@@ -0,0 +1,134 @@
+ * Copyright (c) 2004 - 2010, Intel Corporation. All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
+ * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
+ * THE POSSIBILITY OF SUCH DAMAGE.
+ * Original Module Name: ConsoleControl.h
+ * Abstract: Abstraction of a Text mode or GOP/UGA screen
+/* $FreeBSD$ */
+#ifndef _EFI_CONS_CTL_H
+#define _EFI_CONS_CTL_H
+#define EFI_CONSOLE_CONTROL_PROTOCOL_GUID \
+ { 0xf42f7782, 0x12e, 0x4c12, {0x99, 0x56, 0x49, 0xf9, 0x43, 0x4, 0xf7, 0x21} }
+typedef struct _EFI_CONSOLE_CONTROL_PROTOCOL EFI_CONSOLE_CONTROL_PROTOCOL;
+typedef enum {
+ EfiConsoleControlScreenText,
+ EfiConsoleControlScreenGraphics,
+ EfiConsoleControlScreenMaxValue
+} EFI_CONSOLE_CONTROL_SCREEN_MODE;
+typedef
+EFI_STATUS
+(EFIAPI *EFI_CONSOLE_CONTROL_PROTOCOL_GET_MODE) (
+ IN EFI_CONSOLE_CONTROL_PROTOCOL *This,
+ OUT EFI_CONSOLE_CONTROL_SCREEN_MODE *Mode,
+ OUT BOOLEAN *GopUgaExists, OPTIONAL
+ OUT BOOLEAN *StdInLocked OPTIONAL
+ Return the current video mode information. Also returns info about existence
+ of Graphics Output devices or UGA Draw devices in system, and if the Std In
+ device is locked. All the arguments are optional and only returned if a non
+ NULL pointer is passed in.
+ Arguments:
+ Mode - Are we in text of grahics mode.
+ GopUgaExists - TRUE if Console Spliter has found a GOP or UGA device
+ StdInLocked - TRUE if StdIn device is keyboard locked
+ Returns:
+ EFI_SUCCESS - Mode information returned.
+typedef
+EFI_STATUS
+(EFIAPI *EFI_CONSOLE_CONTROL_PROTOCOL_SET_MODE) (
+ IN EFI_CONSOLE_CONTROL_SCREEN_MODE Mode
+ Set the current mode to either text or graphics. Graphics is
+ for Quiet Boot.
+ Arguments:
+ Mode - Mode to set the
+ Returns:
+typedef
+EFI_STATUS
+(EFIAPI *EFI_CONSOLE_CONTROL_PROTOCOL_LOCK_STD_IN) (
+ IN CHAR16 *Password
+ Lock Std In devices until Password is typed.
+ Arguments:
+ Password - Password needed to unlock screen. NULL means unlock keyboard
+ Returns:
+ EFI_DEVICE_ERROR - Std In not locked
+struct _EFI_CONSOLE_CONTROL_PROTOCOL {
+ EFI_CONSOLE_CONTROL_PROTOCOL_GET_MODE GetMode;
+ EFI_CONSOLE_CONTROL_PROTOCOL_SET_MODE SetMode;
+ EFI_CONSOLE_CONTROL_PROTOCOL_LOCK_STD_IN LockStdIn;
+extern EFI_GUID gEfiConsoleControlProtocolGuid;
+#endif
diff --git a/bsps/shared/freebsd/stand/efi/include/efidef.h b/bsps/shared/freebsd/stand/efi/include/efidef.h
index 0000000000..a8f88d41df
--- /dev/null
+++ b/bsps/shared/freebsd/stand/efi/include/efidef.h
@@ -0,0 +1,224 @@
+/* $FreeBSD$ */
+#ifndef _EFI_DEF_H
+#define _EFI_DEF_H
+Intel Corporation.
+Module Name:
+ efidef.h
+Abstract:
+ EFI definitions
+Revision History
+typedef UINT16 CHAR16;
+typedef UINT8 CHAR8;
+typedef UINT8 BOOLEAN;
+#endif
+#ifndef TRUE
+ #define TRUE ((BOOLEAN) 1)
+ #define FALSE ((BOOLEAN) 0)
+#endif
+#ifndef NULL
+ #define NULL ((VOID *) 0)
+#endif
+typedef UINTN EFI_STATUS;
+typedef UINT64 EFI_LBA;
+typedef UINTN EFI_TPL;
+typedef VOID *EFI_HANDLE;
+typedef VOID *EFI_EVENT;
+// Prototype argument decoration for EFI parameters to indicate
+// their direction
+// IN - argument is passed into the function
+// OUT - argument (pointer) is returned from the function
+// OPTIONAL - argument is optional
+#ifndef IN
+ #define IN
+ #define OUT
+ #define OPTIONAL
+ #define CONST const
+#endif
+// A GUID
+typedef struct {
+ UINT32 Data1;
+ UINT16 Data2;
+ UINT16 Data3;
+ UINT8 Data4[8];
+} EFI_GUID;
+// Time
+typedef struct {
+ UINT16 Year; // 1998 - 20XX
+ UINT8 Month; // 1 - 12
+ UINT8 Day; // 1 - 31
+ UINT8 Hour; // 0 - 23
+ UINT8 Minute; // 0 - 59
+ UINT8 Second; // 0 - 59
+ UINT8 Pad1;
+ UINT32 Nanosecond; // 0 - 999,999,999
+ INT16 TimeZone; // -1440 to 1440 or 2047
+ UINT8 Daylight;
+ UINT8 Pad2;
+} EFI_TIME;
+// Bit definitions for EFI_TIME.Daylight
+#define EFI_TIME_ADJUST_DAYLIGHT 0x01
+#define EFI_TIME_IN_DAYLIGHT 0x02
+// Value definition for EFI_TIME.TimeZone
+#define EFI_UNSPECIFIED_TIMEZONE 0x07FF
+// Networking
+typedef struct {
+ UINT8 Addr[4];
+} EFI_IPv4_ADDRESS;
+typedef struct {
+ UINT8 Addr[16];
+} EFI_IPv6_ADDRESS;
+typedef struct {
+ UINT8 Addr[32];
+} EFI_MAC_ADDRESS;
+typedef struct {
+ UINT32 ReceivedQueueTimeoutValue;
+ UINT32 TransmitQueueTimeoutValue;
+ UINT16 ProtocolTypeFilter;
+ BOOLEAN EnableUnicastReceive;
+ BOOLEAN EnableMulticastReceive;
+ BOOLEAN EnableBroadcastReceive;
+ BOOLEAN EnablePromiscuousReceive;
+ BOOLEAN FlushQueuesOnReset;
+ BOOLEAN EnableReceiveTimestamps;
+ BOOLEAN DisableBackgroundPolling;
+} EFI_MANAGED_NETWORK_CONFIG_DATA;
+// Memory
+typedef UINT64 EFI_PHYSICAL_ADDRESS;
+typedef UINT64 EFI_VIRTUAL_ADDRESS;
+typedef enum {
+ AllocateAnyPages,
+ AllocateMaxAddress,
+ AllocateAddress,
+ MaxAllocateType
+} EFI_ALLOCATE_TYPE;
+//Preseve the attr on any range supplied.
+//ConventialMemory must have WB,SR,SW when supplied.
+//When allocating from ConventialMemory always make it WB,SR,SW
+//When returning to ConventialMemory always make it WB,SR,SW
+//When getting the memory map, or on RT for runtime types
+typedef enum {
+ EfiReservedMemoryType,
+ EfiLoaderCode,
+ EfiLoaderData,
+ EfiBootServicesCode,
+ EfiBootServicesData,
+ EfiRuntimeServicesCode,
+ EfiRuntimeServicesData,
+ EfiConventionalMemory,
+ EfiUnusableMemory,
+ EfiACPIReclaimMemory,
+ EfiACPIMemoryNVS,
+ EfiMemoryMappedIO,
+ EfiMemoryMappedIOPortSpace,
+ EfiPalCode,
+ EfiPersistentMemory,
+ EfiMaxMemoryType
+} EFI_MEMORY_TYPE;
+// possible caching types for the memory range
+#define EFI_MEMORY_UC 0x0000000000000001
+#define EFI_MEMORY_WC 0x0000000000000002
+#define EFI_MEMORY_WT 0x0000000000000004
+#define EFI_MEMORY_WB 0x0000000000000008
+#define EFI_MEMORY_UCE 0x0000000000000010
+// physical memory protection on range
+#define EFI_MEMORY_WP 0x0000000000001000
+#define EFI_MEMORY_RP 0x0000000000002000
+#define EFI_MEMORY_XP 0x0000000000004000
+#define EFI_MEMORY_NV 0x0000000000008000
+#define EFI_MEMORY_MORE_RELIABLE 0x0000000000010000
+#define EFI_MEMORY_RO 0x0000000000020000
+// range requires a runtime mapping
+#define EFI_MEMORY_RUNTIME 0x8000000000000000
+#define EFI_MEMORY_DESCRIPTOR_VERSION 1
+typedef struct {
+ UINT32 Type; // Field size is 32 bits followed by 32 bit pad
+ UINT32 Pad;
+ EFI_PHYSICAL_ADDRESS PhysicalStart; // Field size is 64 bits
+ EFI_VIRTUAL_ADDRESS VirtualStart; // Field size is 64 bits
+ UINT64 NumberOfPages; // Field size is 64 bits
+ UINT64 Attribute; // Field size is 64 bits
+} EFI_MEMORY_DESCRIPTOR;
+// International Language
+typedef UINT8 ISO_639_2;
+#define ISO_639_2_ENTRY_SIZE 3
+#define EFI_PAGE_SIZE 4096
+#define EFI_PAGE_MASK 0xFFF
+#define EFI_PAGE_SHIFT 12
+#define EFI_SIZE_TO_PAGES(a) \
+ ( ((a) >> EFI_PAGE_SHIFT) + (((a) & EFI_PAGE_MASK) ? 1 : 0) )
+#endif
diff --git a/bsps/shared/freebsd/stand/efi/include/efidevp.h b/bsps/shared/freebsd/stand/efi/include/efidevp.h
index 0000000000..b00b78f02c
--- /dev/null
+++ b/bsps/shared/freebsd/stand/efi/include/efidevp.h
@@ -0,0 +1,511 @@
+/* $FreeBSD$ */
+#ifndef _DEVPATH_H
+#define _DEVPATH_H
+Intel Corporation.
+Module Name:
+ devpath.h
+Abstract:
+ Defines for parsing the EFI Device Path structures
+Revision History
+// Device Path structures - Section C
+#pragma pack(1)
+typedef struct _EFI_DEVICE_PATH {
+ UINT8 Type;
+ UINT8 SubType;
+ UINT8 Length[2];
+} EFI_DEVICE_PATH;
+#define EFI_DP_TYPE_MASK 0x7F
+#define EFI_DP_TYPE_UNPACKED 0x80
+#define END_DEVICE_PATH_TYPE 0x7f
+#define END_ENTIRE_DEVICE_PATH_SUBTYPE 0xff
+#define END_INSTANCE_DEVICE_PATH_SUBTYPE 0x01
+#define END_DEVICE_PATH_LENGTH (sizeof(EFI_DEVICE_PATH))
+#define DP_IS_END_TYPE(a)
+#define DP_IS_END_SUBTYPE(a) ( ((a)->SubType == END_ENTIRE_DEVICE_PATH_SUBTYPE )
+#define DevicePathType(a) ( ((a)->Type) & EFI_DP_TYPE_MASK )
+#define DevicePathSubType(a) ( (a)->SubType )
+#define DevicePathNodeLength(a) ((size_t)(((a)->Length[0]) | ((a)->Length[1] << 8)))
+#define NextDevicePathNode(a) ( (EFI_DEVICE_PATH *) ( ((UINT8 *) (a)) + DevicePathNodeLength(a)))
+#define IsDevicePathType(a, t) ( DevicePathType(a) == t )
+#define IsDevicePathEndType(a) IsDevicePathType(a, END_DEVICE_PATH_TYPE)
+#define IsDevicePathEndSubType(a) ( (a)->SubType == END_ENTIRE_DEVICE_PATH_SUBTYPE )
+#define IsDevicePathEnd(a) ( IsDevicePathEndType(a) && IsDevicePathEndSubType(a) )
+#define IsDevicePathUnpacked(a) ( (a)->Type & EFI_DP_TYPE_UNPACKED )
+#define SetDevicePathNodeLength(a,l) { \
+ (a)->Length[0] = (UINT8) (l); \
+ (a)->Length[1] = (UINT8) ((l) >> 8); \
+#define SetDevicePathEndNode(a) { \
+ (a)->Type = END_DEVICE_PATH_TYPE; \
+ (a)->SubType = END_ENTIRE_DEVICE_PATH_SUBTYPE; \
+ (a)->Length[0] = sizeof(EFI_DEVICE_PATH); \
+ (a)->Length[1] = 0; \
+#define HARDWARE_DEVICE_PATH 0x01
+#define HW_PCI_DP 0x01
+typedef struct _PCI_DEVICE_PATH {
+ EFI_DEVICE_PATH Header;
+ UINT8 Function;
+ UINT8 Device;
+} PCI_DEVICE_PATH;
+#define HW_PCCARD_DP 0x02
+typedef struct _PCCARD_DEVICE_PATH {
+ UINT8 FunctionNumber;
+} PCCARD_DEVICE_PATH;
+#define HW_MEMMAP_DP 0x03
+typedef struct _MEMMAP_DEVICE_PATH {
+ UINT32 MemoryType;
+ EFI_PHYSICAL_ADDRESS StartingAddress;
+ EFI_PHYSICAL_ADDRESS EndingAddress;
+} MEMMAP_DEVICE_PATH;
+#define HW_VENDOR_DP 0x04
+typedef struct _VENDOR_DEVICE_PATH {
+ EFI_GUID Guid;
+} VENDOR_DEVICE_PATH;
+#define UNKNOWN_DEVICE_GUID \
+ { 0xcf31fac5, 0xc24e, 0x11d2, {0x85, 0xf3, 0x0, 0xa0, 0xc9, 0x3e, 0xc9, 0x3b} }
+typedef struct _UKNOWN_DEVICE_VENDOR_DP {
+ VENDOR_DEVICE_PATH DevicePath;
+ UINT8 LegacyDriveLetter;
+} UNKNOWN_DEVICE_VENDOR_DEVICE_PATH;
+#define HW_CONTROLLER_DP 0x05
+typedef struct _CONTROLLER_DEVICE_PATH {
+ UINT32 Controller;
+} CONTROLLER_DEVICE_PATH;
+#define ACPI_DEVICE_PATH 0x02
+#define ACPI_DP 0x01
+typedef struct _ACPI_HID_DEVICE_PATH {
+ UINT32 HID;
+ UINT32 UID;
+} ACPI_HID_DEVICE_PATH;
+#define ACPI_EXTENDED_DP 0x02
+typedef struct _ACPI_EXTENDED_HID_DEVICE_PATH {
+ UINT32 HID;
+ UINT32 UID;
+ UINT32 CID;
+} ACPI_EXTENDED_HID_DEVICE_PATH;
+#define ACPI_ADR_DP 0x03
+/* ACPI_ADR_DEVICE_PATH not defined */
+// EISA ID Macro
+// EISA ID Definition 32-bits
+// bits[15:0] - three character compressed ASCII EISA ID.
+// bits[31:16] - binary number
+// Compressed ASCII is 5 bits per character 0b00001 = 'A' 0b11010 = 'Z'
+#define PNP_EISA_ID_CONST 0x41d0
+#define EISA_ID(_Name, _Num) ((UINT32) ((_Name) | (_Num) << 16))
+#define EISA_PNP_ID(_PNPId) (EISA_ID(PNP_EISA_ID_CONST, (_PNPId)))
+#define EFI_PNP_ID(_PNPId) (EISA_ID(PNP_EISA_ID_CONST, (_PNPId)))
+#define PNP_EISA_ID_MASK 0xffff
+#define EISA_ID_TO_NUM(_Id) ((_Id) >> 16)
+#define MESSAGING_DEVICE_PATH 0x03
+#define MSG_ATAPI_DP 0x01
+typedef struct _ATAPI_DEVICE_PATH {
+ UINT8 PrimarySecondary;
+ UINT8 SlaveMaster;
+ UINT16 Lun;
+} ATAPI_DEVICE_PATH;
+#define MSG_SCSI_DP 0x02
+typedef struct _SCSI_DEVICE_PATH {
+ UINT16 Pun;
+ UINT16 Lun;
+} SCSI_DEVICE_PATH;
+#define MSG_FIBRECHANNEL_DP 0x03
+typedef struct _FIBRECHANNEL_DEVICE_PATH {
+ UINT32 Reserved;
+ UINT64 WWN;
+ UINT64 Lun;
+} FIBRECHANNEL_DEVICE_PATH;
+#define MSG_1394_DP 0x04
+typedef struct _F1394_DEVICE_PATH {
+ UINT32 Reserved;
+ UINT64 Guid;
+} F1394_DEVICE_PATH;
+#define MSG_USB_DP 0x05
+typedef struct _USB_DEVICE_PATH {
+ UINT8 ParentPortNumber;
+ UINT8 InterfaceNumber;
+} USB_DEVICE_PATH;
+#define MSG_USB_CLASS_DP 0x0F
+typedef struct _USB_CLASS_DEVICE_PATH {
+ UINT16 VendorId;
+ UINT16 ProductId;
+ UINT8 DeviceClass;
+ UINT8 DeviceSubClass;
+ UINT8 DeviceProtocol;
+} USB_CLASS_DEVICE_PATH;
+#define MSG_I2O_DP 0x06
+typedef struct _I2O_DEVICE_PATH {
+ UINT32 Tid;
+} I2O_DEVICE_PATH;
+#define MSG_MAC_ADDR_DP 0x0b
+typedef struct _MAC_ADDR_DEVICE_PATH {
+ EFI_MAC_ADDRESS MacAddress;
+ UINT8 IfType;
+} MAC_ADDR_DEVICE_PATH;
+#define MSG_IPv4_DP 0x0c
+typedef struct _IPv4_DEVICE_PATH {
+ EFI_IPv4_ADDRESS LocalIpAddress;
+ EFI_IPv4_ADDRESS RemoteIpAddress;
+ UINT16 LocalPort;
+ UINT16 RemotePort;
+ UINT16 Protocol;
+ BOOLEAN StaticIpAddress;
+ EFI_IPv4_ADDRESS GatewayIpAddress;
+ EFI_IPv4_ADDRESS SubnetMask;
+} IPv4_DEVICE_PATH;
+#define MSG_IPv6_DP 0x0d
+typedef struct _IPv6_DEVICE_PATH {
+ EFI_IPv6_ADDRESS LocalIpAddress;
+ EFI_IPv6_ADDRESS RemoteIpAddress;
+ UINT16 LocalPort;
+ UINT16 Protocol;
+} IPv6_DEVICE_PATH;
+#define MSG_INFINIBAND_DP 0x09
+typedef struct _INFINIBAND_DEVICE_PATH {
+ UINT32 ResourceFlags;
+ UINT8 PortGid[16];
+ UINT64 ServiceId;
+ UINT64 TargetPortId;
+ UINT64 DeviceId;
+} INFINIBAND_DEVICE_PATH;
+#define INFINIBAND_RESOURCE_FLAG_IOC_SERVICE 0x01
+#define INFINIBAND_RESOURCE_FLAG_EXTENDED_BOOT_ENVIRONMENT 0x02
+#define INFINIBAND_RESOURCE_FLAG_CONSOLE_PROTOCOL 0x04
+#define INFINIBAND_RESOURCE_FLAG_STORAGE_PROTOCOL 0x08
+#define INFINIBAND_RESOURCE_FLAG_NETWORK_PROTOCOL 0x10
+#define MSG_UART_DP 0x0e
+typedef struct _UART_DEVICE_PATH {
+ UINT32 Reserved;
+ UINT64 BaudRate;
+ UINT8 DataBits;
+ UINT8 Parity;
+ UINT8 StopBits;
+} UART_DEVICE_PATH;
+#define MSG_VENDOR_DP 0x0A
+/* Use VENDOR_DEVICE_PATH struct */
+#define DEVICE_PATH_MESSAGING_PC_ANSI \
+ { 0xe0c14753, 0xf9be, 0x11d2, {0x9a, 0x0c, 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define DEVICE_PATH_MESSAGING_VT_100 \
+ { 0xdfa66065, 0xb419, 0x11d3, {0x9a, 0x2d, 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
+#define DEVICE_PATH_MESSAGING_VT_100_PLUS \
+ { 0x7baec70b, 0x57e0, 0x4c76, {0x8e, 0x87, 0x2f, 0x9e, 0x28, 0x08, 0x83, 0x43} }
+#define DEVICE_PATH_MESSAGING_VT_UTF8 \
+ { 0xad15a0d6, 0x8bec, 0x4acf, {0xa0, 0x73, 0xd0, 0x1d, 0xe7, 0x7e, 0x2d, 0x88} }
+/* Device Logical Unit SubType. */
+#define MSG_DEVICE_LOGICAL_UNIT_DP 0x11
+typedef struct {
+ /* Logical Unit Number for the interface. */
+ UINT8 Lun;
+} DEVICE_LOGICAL_UNIT_DEVICE_PATH;
+#define MSG_SATA_DP 0x12
+typedef struct _SATA_DEVICE_PATH {
+ UINT16 HBAPortNumber;
+ UINT16 PortMultiplierPortNumber;
+ UINT16 Lun;
+} SATA_DEVICE_PATH;
+/* DNS Device Path SubType */
+#define MSG_DNS_DP 0x1F
+typedef struct {
+ /* Indicates the DNS server address is IPv4 or IPv6 address. */
+ UINT8 IsIPv6;
+ /* Instance of the DNS server address. */
+ /* XXX: actually EFI_IP_ADDRESS */
+ EFI_IPv4_ADDRESS DnsServerIp[];
+} DNS_DEVICE_PATH;
+/* Uniform Resource Identifiers (URI) Device Path SubType */
+#define MSG_URI_DP 0x18
+typedef struct {
+ /* Instance of the URI pursuant to RFC 3986. */
+ CHAR8 Uri[];
+} URI_DEVICE_PATH;
+#define MEDIA_DEVICE_PATH 0x04
+#define MEDIA_HARDDRIVE_DP 0x01
+typedef struct _HARDDRIVE_DEVICE_PATH {
+ UINT32 PartitionNumber;
+ UINT64 PartitionStart;
+ UINT64 PartitionSize;
+ UINT8 Signature[16];
+ UINT8 MBRType;
+ UINT8 SignatureType;
+} HARDDRIVE_DEVICE_PATH;
+#define MBR_TYPE_PCAT 0x01
+#define MBR_TYPE_EFI_PARTITION_TABLE_HEADER 0x02
+#define SIGNATURE_TYPE_MBR 0x01
+#define SIGNATURE_TYPE_GUID 0x02
+#define MEDIA_CDROM_DP 0x02
+typedef struct _CDROM_DEVICE_PATH {
+ UINT32 BootEntry;
+} CDROM_DEVICE_PATH;
+#define MEDIA_VENDOR_DP 0x03
+#define MEDIA_FILEPATH_DP 0x04
+typedef struct _FILEPATH_DEVICE_PATH {
+ CHAR16 PathName[1];
+} FILEPATH_DEVICE_PATH;
+#define SIZE_OF_FILEPATH_DEVICE_PATH EFI_FIELD_OFFSET(FILEPATH_DEVICE_PATH,PathName)
+#define MEDIA_PROTOCOL_DP 0x05
+typedef struct _MEDIA_PROTOCOL_DEVICE_PATH {
+ EFI_GUID Protocol;
+} MEDIA_PROTOCOL_DEVICE_PATH;
+#define BBS_DEVICE_PATH 0x05
+#define BBS_BBS_DP 0x01
+typedef struct _BBS_BBS_DEVICE_PATH {
+ UINT16 DeviceType;
+ UINT16 StatusFlag;
+ CHAR8 String[1];
+} BBS_BBS_DEVICE_PATH;
+/* DeviceType definitions - from BBS specification */
+#define BBS_TYPE_FLOPPY 0x01
+#define BBS_TYPE_HARDDRIVE 0x02
+#define BBS_TYPE_CDROM 0x03
+#define BBS_TYPE_PCMCIA 0x04
+#define BBS_TYPE_USB 0x05
+#define BBS_TYPE_EMBEDDED_NETWORK 0x06
+#define BBS_TYPE_DEV 0x80
+#define BBS_TYPE_UNKNOWN 0xFF
+typedef union {
+ EFI_DEVICE_PATH DevPath;
+ PCI_DEVICE_PATH Pci;
+ PCCARD_DEVICE_PATH PcCard;
+ MEMMAP_DEVICE_PATH MemMap;
+ VENDOR_DEVICE_PATH Vendor;
+ UNKNOWN_DEVICE_VENDOR_DEVICE_PATH UnknownVendor;
+ CONTROLLER_DEVICE_PATH Controller;
+ ACPI_HID_DEVICE_PATH Acpi;
+ ATAPI_DEVICE_PATH Atapi;
+ SCSI_DEVICE_PATH Scsi;
+ FIBRECHANNEL_DEVICE_PATH FibreChannel;
+ F1394_DEVICE_PATH F1394;
+ USB_DEVICE_PATH Usb;
+ USB_CLASS_DEVICE_PATH UsbClass;
+ I2O_DEVICE_PATH I2O;
+ MAC_ADDR_DEVICE_PATH MacAddr;
+ IPv4_DEVICE_PATH Ipv4;
+ IPv6_DEVICE_PATH Ipv6;
+ INFINIBAND_DEVICE_PATH InfiniBand;
+ UART_DEVICE_PATH Uart;
+ HARDDRIVE_DEVICE_PATH HardDrive;
+ CDROM_DEVICE_PATH CD;
+ FILEPATH_DEVICE_PATH FilePath;
+ MEDIA_PROTOCOL_DEVICE_PATH MediaProtocol;
+ BBS_BBS_DEVICE_PATH Bbs;
+} EFI_DEV_PATH;
+typedef union {
+ EFI_DEVICE_PATH *DevPath;
+ PCI_DEVICE_PATH *Pci;
+ PCCARD_DEVICE_PATH *PcCard;
+ MEMMAP_DEVICE_PATH *MemMap;
+ VENDOR_DEVICE_PATH *Vendor;
+ UNKNOWN_DEVICE_VENDOR_DEVICE_PATH *UnknownVendor;
+ CONTROLLER_DEVICE_PATH *Controller;
+ ACPI_HID_DEVICE_PATH *Acpi;
+ ACPI_EXTENDED_HID_DEVICE_PATH *ExtendedAcpi;
+ ATAPI_DEVICE_PATH *Atapi;
+ SCSI_DEVICE_PATH *Scsi;
+ FIBRECHANNEL_DEVICE_PATH *FibreChannel;
+ F1394_DEVICE_PATH *F1394;
+ USB_DEVICE_PATH *Usb;
+ USB_CLASS_DEVICE_PATH *UsbClass;
+ I2O_DEVICE_PATH *I2O;
+ MAC_ADDR_DEVICE_PATH *MacAddr;
+ IPv4_DEVICE_PATH *Ipv4;
+ IPv6_DEVICE_PATH *Ipv6;
+ INFINIBAND_DEVICE_PATH *InfiniBand;
+ UART_DEVICE_PATH *Uart;
+ HARDDRIVE_DEVICE_PATH *HardDrive;
+ FILEPATH_DEVICE_PATH *FilePath;
+ MEDIA_PROTOCOL_DEVICE_PATH *MediaProtocol;
+ CDROM_DEVICE_PATH *CD;
+ BBS_BBS_DEVICE_PATH *Bbs;
+} EFI_DEV_PATH_PTR;
+#define EFI_LOADED_IMAGE_DEVICE_PATH_PROTOCOL_GUID \
+ { 0xbc62157e, 0x3e33, 0x4fec, { 0x99, 0x20, 0x2d, 0x3b, 0x36, 0xd7, 0x50, 0xdf } }
+#define EFI_DEVICE_PATH_TO_TEXT_PROTOCOL_GUID \
+ { 0x8b843e20, 0x8132, 0x4852, { 0x90, 0xcc, 0x55, 0x1a, 0x4e, 0x4a, 0x7f, 0x1c } }
+#define EFI_DEVICE_PATH_FROM_TEXT_PROTOCOL_GUID \
+ { 0x05c99a21, 0xc70f, 0x4ad2, { 0x8a, 0x5f, 0x35, 0xdf, 0x33, 0x43, 0xf5, 0x1e } }
+INTERFACE_DECL(_EFI_DEVICE_PATH_PROTOCOL);
+typedef
+CHAR16*
+(EFIAPI *EFI_DEVICE_PATH_TO_TEXT_NODE) (
+ IN struct _EFI_DEVICE_PATH *This,
+ IN BOOLEAN DisplayOnly,
+ IN BOOLEAN AllowShortCuts
+typedef
+CHAR16*
+(EFIAPI *EFI_DEVICE_PATH_TO_TEXT_PATH) (
+typedef struct _EFI_DEVICE_PATH_TO_TEXT_PROTOCOL {
+ EFI_DEVICE_PATH_TO_TEXT_NODE ConvertDeviceNodeToText;
+ EFI_DEVICE_PATH_TO_TEXT_PATH ConvertDevicePathToText;
+} EFI_DEVICE_PATH_TO_TEXT_PROTOCOL;
+typedef
+struct _EFI_DEVICE_PATH*
+(EFIAPI *EFI_DEVICE_PATH_FROM_TEXT_NODE) (
+ IN CONST CHAR16* TextDeviceNode
+typedef
+(EFIAPI *EFI_DEVICE_PATH_FROM_TEXT_PATH) (
+ IN CONST CHAR16* TextDevicePath
+typedef struct _EFI_DEVICE_PATH_FROM_TEXT_PROTOCOL {
+ EFI_DEVICE_PATH_FROM_TEXT_NODE ConvertTextToDeviceNode;
+ EFI_DEVICE_PATH_FROM_TEXT_PATH ConvertTextToDevicePath;
+} EFI_DEVICE_PATH_FROM_TEXT_PROTOCOL;
+#pragma pack()
+#endif
diff --git a/bsps/shared/freebsd/stand/efi/include/efierr.h b/bsps/shared/freebsd/stand/efi/include/efierr.h
new file mode 100644
index 0000000000..a8b6557185
--- /dev/null
+++ b/bsps/shared/freebsd/stand/efi/include/efierr.h
@@ -0,0 +1,68 @@
+/* $FreeBSD$ */
+#ifndef _EFI_ERR_H
+#define _EFI_ERR_H
+This software and associated documentation (if any) is furnished
+under a license and may only be used or copied in accordance
+with the terms of the license. Except as permitted by such
+license, no part of this software or documentation may be
+reproduced, stored in a retrieval system, or transmitted in any
+form or by any means without the express written consent of
+Intel Corporation.
+Module Name:
+ efierr.h
+Abstract:
+ EFI error codes
+Revision History
+#define EFIWARN(a) (a)
+#define EFI_ERROR(a) (((INTN) a) < 0)
+#define EFI_ERROR_CODE(a) (unsigned long)(a & ~EFI_ERROR_MASK)
+#define EFI_SUCCESS 0
+#define EFI_LOAD_ERROR EFIERR(1)
+#define EFI_INVALID_PARAMETER EFIERR(2)
+#define EFI_UNSUPPORTED EFIERR(3)
+#define EFI_BAD_BUFFER_SIZE EFIERR(4)
+#define EFI_BUFFER_TOO_SMALL EFIERR(5)
+#define EFI_NOT_READY EFIERR(6)
+#define EFI_DEVICE_ERROR EFIERR(7)
+#define EFI_WRITE_PROTECTED EFIERR(8)
+#define EFI_OUT_OF_RESOURCES EFIERR(9)
+#define EFI_VOLUME_CORRUPTED EFIERR(10)
+#define EFI_VOLUME_FULL EFIERR(11)
+#define EFI_NO_MEDIA EFIERR(12)
+#define EFI_MEDIA_CHANGED EFIERR(13)
+#define EFI_NOT_FOUND EFIERR(14)
+#define EFI_ACCESS_DENIED EFIERR(15)
+#define EFI_NO_RESPONSE EFIERR(16)
+#define EFI_NO_MAPPING EFIERR(17)
+#define EFI_TIMEOUT EFIERR(18)
+#define EFI_NOT_STARTED EFIERR(19)
+#define EFI_ALREADY_STARTED EFIERR(20)
+#define EFI_ABORTED EFIERR(21)
+#define EFI_ICMP_ERROR EFIERR(22)
+#define EFI_TFTP_ERROR EFIERR(23)
+#define EFI_PROTOCOL_ERROR EFIERR(24)
+#define EFI_WARN_UNKNOWN_GLYPH EFIWARN(1)
+#define EFI_WARN_DELETE_FAILURE EFIWARN(2)
+#define EFI_WARN_WRITE_FAILURE EFIWARN(3)
+#define EFI_WARN_BUFFER_TOO_SMALL EFIWARN(4)
+#endif
diff --git a/bsps/shared/freebsd/stand/efi/include/efigop.h b/bsps/shared/freebsd/stand/efi/include/efigop.h
index 0000000000..104fa6e44b
--- /dev/null
+++ b/bsps/shared/freebsd/stand/efi/include/efigop.h
@@ -0,0 +1,121 @@
+/* $FreeBSD$ */
+Copyright (c) 1999 - 2002 Intel Corporation. All rights reserved
+Intel Corporation.
+Module Name:
+ efigop.h
+Abstract:
+ Info about framebuffers
+Revision History
+#ifndef _EFIGOP_H
+#define _EFIGOP_H
+#define EFI_GRAPHICS_OUTPUT_PROTOCOL_GUID \
+ { 0x9042a9de, 0x23dc, 0x4a38, {0x96, 0xfb, 0x7a, 0xde, 0xd0, 0x80, 0x51, 0x6a} }
+INTERFACE_DECL(_EFI_GRAPHICS_OUTPUT);
+typedef struct {
+ UINT32 RedMask;
+ UINT32 GreenMask;
+ UINT32 BlueMask;
+ UINT32 ReservedMask;
+} EFI_PIXEL_BITMASK;
+typedef enum {
+ PixelRedGreenBlueReserved8BitPerColor,
+ PixelBlueGreenRedReserved8BitPerColor,
+ PixelBitMask,
+ PixelBltOnly,
+ PixelFormatMax,
+} EFI_GRAPHICS_PIXEL_FORMAT;
+typedef struct {
+ UINT32 Version;
+ UINT32 HorizontalResolution;
+ UINT32 VerticalResolution;
+ EFI_GRAPHICS_PIXEL_FORMAT PixelFormat;
+ EFI_PIXEL_BITMASK PixelInformation;
+ UINT32 PixelsPerScanLine;
+} EFI_GRAPHICS_OUTPUT_MODE_INFORMATION;
+typedef struct {
+ UINT32 MaxMode;
+ UINT32 Mode;
+ EFI_GRAPHICS_OUTPUT_MODE_INFORMATION *Info;
+ UINTN SizeOfInfo;
+ EFI_PHYSICAL_ADDRESS FrameBufferBase;
+ UINTN FrameBufferSize;
+} EFI_GRAPHICS_OUTPUT_PROTOCOL_MODE;
+typedef
+EFI_STATUS
+(EFIAPI *EFI_GRAPHICS_OUTPUT_PROTOCOL_QUERY_MODE) (
+ IN struct _EFI_GRAPHICS_OUTPUT *This,
+ IN UINT32 ModeNumber,
+ OUT UINTN *SizeOfInfo,
+ OUT EFI_GRAPHICS_OUTPUT_MODE_INFORMATION **Info
+typedef
+EFI_STATUS
+(EFIAPI *EFI_GRAPHICS_OUTPUT_PROTOCOL_SET_MODE) (
+typedef struct {
+ UINT8 Blue;
+ UINT8 Green;
+ UINT8 Red;
+ UINT8 Reserved;
+} EFI_GRAPHICS_OUTPUT_BLT_PIXEL;
+typedef enum {
+ EfiBltVideoFill,
+ EfiBltVideoToBltBuffer,
+ EfiBltBufferToVideo,
+ EfiBltVideoToVideo,
+ EfiGraphcisOutputBltOperationMax,
+} EFI_GRAPHICS_OUTPUT_BLT_OPERATION;
+typedef
+EFI_STATUS
+(EFIAPI *EFI_GRAPHICS_OUTPUT_PROTOCOL_BLT) (
+ IN OUT EFI_GRAPHICS_OUTPUT_BLT_PIXEL *BltBuffer,
+ IN EFI_GRAPHICS_OUTPUT_BLT_OPERATION BltOperation,
+ IN UINTN SourceX,
+ IN UINTN SourceY,
+ IN UINTN DestinationX,
+ IN UINTN DestinationY,
+ IN UINTN Width,
+ IN UINTN Height,
+ IN UINTN Delta
+typedef struct _EFI_GRAPHICS_OUTPUT {
+ EFI_GRAPHICS_OUTPUT_PROTOCOL_QUERY_MODE QueryMode;
+ EFI_GRAPHICS_OUTPUT_PROTOCOL_SET_MODE SetMode;
+ EFI_GRAPHICS_OUTPUT_PROTOCOL_BLT Blt;
+ EFI_GRAPHICS_OUTPUT_PROTOCOL_MODE *Mode;
+} EFI_GRAPHICS_OUTPUT;
+#endif /* _EFIGOP_H */
diff --git a/bsps/shared/freebsd/stand/efi/include/efilib.h b/bsps/shared/freebsd/stand/efi/include/efilib.h
index 0000000000..d31212ff9a
--- /dev/null
+++ b/bsps/shared/freebsd/stand/efi/include/efilib.h
@@ -0,0 +1,172 @@
+ * Copyright (c) 2000 Doug Rabson
+ * Copyright (c) 2006 Marcel Moolenaar
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _LOADER_EFILIB_H
+#define _LOADER_EFILIB_H
+#ifndef __rtems__
+#include <stand.h>
+#endif /* __rtems__ */
+#include <stdbool.h>
+#include <sys/queue.h>
+#ifdef __rtems__
+#include <errno.h>
+#include <stdlib.h>
+extern EFI_HANDLE IH;
+extern EFI_SYSTEM_TABLE *ST;
+extern EFI_BOOT_SERVICES *BS;
+extern EFI_RUNTIME_SERVICES *RS;
+#ifndef __rtems__
+extern struct devsw efipart_fddev;
+extern struct devsw efipart_cddev;
+extern struct devsw efipart_hddev;
+extern struct devsw efihttp_dev;
+extern struct devsw efinet_dev;
+extern struct netif_driver efinetif;
+/* EFI block device data, included here to help efi_zfs_probe() */
+typedef STAILQ_HEAD(pdinfo_list, pdinfo) pdinfo_list_t;
+typedef struct pdinfo
+ STAILQ_ENTRY(pdinfo) pd_link; /* link in device list */
+ pdinfo_list_t pd_part; /* list of partitions */
+ EFI_HANDLE pd_handle;
+ EFI_HANDLE pd_alias;
+ EFI_DEVICE_PATH *pd_devpath;
+ EFI_BLOCK_IO *pd_blkio;
+ uint32_t pd_unit; /* unit number */
+ uint32_t pd_open; /* reference counter */
+ void *pd_bcache; /* buffer cache data */
+ struct pdinfo *pd_parent; /* Linked items (eg partitions) */
+ struct devsw *pd_devsw; /* Back pointer to devsw */
+} pdinfo_t;
+pdinfo_list_t *efiblk_get_pdinfo_list(struct devsw *dev);
+pdinfo_t *efiblk_get_pdinfo(struct devdesc *dev);
+pdinfo_t *efiblk_get_pdinfo_by_handle(EFI_HANDLE h);
+pdinfo_t *efiblk_get_pdinfo_by_device_path(EFI_DEVICE_PATH *path);
+/* libefi.c */
+void *efi_get_table(EFI_GUID *tbl);
+EFI_STATUS OpenProtocolByHandle(EFI_HANDLE, EFI_GUID *, void **);
+static inline EFI_STATUS
+efi_exit_boot_services(UINTN key)
+ EFI_STATUS status;
+ status = BS->ExitBootServices(IH, key);
+ if (!EFI_ERROR(status))
+ boot_services_active = false;
+ return (status);
+int efi_getdev(void **vdev, const char *devspec, const char **path);
+int efi_register_handles(struct devsw *, EFI_HANDLE *, EFI_HANDLE *, int);
+EFI_HANDLE efi_find_handle(struct devsw *, int);
+int efi_handle_lookup(EFI_HANDLE, struct devsw **, int *, uint64_t *);
+int efi_handle_update_dev(EFI_HANDLE, struct devsw *, int, uint64_t);
+EFI_DEVICE_PATH *efi_lookup_image_devpath(EFI_HANDLE);
+EFI_DEVICE_PATH *efi_lookup_devpath(EFI_HANDLE);
+void efi_close_devpath(EFI_HANDLE);
+EFI_HANDLE efi_devpath_handle(EFI_DEVICE_PATH *);
+EFI_DEVICE_PATH *efi_devpath_last_node(EFI_DEVICE_PATH *);
+EFI_DEVICE_PATH *efi_devpath_trim(EFI_DEVICE_PATH *);
+bool efi_devpath_match(EFI_DEVICE_PATH *, EFI_DEVICE_PATH *);
+bool efi_devpath_match_node(EFI_DEVICE_PATH *, EFI_DEVICE_PATH *);
+bool efi_devpath_is_prefix(EFI_DEVICE_PATH *, EFI_DEVICE_PATH *);
+CHAR16 *efi_devpath_name(EFI_DEVICE_PATH *);
+void efi_free_devpath_name(CHAR16 *);
+bool efi_devpath_same_disk(EFI_DEVICE_PATH *, EFI_DEVICE_PATH *);
+EFI_DEVICE_PATH *efi_devpath_to_media_path(EFI_DEVICE_PATH *);
+UINTN efi_devpath_length(EFI_DEVICE_PATH *);
+EFI_DEVICE_PATH *efi_name_to_devpath(const char *path);
+EFI_DEVICE_PATH *efi_name_to_devpath16(CHAR16 *path);
+void efi_devpath_free(EFI_DEVICE_PATH *dp);
+EFI_HANDLE efi_devpath_to_handle(EFI_DEVICE_PATH *path, EFI_HANDLE *handles, unsigned nhandles);
+int efi_status_to_errno(EFI_STATUS);
+EFI_STATUS errno_to_efi_status(int errno);
+void efi_time_init(void);
+void efi_time_fini(void);
+int parse_uefi_con_out(void);
+EFI_STATUS efi_main(EFI_HANDLE Ximage, EFI_SYSTEM_TABLE* Xsystab);
+EFI_STATUS main(int argc, CHAR16 *argv[]);
+void efi_exit(EFI_STATUS status) __dead2;
+/* EFI environment initialization. */
+void efi_init_environment(void);
+/* EFI Memory type strings. */
+const char *efi_memory_type(EFI_MEMORY_TYPE);
+/* CHAR16 utility functions. */
+int wcscmp(CHAR16 *, CHAR16 *);
+void cpy8to16(const char *, CHAR16 *, size_t);
+void cpy16to8(const CHAR16 *, char *, size_t);
+#ifndef __rtems__
+ * Routines for interacting with EFI's env vars in a more unix-like
+ * way than the standard APIs. In addition, convenience routines for
+ * the loader setting / getting FreeBSD specific variables.
+EFI_STATUS efi_delenv(EFI_GUID *guid, const char *varname);
+EFI_STATUS efi_freebsd_delenv(const char *varname);
+EFI_STATUS efi_freebsd_getenv(const char *v, void *data, __size_t *len);
+EFI_STATUS efi_getenv(EFI_GUID *g, const char *v, void *data, __size_t *len);
+EFI_STATUS efi_global_getenv(const char *v, void *data, __size_t *len);
+EFI_STATUS efi_setenv(EFI_GUID *guid, const char *varname, UINT32 attr, void *data, __size_t len);
+EFI_STATUS efi_setenv_freebsd_wcs(const char *varname, CHAR16 *valstr);
+/* guids and names */
+bool efi_guid_to_str(const EFI_GUID *, char **);
+bool efi_str_to_guid(const char *, EFI_GUID *);
+bool efi_name_to_guid(const char *, EFI_GUID *);
+bool efi_guid_to_name(EFI_GUID *, char **);
+/* efipart.c */
+int efipart_inithandles(void);
+#endif /* _LOADER_EFILIB_H */
diff --git a/bsps/shared/freebsd/stand/efi/libefi/libefi.c b/bsps/shared/freebsd/stand/efi/libefi/libefi.c
index 0000000000..f63e146f2e
--- /dev/null
+++ b/bsps/shared/freebsd/stand/efi/libefi/libefi.c
@@ -0,0 +1,63 @@
+ * are met:
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <efi.h>
+#ifndef __rtems__
+#include <eficonsctl.h>
+#include <efilib.h>
+#include <stand.h>
+EFI_HANDLE IH;
+EFI_SYSTEM_TABLE *ST;
+EFI_BOOT_SERVICES *BS;
+EFI_RUNTIME_SERVICES *RS;
+#ifndef __rtems__
+void *
+efi_get_table(EFI_GUID *tbl)
+ EFI_GUID *id;
+ int i;
+ for (i = 0; i < ST->NumberOfTableEntries; i++) {
+ id = &ST->ConfigurationTable[i].VendorGuid;
+ if (!memcmp(id, tbl, sizeof(EFI_GUID)))
+ return (ST->ConfigurationTable[i].VendorTable);
+ return (NULL);
+EFI_STATUS
+OpenProtocolByHandle(EFI_HANDLE handle, EFI_GUID *protocol, void **interface)
+ return (BS->OpenProtocol(handle, protocol, interface, IH, NULL,
+ EFI_OPEN_PROTOCOL_BY_HANDLE_PROTOCOL));
+#endif
diff --git a/bsps/shared/freebsd/stand/efi/libefi/wchar.c b/bsps/shared/freebsd/stand/efi/libefi/wchar.c
index 0000000000..d0c6535143
--- /dev/null
+++ b/bsps/shared/freebsd/stand/efi/libefi/wchar.c
@@ -0,0 +1,73 @@
+ * Copyright 2016 Netflix, Inc.
+ * are met:
+ * SUCH DAMAGE.
+#include <efi.h>
+ * CHAR16 related functions moved from loader.
+ * Perhaps we should move those to libsa afterall, but they are
+ * needed only by UEFI.
+int
+wcscmp(CHAR16 *a, CHAR16 *b)
+ while (*a && *b && *a == *b) {
+ a++;
+ b++;
+ return *a - *b;
+ * cpy8to16 copies a traditional C string into a CHAR16 string and
+ * 0 terminates it. len is the size of *dst in bytes.
+void
+cpy8to16(const char *src, CHAR16 *dst, size_t len)
+ len <<= 1; /* Assume CHAR16 is 2 bytes */
+ while (len > 0 && *src) {
+ *dst++ = *src++;
+ len--;
+ *dst++ = (CHAR16)0;
+void
+cpy16to8(const CHAR16 *src, char *dst, size_t len)
+ size_t i;
+ for (i = 0; i < len && src[i]; i++)
+ dst[i] = (char)src[i];
+ if (i < len)
+ dst[i] = '\0';
2.25.1
