[rtems-net-legacy PATCH 2/4] waf: Build libs before tests
chrisj at rtems.org chrisj at rtems.org
Sat Apr 22 23:02:28 UTC 2023
The built libs are in lib and use when linking to get a working
order. Make sure they are built before building an tests.
 netlegacy.py | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/netlegacy.py b/netlegacy.py
index bf816f4..8533f4c 100644
--- a/netlegacy.py
+++ b/netlegacy.py
@@ -216,3 +216,5 @@ def build(bld):
     bld.install_as(
         os.path.join(bld.env.PREFIX, arch_inc_path, 'rtems',
                      'rtems-net-legacy.h'), 'include/rtems/rtems-net-legacy.h')
+    bld.add_group()
2.37.1
