[rtems-net-legacy PATCH 3/4] net: Update sysctl to use the latest libbsd linker set
    chrisj at rtems.org
    chrisj at rtems.org
    Sat Apr 22 23:02:29 UTC 2023
- Update linker_set.h to the latest from libbsd so the linker
  scripts work.
- Add a sysctl command to check on sysctls
- Add set defines to the networking stack
 netsources.py                |    1 +
 rtems/rtems_bsdnet.h         |    1 +
 rtems/rtems_glue.c           |    7 +-
 rtems/rtems_showsysctl.c     | 1340 ++++++++++++++++++++++++++++++++++
 sys/linker_set.h             |  131 +++-
 testsuites/telnetd02/init.c  |    4 +
 testsuites/telnetd02/wscript |    1 +
 7 files changed, 1455 insertions(+), 30 deletions(-)
 create mode 100755 rtems/rtems_showsysctl.c
diff --git a/netsources.py b/netsources.py
index 54dbbf1..550c741 100644
--- a/netsources.py
+++ b/netsources.py
@@ -46,6 +46,7 @@ class source:
         'rtems/rtems_showipstat.c',
         'rtems/rtems_showmbuf.c',
         'rtems/rtems_showroute.c',
+        'rtems/rtems_showsysctl.c',
         'rtems/rtems_showtcpstat.c',
         'rtems/rtems_showudpstat.c',
         'rtems/rtems_socketpair.c',
diff --git a/rtems/rtems_bsdnet.h b/rtems/rtems_bsdnet.h
index 4607f42..9bd3dee 100644
--- a/rtems/rtems_bsdnet.h
+++ b/rtems/rtems_bsdnet.h
@@ -48,6 +48,7 @@ void rtems_bsdnet_show_ip_stats (void);
 void rtems_bsdnet_show_icmp_stats (void);
 void rtems_bsdnet_show_udp_stats (void);
 void rtems_bsdnet_show_tcp_stats (void);
+int rtems_shell_main_sysctl(int argc, char *argv[]);
  * Network configuration
diff --git a/rtems/rtems_glue.c b/rtems/rtems_glue.c
index ee6c8f5..e05a2c4 100644
--- a/rtems/rtems_glue.c
+++ b/rtems/rtems_glue.c
@@ -14,6 +14,7 @@
 #include <rtems/libio.h>
 #include <rtems/error.h>
+#include <sys/linker_set.h>
 #include <rtems/thread.h>
 #include <sys/types.h>
@@ -56,6 +57,11 @@ static size_t          networkDaemonCpusetSize = 0;
 #endif
 static void networkDaemon (void *task_argument);
+ * SYSCTL data
+RTEMS_BSD_DEFINE_SET(sysctl_set, struct sysctl_oid *);
  * Network timing
@@ -1261,4 +1267,3 @@ m_clalloc(int ncl, int nowait)
 	return 1;
diff --git a/rtems/rtems_showsysctl.c b/rtems/rtems_showsysctl.c
new file mode 100755
index 0000000..cf3d6e2
--- /dev/null
+++ b/rtems/rtems_showsysctl.c
@@ -0,0 +1,1340 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1993
+ *	The Regents of the University of California.  All rights reserved.
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#ifndef lint
+static const char copyright[] =
+"@(#) Copyright (c) 1993\n\
+	The Regents of the University of California.  All rights reserved.\n";
+#endif /* not lint */
+#ifndef lint
+#if 0
+static char sccsid[] = "@(#)from: sysctl.c	8.1 (Berkeley) 6/6/93";
+#endif
+static const char rcsid[] =
+  "$FreeBSD$";
+#ifdef __rtems__
+#define __need_getopt_newlib
+#include <getopt.h>
+#include <rtems/shell.h>
+#include <setjmp.h>
+#define CHAR_BIT 8
+#endif /* __rtems__ */
+#include <sys/param.h>
+#include <sys/time.h>
+#include <sys/stat.h>
+#include <sys/sysctl.h>
+#ifdef __amd64__
+#include <sys/efi.h>
+#include <machine/metadata.h>
+#endif
+#if defined(__amd64__) || defined(__i386__)
+#ifndef __rtems__
+#include <machine/pc/bios.h>
+#endif
+#include <assert.h>
+#include <ctype.h>
+#ifndef __rtems__
+#include <err.h>
+#include <errno.h>
+#include <inttypes.h>
+#include <locale.h>
+#include <stdbool.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#ifndef __rtems__
+#include <sysexits.h>
+#include <unistd.h>
+#ifndef __rtems__
+static const char *conffile;
+static int	aflag, bflag, Bflag, dflag, eflag, hflag, iflag;
+static int	Nflag, nflag, oflag, qflag, tflag, Tflag, Wflag, xflag;
+static int	oidfmt(int *, int, char *, u_int *);
+static int	parsefile(const char *);
+static int	parse(const char *, int);
+static int	show_var(int *, int);
+static int	sysctl_all(int *oid, int len);
+static int	name2oid(const char *, int *);
+static int	strIKtoi(const char *, char **, const char *);
+static const int ctl_sign[CTLTYPE+1] = {
+	[CTLTYPE_INT] = 1,
+	[CTLTYPE_LONG] = 1,
+#ifndef __rtems__
+	[CTLTYPE_S8] = 1,
+	[CTLTYPE_S16] = 1,
+	[CTLTYPE_S32] = 1,
+	[CTLTYPE_S64] = 1,
+static int ctl_size[CTLTYPE+1] = {
+	[CTLTYPE_INT] = sizeof(int),
+	[CTLTYPE_UINT] = sizeof(u_int),
+	[CTLTYPE_LONG] = sizeof(long),
+	[CTLTYPE_ULONG] = sizeof(u_long),
+#ifndef __rtems__
+	[CTLTYPE_S8] = sizeof(int8_t),
+	[CTLTYPE_S16] = sizeof(int16_t),
+	[CTLTYPE_S32] = sizeof(int32_t),
+	[CTLTYPE_S64] = sizeof(int64_t),
+	[CTLTYPE_U8] = sizeof(uint8_t),
+	[CTLTYPE_U16] = sizeof(uint16_t),
+	[CTLTYPE_U32] = sizeof(uint32_t),
+	[CTLTYPE_U64] = sizeof(uint64_t),
+static const char *ctl_typename[CTLTYPE+1] = {
+	[CTLTYPE_INT] = "integer",
+	[CTLTYPE_UINT] = "unsigned integer",
+	[CTLTYPE_LONG] = "long integer",
+	[CTLTYPE_ULONG] = "unsigned long",
+#ifndef __rtems__
+	[CTLTYPE_U8] = "uint8_t",
+	[CTLTYPE_U16] = "uint16_t",
+	[CTLTYPE_U32] = "uint32_t",
+	[CTLTYPE_U64] = "uint64_t",
+	[CTLTYPE_S8] = "int8_t",
+	[CTLTYPE_S16] = "int16_t",
+	[CTLTYPE_S32] = "int32_t",
+	[CTLTYPE_S64] = "int64_t",
+	[CTLTYPE_NODE] = "node",
+	[CTLTYPE_STRING] = "string",
+	[CTLTYPE_OPAQUE] = "opaque",
+#ifdef __rtems__
+static int main(int argc, char *argv[]);
+typedef struct {
+	const char *conffile;
+	int	aflag, bflag, Bflag, dflag, eflag, hflag, iflag;
+	int	Nflag, nflag, oflag, qflag, tflag, Tflag, Wflag, xflag;
+	int exit_code;
+	jmp_buf exit_jmp;
+} rtems_shell_sysctl_globals;
+void
+rtems_shell_sysctl_exit (rtems_shell_sysctl_globals* globals, int code)
+	longjmp (globals->exit_jmp, 1);
+/* only run this command one at a time */
+static rtems_shell_sysctl_globals  _globals;
+#define conffile _globals.conffile
+#define aflag _globals.aflag
+#define bflag _globals.bflag
+#define Bflag _globals.Bflag
+#define dflag _globals.dflag
+#define eflag _globals.eflag
+#define hflag _globals.hflag
+#define iflag _globals.iflag
+#define Nflag _globals.Nflag
+#define nflag _globals.nflag
+#define oflag _globals.oflag
+#define qflag _globals.qflag
+#define tflag _globals.tflag
+#define Tflag _globals.Tflag
+#define Wflag _globals.Wflag
+#define xflag _globals.xflag
+#define err(e, s, ...) \
+ do { printf("error: %d " #s "\n", e,  ## __VA_ARGS__); exit(e); } while (0)
+#define warn(s, ...) printf("warning: " #s "\n",  ## __VA_ARGS__); return
+#define warnx(s, ...) printf("warning: " #s "\n",  ## __VA_ARGS__); return
+#define EX_NOINPUT 1
+int
+rtems_shell_main_sysctl(int argc, char *argv[])
+	int ec = 1;
+	memset (&_globals, 0, sizeof (_globals));
+	_globals.exit_code = 1;
+	if (setjmp (_globals.exit_jmp) == 0)
+		ec = main(argc, argv);
+	else
+		ec = _globals.exit_code;
+	fflush(stdout);
+	return ec;
+#undef exit
+#define exit(rc) rtems_shell_sysctl_exit(&_globals, rc)
+static void
+usage(void)
+	(void)fprintf(stderr, "%s\n%s\n",
+	    "usage: sysctl [-bdehiNnoqTtWx] [ -B <bufsize> ] [-f filename] name[=value] ...",
+	    "       sysctl [-bdehNnoqTtWx] [ -B <bufsize> ] -a");
+	exit(1);
+int
+main(int argc, char **argv)
+	int ch;
+	int warncount = 0;
+#ifdef __rtems__
+	struct getopt_data getopt_data;
+	memset(&getopt_data, 0, sizeof(getopt_data));
+#define optind getopt_data.optind
+#define optarg getopt_data.optarg
+#define opterr getopt_data.opterr
+#define optopt getopt_data.optopt
+#define getopt(argc, argv, opt) getopt_r(argc, argv, "+" opt, &getopt_data)
+	setlocale(LC_NUMERIC, "");
+	setbuf(stdout,0);
+	setbuf(stderr,0);
+	while ((ch = getopt(argc, argv, "AabB:def:hiNnoqtTwWxX")) != -1) {
+		switch (ch) {
+		case 'A':
+			/* compatibility */
+			aflag = oflag = 1;
+			break;
+		case 'a':
+			aflag = 1;
+			break;
+		case 'b':
+			bflag = 1;
+			break;
+		case 'B':
+			Bflag = strtol(optarg, NULL, 0);
+			break;
+		case 'd':
+			dflag = 1;
+			break;
+		case 'e':
+			eflag = 1;
+			break;
+		case 'f':
+			conffile = optarg;
+			break;
+		case 'h':
+			hflag = 1;
+			break;
+		case 'i':
+			iflag = 1;
+			break;
+		case 'N':
+			Nflag = 1;
+			break;
+		case 'n':
+			nflag = 1;
+			break;
+		case 'o':
+			oflag = 1;
+			break;
+		case 'q':
+			qflag = 1;
+			break;
+		case 't':
+			tflag = 1;
+			break;
+		case 'T':
+			Tflag = 1;
+			break;
+		case 'w':
+			/* ignored */
+			break;
+		case 'W':
+			Wflag = 1;
+			break;
+		case 'X':
+			aflag = xflag = 1;
+			break;
+		case 'x':
+			xflag = 1;
+			break;
+		default:
+			usage();
+	argc -= optind;
+	argv += optind;
+	if (Nflag && nflag)
+		usage();
+	if (aflag && argc == 0)
+		exit(sysctl_all(0, 0));
+	if (argc == 0 && conffile == NULL)
+		usage();
+	warncount = 0;
+	if (conffile != NULL)
+		warncount += parsefile(conffile);
+	while (argc-- > 0)
+		warncount += parse(*argv++, 0);
+	return (warncount);
+ * Parse a single numeric value, append it to 'newbuf', and update
+ * 'newsize'.  Returns true if the value was parsed and false if the
+ * value was invalid.  Non-numeric types (strings) are handled
+ * directly in parse().
+static bool
+parse_numeric(const char *newvalstr, const char *fmt, u_int kind,
+    void **newbufp, size_t *newsizep)
+	void *newbuf;
+	const void *newval;
+	int8_t i8val;
+	uint8_t u8val;
+	int16_t i16val;
+	uint16_t u16val;
+	int32_t i32val;
+	uint32_t u32val;
+	int intval;
+	unsigned int uintval;
+	long longval;
+	unsigned long ulongval;
+	int64_t i64val;
+	uint64_t u64val;
+	size_t valsize;
+	char *endptr = NULL;
+	errno = 0;
+	switch (kind & CTLTYPE) {
+	case CTLTYPE_INT:
+		if (strncmp(fmt, "IK", 2) == 0)
+			intval = strIKtoi(newvalstr, &endptr, fmt);
+		else
+			intval = (int)strtol(newvalstr, &endptr, 0);
+		newval = &intval;
+		valsize = sizeof(intval);
+		break;
+	case CTLTYPE_UINT:
+		uintval = (int) strtoul(newvalstr, &endptr, 0);
+		newval = &uintval;
+		valsize = sizeof(uintval);
+		break;
+	case CTLTYPE_LONG:
+		longval = strtol(newvalstr, &endptr, 0);
+		newval = &longval;
+		valsize = sizeof(longval);
+		break;
+	case CTLTYPE_ULONG:
+		ulongval = strtoul(newvalstr, &endptr, 0);
+		newval = &ulongval;
+		valsize = sizeof(ulongval);
+		break;
+#ifndef __rtems__
+	case CTLTYPE_S8:
+		i8val = (int8_t)strtol(newvalstr, &endptr, 0);
+		newval = &i8val;
+		valsize = sizeof(i8val);
+		break;
+	case CTLTYPE_S16:
+		i16val = (int16_t)strtol(newvalstr, &endptr, 0);
+		newval = &i16val;
+		valsize = sizeof(i16val);
+		break;
+	case CTLTYPE_S32:
+		i32val = (int32_t)strtol(newvalstr, &endptr, 0);
+		newval = &i32val;
+		valsize = sizeof(i32val);
+		break;
+	case CTLTYPE_S64:
+		i64val = strtoimax(newvalstr, &endptr, 0);
+		newval = &i64val;
+		valsize = sizeof(i64val);
+		break;
+	case CTLTYPE_U8:
+		u8val = (uint8_t)strtoul(newvalstr, &endptr, 0);
+		newval = &u8val;
+		valsize = sizeof(u8val);
+		break;
+	case CTLTYPE_U16:
+		u16val = (uint16_t)strtoul(newvalstr, &endptr, 0);
+		newval = &u16val;
+		valsize = sizeof(u16val);
+		break;
+	case CTLTYPE_U32:
+		u32val = (uint32_t)strtoul(newvalstr, &endptr, 0);
+		newval = &u32val;
+		valsize = sizeof(u32val);
+		break;
+	case CTLTYPE_U64:
+		u64val = strtoumax(newvalstr, &endptr, 0);
+		newval = &u64val;
+		valsize = sizeof(u64val);
+		break;
+	default:
+		/* NOTREACHED */
+		abort();
+	if (errno != 0 || endptr == newvalstr ||
+	    (endptr != NULL && *endptr != '\0'))
+		return (false);
+	newbuf = realloc(*newbufp, *newsizep + valsize);
+	if (newbuf == NULL)
+		err(1, "out of memory");
+	memcpy((char *)newbuf + *newsizep, newval, valsize);
+	*newbufp = newbuf;
+	*newsizep += valsize;
+	return (true);
+ * Parse a name into a MIB entry.
+ * Lookup and print out the MIB entry if it exists.
+ * Set a new value if requested.
+static int
+parse(const char *string, int lineno)
+	int len, i, j;
+	char *newvalstr = NULL;
+	void *newbuf;
+	size_t newsize = Bflag;
+	int mib[CTL_MAXNAME];
+	char *cp, *bufp, buf[BUFSIZ], fmt[BUFSIZ], line[BUFSIZ];
+	u_int kind;
+	if (lineno)
+		snprintf(line, sizeof(line), " at line %d", lineno);
+	else
+		line[0] = '\0';
+	cp = buf;
+	if (snprintf(buf, BUFSIZ, "%s", string) >= BUFSIZ) {
+		warnx("oid too long: '%s'%s", string, line);
+		return (1);
+	bufp = strsep(&cp, "=:");
+	if (cp != NULL) {
+		/* Tflag just lists tunables, do not allow assignment */
+		if (Tflag || Wflag) {
+			warnx("Can't set variables when using -T or -W");
+			usage();
+		while (isspace(*cp))
+			cp++;
+		/* Strip a pair of " or ' if any. */
+		switch (*cp) {
+		case '\"':
+		case '\'':
+			if (cp[strlen(cp) - 1] == *cp)
+				cp[strlen(cp) - 1] = '\0';
+			cp++;
+		newvalstr = cp;
+		newsize = strlen(cp);
+	/* Trim spaces */
+	cp = bufp + strlen(bufp) - 1;
+	while (cp >= bufp && isspace((int)*cp)) {
+		*cp = '\0';
+		cp--;
+	len = name2oid(bufp, mib);
+	if (len < 0) {
+		if (iflag)
+			return (0);
+		if (qflag)
+			return (1);
+		else {
+			if (errno == ENOENT) {
+				warnx("unknown oid '%s'%s", bufp, line);
+			} else {
+				warn("unknown oid '%s'%s", bufp, line);
+			return (1);
+	if (oidfmt(mib, len, fmt, &kind)) {
+		warn("couldn't find format of oid '%s'%s", bufp, line);
+		if (iflag)
+			return (1);
+		else
+			exit(1);
+	if (newvalstr == NULL || dflag) {
+		if ((kind & CTLTYPE) == CTLTYPE_NODE) {
+			if (dflag) {
+				i = show_var(mib, len);
+				if (!i && !bflag)
+					putchar('\n');
+			sysctl_all(mib, len);
+		} else {
+			if (!i && !bflag)
+				putchar('\n');
+	} else {
+			warnx("oid '%s' isn't a leaf node%s", bufp, line);
+			return (1);
+		if (!(kind & CTLFLAG_WR)) {
+			if (kind & CTLFLAG_TUN) {
+				warnx("oid '%s' is a read only tunable%s", bufp, line);
+				warnx("Tunable values are set in /boot/loader.conf");
+			} else
+				warnx("oid '%s' is read only%s", bufp, line);
+			return (1);
+		case CTLTYPE_INT:
+#ifndef __rtems__
+		case CTLTYPE_S8:
+		case CTLTYPE_S16:
+		case CTLTYPE_S32:
+		case CTLTYPE_S64:
+		case CTLTYPE_U8:
+		case CTLTYPE_U16:
+		case CTLTYPE_U32:
+		case CTLTYPE_U64:
+			if (strlen(newvalstr) == 0) {
+				warnx("empty numeric value");
+				return (1);
+			/* FALLTHROUGH */
+		case CTLTYPE_STRING:
+			break;
+		default:
+			warnx("oid '%s' is type %d,"
+				" cannot set that%s", bufp,
+				kind & CTLTYPE, line);
+			return (1);
+		newbuf = NULL;
+			newval = newvalstr;
+			break;
+		default:
+			newsize = 0;
+			while ((cp = strsep(&newvalstr, " ,")) != NULL) {
+				if (*cp == '\0')
+					continue;
+				if (!parse_numeric(cp, fmt, kind, &newbuf,
+				    &newsize)) {
+					warnx("invalid %s '%s'%s",
+					    ctl_typename[kind & CTLTYPE],
+					    cp, line);
+					free(newbuf);
+					return (1);
+			newval = newbuf;
+			break;
+		if (sysctl(mib, len, 0, 0, newval, newsize) == -1) {
+			free(newbuf);
+			if (!i && !bflag)
+				putchar('\n');
+			switch (errno) {
+			case EOPNOTSUPP:
+				warnx("%s: value is not available%s",
+					string, line);
+				return (1);
+			case ENOTDIR:
+				warnx("%s: specification is incomplete%s",
+					string, line);
+				return (1);
+			case ENOMEM:
+				warnx("%s: type is unknown to this program%s",
+					string, line);
+				return (1);
+			default:
+				warn("%s%s", string, line);
+				return (1);
+		free(newbuf);
+		if (!bflag)
+			printf(" -> ");
+		i = nflag;
+		nflag = 1;
+		j = show_var(mib, len);
+		if (!j && !bflag)
+			putchar('\n');
+		nflag = i;
+	return (0);
+static int
+parsefile(const char *filename)
+	FILE *file;
+	char line[BUFSIZ], *p, *pq, *pdq;
+	int warncount = 0, lineno = 0;
+	file = fopen(filename, "r");
+	if (file == NULL)
+		err(EX_NOINPUT, "%s", filename);
+	while (fgets(line, sizeof(line), file) != NULL) {
+		lineno++;
+		p = line;
+		pq = strchr(line, '\'');
+		pdq = strchr(line, '\"');
+		/* Replace the first # with \0. */
+		while((p = strchr(p, '#')) != NULL) {
+			if (pq != NULL && p > pq) {
+				if ((p = strchr(pq+1, '\'')) != NULL)
+					*(++p) = '\0';
+				break;
+			} else if (pdq != NULL && p > pdq) {
+				if ((p = strchr(pdq+1, '\"')) != NULL)
+					*(++p) = '\0';
+				break;
+			} else if (p == line || *(p-1) != '\\') {
+				*p = '\0';
+				break;
+			p++;
+		/* Trim spaces */
+		p = line + strlen(line) - 1;
+		while (p >= line && isspace((int)*p)) {
+			*p = '\0';
+			p--;
+		p = line;
+		while (isspace((int)*p))
+			p++;
+		if (*p == '\0')
+			continue;
+		else
+			warncount += parse(p, lineno);
+	fclose(file);
+/* These functions will dump out various interesting structures. */
+#ifndef __rtems__
+static int
+S_clockinfo(size_t l2, void *p)
+	struct clockinfo *ci = (struct clockinfo*)p;
+	if (l2 != sizeof(*ci)) {
+		warnx("S_clockinfo %zu != %zu", l2, sizeof(*ci));
+		return (1);
+	printf(hflag ? "{ hz = %'d, tick = %'d, profhz = %'d, stathz = %'d }" :
+		"{ hz = %d, tick = %d, profhz = %d, stathz = %d }",
+		ci->hz, ci->tick, ci->profhz, ci->stathz);
+	return (0);
+static int
+S_loadavg(size_t l2, void *p)
+#ifndef __rtems__
+	struct loadavg *tv = (struct loadavg*)p;
+	if (l2 != sizeof(*tv)) {
+		warnx("S_loadavg %zu != %zu", l2, sizeof(*tv));
+		return (1);
+	printf(hflag ? "{ %'.2f %'.2f %'.2f }" : "{ %.2f %.2f %.2f }",
+		(double)tv->ldavg[0]/(double)tv->fscale,
+		(double)tv->ldavg[1]/(double)tv->fscale,
+		(double)tv->ldavg[2]/(double)tv->fscale);
+	return (0);
+static int
+S_timeval(size_t l2, void *p)
+	struct timeval *tv = (struct timeval*)p;
+	time_t tv_sec;
+	char *p1, *p2;
+		warnx("S_timeval %zu != %zu", l2, sizeof(*tv));
+		return (1);
+	printf(hflag ? "{ sec = %'jd, usec = %'ld } " :
+		"{ sec = %jd, usec = %ld } ",
+		(intmax_t)tv->tv_sec, tv->tv_usec);
+	tv_sec = tv->tv_sec;
+	p1 = strdup(ctime(&tv_sec));
+	for (p2=p1; *p2 ; p2++)
+		if (*p2 == '\n')
+			*p2 = '\0';
+	fputs(p1, stdout);
+	free(p1);
+	return (0);
+static int
+S_vmtotal(size_t l2, void *p)
+#ifndef __rtems__
+	struct vmtotal *v;
+	int pageKilo;
+	if (l2 != sizeof(*v)) {
+		warnx("S_vmtotal %zu != %zu", l2, sizeof(*v));
+		return (1);
+	v = p;
+	pageKilo = getpagesize() / 1024;
+#define	pg2k(a)	((uintmax_t)(a) * pageKilo)
+	printf("\nSystem wide totals computed every five seconds:"
+	    " (values in kilobytes)\n");
+	printf("===============================================\n");
+	printf("Processes:\t\t(RUNQ: %d Disk Wait: %d Page Wait: "
+	    "%d Sleep: %d)\n",
+	    v->t_rq, v->t_dw, v->t_pw, v->t_sl);
+	printf("Virtual Memory:\t\t(Total: %juK Active: %juK)\n",
+	    pg2k(v->t_vm), pg2k(v->t_avm));
+	printf("Real Memory:\t\t(Total: %juK Active: %juK)\n",
+	    pg2k(v->t_rm), pg2k(v->t_arm));
+	printf("Shared Virtual Memory:\t(Total: %juK Active: %juK)\n",
+	    pg2k(v->t_vmshr), pg2k(v->t_avmshr));
+	printf("Shared Real Memory:\t(Total: %juK Active: %juK)\n",
+	    pg2k(v->t_rmshr), pg2k(v->t_armshr));
+	printf("Free Memory:\t%juK", pg2k(v->t_free));
+	return (0);
+static int
+S_input_id(size_t l2, void *p)
+#ifndef __rtems__
+	struct input_id *id = p;
+	if (l2 != sizeof(*id)) {
+		warnx("S_input_id %zu != %zu", l2, sizeof(*id));
+		return (1);
+	printf("{ bustype = 0x%04x, vendor = 0x%04x, "
+	    "product = 0x%04x, version = 0x%04x }",
+	    id->bustype, id->vendor, id->product, id->version);
+	return (0);
+#ifdef __amd64__
+static int
+S_efi_map(size_t l2, void *p)
+	struct efi_map_header *efihdr;
+	struct efi_md *map;
+	const char *type;
+	size_t efisz;
+	int ndesc, i;
+	static const char * const types[] = {
+		[EFI_MD_TYPE_NULL] =	"Reserved",
+		[EFI_MD_TYPE_CODE] =	"LoaderCode",
+		[EFI_MD_TYPE_DATA] =	"LoaderData",
+		[EFI_MD_TYPE_BS_CODE] =	"BootServicesCode",
+		[EFI_MD_TYPE_BS_DATA] =	"BootServicesData",
+		[EFI_MD_TYPE_RT_CODE] =	"RuntimeServicesCode",
+		[EFI_MD_TYPE_RT_DATA] =	"RuntimeServicesData",
+		[EFI_MD_TYPE_FREE] =	"ConventionalMemory",
+		[EFI_MD_TYPE_BAD] =	"UnusableMemory",
+		[EFI_MD_TYPE_RECLAIM] =	"ACPIReclaimMemory",
+		[EFI_MD_TYPE_FIRMWARE] = "ACPIMemoryNVS",
+		[EFI_MD_TYPE_IOMEM] =	"MemoryMappedIO",
+		[EFI_MD_TYPE_IOPORT] =	"MemoryMappedIOPortSpace",
+		[EFI_MD_TYPE_PALCODE] =	"PalCode",
+		[EFI_MD_TYPE_PERSISTENT] = "PersistentMemory",
+	 * Memory map data provided by UEFI via the GetMemoryMap
+	 * Boot Services API.
+	if (l2 < sizeof(*efihdr)) {
+		warnx("S_efi_map length less than header");
+		return (1);
+	efihdr = p;
+	efisz = (sizeof(struct efi_map_header) + 0xf) & ~0xf;
+	map = (struct efi_md *)((uint8_t *)efihdr + efisz);
+	if (efihdr->descriptor_size == 0)
+		return (0);
+	if (l2 != efisz + efihdr->memory_size) {
+		warnx("S_efi_map length mismatch %zu vs %zu", l2, efisz +
+		    efihdr->memory_size);
+		return (1);
+	ndesc = efihdr->memory_size / efihdr->descriptor_size;
+	printf("\n%23s %12s %12s %8s %4s",
+	    "Type", "Physical", "Virtual", "#Pages", "Attr");
+	for (i = 0; i < ndesc; i++,
+	    map = efi_next_descriptor(map, efihdr->descriptor_size)) {
+		type = NULL;
+		if (map->md_type < nitems(types))
+			type = types[map->md_type];
+		if (type == NULL)
+			type = "<INVALID>";
+		printf("\n%23s %012jx %12p %08jx ", type,
+		    (uintmax_t)map->md_phys, map->md_virt,
+		    (uintmax_t)map->md_pages);
+		if (map->md_attr & EFI_MD_ATTR_UC)
+			printf("UC ");
+		if (map->md_attr & EFI_MD_ATTR_WC)
+			printf("WC ");
+		if (map->md_attr & EFI_MD_ATTR_WT)
+			printf("WT ");
+		if (map->md_attr & EFI_MD_ATTR_WB)
+			printf("WB ");
+		if (map->md_attr & EFI_MD_ATTR_UCE)
+			printf("UCE ");
+		if (map->md_attr & EFI_MD_ATTR_WP)
+			printf("WP ");
+		if (map->md_attr & EFI_MD_ATTR_RP)
+			printf("RP ");
+		if (map->md_attr & EFI_MD_ATTR_XP)
+			printf("XP ");
+		if (map->md_attr & EFI_MD_ATTR_RT)
+			printf("RUNTIME");
+	return (0);
+#endif
+#ifndef __rtems__
+static int
+S_bios_smap_xattr(size_t l2, void *p)
+	struct bios_smap_xattr *smap, *end;
+	if (l2 % sizeof(*smap) != 0) {
+		warnx("S_bios_smap_xattr %zu is not a multiple of %zu", l2,
+		    sizeof(*smap));
+		return (1);
+	end = (struct bios_smap_xattr *)((char *)p + l2);
+	for (smap = p; smap < end; smap++)
+		printf("\nSMAP type=%02x, xattr=%02x, base=%016jx, len=%016jx",
+		    smap->type, smap->xattr, (uintmax_t)smap->base,
+		    (uintmax_t)smap->length);
+	return (0);
+#endif
+static int
+strIKtoi(const char *str, char **endptrp, const char *fmt)
+	int kelv;
+	float temp;
+	size_t len;
+	const char *p;
+	int prec, i;
+	assert(errno == 0);
+	len = strlen(str);
+	/* caller already checked this */
+	assert(len > 0);
+	 * A format of "IK" is in deciKelvin. A format of "IK3" is in
+	 * milliKelvin. The single digit following IK is log10 of the
+	 * multiplying factor to convert Kelvin into the untis of this sysctl,
+	 * or the dividing factor to convert the sysctl value to Kelvin. Numbers
+	 * larger than 6 will run into precision issues with 32-bit integers.
+	 * Characters that aren't ASCII digits after the 'K' are ignored. No
+	 * localization is present because this is an interface from the kernel
+	 * to this program (eg not an end-user interface), so isdigit() isn't
+	 * used here.
+	if (fmt[2] != '\0' && fmt[2] >= '0' && fmt[2] <= '9')
+		prec = fmt[2] - '0';
+	else
+		prec = 1;
+	p = &str[len - 1];
+	if (*p == 'C' || *p == 'F' || *p == 'K') {
+		temp = strtof(str, endptrp);
+		if (*endptrp != str && *endptrp == p && errno == 0) {
+			if (*p == 'F')
+				temp = (temp - 32) * 5 / 9;
+			*endptrp = NULL;
+			if (*p != 'K')
+				temp += 273.15;
+			for (i = 0; i < prec; i++)
+				temp *= 10.0;
+			return ((int)(temp + 0.5));
+	} else {
+		/* No unit specified -> treat it as a raw number */
+		kelv = (int)strtol(str, endptrp, 10);
+			*endptrp = NULL;
+			return (kelv);
+	errno = ERANGE;
+	return (0);
+ * These functions uses a presently undocumented interface to the kernel
+ * to walk the tree and get the type so it can print the value.
+ * This interface is under work and consideration, and should probably
+ * be killed with a big axe by the first person who can find the time.
+ * (be aware though, that the proper interface isn't as obvious as it
+ * may seem, there are various conflicting requirements.
+static int
+name2oid(const char *name, int *oidp)
+	int oid[2];
+	int i;
+	size_t j;
+	oid[0] = 0;
+	oid[1] = 3;
+	j = CTL_MAXNAME * sizeof(int);
+	i = sysctl(oid, 2, oidp, &j, name, strlen(name));
+	if (i < 0)
+		return (i);
+	j /= sizeof(int);
+	return (j);
+static int
+oidfmt(int *oid, int len, char *fmt, u_int *kind)
+	int qoid[CTL_MAXNAME+2];
+	u_char buf[BUFSIZ];
+	int i;
+	size_t j;
+	qoid[0] = 0;
+	qoid[1] = 4;
+	memcpy(qoid + 2, oid, len * sizeof(int));
+	j = sizeof(buf);
+	i = sysctl(qoid, len + 2, buf, &j, 0, 0);
+	if (i)
+		err(1, "sysctl fmt %d %zu %d", i, j, errno);
+	if (kind)
+		*kind = *(u_int *)buf;
+	if (fmt)
+		strcpy(fmt, (char *)(buf + sizeof(u_int)));
+	return (0);
+ * This formats and outputs the value of one variable
+ * Returns zero if anything was actually output.
+ * Returns one if didn't know what to do with this.
+ * Return minus one if we had errors.
+static int
+show_var(int *oid, int nlen)
+	u_char buf[BUFSIZ], *val, *oval, *p;
+	char name[BUFSIZ], fmt[BUFSIZ];
+	const char *sep, *sep1, *prntype;
+	uintmax_t umv;
+	intmax_t mv;
+	int i, hexlen, sign, ctltype;
+	size_t intlen;
+	size_t j, len;
+	u_int kind;
+	float base;
+	int (*func)(size_t, void *);
+	int prec;
+	/* Silence GCC. */
+	umv = mv = intlen = 0;
+	bzero(buf, BUFSIZ);
+	bzero(fmt, BUFSIZ);
+	bzero(name, BUFSIZ);
+	qoid[0] = 0;
+	memcpy(qoid + 2, oid, nlen * sizeof(int));
+	qoid[1] = 1;
+	j = sizeof(name);
+	i = sysctl(qoid, nlen + 2, name, &j, 0, 0);
+	if (i || !j)
+		err(1, "sysctl name %d %zu %d", i, j, errno);
+	oidfmt(oid, nlen, fmt, &kind);
+	/* if Wflag then only list sysctls that are writeable and not stats. */
+#ifndef __rtems__
+	if (Wflag && ((kind & CTLFLAG_WR) == 0 || (kind & CTLFLAG_STATS) != 0))
+		return 1;
+	/* if Tflag then only list sysctls that are tuneables. */
+	if (Tflag && (kind & CTLFLAG_TUN) == 0)
+		return 1;
+	if (Nflag) {
+		printf("%s", name);
+		return (0);
+	if (eflag)
+		sep = "=";
+	else
+		sep = ": ";
+	ctltype = (kind & CTLTYPE);
+	if (tflag || dflag) {
+		if (!nflag)
+			printf("%s%s", name, sep);
+        	if (ctl_typename[ctltype] != NULL)
+            		prntype = ctl_typename[ctltype];
+        	else
+            		prntype = "unknown";
+		if (tflag && dflag)
+			printf("%s%s", prntype, sep);
+		else if (tflag) {
+			printf("%s", prntype);
+			return (0);
+		qoid[1] = 5;
+		j = sizeof(buf);
+		i = sysctl(qoid, nlen + 2, buf, &j, 0, 0);
+		printf("%s", buf);
+		return (0);
+	/* don't fetch opaques that we don't know how to print */
+	if (ctltype == CTLTYPE_OPAQUE) {
+		if (strcmp(fmt, "S,clockinfo") == 0)
+#ifndef __rtems__
+			func = S_clockinfo;
+#else /* __rtems__ */
+			func = NULL;
+		else if (strcmp(fmt, "S,timeval") == 0)
+			func = S_timeval;
+		else if (strcmp(fmt, "S,loadavg") == 0)
+			func = S_loadavg;
+		else if (strcmp(fmt, "S,vmtotal") == 0)
+			func = S_vmtotal;
+		else if (strcmp(fmt, "S,input_id") == 0)
+			func = S_input_id;
+#ifdef __amd64__
+		else if (strcmp(fmt, "S,efi_map_header") == 0)
+			func = S_efi_map;
+#endif
+		else if (strcmp(fmt, "S,bios_smap_xattr") == 0)
+#ifndef __rtems__
+			func = S_bios_smap_xattr;
+			func = NULL;
+#endif
+		else {
+			func = NULL;
+			if (!bflag && !oflag && !xflag)
+				return (1);
+	/* find an estimate of how much we need for this var */
+	if (Bflag)
+		j = Bflag;
+	else {
+		j = 0;
+		i = sysctl(oid, nlen, 0, &j, 0, 0);
+		j += j; /* we want to be sure :-) */
+	val = oval = malloc(j + 1);
+	if (val == NULL) {
+		warnx("malloc failed");
+		return (1);
+	len = j;
+	i = sysctl(oid, nlen, val, &len, 0, 0);
+	if (i != 0 || (len == 0 && ctltype != CTLTYPE_STRING)) {
+		free(oval);
+		return (1);
+	if (bflag) {
+		fwrite(val, 1, len, stdout);
+		free(oval);
+		return (0);
+	val[len] = '\0';
+	p = val;
+	sign = ctl_sign[ctltype];
+	intlen = ctl_size[ctltype];
+	switch (ctltype) {
+		if (!nflag)
+		printf("%.*s", (int)len, p);
+		free(oval);
+		return (0);
+	case CTLTYPE_INT:
+#ifndef __rtems__
+	case CTLTYPE_S8:
+	case CTLTYPE_S16:
+	case CTLTYPE_S32:
+	case CTLTYPE_S64:
+	case CTLTYPE_U8:
+	case CTLTYPE_U16:
+	case CTLTYPE_U32:
+	case CTLTYPE_U64:
+		if (!nflag)
+		hexlen = 2 + (intlen * CHAR_BIT + 3) / 4;
+		sep1 = "";
+		while (len >= intlen) {
+			case CTLTYPE_INT:
+				umv = *(u_int *)p;
+				mv = *(int *)p;
+				break;
+				umv = *(u_long *)p;
+				mv = *(long *)p;
+				break;
+#ifndef __rtems__
+			case CTLTYPE_S8:
+			case CTLTYPE_U8:
+				umv = *(uint8_t *)p;
+				mv = *(int8_t *)p;
+				break;
+			case CTLTYPE_S16:
+			case CTLTYPE_U16:
+				umv = *(uint16_t *)p;
+				mv = *(int16_t *)p;
+				break;
+			case CTLTYPE_S32:
+			case CTLTYPE_U32:
+				umv = *(uint32_t *)p;
+				mv = *(int32_t *)p;
+				break;
+			case CTLTYPE_S64:
+			case CTLTYPE_U64:
+				umv = *(uint64_t *)p;
+				mv = *(int64_t *)p;
+				break;
+			fputs(sep1, stdout);
+			if (xflag)
+				printf("%#0*jx", hexlen, umv);
+			else if (!sign)
+				printf(hflag ? "%'ju" : "%ju", umv);
+			else if (fmt[1] == 'K') {
+				if (mv < 0)
+					printf("%jd", mv);
+				else {
+					 * See strIKtoi for details on fmt.
+					prec = 1;
+					if (fmt[2] != '\0')
+					base = 1.0;
+					for (int i = 0; i < prec; i++)
+						base *= 10.0;
+					printf("%.*fC", prec,
+					    (float)mv / base - 273.15);
+			} else
+				printf(hflag ? "%'jd" : "%jd", mv);
+			sep1 = " ";
+			len -= intlen;
+			p += intlen;
+		free(oval);
+		return (0);
+	case CTLTYPE_OPAQUE:
+		i = 0;
+		if (func) {
+			if (!nflag)
+			i = (*func)(len, p);
+			free(oval);
+			return (i);
+		/* FALLTHROUGH */
+	default:
+		if (!oflag && !xflag) {
+			free(oval);
+			return (1);
+		if (!nflag)
+		printf("Format:%s Length:%zu Dump:0x", fmt, len);
+		while (len-- && (xflag || p < val + 16))
+			printf("%02x", *p++);
+		if (!xflag && len > 16)
+			printf("...");
+		free(oval);
+		return (0);
+	free(oval);
+	return (1);
+static int
+sysctl_all(int *oid, int len)
+	int name1[22], name2[22];
+	int i, j;
+	size_t l1, l2;
+	name1[0] = 0;
+	name1[1] = 2;
+	l1 = 2;
+	if (len) {
+		memcpy(name1+2, oid, len * sizeof(int));
+		l1 += len;
+	} else {
+		name1[2] = 1;
+		l1++;
+	for (;;) {
+		l2 = sizeof(name2);
+		j = sysctl(name1, l1, name2, &l2, 0, 0);
+		if (j < 0) {
+				return (0);
+			else
+				err(1, "sysctl(getnext) %d %zu", j, l2);
+		l2 /= sizeof(int);
+		if (len < 0 || l2 < (unsigned int)len)
+			return (0);
+		for (i = 0; i < len; i++)
+			if (name2[i] != oid[i])
+				return (0);
+		i = show_var(name2, l2);
+		if (!i && !bflag)
+			putchar('\n');
+		memcpy(name1+2, name2, l2 * sizeof(int));
+		l1 = 2 + l2;
+#ifdef __rtems__
+rtems_shell_cmd_t rtems_shell_SYSCTL_Command = {
+  "sysctl",                                     /* name */
+  "sysctl [-bdehNnoqTtWx] [ -B <bufsize> ] [-a | name[=value]] ... ", /* usage */
+  "rtems",                                      /* topic */
+  rtems_shell_main_sysctl,                      /* command */
+  NULL,                                         /* alias */
+  NULL                                          /* next */
diff --git a/sys/linker_set.h b/sys/linker_set.h
index c83d7c8..e10be24 100644
--- a/sys/linker_set.h
+++ b/sys/linker_set.h
@@ -1,4 +1,6 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
  * Copyright (c) 1999 John D. Polstra
  * Copyright (c) 1999,2001 Peter Wemm <peter at FreeBSD.org>
  * All rights reserved.
@@ -24,27 +26,18 @@
  * SUCH DAMAGE.
- * $FreeBSD: src/sys/sys/linker_set.h,v 1.13 2002/09/23 06:11:29 peter Exp $
+ * $FreeBSD$
 #ifndef _SYS_LINKER_SET_H_
 #define _SYS_LINKER_SET_H_
-/* FIXME: These macros should not be here
- * BSD has them macros in sys/cdefs.h
- * older rtems had them in rtems/bsd/sys/cdefs.h
- * newlib has some of them in sys/cdefs.h
-#if defined(__rtems__)
-#ifndef	__used
-#define	__used		__attribute__((__used__))
-#endif
-#ifndef __CONCAT
-#define	__CONCAT1(x,y)	x ## y
-#define	__CONCAT(x,y)	__CONCAT1(x,y)
-#endif
+#ifndef _SYS_CDEFS_H_
+#error this file needs sys/cdefs.h as a prerequisite
 #endif
+#ifdef __rtems__
+#include <sys/_types.h>
  * The following macros are used to declare global sets of objects, which
@@ -52,40 +45,120 @@
  * For ELF, this is done by constructing a separate segment for each set.
+#if defined(__powerpc64__)
+ * Move the symbol pointer from ".text" to ".data" segment, to make
+ * the GCC compiler happy:
+#define	__MAKE_SET_CONST
+#else
+#define	__MAKE_SET_CONST const
+#endif
  * Private macros, not to be used outside this header file.
-#ifdef __GNUC__
+#ifdef __GNUCLIKE___SECTION
+#ifndef __rtems__
+#define __MAKE_SET_QV(set, sym, qv)			\
+	__GLOBL(__CONCAT(__start_set_,set));		\
+	__GLOBL(__CONCAT(__stop_set_,set));		\
+	static void const * qv				\
+	__set_##set##_sym_##sym __section("set_" #set)	\
+	__used = &(sym)
+#define __MAKE_SET(set, sym)	__MAKE_SET_QV(set, sym, __MAKE_SET_CONST)
+#define RTEMS_BSD_DEFINE_SET(set, type)					\
+	type const __CONCAT(_bsd__start_set_,set)[0]		\
+	__section(".rtemsroset.bsd." __STRING(set) ".begin") __used;	\
+	type const __CONCAT(_bsd__stop_set_,set)[0]		\
+	__section(".rtemsroset.bsd." __STRING(set) ".end") __used
+#define RTEMS_BSD_DECLARE_SET(set, type)				\
+	extern type const __CONCAT(_bsd__start_set_,set)[0];		\
+	extern type const __CONCAT(_bsd__stop_set_,set)[0]
+#define RTEMS_BSD_DEFINE_SET_ITEM(set, sym, type)			\
+	static type const __set_##set##_sym_##sym			\
+       __section(".rtemsroset.bsd." __STRING(set) ".content.1") __used
+#define RTEMS_BSD_DEFINE_SET_ITEM_ORDERED(set, sym, order, type)     \
+       __section(".rtemsroset.bsd." __STRING(set) ".content.0."  RTEMS_XSTRING( order )) __used
 #define __MAKE_SET(set, sym)						\
-	static void const * const __set_##set##_sym_##sym 		\
-	__attribute((section("set_" #set))) __used = &sym
-#else /* !__GNUC__ */
-#ifndef lint
-#error "This file needs to be compiled by GCC or lint"
-#endif /* lint */
-#define __MAKE_SET(set, sym)	extern void const * const (__set_##set##_sym_##sym)
-#endif /* __GNUC__ */
+	RTEMS_BSD_DEFINE_SET_ITEM(set, sym, const void *) = &sym
+#define RTEMS_BSD_DEFINE_RWSET(set, type)				\
+	type __CONCAT(_bsd__start_set_,set)[0]				\
+	__section(".rtemsrwset.bsd." __STRING(set) ".begin") __used;	\
+	type __CONCAT(_bsd__stop_set_,set)[0]				\
+	__section(".rtemsrwset.bsd." __STRING(set) ".end") __used
+#define RTEMS_BSD_DECLARE_RWSET(set, type)				\
+	extern type __CONCAT(_bsd__start_set_,set)[0];			\
+	extern type __CONCAT(_bsd__stop_set_,set)[0]
+#define RTEMS_BSD_DEFINE_RWSET_ITEM(set, sym, type)			\
+	static type __set_##set##_sym_##sym 				\
+	__section(".rtemsrwset.bsd." __STRING(set) ".content") __used
+#define __MAKE_RWSET(set, sym)						\
+	RTEMS_BSD_DEFINE_RWSET_ITEM(set, sym, const void *) = &sym
+#else /* !__GNUCLIKE___SECTION */
+#error this file needs to be ported to your compiler
+#endif /* __GNUCLIKE___SECTION */
  * Public macros.
 #define TEXT_SET(set, sym)	__MAKE_SET(set, sym)
 #define DATA_SET(set, sym)	__MAKE_SET(set, sym)
+#ifndef __rtems__
+#define DATA_WSET(set, sym)	__MAKE_SET_QV(set, sym, )
+#define DATA_WSET(set, sym)	__MAKE_RWSET(set, sym)
 #define BSS_SET(set, sym)	__MAKE_SET(set, sym)
 #define ABS_SET(set, sym)	__MAKE_SET(set, sym)
 #define SET_ENTRY(set, sym)	__MAKE_SET(set, sym)
- * Initialize before referring to a give linker set
+ * Initialize before referring to a given linker set.
+#ifndef __rtems__
+#define SET_DECLARE(set, ptype)					\
+	extern ptype __weak_symbol *__CONCAT(__start_set_,set);	\
+	extern ptype __weak_symbol *__CONCAT(__stop_set_,set)
+#define SET_BEGIN(set)							\
+	(&__CONCAT(__start_set_,set))
+#define SET_LIMIT(set)							\
+	(&__CONCAT(__stop_set_,set))
-	extern ptype *__CONCAT(__start_set_,set)[];			\
-	extern ptype *__CONCAT(__stop_set_,set)[]
+	RTEMS_BSD_DECLARE_SET(set, ptype *)
+#define RWSET_DECLARE(set, ptype)					\
+	RTEMS_BSD_DECLARE_RWSET(set, ptype *)
+static __inline __uintptr_t
+_linker_set_obfuscate(const void *marker)
+	/* Obfuscate the variable, so that the compiler cannot optimize */
+	__asm__("" : "+r" (marker));
+	return ((__uintptr_t)marker);
-	(__CONCAT(__start_set_,set))
+	((__typeof(&__CONCAT(_bsd__start_set_,set)[0]))			\
+	     _linker_set_obfuscate(__CONCAT(_bsd__start_set_,set)))
-	(__CONCAT(__stop_set_,set))
+	((__typeof(&__CONCAT(_bsd__stop_set_,set)[0]))			\
+	     _linker_set_obfuscate(__CONCAT(_bsd__stop_set_,set)))
  * Iterate over all the elements of a set.
diff --git a/testsuites/telnetd02/init.c b/testsuites/telnetd02/init.c
index 6f762db..7a450fa 100644
--- a/testsuites/telnetd02/init.c
+++ b/testsuites/telnetd02/init.c
@@ -111,6 +111,10 @@ static rtems_task Init(rtems_task_argument argument)
 #define CONFIGURE_SHELL_COMMANDS_ALL
 #define CONFIGURE_SHELL_COMMANDS_ALL_NETWORKING
+extern rtems_shell_cmd_t rtems_shell_SYSCTL_Command;
+#define CONFIGURE_SHELL_USER_COMMANDS \
+  &rtems_shell_SYSCTL_Command
 #include <rtems/shellconfig.h>
 #include <rtems/confdefs.h>
diff --git a/testsuites/telnetd02/wscript b/testsuites/telnetd02/wscript
index b59c040..9a04c59 100644
--- a/testsuites/telnetd02/wscript
+++ b/testsuites/telnetd02/wscript
@@ -47,4 +47,5 @@ def build(bld):
                 lib=['telnetd', 'networking'],
                 libpath=['.'],
                 source=source,
+                use=['networking'],
                 install_path=False)
2.37.1
