Fwd: [rtems-bsp-builder] 2023-04-22 14:51:16: Profile(s): everything
Joel Sherrill
joel at rtems.org
Sun Apr 23 16:02:08 UTC 2023
Not sure what broke this. The only recent change I could think of was your
fix for the MVME BSPs.
--joel
---------- Forwarded message ---------
From: OAR Tester for Ubuntu 22.04 <rtems-tester at oarcorp.com>
Date: Sat, Apr 22, 2023 at 9:47 PM
Subject: [rtems-bsp-builder] 2023-04-22 14:51:16: Profile(s): everything
To: <build at rtems.org>
RTEMS Tools Project - RTEMS Kernel BSP Builder, 6.0.not_released
Host: #39~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Mar 17 21:16:15 UTC 2
command: /home/tester/rtems-cron-6/tools/6/bin/rtems-bsp-builder\
--rtems=/home/tester/rtems-cron-6/rtems --build-path=/home/tester\
/rtems-cron-6/build --prefix=/home/tester/rtems-\
cron-6/tools/6/bsps --log=/home/tester/rtems-cron-6/bsp-\
builder.log --warnings-report=warnings.log --mail --use-gitconfig\
--profiles=everything
Total Time : 6:59:37.830504 for 1298 completed job(s)
Average BSP Build Time: 0:00:19.397404
Builds
debug
no-posix
posix
posix-debug
posix-profiling
profiling
smp
smp-debug
Failures Report
1 debug powerpc/br_uid build:
configure: /home/tester/rtems-cron-6/rtems/waf configure\
--prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
/rtems-cron-6/rtems --rtems-config=config-powerpc-br_uid-debug.ini
error: home/tester/bsps/powerpc/gen83xx/start/bsprestart.c:49:10:
error: 'PPC_SPECIAL_PURPOSE_REGISTER' undeclared (first use in
this function)
error: home/tester/bsps/powerpc/gen83xx/start/cpuinit.c:96:10: error:
'PPC_SPECIAL_PURPOSE_REGISTER' undeclared (first use in this
function)
error: home/tester/bsps/powerpc/gen83xx/start/cpuinit.c:96:43: error:
macro "PPC_SPECIAL_PURPOSE_REGISTER" requires 2 arguments, but
only 1 given
error: home/tester/bsps/powerpc/gen83xx/start/bsprestart.c:49:43:
error: macro "PPC_SPECIAL_PURPOSE_REGISTER" requires 2
arguments, but only 1 given
2 no-posix powerpc/br_uid build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-br_uid-no-\
posix.ini
function)
only 1 given
3 posix powerpc/br_uid build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-br_uid-posix.ini
function)
only 1 given
4 posix-debug powerpc/br_uid build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-br_uid-posix-\
debug.ini
this function)
5 posix-profiling powerpc/br_uid build:
profiling.ini
this function)
function)
only 1 given
6 profiling powerpc/br_uid build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-br_uid-\
profiling.ini
this function)
function)
only 1 given
7 debug powerpc/hsc_cm01 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-hsc_cm01-debug.ini
function)
only 1 given
8 no-posix powerpc/hsc_cm01 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-hsc_cm01-no-\
posix.ini
this function)
function)
only 1 given
9 posix powerpc/hsc_cm01 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-hsc_cm01-posix.ini
function)
only 1 given
10 posix-debug powerpc/hsc_cm01 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-hsc_cm01-posix-\
debug.ini
this function)
function)
only 1 given
11 posix-profiling powerpc/hsc_cm01 build:
profiling.ini
this function)
function)
only 1 given
12 profiling powerpc/hsc_cm01 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-\
hsc_cm01-profiling.ini
function)
only 1 given
13 debug powerpc/mpc5566evb build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc5566evb-\
debug.ini
error: home/tester/bsps/powerpc/mpc55xxevb/start/bspstart.c:72:22:
this function)
error: home/tester/bsps/powerpc/mpc55xxevb/start/flash_support.c:674:
53: error: macro "PPC_SPECIAL_PURPOSE_REGISTER" requires 2
error: home/tester/bsps/powerpc/mpc55xxevb/start/flash_support.c:300:
14: error: 'PPC_SPECIAL_PURPOSE_REGISTER' undeclared (first
use in this function)
55: error: macro "PPC_SPECIAL_PURPOSE_REGISTER" requires 2
error: home/tester/bsps/powerpc/mpc55xxevb/start/flash_support.c:301:
error: home/tester/bsps/powerpc/mpc55xxevb/start/flash_support.c:692:
12: error: 'PPC_SPECIAL_PURPOSE_REGISTER' undeclared (first
error: home/tester/bsps/powerpc/mpc55xxevb/start/flash_support.c:302:
error: home/tester/bsps/powerpc/mpc55xxevb/start/bspstart.c:72:63:
14 no-posix powerpc/mpc5566evb build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc5566evb-no-\
posix.ini
this function)
15 posix powerpc/mpc5566evb build:
posix.ini
this function)
16 posix-debug powerpc/mpc5566evb build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc5566evb-posix-\
debug.ini
17 posix-profiling powerpc/mpc5566evb build:
profiling.ini
this function)
18 profiling powerpc/mpc5566evb build:
profiling.ini
this function)
19 debug powerpc/mpc5674fevb build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc5674fevb-\
debug.ini
this function)
20 no-posix powerpc/mpc5674fevb build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc5674fevb-no-\
posix.ini
this function)
21 posix powerpc/mpc5674fevb build:
posix.ini
this function)
22 posix-debug powerpc/mpc5674fevb build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc5674fevb-posix-\
debug.ini
this function)
23 posix-profiling powerpc/mpc5674fevb build:
profiling.ini
this function)
24 profiling powerpc/mpc5674fevb build:
profiling.ini
this function)
25 debug powerpc/mpc8309som build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8309som-\
debug.ini
this function)
function)
only 1 given
26 no-posix powerpc/mpc8309som build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8309som-no-\
posix.ini
this function)
27 posix powerpc/mpc8309som build:
posix.ini
this function)
function)
only 1 given
28 posix-debug powerpc/mpc8309som build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8309som-posix-\
debug.ini
this function)
function)
only 1 given
29 posix-profiling powerpc/mpc8309som build:
profiling.ini
function)
only 1 given
30 profiling powerpc/mpc8309som build:
profiling.ini
this function)
function)
only 1 given
31 debug powerpc/mpc8313erdb build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8313erdb-\
debug.ini
this function)
function)
only 1 given
32 no-posix powerpc/mpc8313erdb build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8313erdb-no-\
posix.ini
function)
only 1 given
33 posix powerpc/mpc8313erdb build:
posix.ini
this function)
function)
only 1 given
34 posix-debug powerpc/mpc8313erdb build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8313erdb-posix-\
debug.ini
function)
only 1 given
35 posix-profiling powerpc/mpc8313erdb build:
profiling.ini
this function)
function)
only 1 given
36 profiling powerpc/mpc8313erdb build:
profiling.ini
this function)
function)
only 1 given
37 debug powerpc/mpc8349eamds build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8349eamds-\
debug.ini
this function)
function)
only 1 given
38 no-posix powerpc/mpc8349eamds build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8349eamds-no-\
posix.ini
this function)
function)
only 1 given
39 posix powerpc/mpc8349eamds build:
posix.ini
this function)
function)
only 1 given
40 posix-debug powerpc/mpc8349eamds build:
posix-debug.ini
this function)
function)
only 1 given
41 posix-profiling powerpc/mpc8349eamds build:
posix-profiling.ini
this function)
function)
only 1 given
42 profiling powerpc/mpc8349eamds build:
profiling.ini
this function)
function)
only 1 given
43 debug powerpc/phycore_mpc5554 build:
phycore_mpc5554-debug.ini
44 no-posix powerpc/phycore_mpc5554 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-phycore_mpc5554\
-no-posix.ini
45 posix powerpc/phycore_mpc5554 build:
phycore_mpc5554-posix.ini
46 posix-debug powerpc/phycore_mpc5554 build:
-posix-debug.ini
47 posix-profiling powerpc/phycore_mpc5554 build:
-posix-profiling.ini
48 profiling powerpc/phycore_mpc5554 build:
phycore_mpc5554-profiling.ini
49 debug powerpc/qoriq_core_0 build:
qoriq_core_0-debug.ini
error: home/tester/bsps/powerpc/qoriq/start/mmu.c:401:24: error:
function)
error: home/tester/bsps/powerpc/qoriq/start/mmu.c:401:65: error:
only 1 given
error: home/tester/bsps/powerpc/qoriq/start/mmu.c:370:65: error:
only 1 given
error: home/tester/bsps/powerpc/qoriq/start/mmu.c:370:24: error:
function)
error: home/tester/bsps/powerpc/qoriq/start/mmu.c:373:82: error:
only 1 given
50 no-posix powerpc/qoriq_core_0 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_core_0-no-\
posix.ini
function)
only 1 given
only 1 given
function)
only 1 given
51 posix powerpc/qoriq_core_0 build:
qoriq_core_0-posix.ini
function)
only 1 given
only 1 given
function)
only 1 given
52 posix-debug powerpc/qoriq_core_0 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_core_0\
-posix-debug.ini
function)
only 1 given
only 1 given
function)
only 1 given
53 posix-profiling powerpc/qoriq_core_0 build:
function)
only 1 given
only 1 given
function)
only 1 given
54 profiling powerpc/qoriq_core_0 build:
qoriq_core_0-profiling.ini
function)
only 1 given
only 1 given
function)
only 1 given
55 debug powerpc/qoriq_core_1 build:
qoriq_core_1-debug.ini
function)
only 1 given
only 1 given
function)
only 1 given
56 no-posix powerpc/qoriq_core_1 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_core_1-no-\
posix.ini
function)
only 1 given
only 1 given
function)
only 1 given
57 posix powerpc/qoriq_core_1 build:
qoriq_core_1-posix.ini
function)
only 1 given
only 1 given
function)
only 1 given
58 posix-debug powerpc/qoriq_core_1 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_core_1\
-posix-debug.ini
function)
only 1 given
only 1 given
function)
only 1 given
59 posix-profiling powerpc/qoriq_core_1 build:
function)
only 1 given
only 1 given
function)
only 1 given
60 profiling powerpc/qoriq_core_1 build:
qoriq_core_1-profiling.ini
function)
only 1 given
only 1 given
function)
only 1 given
61 debug powerpc/qoriq_e500 build:
qoriq_e500-debug.ini
function)
only 1 given
only 1 given
function)
only 1 given
62 no-posix powerpc/qoriq_e500 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e500-no-\
posix.ini
function)
only 1 given
only 1 given
function)
only 1 given
63 posix powerpc/qoriq_e500 build:
qoriq_e500-posix.ini
function)
only 1 given
only 1 given
function)
only 1 given
64 posix-debug powerpc/qoriq_e500 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e500-posix-\
debug.ini
function)
only 1 given
only 1 given
function)
only 1 given
65 posix-profiling powerpc/qoriq_e500 build:
profiling.ini
function)
only 1 given
only 1 given
function)
only 1 given
66 profiling powerpc/qoriq_e500 build:
qoriq_e500-profiling.ini
function)
only 1 given
only 1 given
function)
only 1 given
67 smp powerpc/qoriq_e500 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e500-smp.ini
function)
only 1 given
only 1 given
function)
only 1 given
68 smp-debug powerpc/qoriq_e500 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e500-smp-\
debug.ini
function)
only 1 given
only 1 given
function)
only 1 given
69 debug powerpc/qoriq_e6500_32 build:
qoriq_e6500_32-debug.ini
function)
only 1 given
only 1 given
function)
only 1 given
70 no-posix powerpc/qoriq_e6500_32 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e6500_32-no-\
posix.ini
function)
only 1 given
only 1 given
function)
only 1 given
71 posix powerpc/qoriq_e6500_32 build:
qoriq_e6500_32-posix.ini
function)
only 1 given
only 1 given
function)
only 1 given
72 posix-debug powerpc/qoriq_e6500_32 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e6500_32\
-posix-debug.ini
function)
only 1 given
only 1 given
function)
only 1 given
73 posix-profiling powerpc/qoriq_e6500_32 build:
function)
only 1 given
only 1 given
function)
only 1 given
74 profiling powerpc/qoriq_e6500_32 build:
qoriq_e6500_32-profiling.ini
function)
only 1 given
only 1 given
function)
only 1 given
75 smp powerpc/qoriq_e6500_32 build:
qoriq_e6500_32-smp.ini
function)
only 1 given
only 1 given
function)
only 1 given
76 smp-debug powerpc/qoriq_e6500_32 build:
-smp-debug.ini
function)
only 1 given
only 1 given
function)
only 1 given
77 debug powerpc/qoriq_e6500_64 build:
qoriq_e6500_64-debug.ini
function)
only 1 given
only 1 given
function)
only 1 given
78 no-posix powerpc/qoriq_e6500_64 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e6500_64-no-\
posix.ini
function)
only 1 given
only 1 given
function)
only 1 given
79 posix powerpc/qoriq_e6500_64 build:
qoriq_e6500_64-posix.ini
function)
only 1 given
only 1 given
function)
only 1 given
80 posix-debug powerpc/qoriq_e6500_64 build:
/rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e6500_64\
-posix-debug.ini
function)
only 1 given
only 1 given
function)
only 1 given
81 posix-profiling powerpc/qoriq_e6500_64 build:
function)
only 1 given
only 1 given
function)
only 1 given
82 profiling powerpc/qoriq_e6500_64 build:
qoriq_e6500_64-profiling.ini
function)
only 1 given
only 1 given
function)
only 1 given
83 smp powerpc/qoriq_e6500_64 build:
qoriq_e6500_64-smp.ini
function)
only 1 given
only 1 given
function)
only 1 given
84 smp-debug powerpc/qoriq_e6500_64 build:
-smp-debug.ini
function)
only 1 given
only 1 given
function)
only 1 given
Warnings Report
| By Architecture (total : 9930) |
| common : 14 warning(s) |
| Shared : 738 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 168 | | |
| arm : 32 warning(s) |
| Shared : 192 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 208 | | |
| bfin : 32 warning(s) |
| Shared : 138 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 234 | CPU Kit : 90 | | |
| i386 : 31 warning(s) |
| Shared : 0 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 60 | | |
| lm32 : 14 warning(s) |
| Shared : 156 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 72 | | |
| m68k : 33 warning(s) |
| Shared : 936 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 330 | | |
| microblaze : 0 warning(s) |
| mips : 8 warning(s) |
| LibCPU : 0 | CPU Kit : 24 | | |
| moxie : 2 warning(s) |
| Shared : 12 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 18 | | |
| nios2 : 0 warning(s) |
| or1k : 1 warning(s) |
| Shared : 6 | BSP : 0 | Network : 0 | Tests : 0 |
| powerpc : 43 warning(s) |
| Shared : 254 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 12 | CPU Kit : 148 | | |
| sh : 162 warning(s) |
| Shared : 84 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 84 | | |
| sparc : 4 warning(s) |
| LibCPU : 0 | CPU Kit : 0 | | |
| sparc64 : 2 warning(s) |
| Shared : 36 | BSP : 0 | Network : 0 | Tests : 0 |
| v850 : 1 warning(s) |
| Shared : 72 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 36 | | |
| x86_64 : 1 warning(s) |
| LibCPU : 0 | CPU Kit : 6 | | |
| By BSP (total : 9930) |
| common : 275 warning(s) |
| Shared : 1584 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 96 | CPU Kit : 912 | | |
| arm/altcycv_devkit : 7 warning(s) |
| arm/atsamv : 6 warning(s) |
| arm/csb336 : 0 warning(s) |
| arm/csb337 : 0 warning(s) |
| arm/csb637 : 0 warning(s) |
| arm/gumstix : 0 warning(s) |
| arm/imx7 : 2 warning(s) |
| LibCPU : 0 | CPU Kit : 32 | | |
| arm/imxrt1052 : 0 warning(s) |
| arm/kit637_v6 : 0 warning(s) |
| arm/lm3s3749 : 0 warning(s) |
| arm/lm3s6965 : 0 warning(s) |
| arm/lm3s6965_qemu : 0 warning(s) |
| arm/lm4f120 : 0 warning(s) |
| arm/lpc1768_mbed : 0 warning(s) |
| arm/lpc1768_mbed_ahb_ram : 0 warning(s) |
| arm/lpc1768_mbed_ahb_ram_eth : 0 warning(s) |
| arm/lpc17xx_ea_ram : 0 warning(s) |
| arm/lpc17xx_ea_rom_int : 0 warning(s) |
| arm/lpc17xx_plx800_ram : 0 warning(s) |
| arm/lpc17xx_plx800_rom_int : 0 warning(s) |
| arm/lpc2362 : 0 warning(s) |
| arm/lpc23xx_tli800 : 0 warning(s) |
| arm/lpc24xx_ea : 0 warning(s) |
| arm/lpc24xx_ncs_ram : 0 warning(s) |
| arm/lpc24xx_ncs_rom_ext : 0 warning(s) |
| arm/lpc24xx_ncs_rom_int : 0 warning(s) |
| arm/lpc24xx_plx800_ram : 0 warning(s) |
| arm/lpc24xx_plx800_rom_int : 0 warning(s) |
| arm/lpc32xx_mzx : 0 warning(s) |
| arm/lpc32xx_mzx_stage_1 : 0 warning(s) |
| arm/lpc32xx_mzx_stage_2 : 0 warning(s) |
| arm/lpc32xx_phycore : 0 warning(s) |
| arm/lpc40xx_ea_ram : 0 warning(s) |
| arm/lpc40xx_ea_rom_int : 0 warning(s) |
| arm/nucleo-h743zi : 0 warning(s) |
| arm/raspberrypi : 0 warning(s) |
| arm/raspberrypi2 : 0 warning(s) |
| arm/realview_pbx_a9_qemu : 0 warning(s) |
| arm/smdk2410 : 0 warning(s) |
| arm/stm32f105rc : 0 warning(s) |
| arm/stm32f4 : 2 warning(s) |
| arm/stm32h7 : 0 warning(s) |
| arm/stm32h747i-disco : 0 warning(s) |
| arm/stm32h747i-disco-m4 : 0 warning(s) |
| arm/stm32h757i-eval : 0 warning(s) |
| arm/stm32h757i-eval-m4 : 0 warning(s) |
| arm/stm32h7b3i-dk : 0 warning(s) |
| arm/xilinx_zynqmp_ultra96 : 1 warning(s) |
| bfin/TLL6527M : 11 warning(s) |
| Shared : 42 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 138 | CPU Kit : 30 | | |
| bfin/bf537Stamp : 0 warning(s) |
| bfin/eZKit533 : 0 warning(s) |
| i386/pc386 : 0 warning(s) |
| i386/pc486 : 0 warning(s) |
| i386/pc586 : 0 warning(s) |
| i386/pc586-sse : 0 warning(s) |
| i386/pc686 : 0 warning(s) |
| i386/pcp4 : 0 warning(s) |
| lm32/lm32_evr : 0 warning(s) |
| lm32/lm32_evr_gdbsim : 0 warning(s) |
| lm32/milkymist : 12 warning(s) |
| Shared : 96 | BSP : 0 | Network : 0 | Tests : 0 |
| m68k/COBRA5475 : 0 warning(s) |
| m68k/av5282 : 0 warning(s) |
| m68k/csb360 : 0 warning(s) |
| m68k/gen68340 : 0 warning(s) |
| m68k/gen68360 : 2 warning(s) |
| Shared : 18 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 12 | | |
| m68k/gen68360_040 : 0 warning(s) |
| m68k/m5484FireEngine : 3 warning(s) |
| Shared : 66 | BSP : 0 | Network : 0 | Tests : 0 |
| m68k/mcf5206elite : 1 warning(s) |
| Shared : 78 | BSP : 0 | Network : 0 | Tests : 0 |
| m68k/mcf52235 : 3 warning(s) |
| m68k/mcf5225x : 3 warning(s) |
| m68k/mcf5235 : 1 warning(s) |
| m68k/mcf5329 : 3 warning(s) |
| m68k/mrm332 : 0 warning(s) |
| m68k/mvme147 : 0 warning(s) |
| m68k/mvme147s : 0 warning(s) |
| m68k/mvme162 : 0 warning(s) |
| m68k/mvme162lx : 0 warning(s) |
| m68k/mvme167 : 0 warning(s) |
| m68k/pgh360 : 0 warning(s) |
| m68k/uC5282 : 6 warning(s) |
| microblaze/kcu105 : 0 warning(s) |
| microblaze/kcu105_qemu : 0 warning(s) |
| mips/hurricane : 1 warning(s) |
| mips/malta : 6 warning(s) |
| mips/rbtx4938 : 1 warning(s) |
| moxie/moxiesim : 2 warning(s) |
| nios2/nios2_iss : 0 warning(s) |
| or1k/generic_or1k : 1 warning(s) |
| powerpc/beatnik : 2 warning(s) |
| LibCPU : 12 | CPU Kit : 4 | | |
| powerpc/gwlcfm : 0 warning(s) |
| powerpc/icecube : 0 warning(s) |
| powerpc/mcp750 : 0 warning(s) |
| powerpc/mpc5643l_evb : 0 warning(s) |
| powerpc/mpc5668g : 0 warning(s) |
| powerpc/mpc8260ads : 0 warning(s) |
| powerpc/mtx603e : 0 warning(s) |
| powerpc/mvme2100 : 0 warning(s) |
| powerpc/mvme2307 : 0 warning(s) |
| powerpc/mvme3100 : 1 warning(s) |
| LibCPU : 0 | CPU Kit : 4 | | |
| powerpc/mvme5500 : 2 warning(s) |
| powerpc/pghplus : 0 warning(s) |
| powerpc/pm520_cr825 : 0 warning(s) |
| powerpc/pm520_ze30 : 0 warning(s) |
| powerpc/psim : 1 warning(s) |
| powerpc/qemuppc : 1 warning(s) |
| powerpc/qemuprep : 0 warning(s) |
| powerpc/qemuprep-altivec : 0 warning(s) |
| powerpc/qoriq_e500 : 0 warning(s) |
| powerpc/qoriq_e6500_32 : 0 warning(s) |
| powerpc/qoriq_e6500_64 : 13 warning(s) |
| Shared : 98 | BSP : 0 | Network : 0 | Tests : 0 |
| powerpc/ss555 : 2 warning(s) |
| powerpc/t32mppc : 4 warning(s) |
| LibCPU : 0 | CPU Kit : 52 | | |
| powerpc/tqm8xx_stk8xx : 0 warning(s) |
| powerpc/virtex : 0 warning(s) |
| powerpc/virtex4 : 0 warning(s) |
| powerpc/virtex5 : 0 warning(s) |
| sh/gensh1 : 1 warning(s) |
| sh/gensh2 : 1 warning(s) |
| sh/gensh4 : 1 warning(s) |
| sh/simsh1 : 0 warning(s) |
| sh/simsh2 : 0 warning(s) |
| sh/simsh2e : 0 warning(s) |
| sh/simsh4 : 0 warning(s) |
| sparc/at697f : 0 warning(s) |
| sparc/gr712rc : 0 warning(s) |
| sparc/gr740 : 0 warning(s) |
| sparc/leon2 : 0 warning(s) |
| sparc/leon3 : 0 warning(s) |
| sparc/ut699 : 0 warning(s) |
| sparc/ut700 : 0 warning(s) |
| sparc64/niagara : 0 warning(s) |
| sparc64/usiii : 1 warning(s) |
| v850/v850e1sim : 0 warning(s) |
| v850/v850e2sim : 0 warning(s) |
| v850/v850e2v3sim : 0 warning(s) |
| v850/v850esim : 0 warning(s) |
| v850/v850essim : 0 warning(s) |
| v850/v850sim : 0 warning(s) |
| x86_64/amd64 : 1 warning(s) |
| By Build (total : 9930) |
| common : 378 warning(s) |
| Shared : 1543 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 205 | CPU Kit : 922 | | |
| debug : 2 warning(s) |
| Shared : 301 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 41 | CPU Kit : 222 | | |
| no-posix : 0 warning(s) |
| posix-debug : 0 warning(s) |
| posix-profiling : 0 warning(s) |
| smp : 0 warning(s) |
| smp-debug : 0 warning(s) |
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230423/5fd3ea0d/attachment-0001.htm>
