Fwd: [rtems-bsp-builder] 2023-04-22 14:51:16: Profile(s): everything
Sun Apr 23 22:15:45 UTC 2023
Hi
I missed the use of this register in this BSP. There are a few other spots I
will fix and post a patch.
Thanks
On 24/4/2023 2:02 am, Joel Sherrill wrote:
> Not sure what broke this. The only recent change I could think of was your fix
> for the MVME BSPs.
> --joel
> ---------- Forwarded message ---------
> From: *OAR Tester for Ubuntu 22.04* <rtems-tester at oarcorp.com
> <mailto:rtems-tester at oarcorp.com>>
> Date: Sat, Apr 22, 2023 at 9:47 PM
> Subject: [rtems-bsp-builder] 2023-04-22 14:51:16: Profile(s): everything
> To: <build at rtems.org <mailto:build at rtems.org>>
> RTEMS Tools Project - RTEMS Kernel BSP Builder, 6.0.not_released
> Host: #39~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Mar 17 21:16:15 UTC 2
> command: /home/tester/rtems-cron-6/tools/6/bin/rtems-bsp-builder\
>          --rtems=/home/tester/rtems-cron-6/rtems --build-path=/home/tester\
>          /rtems-cron-6/build --prefix=/home/tester/rtems-\
>          cron-6/tools/6/bsps --log=/home/tester/rtems-cron-6/bsp-\
>          builder.log --warnings-report=warnings.log --mail --use-gitconfig\
>          --profiles=everything
> Total Time            : 6:59:37.830504 for 1298 completed job(s)
> Average BSP Build Time: 0:00:19.397404
> Builds
>  debug
>  no-posix
>  posix
>  posix-debug
>  posix-profiling
>  profiling
>  smp
>  smp-debug
> Failures Report
>    1 debug powerpc/br_uid build:
>       configure: /home/tester/rtems-cron-6/rtems/waf configure\
>       --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-br_uid-debug.ini
>      error: home/tester/bsps/powerpc/gen83xx/start/bsprestart.c:49:10:
>             error: 'PPC_SPECIAL_PURPOSE_REGISTER' undeclared (first use in
>             this function)
>      error: home/tester/bsps/powerpc/gen83xx/start/cpuinit.c:96:10: error:
>             'PPC_SPECIAL_PURPOSE_REGISTER' undeclared (first use in this
>             function)
>      error: home/tester/bsps/powerpc/gen83xx/start/cpuinit.c:96:43: error:
>             macro "PPC_SPECIAL_PURPOSE_REGISTER" requires 2 arguments, but
>             only 1 given
>      error: home/tester/bsps/powerpc/gen83xx/start/bsprestart.c:49:43:
>             error: macro "PPC_SPECIAL_PURPOSE_REGISTER" requires 2
>             arguments, but only 1 given
>    2 no-posix powerpc/br_uid build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-br_uid-no-\
>       posix.ini
>             function)
>             only 1 given
>    3 posix powerpc/br_uid build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-br_uid-posix.ini
>             function)
>             only 1 given
>    4 posix-debug powerpc/br_uid build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-br_uid-posix-\
>       debug.ini
>             this function)
>    5 posix-profiling powerpc/br_uid build:
>       profiling.ini
>             this function)
>             function)
>             only 1 given
>    6 profiling powerpc/br_uid build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-br_uid-\
>       profiling.ini
>             this function)
>             function)
>             only 1 given
>    7 debug powerpc/hsc_cm01 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-hsc_cm01-debug.ini
>             function)
>             only 1 given
>    8 no-posix powerpc/hsc_cm01 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-hsc_cm01-no-\
>       posix.ini
>             this function)
>             function)
>             only 1 given
>    9 posix powerpc/hsc_cm01 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-hsc_cm01-posix.ini
>             function)
>             only 1 given
>   10 posix-debug powerpc/hsc_cm01 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-hsc_cm01-posix-\
>       debug.ini
>             this function)
>             function)
>             only 1 given
>   11 posix-profiling powerpc/hsc_cm01 build:
>       profiling.ini
>             this function)
>             function)
>             only 1 given
>   12 profiling powerpc/hsc_cm01 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-\
>       hsc_cm01-profiling.ini
>             function)
>             only 1 given
>   13 debug powerpc/mpc5566evb build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc5566evb-\
>       debug.ini
>      error: home/tester/bsps/powerpc/mpc55xxevb/start/bspstart.c:72:22:
>             this function)
>      error: home/tester/bsps/powerpc/mpc55xxevb/start/flash_support.c:674:
>             53: error: macro "PPC_SPECIAL_PURPOSE_REGISTER" requires 2
>      error: home/tester/bsps/powerpc/mpc55xxevb/start/flash_support.c:300:
>             14: error: 'PPC_SPECIAL_PURPOSE_REGISTER' undeclared (first
>             use in this function)
>             55: error: macro "PPC_SPECIAL_PURPOSE_REGISTER" requires 2
>      error: home/tester/bsps/powerpc/mpc55xxevb/start/flash_support.c:301:
>      error: home/tester/bsps/powerpc/mpc55xxevb/start/flash_support.c:692:
>             12: error: 'PPC_SPECIAL_PURPOSE_REGISTER' undeclared (first
>      error: home/tester/bsps/powerpc/mpc55xxevb/start/flash_support.c:302:
>      error: home/tester/bsps/powerpc/mpc55xxevb/start/bspstart.c:72:63:
>   14 no-posix powerpc/mpc5566evb build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc5566evb-no-\
>       posix.ini
>             this function)
>   15 posix powerpc/mpc5566evb build:
>       posix.ini
>             this function)
>   16 posix-debug powerpc/mpc5566evb build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc5566evb-posix-\
>       debug.ini
>   17 posix-profiling powerpc/mpc5566evb build:
>       profiling.ini
>             this function)
>   18 profiling powerpc/mpc5566evb build:
>       profiling.ini
>             this function)
>   19 debug powerpc/mpc5674fevb build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc5674fevb-\
>       debug.ini
>             this function)
>   20 no-posix powerpc/mpc5674fevb build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc5674fevb-no-\
>       posix.ini
>             this function)
>   21 posix powerpc/mpc5674fevb build:
>       posix.ini
>             this function)
>   22 posix-debug powerpc/mpc5674fevb build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc5674fevb-posix-\
>       debug.ini
>             this function)
>   23 posix-profiling powerpc/mpc5674fevb build:
>       profiling.ini
>             this function)
>   24 profiling powerpc/mpc5674fevb build:
>       profiling.ini
>             this function)
>   25 debug powerpc/mpc8309som build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8309som-\
>       debug.ini
>             this function)
>             function)
>             only 1 given
>   26 no-posix powerpc/mpc8309som build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8309som-no-\
>       posix.ini
>             this function)
>   27 posix powerpc/mpc8309som build:
>       posix.ini
>             this function)
>             function)
>             only 1 given
>   28 posix-debug powerpc/mpc8309som build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8309som-posix-\
>       debug.ini
>             this function)
>             function)
>             only 1 given
>   29 posix-profiling powerpc/mpc8309som build:
>       profiling.ini
>             function)
>             only 1 given
>   30 profiling powerpc/mpc8309som build:
>       profiling.ini
>             this function)
>             function)
>             only 1 given
>   31 debug powerpc/mpc8313erdb build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8313erdb-\
>       debug.ini
>             this function)
>             function)
>             only 1 given
>   32 no-posix powerpc/mpc8313erdb build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8313erdb-no-\
>       posix.ini
>             function)
>             only 1 given
>   33 posix powerpc/mpc8313erdb build:
>       posix.ini
>             this function)
>             function)
>             only 1 given
>   34 posix-debug powerpc/mpc8313erdb build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8313erdb-posix-\
>       debug.ini
>             function)
>             only 1 given
>   35 posix-profiling powerpc/mpc8313erdb build:
>       profiling.ini
>             this function)
>             function)
>             only 1 given
>   36 profiling powerpc/mpc8313erdb build:
>       profiling.ini
>             this function)
>             function)
>             only 1 given
>   37 debug powerpc/mpc8349eamds build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8349eamds-\
>       debug.ini
>             this function)
>             function)
>             only 1 given
>   38 no-posix powerpc/mpc8349eamds build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-mpc8349eamds-no-\
>       posix.ini
>             this function)
>             function)
>             only 1 given
>   39 posix powerpc/mpc8349eamds build:
>       posix.ini
>             this function)
>             function)
>             only 1 given
>   40 posix-debug powerpc/mpc8349eamds build:
>       posix-debug.ini
>             this function)
>             function)
>             only 1 given
>   41 posix-profiling powerpc/mpc8349eamds build:
>       posix-profiling.ini
>             this function)
>             function)
>             only 1 given
>   42 profiling powerpc/mpc8349eamds build:
>       profiling.ini
>             this function)
>             function)
>             only 1 given
>   43 debug powerpc/phycore_mpc5554 build:
>       phycore_mpc5554-debug.ini
>   44 no-posix powerpc/phycore_mpc5554 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-phycore_mpc5554\
>       -no-posix.ini
>   45 posix powerpc/phycore_mpc5554 build:
>       phycore_mpc5554-posix.ini
>   46 posix-debug powerpc/phycore_mpc5554 build:
>       -posix-debug.ini
>   47 posix-profiling powerpc/phycore_mpc5554 build:
>       -posix-profiling.ini
>   48 profiling powerpc/phycore_mpc5554 build:
>       phycore_mpc5554-profiling.ini
>   49 debug powerpc/qoriq_core_0 build:
>       qoriq_core_0-debug.ini
>      error: home/tester/bsps/powerpc/qoriq/start/mmu.c:401:24: error:
>             function)
>      error: home/tester/bsps/powerpc/qoriq/start/mmu.c:401:65: error:
>             only 1 given
>      error: home/tester/bsps/powerpc/qoriq/start/mmu.c:370:65: error:
>             only 1 given
>      error: home/tester/bsps/powerpc/qoriq/start/mmu.c:370:24: error:
>             function)
>      error: home/tester/bsps/powerpc/qoriq/start/mmu.c:373:82: error:
>             only 1 given
>   50 no-posix powerpc/qoriq_core_0 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_core_0-no-\
>       posix.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   51 posix powerpc/qoriq_core_0 build:
>       qoriq_core_0-posix.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   52 posix-debug powerpc/qoriq_core_0 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_core_0\
>       -posix-debug.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   53 posix-profiling powerpc/qoriq_core_0 build:
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   54 profiling powerpc/qoriq_core_0 build:
>       qoriq_core_0-profiling.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   55 debug powerpc/qoriq_core_1 build:
>       qoriq_core_1-debug.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   56 no-posix powerpc/qoriq_core_1 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_core_1-no-\
>       posix.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   57 posix powerpc/qoriq_core_1 build:
>       qoriq_core_1-posix.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   58 posix-debug powerpc/qoriq_core_1 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_core_1\
>       -posix-debug.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   59 posix-profiling powerpc/qoriq_core_1 build:
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   60 profiling powerpc/qoriq_core_1 build:
>       qoriq_core_1-profiling.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   61 debug powerpc/qoriq_e500 build:
>       qoriq_e500-debug.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   62 no-posix powerpc/qoriq_e500 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e500-no-\
>       posix.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   63 posix powerpc/qoriq_e500 build:
>       qoriq_e500-posix.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   64 posix-debug powerpc/qoriq_e500 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e500-posix-\
>       debug.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   65 posix-profiling powerpc/qoriq_e500 build:
>       profiling.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   66 profiling powerpc/qoriq_e500 build:
>       qoriq_e500-profiling.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   67 smp powerpc/qoriq_e500 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e500-smp.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   68 smp-debug powerpc/qoriq_e500 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e500-smp-\
>       debug.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   69 debug powerpc/qoriq_e6500_32 build:
>       qoriq_e6500_32-debug.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   70 no-posix powerpc/qoriq_e6500_32 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e6500_32-no-\
>       posix.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   71 posix powerpc/qoriq_e6500_32 build:
>       qoriq_e6500_32-posix.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   72 posix-debug powerpc/qoriq_e6500_32 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e6500_32\
>       -posix-debug.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   73 posix-profiling powerpc/qoriq_e6500_32 build:
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   74 profiling powerpc/qoriq_e6500_32 build:
>       qoriq_e6500_32-profiling.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   75 smp powerpc/qoriq_e6500_32 build:
>       qoriq_e6500_32-smp.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   76 smp-debug powerpc/qoriq_e6500_32 build:
>       -smp-debug.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   77 debug powerpc/qoriq_e6500_64 build:
>       qoriq_e6500_64-debug.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   78 no-posix powerpc/qoriq_e6500_64 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e6500_64-no-\
>       posix.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   79 posix powerpc/qoriq_e6500_64 build:
>       qoriq_e6500_64-posix.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   80 posix-debug powerpc/qoriq_e6500_64 build:
>       /rtems-cron-6/rtems --rtems-config=config-powerpc-qoriq_e6500_64\
>       -posix-debug.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   81 posix-profiling powerpc/qoriq_e6500_64 build:
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   82 profiling powerpc/qoriq_e6500_64 build:
>       qoriq_e6500_64-profiling.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   83 smp powerpc/qoriq_e6500_64 build:
>       qoriq_e6500_64-smp.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
>   84 smp-debug powerpc/qoriq_e6500_64 build:
>       -smp-debug.ini
>             function)
>             only 1 given
>             only 1 given
>             function)
>             only 1 given
> Warnings Report
>  | By Architecture (total : 9930)                                      |
>  | common : 14 warning(s)                                              |
>  |   Shared :  738 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :  168 |                |                 |
>  | arm : 32 warning(s)                                                 |
>  |   Shared :  192 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :  208 |                |                 |
>  | bfin : 32 warning(s)                                                |
>  |   Shared :  138 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :  234 | CPU Kit :   90 |                |                 |
>  | i386 : 31 warning(s)                                                |
>  |   Shared :    0 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :   60 |                |                 |
>  | lm32 : 14 warning(s)                                                |
>  |   Shared :  156 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :   72 |                |                 |
>  | m68k : 33 warning(s)                                                |
>  |   Shared :  936 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :  330 |                |                 |
>  | microblaze : 0 warning(s)                                           |
>  | mips : 8 warning(s)                                                 |
>  |   LibCPU :    0 | CPU Kit :   24 |                |                 |
>  | moxie : 2 warning(s)                                                |
>  |   Shared :   12 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :   18 |                |                 |
>  | nios2 : 0 warning(s)                                                |
>  | or1k : 1 warning(s)                                                 |
>  |   Shared :    6 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  | powerpc : 43 warning(s)                                             |
>  |   Shared :  254 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :   12 | CPU Kit :  148 |                |                 |
>  | sh : 162 warning(s)                                                 |
>  |   Shared :   84 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :   84 |                |                 |
>  | sparc : 4 warning(s)                                                |
>  |   LibCPU :    0 | CPU Kit :    0 |                |                 |
>  | sparc64 : 2 warning(s)                                              |
>  |   Shared :   36 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  | v850 : 1 warning(s)                                                 |
>  |   Shared :   72 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :   36 |                |                 |
>  | x86_64 : 1 warning(s)                                               |
>  |   LibCPU :    0 | CPU Kit :    6 |                |                 |
>  | By BSP (total : 9930)                                               |
>  | common : 275 warning(s)                                             |
>  |   Shared : 1584 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :   96 | CPU Kit :  912 |                |                 |
>  | arm/altcycv_devkit : 7 warning(s)                                   |
>  | arm/atsamv : 6 warning(s)                                           |
>  | arm/csb336 : 0 warning(s)                                           |
>  | arm/csb337 : 0 warning(s)                                           |
>  | arm/csb637 : 0 warning(s)                                           |
>  | arm/gumstix : 0 warning(s)                                          |
>  | arm/imx7 : 2 warning(s)                                             |
>  |   LibCPU :    0 | CPU Kit :   32 |                |                 |
>  | arm/imxrt1052 : 0 warning(s)                                        |
>  | arm/kit637_v6 : 0 warning(s)                                        |
>  | arm/lm3s3749 : 0 warning(s)                                         |
>  | arm/lm3s6965 : 0 warning(s)                                         |
>  | arm/lm3s6965_qemu : 0 warning(s)                                    |
>  | arm/lm4f120 : 0 warning(s)                                          |
>  | arm/lpc1768_mbed : 0 warning(s)                                     |
>  | arm/lpc1768_mbed_ahb_ram : 0 warning(s)                             |
>  | arm/lpc1768_mbed_ahb_ram_eth : 0 warning(s)                         |
>  | arm/lpc17xx_ea_ram : 0 warning(s)                                   |
>  | arm/lpc17xx_ea_rom_int : 0 warning(s)                               |
>  | arm/lpc17xx_plx800_ram : 0 warning(s)                               |
>  | arm/lpc17xx_plx800_rom_int : 0 warning(s)                           |
>  | arm/lpc2362 : 0 warning(s)                                          |
>  | arm/lpc23xx_tli800 : 0 warning(s)                                   |
>  | arm/lpc24xx_ea : 0 warning(s)                                       |
>  | arm/lpc24xx_ncs_ram : 0 warning(s)                                  |
>  | arm/lpc24xx_ncs_rom_ext : 0 warning(s)                              |
>  | arm/lpc24xx_ncs_rom_int : 0 warning(s)                              |
>  | arm/lpc24xx_plx800_ram : 0 warning(s)                               |
>  | arm/lpc24xx_plx800_rom_int : 0 warning(s)                           |
>  | arm/lpc32xx_mzx : 0 warning(s)                                      |
>  | arm/lpc32xx_mzx_stage_1 : 0 warning(s)                              |
>  | arm/lpc32xx_mzx_stage_2 : 0 warning(s)                              |
>  | arm/lpc32xx_phycore : 0 warning(s)                                  |
>  | arm/lpc40xx_ea_ram : 0 warning(s)                                   |
>  | arm/lpc40xx_ea_rom_int : 0 warning(s)                               |
>  | arm/nucleo-h743zi : 0 warning(s)                                    |
>  | arm/raspberrypi : 0 warning(s)                                      |
>  | arm/raspberrypi2 : 0 warning(s)                                     |
>  | arm/realview_pbx_a9_qemu : 0 warning(s)                             |
>  | arm/smdk2410 : 0 warning(s)                                         |
>  | arm/stm32f105rc : 0 warning(s)                                      |
>  | arm/stm32f4 : 2 warning(s)                                          |
>  | arm/stm32h7 : 0 warning(s)                                          |
>  | arm/stm32h747i-disco : 0 warning(s)                                 |
>  | arm/stm32h747i-disco-m4 : 0 warning(s)                              |
>  | arm/stm32h757i-eval : 0 warning(s)                                  |
>  | arm/stm32h757i-eval-m4 : 0 warning(s)                               |
>  | arm/stm32h7b3i-dk : 0 warning(s)                                    |
>  | arm/xilinx_zynqmp_ultra96 : 1 warning(s)                            |
>  | bfin/TLL6527M : 11 warning(s)                                       |
>  |   Shared :   42 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :  138 | CPU Kit :   30 |                |                 |
>  | bfin/bf537Stamp : 0 warning(s)                                      |
>  | bfin/eZKit533 : 0 warning(s)                                        |
>  | i386/pc386 : 0 warning(s)                                           |
>  | i386/pc486 : 0 warning(s)                                           |
>  | i386/pc586 : 0 warning(s)                                           |
>  | i386/pc586-sse : 0 warning(s)                                       |
>  | i386/pc686 : 0 warning(s)                                           |
>  | i386/pcp4 : 0 warning(s)                                            |
>  | lm32/lm32_evr : 0 warning(s)                                        |
>  | lm32/lm32_evr_gdbsim : 0 warning(s)                                 |
>  | lm32/milkymist : 12 warning(s)                                      |
>  |   Shared :   96 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  | m68k/COBRA5475 : 0 warning(s)                                       |
>  | m68k/av5282 : 0 warning(s)                                          |
>  | m68k/csb360 : 0 warning(s)                                          |
>  | m68k/gen68340 : 0 warning(s)                                        |
>  | m68k/gen68360 : 2 warning(s)                                        |
>  |   Shared :   18 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :   12 |                |                 |
>  | m68k/gen68360_040 : 0 warning(s)                                    |
>  | m68k/m5484FireEngine : 3 warning(s)                                 |
>  |   Shared :   66 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  | m68k/mcf5206elite : 1 warning(s)                                    |
>  |   Shared :   78 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  | m68k/mcf52235 : 3 warning(s)                                        |
>  | m68k/mcf5225x : 3 warning(s)                                        |
>  | m68k/mcf5235 : 1 warning(s)                                         |
>  | m68k/mcf5329 : 3 warning(s)                                         |
>  | m68k/mrm332 : 0 warning(s)                                          |
>  | m68k/mvme147 : 0 warning(s)                                         |
>  | m68k/mvme147s : 0 warning(s)                                        |
>  | m68k/mvme162 : 0 warning(s)                                         |
>  | m68k/mvme162lx : 0 warning(s)                                       |
>  | m68k/mvme167 : 0 warning(s)                                         |
>  | m68k/pgh360 : 0 warning(s)                                          |
>  | m68k/uC5282 : 6 warning(s)                                          |
>  | microblaze/kcu105 : 0 warning(s)                                    |
>  | microblaze/kcu105_qemu : 0 warning(s)                               |
>  | mips/hurricane : 1 warning(s)                                       |
>  | mips/malta : 6 warning(s)                                           |
>  | mips/rbtx4938 : 1 warning(s)                                        |
>  | moxie/moxiesim : 2 warning(s)                                       |
>  | nios2/nios2_iss : 0 warning(s)                                      |
>  | or1k/generic_or1k : 1 warning(s)                                    |
>  | powerpc/beatnik : 2 warning(s)                                      |
>  |   LibCPU :   12 | CPU Kit :    4 |                |                 |
>  | powerpc/gwlcfm : 0 warning(s)                                       |
>  | powerpc/icecube : 0 warning(s)                                      |
>  | powerpc/mcp750 : 0 warning(s)                                       |
>  | powerpc/mpc5643l_evb : 0 warning(s)                                 |
>  | powerpc/mpc5668g : 0 warning(s)                                     |
>  | powerpc/mpc8260ads : 0 warning(s)                                   |
>  | powerpc/mtx603e : 0 warning(s)                                      |
>  | powerpc/mvme2100 : 0 warning(s)                                     |
>  | powerpc/mvme2307 : 0 warning(s)                                     |
>  | powerpc/mvme3100 : 1 warning(s)                                     |
>  |   LibCPU :    0 | CPU Kit :    4 |                |                 |
>  | powerpc/mvme5500 : 2 warning(s)                                     |
>  | powerpc/pghplus : 0 warning(s)                                      |
>  | powerpc/pm520_cr825 : 0 warning(s)                                  |
>  | powerpc/pm520_ze30 : 0 warning(s)                                   |
>  | powerpc/psim : 1 warning(s)                                         |
>  | powerpc/qemuppc : 1 warning(s)                                      |
>  | powerpc/qemuprep : 0 warning(s)                                     |
>  | powerpc/qemuprep-altivec : 0 warning(s)                             |
>  | powerpc/qoriq_e500 : 0 warning(s)                                   |
>  | powerpc/qoriq_e6500_32 : 0 warning(s)                               |
>  | powerpc/qoriq_e6500_64 : 13 warning(s)                              |
>  |   Shared :   98 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  | powerpc/ss555 : 2 warning(s)                                        |
>  | powerpc/t32mppc : 4 warning(s)                                      |
>  |   LibCPU :    0 | CPU Kit :   52 |                |                 |
>  | powerpc/tqm8xx_stk8xx : 0 warning(s)                                |
>  | powerpc/virtex : 0 warning(s)                                       |
>  | powerpc/virtex4 : 0 warning(s)                                      |
>  | powerpc/virtex5 : 0 warning(s)                                      |
>  | sh/gensh1 : 1 warning(s)                                            |
>  | sh/gensh2 : 1 warning(s)                                            |
>  | sh/gensh4 : 1 warning(s)                                            |
>  | sh/simsh1 : 0 warning(s)                                            |
>  | sh/simsh2 : 0 warning(s)                                            |
>  | sh/simsh2e : 0 warning(s)                                           |
>  | sh/simsh4 : 0 warning(s)                                            |
>  | sparc/at697f : 0 warning(s)                                         |
>  | sparc/gr712rc : 0 warning(s)                                        |
>  | sparc/gr740 : 0 warning(s)                                          |
>  | sparc/leon2 : 0 warning(s)                                          |
>  | sparc/leon3 : 0 warning(s)                                          |
>  | sparc/ut699 : 0 warning(s)                                          |
>  | sparc/ut700 : 0 warning(s)                                          |
>  | sparc64/niagara : 0 warning(s)                                      |
>  | sparc64/usiii : 1 warning(s)                                        |
>  | v850/v850e1sim : 0 warning(s)                                       |
>  | v850/v850e2sim : 0 warning(s)                                       |
>  | v850/v850e2v3sim : 0 warning(s)                                     |
>  | v850/v850esim : 0 warning(s)                                        |
>  | v850/v850essim : 0 warning(s)                                       |
>  | v850/v850sim : 0 warning(s)                                         |
>  | x86_64/amd64 : 1 warning(s)                                         |
>  | By Build (total : 9930)                                             |
>  | common : 378 warning(s)                                             |
>  |   Shared : 1543 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :  205 | CPU Kit :  922 |                |                 |
>  | debug : 2 warning(s)                                                |
>  |   Shared :  301 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :   41 | CPU Kit :  222 |                |                 |
>  | no-posix : 0 warning(s)                                             |
>  | posix : 0 warning(s)                                                |
>  | posix-debug : 0 warning(s)                                          |
>  | posix-profiling : 0 warning(s)                                      |
>  | profiling : 0 warning(s)                                            |
>  | smp : 0 warning(s)                                                  |
>  | smp-debug : 0 warning(s)                                            |
> build mailing list
> http://lists.rtems.org/mailman/listinfo/build
> <http://lists.rtems.org/mailman/listinfo/build>
