FW: Change build specification files from YAML to JSON?
Andrew.Butterfield at scss.tcd.ie
Mon Apr 24 09:58:13 UTC 2023
Hi Sebastian,
would this also affect the specification item YAML files in RTEMS Central?
I have no strong opinions about this either way.
Regards,
Andrew
Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
Lero at TCD, Head of Software Foundations & Verification Research Group
School of Computer Science and Statistics,
Room G.39, O'Reilly Institute, Trinity College, University of Dublin
http://www.scss.tcd.ie/Andrew.Butterfield/ <http://www.scss.tcd.ie/Andrew.Butterfield/> <http://www.scss.tcd.ie/Andrew.Butterfield/> <http://www.scss.tcd.ie/Andrew.Butterfield/>>
On 24/04/2023, 10:32, "devel on behalf of Sebastian Huber" <devel-bounces at rtems.org <mailto:devel-bounces at rtems.org> <mailto:devel-bounces at rtems.org <mailto:devel-bounces at rtems.org>> on behalf of sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de> <mailto:sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>> wrote:
Hello,
I would like to change the build specification files from YAML to JSON
to get rid of the complicated caching mechanism. Python has a built in
JSON loader which is quite fast compared to the YAML loader. For the
configure/build steps we have to load all items currently due to the
item pickle cache (about 2000 files). With the built in JSON support we
can optimize this to only load the required files (probably less than
100 if the test suite is disabled).
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
email: sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de> <mailto:sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
https://embedded-brains.de/datenschutzerklaerung/ <https://embedded-brains.de/datenschutzerklaerung/> <https://embedded-brains.de/datenschutzerklaerung/> <https://embedded-brains.de/datenschutzerklaerung/>>
devel mailing list
devel at rtems.org <mailto:devel at rtems.org> <mailto:devel at rtems.org <mailto:devel at rtems.org>>
http://lists.rtems.org/mailman/listinfo/devel <http://lists.rtems.org/mailman/listinfo/devel> <http://lists.rtems.org/mailman/listinfo/devel> <http://lists.rtems.org/mailman/listinfo/devel>>
