Qemu and missing dynamic libraries
Mon Apr 24 19:33:43 UTC 2023
On Mon, Apr 24, 2023, 2:11 PM Karel Gardas <karel at functional.vision> wrote:
> What have you done to this poor FBSD? ;-)
> Anyway, I've just pkg update; pkg upgrade and result is:
> karel at rtems:/usr/local/lib $ ls -la libglib-2.0.*
> -rw-r--r--  1 root  wheel  2434866 Apr  2 03:18 libglib-2.0.a
> lrwxr-xr-x  1 root  wheel       16 Apr  2 03:19 libglib-2.0.so ->
> libglib-2.0.so.0
> lrwxr-xr-x  1 root  wheel       23 Apr  2 03:19 libglib-2.0.so.0 ->
> libglib-2.0.so.0.7600.1
> -rwxr-xr-x  1 root  wheel  1332424 Apr  2 03:19 libglib-2.0.so.0.7600.1
> karel at rtems:/usr/local/lib $ ls -la libintl.*
> -rw-r--r--  1 root  wheel  115868 Jan  3 02:12 libintl.a
> lrwxr-xr-x  1 root  wheel      16 Jan  3 02:12 libintl.so ->
> libintl.so.8.3.0
> lrwxr-xr-x  1 root  wheel      16 Jan  3 02:12 libintl.so.8 ->
> libintl.so.8.3.0
> -rw-r--r--  1 root  wheel   55552 Jan  3 02:12 libintl.so.8.3.0
> karel at rtems:/usr/local/lib $ ldd libglib-2.0.so.0.7600.1
> libglib-2.0.so.0.7600.1:
>          libiconv.so.2 => /usr/local/lib/libiconv.so.2 (0x1385d09a2000)
>          libintl.so.8 => /usr/local/lib/libintl.so.8 (0x1385d19dc000)
>          libpcre2-8.so.0 => /usr/local/lib/libpcre2-8.so.0 (0x1385d23ff000)
>          libutil.so.9 => /lib/libutil.so.9 (0x1385d27d9000)
>          libthr.so.3 => /lib/libthr.so.3 (0x1385d2e51000)
>          libc.so.7 => /lib/libc.so.7 (0x1385cdce8000)
> so in the worst case you would need to do some house cleaning...
Just got this to repeat with someone in the class this week with Ubuntu 22
in a VM. The needed dynamic libraries are installed with the RTEMS tools in
lib64. Weird
> And while doing that, you may as well upgrade 13.1 -> 13.2.
> Good luck!
> Karel
> On 4/24/23 20:28, Joel Sherrill wrote:
> > Hi
> > It looks like something has broken recently with building qemu via the
> > RSB and dynamic libraries. All invocations of qemu are failing
> > https://lists.rtems.org/pipermail/build/2023-April/044792.html
> > <https://lists.rtems.org/pipermail/build/2023-April/044792.html>
> > Not sure what to do. Maybe LD_LIBRARY_PATH but that wasn't needed before
> > --joel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230424/9a0da5eb/attachment.htm>
