Qemu and missing dynamic libraries
Karel Gardas
karel at functional.vision
Mon Apr 24 20:11:52 UTC 2023
On 4/24/23 21:33, Joel Sherrill wrote:
> On Mon, Apr 24, 2023, 2:11 PM Karel Gardas <karel at functional.vision> wrote:
> What have you done to this poor FBSD? ;-)
> Anyway, I've just pkg update; pkg upgrade and result is:
> karel at rtems:/usr/local/lib $ ls -la libglib-2.0.*
> -rw-r--r-- 1 root wheel 2434866 Apr 2 03:18 libglib-2.0.a
> lrwxr-xr-x 1 root wheel 16 Apr 2 03:19 libglib-2.0.so
> <http://libglib-2.0.so> ->
> libglib-2.0.so.0
> lrwxr-xr-x 1 root wheel 23 Apr 2 03:19 libglib-2.0.so.0 ->
> libglib-2.0.so.0.7600.1
> -rwxr-xr-x 1 root wheel 1332424 Apr 2 03:19 libglib-2.0.so.0.7600.1
> karel at rtems:/usr/local/lib $ ls -la libintl.*
> -rw-r--r-- 1 root wheel 115868 Jan 3 02:12 libintl.a
> lrwxr-xr-x 1 root wheel 16 Jan 3 02:12 libintl.so ->
> libintl.so.8.3.0
> lrwxr-xr-x 1 root wheel 16 Jan 3 02:12 libintl.so.8 ->
> libintl.so.8.3.0
> -rw-r--r-- 1 root wheel 55552 Jan 3 02:12 libintl.so.8.3.0
> karel at rtems:/usr/local/lib $ ldd libglib-2.0.so.0.7600.1
> libglib-2.0.so.0.7600.1:
> libiconv.so.2 => /usr/local/lib/libiconv.so.2 (0x1385d09a2000)
> libintl.so.8 => /usr/local/lib/libintl.so.8 (0x1385d19dc000)
> libpcre2-8.so.0 => /usr/local/lib/libpcre2-8.so.0
> (0x1385d23ff000)
> libutil.so.9 => /lib/libutil.so.9 (0x1385d27d9000)
> libthr.so.3 => /lib/libthr.so.3 (0x1385d2e51000)
> libc.so.7 => /lib/libc.so.7 (0x1385cdce8000)
> so in the worst case you would need to do some house cleaning...
> Just got this to repeat with someone in the class this week with Ubuntu
> 22 in a VM. The needed dynamic libraries are installed with the RTEMS
> tools in lib64. Weird
This sounds strange. First of all, your original report was about FBSD
13.1-p6. Obviously you have not been lucky and glib package maintainer
published library requiring libintl.so.9 and then probably reverted to
.8. So high chance is pkg update; pkg upgrade may solve the issue.
W.r.t. RTEMS tools installing glib/libintl ? Never heard/seen anything
like that and Ubuntu is pretty close to home call here...
Karel
