[PATCH] score: Simplify _Objects_Is_api_valid()
Sebastian Huber
Tue Apr 25 06:34:53 UTC 2023
On 23.03.23 17:46, Joel Sherrill wrote:
> On Thu, Mar 23, 2023 at 11:09 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 23.03.23 17:03, Joel Sherrill wrote:
> > On Thu, Mar 23, 2023 at 10:40 AM Sebastian Huber
> <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> > Close #4863.
> > cpukit/include/rtems/score/objectimpl.h | 4 +---
> > 1 file changed, 1 insertion(+), 3 deletions(-)
> > diff --git a/cpukit/include/rtems/score/objectimpl.h
> > b/cpukit/include/rtems/score/objectimpl.h
> > index c58957ccb5..a1a87b5ccb 100644
> > --- a/cpukit/include/rtems/score/objectimpl.h
> > +++ b/cpukit/include/rtems/score/objectimpl.h
> > @@ -542,9 +542,7 @@ static inline bool _Objects_Is_api_valid(
> > uint32_t the_api
> > - if ( !the_api || the_api > OBJECTS_APIS_LAST )
> > - return false;
> > - return true;
> > + return ( 1 <= the_api && the_api <= OBJECTS_APIS_LAST );
> > I'd really prefer we avoid compound logical expressions since it
> > becomes something that needs MCDC analysis at higher levels
> > of verification/qualification.
> How does this simplify MC/DC analysis? The truth table doesn't
> change if
> I replace a short-circuit boolean expression with if + return.
> gcov cannot directly do mcdc analysis but using simple expressions
> avoids the introduction of those cases. So gcov reports can be equivalent
> of an expensive MCDC analysis tool.
> I'm at the FSW this week and one of the NASA Johnson people shared
> information on an open source tool and way to use gcov where you
> are guaranteed to have gcov reports cover this. I'm going to experiment
> with this when I get home. If it is as easy as it sounds, I'll write up
> something
> on the technique and we can discuss if we want to apply this to RTEMS.
> I think we do since it would allow us to use gcov to ensure we do
> MCDC level analysis as required by the highest level of all the safety
> standards I know.
Any news with respect to this topic?
> > Please rewrite using simple logical expressions even if it means
> > two exit paths at the source leve. It's the same machine code.
> Yes.
Do you really want to change
uint32_t the_api
in
uint32_t the_api
if ( the_api < 1 ) {
return false;
if ( the_api > OBJECTS_APIS_LAST ) {
return false;
return true;
I am not really sure why we should do this.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
