[PATCH 4/5] build: Rename TOPGROUP in TOPGROUP_UID
Sebastian Huber
Wed Apr 26 08:04:02 UTC 2023
This makes it more obvious that this is an item UID.
wscript | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/wscript b/wscript
index 143ee722e2..cb5674b5b9 100755
--- a/wscript
+++ b/wscript
@@ -1511,12 +1511,12 @@ def configure_variant(conf, cp, bsp_map, path_list, top_group, variant):
conf.env["TOP"] = conf.path.abspath()
- conf.env["TOPGROUP"] = top_group
+ conf.env["TOPGROUP_UID"] = top_group
conf.env["VARIANT"] = variant
prepare_rtems_options(conf)
cic = ConfigItemContext(cp, path_list)
- items[conf.env.TOPGROUP].configure(conf, cic)
+ items[conf.env.TOPGROUP_UID].configure(conf, cic)
bsp_item.configure(conf, cic)
options = set([o[0].upper() for o in cp.items(variant)])
@@ -1640,7 +1640,7 @@ def build(bld):
bic = BuildItemContext(bld.env.ARCH_INCLUDES.split(), [], [], [], [], [],
bsps[bld.env.ARCH][bld.env.BSP_BASE].build(bld, bic)
- items[bld.env.TOPGROUP].build(bld, bic)
+ items[bld.env.TOPGROUP_UID].build(bld, bic)
def add_log_filter(name):
2.35.3
