[PATCH 5/5] build: Load items on demand during a build
Wed Apr 26 08:04:03 UTC 2023
If the CSafeLoader is available, load only the necessary build items.
This considerably speeds up the build setup time if the CSafeLoader is
used.
 wscript | 27 +++++++++++++++++++++++++--
 1 file changed, 25 insertions(+), 2 deletions(-)
diff --git a/wscript b/wscript
index cb5674b5b9..3b7c4f9fe7 100755
--- a/wscript
+++ b/wscript
@@ -1170,6 +1170,22 @@ try:
             super(ItemCache, self).__init__()
             self.spec_directories = []
+        def __missing__(self, uid):
+            name = uid + ".yml"
+            for path in self.spec_directories:
+                path2 = os.path.join(path, name[1:])
+                try:
+                    with open(path2, "r") as f:
+                        content = f.read()
+                except OSError:
+                    pass
+                else:
+                    data = load(content, SafeLoader)
+                    item = ctors[data["build-type"]](uid, data)
+                    self[uid] = item
+                    return item
+            raise KeyError
         def set_spec_directories(self, spec_directories):
             self.spec_directories = spec_directories
@@ -1199,6 +1215,9 @@ try:
                 self.load_from_yaml(path, path)
+        def load_on_demand(self, ctx):
+            pass
 except ImportError:
     # Fall back to the Python implementation provided by the project.  This
@@ -1299,6 +1318,9 @@ except ImportError:
                 load_items_in_directory(ctx, path)
+            self.load_all(ctx)
 items = ItemCache()
@@ -1499,6 +1521,7 @@ def configure_variant(conf, cp, bsp_map, path_list, top_group, variant):
     conf.env["BSP_BASE"] = bsp_base
     conf.env["BSP_NAME"] = bsp_name
     conf.env["BSP_FAMILY"] = family
+    conf.env["BSP_UID"] = bsp_item.uid
     conf.env["DEST_OS"] = "rtems"
     # For the enabled-by evaluation we have to use the base BSP defined by the
@@ -1633,13 +1656,13 @@ def build(bld):
         items.set_spec_directories(bld.env.SPECS)
-        items.load_all(bld)
+        items.load_on_demand(bld)
         append_variant_builds(bld)
         return
     long_command_line_workaround(bld)
     bic = BuildItemContext(bld.env.ARCH_INCLUDES.split(), [], [], [], [], [],
-    bsps[bld.env.ARCH][bld.env.BSP_BASE].build(bld, bic)
+    items[bld.env.BSP_UID].build(bld, bic)
     items[bld.env.TOPGROUP_UID].build(bld, bic)
2.35.3
