[PATCH 2/2] RISC-V: Test rv32i and rv32imafdc on QEMU
Hesham Almatary
Hesham.Almatary at cl.cam.ac.uk
Mon Feb 6 08:51:50 UTC 2023
This needs to be merged for the tests to pass.
On Mon, 9 Jan 2023 at 18:28, Hesham Almatary
<Hesham.Almatary at cl.cam.ac.uk> wrote:
> Is this patchset fine to merge?
> On Fri, 23 Dec 2022 at 09:25, <heshamelmatary at gmail.com> wrote:
> > From: Hesham Almatary <hesham.almatary at cl.cam.ac.uk>
> > Updates #4775
> > tester/rtems/testing/bsps/rv32i.ini | 37 ++++++++++++++++++++++++
> > tester/rtems/testing/bsps/rv32imafdc.ini | 37 ++++++++++++++++++++++++
> > 2 files changed, 74 insertions(+)
> > create mode 100644 tester/rtems/testing/bsps/rv32i.ini
> > create mode 100644 tester/rtems/testing/bsps/rv32imafdc.ini
> > diff --git a/tester/rtems/testing/bsps/rv32i.ini b/tester/rtems/testing/bsps/rv32i.ini
> > new file mode 100644
> > index 0000000..1817216
> > --- /dev/null
> > +++ b/tester/rtems/testing/bsps/rv32i.ini
> > @@ -0,0 +1,37 @@
> > +# RTEMS Tools Project (http://www.rtems.org/)
> > +# Copyright 2020 Hesham Almatary
> > +# Copyright 2018 embedded brains GmbH
> > +# All rights reserved.
> > +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> > +# Redistribution and use in source and binary forms, with or without
> > +# modification, are permitted provided that the following conditions are met:
> > +# 1. Redistributions of source code must retain the above copyright notice,
> > +# this list of conditions and the following disclaimer.
> > +# 2. Redistributions in binary form must reproduce the above copyright notice,
> > +# this list of conditions and the following disclaimer in the documentation
> > +# and/or other materials provided with the distribution.
> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> > +# POSSIBILITY OF SUCH DAMAGE.
> > +[rv32i]
> > +bsp = rv32i
> > +arch = riscv32
> > +tester = %{_rtscripts}/qemu.cfg
> > +bsp_qemu_image_type = -bios
> > +bsp_qemu_opts = -no-reboot -nographic %{qemu_opts_no_net} -machine virt -m 128M
> > diff --git a/tester/rtems/testing/bsps/rv32imafdc.ini b/tester/rtems/testing/bsps/rv32imafdc.ini
> > index 0000000..2f91a9a
> > --- /dev/null
> > +++ b/tester/rtems/testing/bsps/rv32imafdc.ini
> > @@ -0,0 +1,37 @@
> > +[rv32imafdc]
> > +bsp = rv32imafdc
> > +arch = riscv32
> > 2.25.1
