libbsd development policy clarification needed?
Christian MAUDERER
christian.mauderer at embedded-brains.de
Mon Feb 6 09:02:55 UTC 2023
On 2023-02-05 11:38, Christian Mauderer wrote:
> Am 04.02.23 um 01:25 schrieb Gedare Bloom:
>> On Fri, Feb 3, 2023 at 3:29 PM Christian Mauderer <oss at c-mauderer.de>
>> wrote:
>>> Am 3. Februar 2023 22:52:48 MEZ schrieb Gedare Bloom <gedare at rtems.org>:
>>>> On Fri, Feb 3, 2023 at 2:39 PM Christian Mauderer
>>>> <oss at c-mauderer.de> wrote:
>>>>> Am 3. Februar 2023 22:12:06 MEZ schrieb Gedare Bloom
>>>>>> On Fri, Feb 3, 2023 at 12:52 PM <oss at c-mauderer.de> wrote:
>>>>>>> Hello Gedare,
>>>>>>> Am 03.02.23 um 19:51 schrieb Gedare Bloom:
>>>>>>>> On Thu, Feb 2, 2023 at 11:24 PM Christian MAUDERER
>>>>>>>> <christian.mauderer at embedded-brains.de> wrote:
>>>>>>>>> Hello Karel,
>>>>>>>>> On 2023-02-02 12:43, Karel Gardas wrote:
>>>>>>>>>> Guys,
>>>>>>>>>> recently I needed to work with RTEMS/NFS. As this is provided
>>>>>>>>>> by libbsd
>>>>>>>>>> I took this and following two sentences below from master branch
>>>>>>>>>> description provided in README I took as granted that master
>>>>>>>>>> does have
>>>>>>>>>> all the features which are currently available and provided by
>>>>>>>>>> the project:
>>>>>>>>>> "This branch must be used for libbsd development. Back ports
>>>>>>>>>> to the
>>>>>>>>>> 6-freebsd-12 are allowed."
>>>>>>>>>> I was surprised to be proven wrong then by Fabrizio here:
>>>>>>>>>> https://devel.rtems.org/ticket/4723
>>>>>>>>>> and by later investigation which shows that 6-freebsd-12 branch
>>>>>>>>>> accumulated NFS work by Chris done in 2021 which is not
>>>>>>>>>> presented on
>>>>>>>>>> master. I've investigated just NFS as this was my focus here.
>>>>>>>>>> So if 6-freebsd-12 became development branch of some sort,
>>>>>>>>>> then it would
>>>>>>>>>> be great to have that clarified in the project README file to
>>>>>>>>>> prevent
>>>>>>>>>> users confusion? Or if the policy is still the same, then
>>>>>>>>>> perhaps some
>>>>>>>>>> branch sync is needed here?
>>>>>>>>> That currently is an open issue. Basically there is a pending
>>>>>>>>> patch set
>>>>>>>>> that should fix that since several months. But there is a
>>>>>>>>> disagreement
>>>>>>>>> about some of the changes in that patch set (and about the patches
>>>>>>>>> checked in to 6-freebsd-12). Therefore, it still hasn't been
>>>>>>>>> merged.
>>>>>>>>> If you want to know some more about the problematic points, I
>>>>>>>>> recommend
>>>>>>>>> reading this (long) thread:
>>>>>>>>> https://lists.rtems.org/pipermail/devel/2023-January/074164.html
>>>>>>>>> The statement that development has to happen on the master
>>>>>>>>> branch is
>>>>>>>>> still true. The master is intended to track the FreeBSD upstream
>>>>>>>>> development. Only changes on that branch are guaranteed to live
>>>>>>>>> through
>>>>>>>>> an upgrade to a newer base version of FreeBSD. It's very
>>>>>>>>> unfortunate,
>>>>>>>>> that there are some patches on the 6-freebsd-12 branch only. On
>>>>>>>>> the long
>>>>>>>>> term, that issue has to be resolved.
>>>>>>>> I have been investigating this problem in the background, and I
>>>>>>>> have
>>>>>>>> some findings and some questions. First, I have found that there
>>>>>>>> is a
>>>>>>>> most-common ancestor between master and 6-freebsd-12 at commit
>>>>>>>> https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=2ce13cf6dc73855f28bc7edbbc64dc4b482a4976
>>>>>>>> This is at least promising that the discrepancy between the
>>>>>>>> branches
>>>>>>>> can be resolved.
>>>>>>>> The proposed pending patch set to "fix" the NFS issue does not
>>>>>>>> fix the
>>>>>>>> underlying problem. Instead, it introduces further divergence
>>>>>>>> between
>>>>>>>> the branches. I would instead suggest that we should resolve to fix
>>>>>>>> the underlying problem. I can see two paths forward.
>>>>>>>> 1. Abandon 6-freebsd-12 after releasing 6. This is probably not
>>>>>>>> ideal
>>>>>>>> since what I understand is some users have projects based on
>>>>>>>> 6-freebsd-12 and would like an upgrade path. (I guess there is also
>>>>>>>> the option to abandon master, which also makes little sense.)
>>>>>>> A variant for this would be to introduce a 6-freebsd-13 that is
>>>>>>> based on
>>>>>>> the master branch as soon as we have one. That would allow a longer
>>>>>>> maintenance because FreeBSD 12 reaches it's EoL December 2023.
>>>>>>>> 2. Pull commits from 6-freebsd-12 into master to make sure
>>>>>>>> master is
>>>>>>>> the development head. in the future, reject patches that only go
>>>>>>>> toward release branches. This has its own problems too. It can
>>>>>>>> realistically only be done in three ways:
>>>>>>> Please note that Sebastian mentioned that the file descriptors
>>>>>>> broke the
>>>>>>> NTP support (at least I think it was NTP; possible that it was
>>>>>>> another
>>>>>>> submodule). So picking the current version of the patches into the
>>>>>>> master without adding fixes makes the master unusable for some
>>>>>>> cases.
>>>>>> Fixing the problems after making the branches the same will be better
>>>>>> for the long-term, if we can find a path to do it.
>>>>>>>> 2a: Rebase master and cherry-pick commits from 6-freebsd-12 and
>>>>>>>> master
>>>>>>>> back into master. This rewrites the history of master, and
>>>>>>>> unfortunately will cause the head of 5-freebsd-12 and the tags for
>>>>>>>> rtems-5 to no longer exist on the master branch. They will still
>>>>>>>> exist
>>>>>>>> in the '5' branch. The advantage is in the end there will be a
>>>>>>>> linear
>>>>>>>> history of development on master that reflects the timeline of
>>>>>>>> actual
>>>>>>>> development that spanned both branches. Theoretically, this should
>>>>>>>> make it easier to git-bisect.
>>>>>>>> 2b: Cherry-pick commits from 6-freebsd-12 to master and fix
>>>>>>>> conflicts.
>>>>>>>> This puts all the missing commits from 6-freebsd-12 on to the
>>>>>>>> current
>>>>>>>> head of master. I don't know how messy this would be. It ends up
>>>>>>>> making the history of master convoluted to understand, with
>>>>>>>> fairly old
>>>>>>>> commits from 2018 being placed on top of newer commits from 2020s.
>>>>>>>> 2c: Merge 6-freebsd-12 into master and fixup conflicts in the merge
>>>>>>>> commit. This is pretty similar to 2a but ends up with a non-linear
>>>>>>>> history and a merge commit. It may be a fairly complex merge
>>>>>>>> commit.
>>>>>>> For all of the 2x solutions: The commits from 6-freebsd-12 can't
>>>>>>> just be
>>>>>>> cherry-picked. You have to re-import the NFS files from the FreeBSD
>>>>>>> master version that is used as base for the current libbsd master.
>>>>>>> Otherwise we mix different FreeBSD source versions. We had that some
>>>>>>> time back in libbsd and Sebastian needed a lot of time cleaning
>>>>>>> that up.
>>>>>> Understood.
>>>>>>>> To get a sense of the difference between the two branches, I
>>>>>>>> have done
>>>>>>>> the following command:
>>>>>>>> $ git log --pretty=oneline master...6-freebsd-12 > ../log.txt
>>>>>>>> This uses the ... (three-dot) Symmetric Difference Notation. The
>>>>>>>> result of that is a 750 line file, so 750 commits are different
>>>>>>>> between the two branches. Some of those commits are actually the
>>>>>>>> same
>>>>>>>> content, but they have different parents so different hashes. In a
>>>>>>>> rebase or merge situation, those commits should end up the same.
>>>>>>>> There
>>>>>>>> may be other git-fu to find just the patches that are unique in the
>>>>>>>> two branches.
>>>>>>> 750 commits are a bit too much. The order of patches on master and
>>>>>>> 6-freebsd-12 isn't always the same. I wrote a small python script to
>>>>>>> find the differences somewhere in 2021 when I needed the
>>>>>>> differences in
>>>>>>> a discussion with (I think) Joel. It compares based on author and
>>>>>>> subject which gives a quite good estimate for libbsd. You can
>>>>>>> find the
>>>>>>> script here:
>>>>>>> https://gist.github.com/a82e21eb250cb96c3a36f107b92dab09
>>>>>>> That shows 138 different commits. 86 are only on 6-freebsd-12.
>>>>>>> Complete
>>>>>>> output is here:
>>>>>>> https://gist.github.com/93a2b19a5bf4cd8a6263ae29aa359ac2
>>>>>>> From these you can ignore the "Update to FreeBSD..." commits
>>>>>>> and some
>>>>>>> of the cleanup patches. I assume that quite some of them can be
>>>>>>> cherry-picked with only small or no changes. For example patches
>>>>>>> that
>>>>>>> only add or update drivers in rtemsbsd should work without
>>>>>>> problems. So
>>>>>>> I think a more realistic number of problematic patches should be
>>>>>>> 30 to 50.
>>>>>> Oh, thanks, this is nice. It may be a reasonable place to start by
>>>>>> looking at what is "Only on master" and to consider back-porting to
>>>>>> 6-freebsd-12. That may reduce the delta somewhat in a way that makes
>>>>>> sense.
>>>>> We really should do the other direction. Not all features oft
>>>>> master have to be on the stable branch. But all features of the
>>>>> stable one should be on master.
>>>> I agree, but since there are many fewer changes only on master, if we
>>>> can merge those into 6-freebsd-12, then it becomes simpler to just
>>>> call 6-freebsd-12 as the new master. We can replace the current master
>>>> with this branch, and then update freebsd versions. I think this can
>>>> be a lower burden process to follow, except it requires acceptance of
>>>> the commits that are on 6-freebsd-12, which is a different matter.
>>> You can't just make 6-freebsd-12 a new master. It tracks the FreeBSD
>>> 12 branch.
>>> Every block of updates to a newer FreeBSD base revision was several
>>> days of work for Sebastian. There are a few on master.
>>> An upgrade from a branch tracking FreeBSD 12 to one tracking FreeBSD
>>> 13 is most likely more something in the several week range of work.
>>>>> master tracks the FreeBSD master. As soon as it reaches the point
>>>>> where FreeBSD branched off version 13, we can create a 6-freebsd-13
>>>>> or 7-freebsd-13 from master (depending on which RTEMS version we
>>>>> have then). All features not on master would be lost when we do that.
>>>>> The current 6-freebsd-12 on the other hand should be considered
>>>>> stable. We won't upgrade it to a 7-freensd-12 or similar. It will
>>>>> be a maintenance branch as soon as we reach the release. We can
>>>>> backport features that have been tested on master if there are
>>>>> users for that. But we don't have to. Just like we don't backport
>>>>> every new feature from RTEMS 6 to 5.
>>>> I view this as equivalent to the proposals to revert commits that are
>>>> on 6-freebsd-12. Doing this means that we are discarding quite a lot
>>>> of software engineering effort that was done on 6-freebsd-12. I would
>>>> rather that we determine a way that can retain that effort. At this
>>>> point, there is probably little way to make everyone happy.
>>> I think you misunderstood my intention. We definitively should port
>>> the patches from 6-freebsd-12 to master so that they are on a future
>>> libbsd branch. Like said above: I just don't think it's realistic to
>>> base a new developed branch on the 12 one.
>> I see. This is good to consider.
>>> If I remember correctly, Sebastian's branch that contains his
>>> suggested fixes already ported Chris NFS work to master first and
>>> then added Sebastian's patches that revert the parts where he disagrees.
>> I would leave it to them to determine if the NFSv4 is fully supported.
>>> That leaves some driver patches on the 12 branch that are most likely
>>> a lot simpler to port to master.
>>> My guess would be: Porting the stuff from 6-freebsd-12 to master
>>> should be a few days maximum to a compile clean state. Upgrading
>>> 6-freebsd-12 to something that would follow FreeBSD master again
>>> should be something in the range of weeks.
>> OK, then we should likely follow the path of porting from 6-freebsd-12
>> to master. I would leave the issue of what to do with FDs as a
>> separate concern that can be addressed once we solve this underlying
>> problem.
>> What would you think is the best way to handle the process though? It
>> would seem to still require some kind of cherry-picking + patching
>> FreeBSD and passing some tests? Perhaps it is best to do it that way,
>> on top of the current master branch, attempting to pick up patches
>> from the shared ancestor. ("Only in 6-freebsd-12").
> I would usually just cherry-pick commits that don't import anything from
> FreeBSD. All commits that do import files need a bit more work: For
> these, the files from FreeBSD master have to be re-importet.
> It's basically the same process that I use to back-port something from
> master to 6-freebsd-12. And it's why CONTRIBUTING.md tells that you
> should have one commit that only adds the unmodified imported files.
> With that it's easy to re-import the files from a different version and
> re-apply the patches.
> Best regards
> Christian
I tried to cherry-pick some of the commits yesterday (hobby time on
Sunday!). The first few patches should work quite well. There are some
minor problems that still have to be cleaned up to make it compile clean.
One of the early ones that makes problems is the path-mappings feature
from Jan Sommer because on master something changed the same code parts.
We need someone who understands both changes to port that.
About starting with Chris kernel symbol namespace tool patch
(59f652fe88) the changes start to get bigger and the patches are harder
to apply. I think the kernel symbol namespace is one of the core patches
that would be important to port, but I don't know the code surrounding
it well enough that I can do it fast.
How should we approach that work? One patch at a time? Maybe together
with pinging the original authors to ask them whether they can port
their patches to master or at least test them there?
For the VFS and NFS parts, it depends a bit on the solution of the
discussion. Sebastian already worked on a re-implementation of NFS on
master (not yet entirely finished):
https://github.com/sebhub/rtems-libbsd/commits/master-update
Of course that is based on his solution without the file descriptors and
without the central system calls. So it depends on the results of the
discussion between Sebastian and Chris whether that patch can be used to
have the NFS functionality in master.
Note that Sebastian also mentioned, that FreeBSD changed a lot in the
NFS/VFS in the last few months. So it's possible that both solutions
need quite some changes after we reach that version of FreeBSD.
Best regards
Christian
>>> Best regards
>>> Christian
>>>> it will be much easier to debate the merits of proposed patches to
>>>> address optimization etc., if we have a shared basis of features and
>>>> development. The way this has been heading is going to lead us
>>>> directly into a non-viable mode of trying to support several open
>>>> development branches of libbsd. I can easily see someone wanting to
>>>> carry forward 6-freebsd-12 commits to rtems7. If we don't have a way
>>>> to do that, we will definitely end up with something like
>>>> 7-freebsd-12.
>>>> We have to deal with the fact that there are legitimate developments
>>>> on 6-freebsd-12 that users may expect in future RTEMS releases. I
>>>> cannot agree with having a release of 6-freebsd-12 with rtems6 that is
>>>> followed by a release of 7-freebsd-1x that drops some features such as
>>>> support for NFSv4. It is not pragmatic. But we also don't have the
>>>> resources to be maintaining multiple branches of libbsd.
>>>>> For example, I don't know of a user for the BBB framebuffer on
>>>>> RTEMS 6. It's nice that it is there on master. It will become a
>>>>> stable feature on the next major branch (one of 6 or 7-freebsd-13
>>>>> or 14). But there is no necessity to backport it to the mostly
>>>>> stable 6-freebsd-12.
>>>> I have asked Vijay to look at backporting it anyway, to reduce the
>>>> difference between the branches. I want to get us out of this backward
>>>> way of development / change management that has evolved over time in
>>>> libbsd. How best to get us to a state where new development only goes
>>>> to master is for me still the main question. Once we have this fixed,
>>>> it is my intention to thoroughly reject any development that is only
>>>> submitted to a "stable" branch in the future.
>>>> Gedare
>>>>> Best regards
>>>>> Christian
>>>>>>> Best regards
>>>>>>> Christian
>>>>>>>> In any case, doing this in a way that ensures the commits build and
>>>>>>>> tests run is challenging due to the interactions with the
>>>>>>>> rtems.git,
>>>>>>>> toolchain, and the submodules. >
>>>>>>>> After the 6-freebsd-12 and master are made consistent, then it
>>>>>>>> becomes
>>>>>>>> possible to update freebsd and also to consider what ways can be
>>>>>>>> chosen to fix problems in 6-freebsd-12.
>>>>>>>> -Gedare
>>>>>>>>> Best regards
>>>>>>>>> Christian
>>>>>>>>>> I'm fine with either way, as a user I just need clear not
>>>>>>>>>> confusing
>>>>>>>>>> project message...
>>>>>>>>>> Thanks!
>>>>>>>>>> Karel
>>>>>>>>>> _______________________________________________
>>>>>>>>>> devel mailing list
>>>>>>>>>> devel at rtems.org
>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>>> embedded brains GmbH
>>>>>>>>> Herr Christian MAUDERER
>>>>>>>>> Dornierstr. 4
>>>>>>>>> 82178 Puchheim
>>>>>>>>> Germany
>>>>>>>>> email: christian.mauderer at embedded-brains.de
>>>>>>>>> phone: +49-89-18 94 741 - 18
>>>>>>>>> mobile: +49-176-152 206 08
>>>>>>>>> Registergericht: Amtsgericht München
>>>>>>>>> Registernummer: HRB 157899
>>>>>>>>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
>>>>>>>>> Dörfler
>>>>>>>>> Unsere Datenschutzerklärung finden Sie hier:
>>>>>>>>> https://embedded-brains.de/datenschutzerklaerung/
>>>>>>>>> devel mailing list
>>>>>>>>> devel at rtems.org
>>>>>>>> devel mailing list
>>>>>>>> devel at rtems.org
Dornierstr. 4
82178 Puchheim
Germany
