[PATCH] wscript: Deduplicate installed files
Mon Feb 6 14:44:08 UTC 2023
On 06.02.23 15:30, Joel Sherrill wrote:
> On Mon, Feb 6, 2023 at 12:55 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 06.02.23 03:35, Chris Johns wrote:
>      > On 4/2/2023 6:11 am, Sebastian Huber wrote:
>      >> On 03.02.23 19:45, Kinsey Moore wrote:
>      >>> This is my first stab at solving this duplicate install
>     problem. I could
>      >>> manually solve the problem by deduplicating the object includes
>     and moving it
>      >>> up to the BSP, but that is less intuitive since these drivers
>     both depend on
>      >>> the same code and the BSP doesn't depend on it directly.
>      >> Why don't you add the shared stuff to a objxilcommon.yml?
>      >> The approach in the wscript is a bit complex from my point of view.
>      > I am OK with adding this code or something similar. It is no more
>     complex than
>      > other places I have reviewed, eg `Item._init_link()`.
>      > The issue is currently not easy to see and may be present in
>     other places
>      > without us knowing. I am also fine with a spec file check that
>     highlights a
>      > clash to draw attention to a problem when the spec files are
>     parsed. I feeling
>      > we need something.
>     If you install with
>     ./waf install -vv
>     you see the duplicate install targets. See also
>     https://gitlab.com/ita1024/waf/-/issues/2329#note_467849523
>     <https://gitlab.com/ita1024/waf/-/issues/2329#note_467849523>
>     Before we add double for loops we should first analyze the underlying
>     problem. In this case it is a diamond shaped build dependency graph.
>     spec/build/bsps/objnandpsu.yml:  uid: objxilinxsupport
>     spec/build/bsps/objqspipsu.yml:  uid: objxilinxsupport
>     spec/build/bsps/aarch64/xilinx-zynqmp/objjffs2qspinor.yml:  uid:
>     ../../objqspipsu
>     spec/build/bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml:  uid:
>     ../../objnandpsu
>     In addition to the duplicate install targets you build also the objects
>     of objxilinxsupport twice and add them to the library.
>     I would simply move the links to grp_zu3eg:
>     grp_zu3eg.yml:  uid: ../../objxilinxspport
>     grp_zu3eg.yml:  uid: ../../objnandpsu
>     grp_zu3eg.yml:  uid: ../../objqspipsu
> That's the solution in this case but wouldn't it be nice to detect it
> reliably and
> address it when it shows up again.
You can detect the issue with by calling ./waf -vv install. This is what
the maintainer of waf recommends:
I would rather try to get these warnings by default from waf instead of
tinkering with special case solutions above waf.
The patch doesn't address the issue with the multiple object files in
the library.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
