[PATCH] wscript: Deduplicate installed files
Mon Feb 6 14:30:30 UTC 2023
On Mon, Feb 6, 2023 at 12:55 AM Sebastian Huber <
> On 06.02.23 03:35, Chris Johns wrote:
> > On 4/2/2023 6:11 am, Sebastian Huber wrote:
> >> On 03.02.23 19:45, Kinsey Moore wrote:
> >>> This is my first stab at solving this duplicate install problem. I
> could
> >>> manually solve the problem by deduplicating the object includes and
> moving it
> >>> up to the BSP, but that is less intuitive since these drivers both
> depend on
> >>> the same code and the BSP doesn't depend on it directly.
> >> Why don't you add the shared stuff to a objxilcommon.yml?
> >> The approach in the wscript is a bit complex from my point of view.
> > I am OK with adding this code or something similar. It is no more
> complex than
> > other places I have reviewed, eg `Item._init_link()`.
> > The issue is currently not easy to see and may be present in other places
> > without us knowing. I am also fine with a spec file check that
> highlights a
> > clash to draw attention to a problem when the spec files are parsed. I
> feeling
> > we need something.
> If you install with
> ./waf install -vv
> you see the duplicate install targets. See also
> https://gitlab.com/ita1024/waf/-/issues/2329#note_467849523
> Before we add double for loops we should first analyze the underlying
> problem. In this case it is a diamond shaped build dependency graph.
> spec/build/bsps/objnandpsu.yml:  uid: objxilinxsupport
> spec/build/bsps/objqspipsu.yml:  uid: objxilinxsupport
> spec/build/bsps/aarch64/xilinx-zynqmp/objjffs2qspinor.yml:  uid:
> ../../objqspipsu
> spec/build/bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml:  uid: ../../objnandpsu
> In addition to the duplicate install targets you build also the objects
> of objxilinxsupport twice and add them to the library.
> I would simply move the links to grp_zu3eg:
> grp_zu3eg.yml:  uid: ../../objxilinxspport
> grp_zu3eg.yml:  uid: ../../objqspipsu
That's the solution in this case but wouldn't it be nice to detect it
reliably and
address it when it shows up again.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230206/7d2edf92/attachment.htm>
