[PATCH 2/4] doxygen: Clarify CONFIGURE_DISABLE_BSP_SETTINGS
Sebastian Huber
Mon Feb 6 15:53:19 UTC 2023
Each BSP may optionally provide default values for some application
configuration options. Remove the documentation of these items, since
the BSP provided defines are not application configuration options, they
are optional default values. Clarify CONFIGURE_DISABLE_BSP_SETTINGS
accordingly and move it into the "General System Configuration" group.
Update #3994.
cpukit/doxygen/appl-config.h | 250 +++++------------------------------
1 file changed, 31 insertions(+), 219 deletions(-)
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index a8d964832e..d48fb11741 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -362,225 +362,6 @@
-/* Generated from spec:/acfg/if/group-bsp */
- * @defgroup RTEMSApplConfigBSPRelatedConfigurationOptions \
- * BSP Related Configuration Options
- * @ingroup RTEMSApplConfig
- * This section describes configuration options related to the BSP. Some
- * configuration options may have a BSP-specific setting which is defined by
- * ``<bsp.h>``. The BSP-specific settings can be disabled by the
- * #CONFIGURE_DISABLE_BSP_SETTINGS configuration option.
-/* Generated from spec:/acfg/if/bsp-idle-task-body */
- * @brief This configuration option is an initializer define.
- * If
- * * this configuration option is defined by the BSP
- * * and #CONFIGURE_DISABLE_BSP_SETTINGS is undefined,
- * then the value of this configuration option defines the default value of
- * #CONFIGURE_IDLE_TASK_BODY.
- * @par Default Value
- * The default value is BSP-specific.
- * @par Value Constraints
- * The value of this configuration option shall be defined to a valid function
- * pointer of the type ``void *( *idle_body )( uintptr_t )``.
- * @par Notes
- * As it has knowledge of the specific CPU model, system controller logic, and
- * peripheral buses, a BSP-specific IDLE task may be capable of turning
- * components off to save power during extended periods of no task activity.
-#define BSP_IDLE_TASK_BODY
-/* Generated from spec:/acfg/if/bsp-idle-task-stack-size */
- * @brief This configuration option is an integer define.
- * If
- * #CONFIGURE_IDLE_TASK_STACK_SIZE.
- * @parblock
- * The value of this configuration option shall satisfy all of the following
- * constraints:
- * * It shall be greater than or equal to a BSP-specific and
- * application-specific minimum value.
- * * It shall be small enough so that the IDLE task stack area calculation
- * carried out by ``<rtems/confdefs.h>`` does not overflow an integer of type
- * <a href="https://en.cppreference.com/w/c/types/size_t">size_t</a>.
- * @endparblock
-#define BSP_IDLE_TASK_STACK_SIZE
-/* Generated from spec:/acfg/if/bsp-initial-extension */
- * If
- * then the value of this configuration option is used to initialize the table
- * of initial user extensions.
- * The value of this configuration option shall be a list of initializers for
- * structures of type ::rtems_extensions_table.
- * @par Notes
- * The value of this configuration option is placed after the entries of all
- * other initial user extensions.
-#define BSP_INITIAL_EXTENSION
-/* Generated from spec:/acfg/if/bsp-interrupt-stack-size */
- * If
- * #CONFIGURE_INTERRUPT_STACK_SIZE.
- * @parblock
- * constraints:
- * * It shall be small enough so that the interrupt stack area calculation
- * * It shall be aligned according to #CPU_INTERRUPT_STACK_ALIGNMENT.
- * @endparblock
-#define BSP_INTERRUPT_STACK_SIZE
-/* Generated from spec:/acfg/if/bsp-prerequisite-drivers */
- * If
- * then the value of this configuration option is used to add BSP-provided
- * prerequisite drivers to the Device Driver Table.
- * @par Notes
- * The value of this configuration option is placed before the entries of all
- * other initial user extensions (including
- * #CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS).
-#define CONFIGURE_BSP_PREREQUISITE_DRIVERS
-/* Generated from spec:/acfg/if/disable-bsp-settings */
- * @brief This configuration option is a boolean feature define.
- * In case this configuration option is defined, then the following BSP related
- * configuration options are undefined:
- * * #BSP_IDLE_TASK_BODY
- * * #BSP_IDLE_TASK_STACK_SIZE
- * * #BSP_INITIAL_EXTENSION
- * * #BSP_INTERRUPT_STACK_SIZE
- * * #CONFIGURE_BSP_PREREQUISITE_DRIVERS
- * * #CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
- * @par Default Configuration
- * If this configuration option is undefined, then the described feature is not
- * enabled.
-#define CONFIGURE_DISABLE_BSP_SETTINGS
-/* Generated from spec:/acfg/if/malloc-bsp-supports-sbrk */
- * If
- * then not all memory is made available to the C Program Heap immediately at
- * system initialization time. When malloc() or other standard memory
- * allocation functions are unable to allocate memory, they will call the BSP
- * supplied sbrk() function to obtain more memory.
- * enabled.
- * @par Notes
- * This option should not be defined by the application. Only the BSP knows how
- * it allocates memory to the C Program Heap.
-#define CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
/* Generated from spec:/acfg/if/group-classic */
@@ -2626,6 +2407,37 @@
#define CONFIGURE_DIRTY_MEMORY
+/* Generated from spec:/acfg/if/disable-bsp-settings */
+ * @brief This configuration option is a boolean feature define.
+ * In case this configuration option is defined, then the optional BSP provided
+ * settings listed below are disabled.
+ * The optional BSP provided default values for the following application
+ * configuration options are disabled:
+ * * #CONFIGURE_IDLE_TASK_BODY
+ * * #CONFIGURE_IDLE_TASK_STACK_SIZE
+ * * #CONFIGURE_INTERRUPT_STACK_SIZE
+ * The optional BSP provided initial extension set is disabled (see initial
+ * extension sets). The optional BSP provided prerequisite IO device drivers
+ * are disabled (see Device Driver Configuration). The optional BSP provided
+ * support for sbrk() is disabled.
+ * This configuration option provides an all or nothing choice with respect to
+ * the optional BSP provided settings.
+ * @par Default Configuration
+ * If this configuration option is undefined, then the described feature is not
+ * enabled.
+#define CONFIGURE_DISABLE_BSP_SETTINGS
/* Generated from spec:/acfg/if/disable-newlib-reentrancy */
2.35.3
