[PATCH 3/4] doxygen: Generalize appl config constraints
Mon Feb 6 15:53:20 UTC 2023
Rename the constaints section of application configuration options from
"Value Constraints" in "Constraints.  Adjust the constraint wording
accordingly.  This is in line with the RTEMS Classic API Guide.
Update #3994.
 cpukit/doxygen/appl-config.h | 1101 ++++++++++++++++++----------------
 1 file changed, 576 insertions(+), 525 deletions(-)
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index d48fb11741..0a0de863bf 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -3,7 +3,7 @@
  * Copyright (C) 2019, 2022 embedded brains GmbH (http://www.embedded-brains.de)
  * Copyright (C) 2010 Gedare Bloom
- * Copyright (C) 1988, 2021 On-Line Applications Research Corporation (OAR)
+ * Copyright (C) 1988, 2022 On-Line Applications Research Corporation (OAR)
  * modification, are permitted provided that the following conditions
@@ -94,14 +94,15 @@
  * @par Default Value
  * The default value is 4096.
- * @par Value Constraints
+ * @par Constraints
  * @parblock
- * The value of this configuration option shall satisfy all of the following
- * constraints:
+ * The following constraints apply to this configuration option:
- * * It shall be greater than or equal to zero.
+ * * The value of the configuration option shall be greater than or equal to
+ *   zero.
- * * It shall be an integral multiple of #CONFIGURE_BDBUF_BUFFER_MIN_SIZE.
+ * * The value of the configuration option shall be an integral multiple of
+ *   #CONFIGURE_BDBUF_BUFFER_MIN_SIZE.
  * @endparblock
 #define CONFIGURE_BDBUF_BUFFER_MAX_SIZE
@@ -117,14 +118,14 @@
  * The default value is 512.
  * @parblock
- * constraints:
+ *   zero.
- * * It shall be less than or equal to <a
+ * * The value of the configuration option shall be less than or equal to <a
  *   href="https://en.cppreference.com/w/c/types/integer">UINT32_MAX</a>.
  * @endparblock
@@ -141,14 +142,14 @@
  * The default value is 32768.
  * @parblock
- * constraints:
+ *   zero.
  *   href="https://en.cppreference.com/w/c/types/limits">SIZE_MAX</a>.
  * @endparblock
@@ -165,14 +166,14 @@
  * The default value is 0.
  * @parblock
- * constraints:
+ *   zero.
  * @endparblock
@@ -194,14 +195,14 @@
  * The default value is 16.
  * @parblock
- * constraints:
+ *   zero.
  * @endparblock
@@ -217,8 +218,8 @@
  * The default value is 15.
- * The value of this configuration option shall be a valid Classic API task
+ * The value of the configuration option shall be a valid Classic API task
  * priority.  The set of valid task priorities depends on the scheduler
  * configuration.
@@ -235,19 +236,20 @@
  * The default value is #RTEMS_MINIMUM_STACK_SIZE.
  * @parblock
- * constraints:
- * * It shall be greater than or equal to #CONFIGURE_MINIMUM_TASK_STACK_SIZE.
+ *   #CONFIGURE_MINIMUM_TASK_STACK_SIZE.
- * * It shall be less than or equal to a BSP-specific and application-specific
- *   value which depends on the size of the memory available to the
- *   application.
+ * * The value of the configuration option shall be less than or equal to a
+ *   BSP-specific and application-specific value which depends on the size of
+ *   the memory available to the application.
- * * It shall be small enough so that the task stack space calculation carried
- *   out by ``<rtems/confdefs.h>`` does not overflow an integer of type <a
+ * * The value of the configuration option shall be small enough so that the
+ *   task stack space calculation carried out by ``<rtems/confdefs.h>`` does
+ *   not overflow an integer of type <a
  *   href="https://en.cppreference.com/w/c/types/integer">uintptr_t</a>.
  * @endparblock
@@ -264,14 +266,14 @@
  * The default value is 1000.
  * @parblock
- * constraints:
+ *   zero.
  * @endparblock
@@ -288,14 +290,14 @@
  * The default value is 250.
  * @parblock
- * constraints:
+ *   zero.
  * @endparblock
@@ -311,8 +313,8 @@
  * configuration.
@@ -329,14 +331,14 @@
  * @parblock
- * constraints:
+ *   zero.
  * @endparblock
@@ -353,8 +355,8 @@
  * configuration.
@@ -385,23 +387,24 @@
  * @parblock
- * constraints:
+ *   zero.
- * * It shall be less than or equal to 65535.
+ *   65535.
- *   application.
- * * It may be defined through rtems_resource_unlimited() the enable unlimited
- *   objects for the object class, if the value passed to
- *   rtems_resource_unlimited() satisfies all other constraints of the
- *   configuration option.
+ * * The value of the configuration option may be defined through
+ *   rtems_resource_unlimited() the enable unlimited objects for the object
+ *   class, if the value passed to rtems_resource_unlimited() satisfies all
+ *   other constraints of the configuration option.
  * @endparblock
  * @par Notes
@@ -422,23 +425,24 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -460,23 +464,24 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -497,23 +502,24 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -534,23 +540,24 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -571,23 +578,24 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -608,23 +616,24 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -654,27 +663,29 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -710,23 +721,24 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -747,18 +759,19 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -777,14 +790,15 @@
  * @parblock
- * constraints:
+ *   zero.
- * * It shall be less than or equal to #CONFIGURE_MAXIMUM_TASKS.
+ *   #CONFIGURE_MAXIMUM_TASKS.
  * @endparblock
  * @par Notes
@@ -823,8 +837,8 @@
- * The value of this configuration option shall be convertible to an integer of
+ * The value of the configuration option shall be convertible to an integer of
  * type ::rtems_task_argument.
 #define CONFIGURE_INIT_TASK_ARGUMENTS
@@ -840,8 +854,8 @@
  * The default value is #RTEMS_DEFAULT_ATTRIBUTES.
- * The value of this configuration option shall be a valid task attribute set.
+ * The value of the configuration option shall be a valid task attribute set.
 #define CONFIGURE_INIT_TASK_ATTRIBUTES
@@ -858,14 +872,15 @@
  * then the Classic API initialization task will be created with the stack size
  * defined by the #CONFIGURE_INIT_TASK_STACK_SIZE configuration option.
  * @parblock
- * constraints:
- * * It shall be defined using RTEMS_TASK_STORAGE_SIZE().
+ * * The value of the configuration option shall be defined using
+ *   RTEMS_TASK_STORAGE_SIZE().
  * @endparblock
  * @par Notes
@@ -910,8 +925,8 @@
  * The default value is ``Init``.
- * The value of this configuration option shall be defined to a valid function
+ * The value of the configuration option shall be defined to a valid function
  * pointer of the type ``void ( *entry_point )( rtems_task_argument )``.
  * @par Notes
@@ -932,8 +947,8 @@
  * In SMP  configurations, the default value is #RTEMS_DEFAULT_MODES otherwise
  * the default value is #RTEMS_NO_PREEMPT.
- * The value of this configuration option shall be a valid task mode set.
+ * The value of the configuration option shall be a valid task mode set.
 #define CONFIGURE_INIT_TASK_INITIAL_MODES
@@ -948,8 +963,8 @@
  * The default value is ``rtems_build_name( 'U', 'I', '1', ' ' )``.
  * type ::rtems_name.
  * @par Notes
@@ -968,8 +983,8 @@
  * The default value is 1.
  * configuration.
@@ -986,15 +1001,16 @@
  * The default value is #CONFIGURE_MINIMUM_TASK_STACK_SIZE.
  * @parblock
- * constraints:
  * @endparblock
@@ -1098,8 +1114,8 @@
  * The default value is the empty list.
- * The value of this configuration option shall be a list of initializers for
+ * The value of the configuration option shall be a list of initializers for
  * structures of type ::rtems_driver_address_table.
  * @par Notes
@@ -1470,8 +1486,8 @@
  * @par Notes
@@ -1496,8 +1512,8 @@
  * The default value is 140.
  * configuration.
@@ -1575,23 +1591,24 @@
  * * #CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
- * * #CONFIGURE_BSP_PREREQUISITE_DRIVERS
+ * If the #CONFIGURE_DISABLE_BSP_SETTINGS configuration option is not defined
+ * and the BSP provides #CONFIGURE_BSP_PREREQUISITE_DRIVERS, then the
+ * BSP-provided prerequisite device drivers are also taken into account.
  * @endparblock
  * @parblock
- * constraints:
- * * It shall be greater than or equal than the number of statically configured
- *   device drivers.
+ * * The value of the configuration option shall be greater than or equal than
+ *   the number of statically configured device drivers.
- *   application.
  * @endparblock
  * @par Notes
@@ -1726,21 +1743,21 @@
  * @parblock
- * constraints:
- * * It shall be greater than or equal to 16.
+ *   16.
- * * It shall be a power of two.
+ * * The value of the configuration option shall be a power of two.
- *   application.
  * @endparblock
  * @par Notes
@@ -2242,8 +2259,8 @@
  * The default value is 128.
- * The value of this configuration option shall be equal to 16, 32, 64, 128,
+ * The value of the configuration option shall be equal to 16, 32, 64, 128,
  * 256, or 512.
  * @par Notes
@@ -2471,19 +2488,19 @@
  * stack space size is calculated by ``<rtems/confdefs.h>`` based on the values
  * configuration options.
  * @parblock
- * constraints:
+ *   zero.
  *   href="https://en.cppreference.com/w/c/types/integer">UINTPTR_MAX</a>.
- *   application.
  * @endparblock
  * @par Notes
@@ -2504,15 +2521,16 @@
  * @parblock
- * constraints:
+ *   zero.
  * @endparblock
@@ -2534,8 +2552,8 @@
  * structures of type ::rtems_extensions_table.
  * @par Notes
@@ -2554,22 +2572,25 @@
  * stack in bytes.
- * The default value is #BSP_INTERRUPT_STACK_SIZE in case it is defined,
- * otherwise the default value is #CPU_STACK_MINIMUM_SIZE.
+ * and #BSP_INTERRUPT_STACK_SIZE is provided by the BSP, then the default value
+ * is defined by #BSP_INTERRUPT_STACK_SIZE, otherwise the default value is
+ * #CPU_STACK_MINIMUM_SIZE.
  * @parblock
- * constraints:
- * * It shall be greater than or equal to a BSP-specific and
- *   application-specific minimum value.
+ * * The value of the configuration option shall be greater than or equal to a
+ *   BSP-specific and application-specific minimum value.
- * * It shall be small enough so that the interrupt stack area calculation
- *   carried out by ``<rtems/confdefs.h>`` does not overflow an integer of type
- *   <a href="https://en.cppreference.com/w/c/types/size_t">size_t</a>.
+ *   interrupt stack area calculation carried out by ``<rtems/confdefs.h>``
+ *   does not overflow an integer of type <a
+ *   href="https://en.cppreference.com/w/c/types/size_t">size_t</a>.
- * * It shall be aligned according to #CPU_INTERRUPT_STACK_ALIGNMENT.
+ * * The value of the configuration option shall be aligned according to
+ *   #CPU_INTERRUPT_STACK_ALIGNMENT.
  * @endparblock
  * @par Notes
@@ -2625,19 +2646,19 @@
  * The default value is 3.
  * @parblock
- * constraints:
+ *   zero.
- *   application.
  * @endparblock
  * @par Notes
@@ -2660,14 +2681,15 @@
  * @parblock
- * constraints:
- * * It shall be greater than or equal to one.
+ *   one.
- * * It shall be less than or equal to #CPU_MAXIMUM_PROCESSORS.
+ *   #CPU_MAXIMUM_PROCESSORS.
  * @endparblock
  * @par Notes
@@ -2675,8 +2697,8 @@
  * If there are more processors available than configured, the rest will be
  * ignored.
- * This configuration option is only evaluated in SMP configurations (e.g.
- * RTEMS was built with the ``--enable-smp`` build configuration option).  In
+ * This configuration option is only evaluated in SMP configurations of RTEMS
+ * (e.g. RTEMS was built with the SMP build configuration option enabled). In
  * all other configurations it has no effect.
  * @endparblock
@@ -2741,19 +2763,19 @@
  * @parblock
- * constraints:
+ *   zero.
- *   application.
  * @endparblock
  * @par Notes
@@ -2781,20 +2803,21 @@
  * @parblock
- * constraints:
+ *   zero.
- *   application.
- * * It shall be small enough so that the RTEMS Workspace size calculation
- *   <a href="https://en.cppreference.com/w/c/types/integer">uintptr_t</a>.
+ *   RTEMS Workspace size calculation carried out by ``<rtems/confdefs.h>``
+ *   href="https://en.cppreference.com/w/c/types/integer">uintptr_t</a>.
  * @endparblock
  * @par Notes
@@ -2817,20 +2840,21 @@
  * @parblock
- * constraints:
+ *   zero.
- *   application.
  * @endparblock
  * @par Notes
@@ -2909,14 +2933,15 @@
  * The default value is 10000.
  * @parblock
- * constraints:
- * * It shall be greater than or equal to a value defined by the Clock Driver.
+ *   value defined by the Clock Driver.
- * * It shall be less than or equal to a value defined by the Clock Driver.
  * * The resulting clock ticks per second should be an integer.
  * @endparblock
@@ -2943,17 +2968,17 @@
  * The default value is #CPU_STACK_MINIMUM_SIZE.
  * @parblock
- * constraints:
  * @endparblock
  * @par Notes
@@ -3015,14 +3040,14 @@
  * The default value is 50.
  * @parblock
- * constraints:
+ *   zero.
  * @endparblock
@@ -3074,8 +3099,8 @@
  * The default value is 8.
- * The value of this configuration option shall meet the constraints of all
+ * The value of the configuration option shall meet the constraints of all
  * object classes to which it is applied.
  * @par Notes
@@ -3176,11 +3201,13 @@
  * The value of this configuration option initializes the IDLE thread body.
- * If #BSP_IDLE_TASK_BODY is defined, then this will be the default value,
- * otherwise the default value is ``_CPU_Thread_Idle_body``.
+ * and #BSP_IDLE_TASK_BODY is provided by the BSP, then the default value is
+ * defined by #BSP_IDLE_TASK_BODY, otherwise the default value is
+ * ``_CPU_Thread_Idle_body``.
  * pointer of the type ``void *( *idle_body )( uintptr_t )``.
  * @par Notes
@@ -3191,6 +3218,11 @@
  * IDLE threads can be used to initialize the application, see configuration
  * option #CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION.
+ * The BSP may have knowledge of the specific CPU model, system controller
+ * logic, and peripheral buses, so a BSP-specific IDLE task may be capable of
+ * turning components off to save power during extended periods of no task
+ * activity.
  * @endparblock
 #define CONFIGURE_IDLE_TASK_BODY
@@ -3245,19 +3277,22 @@
  * IDLE task.
- * The default value is #CONFIGURE_MINIMUM_TASK_STACK_SIZE.
+ * and #BSP_IDLE_TASK_STACK_SIZE is provided by the BSP, then the default value
+ * is defined by #BSP_IDLE_TASK_STACK_SIZE, otherwise the default value is
+ * defined by the #CONFIGURE_MINIMUM_TASK_STACK_SIZE configuration option.
  * @parblock
- * constraints:
- * * It shall be small enough so that the IDLE task stack area calculation
+ *   IDLE task stack area calculation carried out by ``<rtems/confdefs.h>``
  * @endparblock
  * @par Notes
@@ -3329,12 +3364,13 @@
  * @ingroup RTEMSApplConfig
- * This section describes multiprocessing related configuration options.  The
- * options are only used if RTEMS was built with the
- * ``--enable-multiprocessing`` build configuration option.  Additionally, this
- * class of configuration options are only applicable if the configuration
- * option #CONFIGURE_MP_APPLICATION is defined.  The multiprocessing (MPCI)
- * support must not be confused with the SMP support.
+ * This section describes multiprocessing related configuration options. The
+ * options are only used if RTEMS was built when the multiprocessing build
+ * configuration option is enabled. The multiprocessing configuration is
+ * distinct from the SMP configuration.  Additionally, this class of
+ * configuration options are only applicable if the configuration option
+ * #CONFIGURE_MP_APPLICATION is defined.  The multiprocessing (MPCI) support
+ * must not be confused with the SMP support.
@@ -3351,19 +3387,19 @@
  * @parblock
- * constraints:
+ *   zero.
- * * It shall be small enough so that the MPCI receive server stack area
- *   calculation carried out by ``<rtems/confdefs.h>`` does not overflow an
- *   integer of type <a
+ *   MPCI receive server stack area calculation carried out by
+ *   ``<rtems/confdefs.h>`` does not overflow an integer of type <a
  * @endparblock
@@ -3388,9 +3424,9 @@
  * @par Notes
  * This configuration option shall be undefined if the multiprocessing support
- * is not enabled (e.g. RTEMS was built without the
- * ``--enable-multiprocessing`` build configuration option).  Otherwise a
- * compile time error in the configuration file will occur.
+ * is not enabled (e.g. RTEMS was built without the multiprocessing build
+ * configuration option enabled).  Otherwise a compile time error in the
+ * configuration file will occur.
 #define CONFIGURE_MP_APPLICATION
@@ -3405,14 +3441,14 @@
  * The default value is 32.
  * @parblock
- * constraints:
+ *   zero.
  * @endparblock
@@ -3438,14 +3474,14 @@
  * The default value is 2.
  * @parblock
- * constraints:
+ *   zero.
  * @endparblock
@@ -3467,14 +3503,14 @@
  * @parblock
- * constraints:
+ *   zero.
  * @endparblock
@@ -3502,8 +3538,8 @@
  * The default value is ``&MPCI_table``.
- * The value of this configuration option shall be a pointer to
+ * The value of the configuration option shall be a pointer to
  * ::rtems_mpci_table.
  * @par Notes
@@ -3529,14 +3565,14 @@
  * The default value is ``NODE_NUMBER``.
  * @parblock
- * constraints:
+ *   zero.
  * @endparblock
@@ -3564,8 +3600,8 @@
  * This section describes configuration options related to the POSIX API.  Most
  * POSIX API objects are available by default since RTEMS 5.1.  The queued
- * signals and timers are only available if RTEMS was built with the
- * ``--enable-posix`` build configuration option.
+ * signals and timers are only available if RTEMS was built with the enable
+ * POSIX build configuration option.
@@ -3581,23 +3617,24 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -3616,26 +3653,27 @@
  * value pairs used by POSIX API Keys that can be concurrently active.
- * The default value is #CONFIGURE_MAXIMUM_POSIX_KEYS *
- * #CONFIGURE_MAXIMUM_TASKS + #CONFIGURE_MAXIMUM_POSIX_THREADS.
+ * The default value is #CONFIGURE_MAXIMUM_POSIX_KEYS * (
+ * #CONFIGURE_MAXIMUM_TASKS + #CONFIGURE_MAXIMUM_POSIX_THREADS ).
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -3662,27 +3700,29 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -3704,32 +3744,34 @@
  * @parblock
- * constraints:
+ *   zero.
- *   application.
- * * It shall be zero if the POSIX API is not enabled (e.g. RTEMS was built
- *   without the ``RTEMS_POSIX_API = True`` build configuration option).
- *   Otherwise a compile time error in the configuration file will occur.
+ * * The value of the configuration option shall be zero if the POSIX API is
+ *   not enabled (e.g. RTEMS was built without the ``RTEMS_POSIX_API = True``
+ *   build configuration option).  Otherwise a compile time error in the
  * @endparblock
  * @par Notes
  * @parblock
  * Unlimited objects are not available for queued signals.
- * Queued signals are only available if RTEMS was built with the
+ * Queued signals are only available if RTEMS was built with the POSIX API
+ * build configuration option enabled.
  * @endparblock
 #define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
@@ -3745,27 +3787,29 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -3792,27 +3836,29 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -3833,21 +3879,23 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
@@ -3882,27 +3930,29 @@
  * @parblock
- * constraints:
+ *   zero.
+ *   65535.
- *   application.
  * @endparblock
  * @par Notes
@@ -3911,8 +3961,8 @@
  * href="https://docs.rtems.org/branches/master/c-user/config/intro.html#unlimited-objects">Unlimited
  * Objects</a>.
- * Timers are only available if RTEMS was built with the ``--enable-posix``
- * build configuration option.
+ * Timers are only available if RTEMS was built with the POSIX API build
+ * configuration option enabled.
  * @endparblock
 #define CONFIGURE_MAXIMUM_POSIX_TIMERS
@@ -3929,17 +3979,17 @@
  * The default value is two times the value of
  * @parblock
- * constraints:
  * @endparblock
 #define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
@@ -3971,8 +4021,8 @@
  * The default value is ``POSIX_Init``.
  * pointer of the type ``void *( *entry_point )( void * )``.
  * @par Notes
@@ -3992,15 +4042,16 @@
  * The default value is #CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE.
  * @parblock
- * constraints:
  * @endparblock
@@ -4083,19 +4134,19 @@
  * The default value is #CONFIGURE_MAXIMUM_TASKS.
  * @parblock
- * constraints:
+ *   zero.
- *   application.
  * @endparblock
  * @par Notes
@@ -4136,8 +4187,8 @@
  * The default value is 255.
- * The value of this configuration option shall be equal to 3, 7, 31, 63, 127,
+ * The value of the configuration option shall be equal to 3, 7, 31, 63, 127,
  * or 255.
  * @par Notes
@@ -4174,12 +4225,12 @@
  * The default value of this configuration option is computed so that the
  * default scheduler is assigned to each configured processor (up to 32).
  * @parblock
- * constraints:
- * * It shall be a list of the following macros:
+ * * The value of the configuration option shall be a list of the following
+ *   macros:
  *   * ``RTEMS_SCHEDULER_ASSIGN( scheduler_index, attributes )``
@@ -4343,8 +4394,8 @@
  *   Priority Scheduler</a>.
  * @endparblock
  * @par Notes
@@ -4672,8 +4723,8 @@
  * The default value is ``_Workspace_Allocate``, which indicates that task
  * stacks will be allocated from the RTEMS Workspace.
  * pointer of the type ``void *( *allocate )( size_t )``.
  * @par Notes
@@ -4721,7 +4772,7 @@
  * By default, the IDLE task storage area will be allocated from the RTEMS
  * Workspace.
  * @parblock
@@ -4768,8 +4819,8 @@
  * The default value is <a
  * href="https://en.cppreference.com/w/c/types/NULL">NULL</a>.
  * pointer of the type ``void ( *initialize )( size_t )`` or to <a
@@ -4799,8 +4850,8 @@
  * The default value is ``_Workspace_Free``, which indicates that task stacks
  * will be allocated from the RTEMS Workspace.
  * pointer of the type ``void ( *deallocate )( void * )``.
  * @par Notes
@@ -4828,8 +4879,8 @@
  * The default value is a macro which supports the system heap allocator.
- * The value of this configuration option shall be defined to a macro which
+ * The value of the configuration option shall be defined to a macro which
  * accepts exactly one parameter and returns an unsigned integer.  The
  * parameter will be an allocation size and the macro shall return this size
  * plus the overhead of the allocator to manage an allocation request for this
2.35.3
