[PATCH 4/4] doxygen: Use @anchor for appl config options
Sebastian Huber
Mon Feb 6 15:53:21 UTC 2023
The application configuration options are documented in
"cpukit/doxygen/appl-config.h". Since the application configuration
option defines are also present in multiple test program sources, the
"#OPTION" references cannot be mapped to a unique definition. Add an
anchor for each option and reference it to avoid the issues with the
multiple definitions.
Update #3994.
cpukit/doxygen/appl-config.h | 762 +++++++++++++++++--------
cpukit/include/rtems/bspIo.h | 2 +-
cpukit/include/rtems/config.h | 60 +-
cpukit/include/rtems/extension.h | 16 +-
cpukit/include/rtems/io.h | 4 +-
cpukit/include/rtems/rtems/barrier.h | 4 +-
cpukit/include/rtems/rtems/clock.h | 8 +-
cpukit/include/rtems/rtems/config.h | 60 +-
cpukit/include/rtems/rtems/dpmem.h | 4 +-
cpukit/include/rtems/rtems/message.h | 28 +-
cpukit/include/rtems/rtems/part.h | 10 +-
cpukit/include/rtems/rtems/ratemon.h | 5 +-
cpukit/include/rtems/rtems/region.h | 5 +-
cpukit/include/rtems/rtems/scheduler.h | 4 +-
cpukit/include/rtems/rtems/sem.h | 10 +-
cpukit/include/rtems/rtems/support.h | 8 +-
cpukit/include/rtems/rtems/tasks.h | 49 +-
cpukit/include/rtems/rtems/timer.h | 7 +-
18 files changed, 678 insertions(+), 368 deletions(-)
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index 0a0de863bf..e13ebb8ba5 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -69,6 +69,8 @@
* @brief This configuration option is a boolean feature define.
+ * @anchor CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
* In case this configuration option is defined, then the Block Device Cache is
* initialized during system initialization.
@@ -88,6 +90,8 @@
* @brief This configuration option is an integer define.
+ * @anchor CONFIGURE_BDBUF_BUFFER_MAX_SIZE
* The value of this configuration option defines the maximum size of a buffer
* in bytes.
@@ -102,7 +106,7 @@
* zero.
* * The value of the configuration option shall be an integral multiple of
- * #CONFIGURE_BDBUF_BUFFER_MIN_SIZE.
+ * @ref CONFIGURE_BDBUF_BUFFER_MIN_SIZE.
* @endparblock
#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE
@@ -112,6 +116,8 @@
+ * @anchor CONFIGURE_BDBUF_BUFFER_MIN_SIZE
* The value of this configuration option defines the minimum size of a buffer
* in bytes.
@@ -136,6 +142,8 @@
+ * @anchor CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
* The value of this configuration option defines the size of the cache memory
* in bytes.
@@ -160,6 +168,8 @@
+ * @anchor CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
* The value of this configuration option defines the maximum blocks per
* read-ahead request.
@@ -189,6 +199,8 @@
+ * @anchor CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
* The value of this configuration option defines the maximum blocks per write
* request.
@@ -213,6 +225,8 @@
+ * @anchor CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
* The value of this configuration option defines the read-ahead task priority.
* @par Default Value
@@ -230,6 +244,8 @@
+ * @anchor CONFIGURE_BDBUF_TASK_STACK_SIZE
* The value of this configuration option defines the task stack size of the
* Block Device Cache tasks in bytes.
@@ -241,7 +257,7 @@
* The following constraints apply to this configuration option:
* * The value of the configuration option shall be greater than or equal to
- * #CONFIGURE_MINIMUM_TASK_STACK_SIZE.
+ * @ref CONFIGURE_MINIMUM_TASK_STACK_SIZE.
* * The value of the configuration option shall be less than or equal to a
* BSP-specific and application-specific value which depends on the size of
@@ -260,6 +276,8 @@
+ * @anchor CONFIGURE_SWAPOUT_BLOCK_HOLD
* The value of this configuration option defines the swapout task maximum
* block hold time in milliseconds.
@@ -284,6 +302,8 @@
+ * @anchor CONFIGURE_SWAPOUT_SWAP_PERIOD
* The value of this configuration option defines the swapout task swap period
* in milliseconds.
@@ -308,6 +328,8 @@
+ * @anchor CONFIGURE_SWAPOUT_TASK_PRIORITY
* The value of this configuration option defines the swapout task priority.
@@ -325,6 +347,8 @@
+ * @anchor CONFIGURE_SWAPOUT_WORKER_TASKS
* The value of this configuration option defines the swapout worker task
* count.
@@ -349,6 +373,8 @@
+ * @anchor CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
* priority.
@@ -381,6 +407,8 @@
+ * @anchor CONFIGURE_MAXIMUM_BARRIERS
* The value of this configuration option defines the maximum number of Classic
* API Barriers that can be concurrently active.
@@ -419,6 +447,8 @@
+ * @anchor CONFIGURE_MAXIMUM_MESSAGE_QUEUES
* API Message Queues that can be concurrently active.
@@ -449,7 +479,7 @@
* This object class can be configured in unlimited allocation mode, see <a
* href="https://docs.rtems.org/branches/master/c-user/config/intro.html#unlimited-objects">Unlimited
* Objects</a>. You have to account for the memory used to store the messages
- * of each message queue, see #CONFIGURE_MESSAGE_BUFFER_MEMORY.
+ * of each message queue, see @ref CONFIGURE_MESSAGE_BUFFER_MEMORY.
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES
@@ -458,6 +488,8 @@
+ * @anchor CONFIGURE_MAXIMUM_PARTITIONS
* API Partitions that can be concurrently active.
@@ -496,6 +528,8 @@
+ * @anchor CONFIGURE_MAXIMUM_PERIODS
* API Periods that can be concurrently active.
@@ -534,6 +568,8 @@
+ * @anchor CONFIGURE_MAXIMUM_PORTS
* API Ports that can be concurrently active.
@@ -572,6 +608,8 @@
+ * @anchor CONFIGURE_MAXIMUM_REGIONS
* API Regions that can be concurrently active.
@@ -610,6 +648,8 @@
+ * @anchor CONFIGURE_MAXIMUM_SEMAPHORES
* API Semaphore that can be concurrently active.
@@ -657,6 +697,8 @@
+ * @anchor CONFIGURE_MAXIMUM_TASKS
* API Tasks that can be concurrently active.
@@ -696,11 +738,12 @@
* The calculations for the required memory in the RTEMS Workspace for tasks
* assume that each task has a minimum stack size and has floating point
- * support enabled. The configuration option #CONFIGURE_EXTRA_TASK_STACKS is
- * used to specify task stack requirements *above* the minimum size required.
+ * support enabled. The configuration option @ref CONFIGURE_EXTRA_TASK_STACKS
+ * is used to specify task stack requirements *above* the minimum size
+ * required.
- * The maximum number of POSIX threads is specified by
- * #CONFIGURE_MAXIMUM_POSIX_THREADS.
+ * The maximum number of POSIX threads is specified by @ref
+ * CONFIGURE_MAXIMUM_POSIX_THREADS.
* A future enhancement to ``<rtems/confdefs.h>`` could be to eliminate the
* assumption that all tasks have floating point enabled. This would require
@@ -715,6 +758,8 @@
+ * @anchor CONFIGURE_MAXIMUM_TIMERS
* API Timers that can be concurrently active.
@@ -753,6 +798,8 @@
+ * @anchor CONFIGURE_MAXIMUM_USER_EXTENSIONS
* API User Extensions that can be concurrently active.
@@ -784,6 +831,8 @@
+ * @anchor CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE
* The value of this configuration option defines the minimum count of Classic
* API Tasks which are constructed by rtems_task_construct().
@@ -797,8 +846,8 @@
* zero.
- * * The value of the configuration option shall be less than or equal to
- * #CONFIGURE_MAXIMUM_TASKS.
+ * * The value of the configuration option shall be less than or equal to @ref
+ * CONFIGURE_MAXIMUM_TASKS.
* @endparblock
* @par Notes
@@ -831,6 +880,8 @@
+ * @anchor CONFIGURE_INIT_TASK_ARGUMENTS
* The value of this configuration option defines task argument of the Classic
* API initialization task.
@@ -848,6 +899,8 @@
+ * @anchor CONFIGURE_INIT_TASK_ATTRIBUTES
* The value of this configuration option defines the task attributes of the
* Classic API initialization task.
@@ -864,20 +917,22 @@
+ * @anchor CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
* The value of this configuration option defines the task storage size of the
* This configuration option has no default value. If it is not specified,
* then the Classic API initialization task will be created with the stack size
- * defined by the #CONFIGURE_INIT_TASK_STACK_SIZE configuration option.
+ * defined by the @ref CONFIGURE_INIT_TASK_STACK_SIZE configuration option.
* @par Constraints
* @parblock
* * The value of the configuration option shall be defined using
* RTEMS_TASK_STORAGE_SIZE().
@@ -893,19 +948,19 @@
* * the Classic API initialization task is constructed by
* rtems_task_construct() instead of using rtems_task_create(),
- * * the maximum thread-local storage size defined by
- * #CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE is used for the Classic API
+ * * the maximum thread-local storage size defined by @ref
+ * CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE is used for the Classic API
* initialization task,
- * * the Classic API initialization task should be accounted for in
- * #CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE, and
+ * * the Classic API initialization task should be accounted for in @ref
+ * CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE, and
* * the task storage area used for the Classic API initialization task is not
* reclaimed by the system if the task is deleted.
* The
- * * #CONFIGURE_INIT_TASK_STACK_SIZE and
+ * * @ref CONFIGURE_INIT_TASK_STACK_SIZE and
* * ``CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE``
@@ -919,6 +974,8 @@
* @brief This configuration option is an initializer define.
+ * @anchor CONFIGURE_INIT_TASK_ENTRY_POINT
* The value of this configuration option initializes the entry point of the
@@ -940,6 +997,8 @@
+ * @anchor CONFIGURE_INIT_TASK_INITIAL_MODES
* The value of this configuration option defines the initial execution mode of
* the Classic API initialization task.
@@ -957,6 +1016,8 @@
+ * @anchor CONFIGURE_INIT_TASK_NAME
* The value of this configuration option defines the name of the Classic API
* initialization task.
@@ -977,6 +1038,8 @@
+ * @anchor CONFIGURE_INIT_TASK_PRIORITY
* The value of this configuration option defines the initial priority of the
@@ -995,18 +1058,20 @@
+ * @anchor CONFIGURE_INIT_TASK_STACK_SIZE
- * The default value is #CONFIGURE_MINIMUM_TASK_STACK_SIZE.
+ * The default value is @ref CONFIGURE_MINIMUM_TASK_STACK_SIZE.
* @par Constraints
* @parblock
* * The value of the configuration option shall be small enough so that the
* task stack space calculation carried out by ``<rtems/confdefs.h>`` does
@@ -1020,7 +1085,7 @@
* * ``CONFIGURE_INIT_TASK_STACK_SIZE`` and
- * * #CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
+ * * @ref CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
* configuration options are mutually exclusive.
* @endparblock
@@ -1032,6 +1097,8 @@
+ * @anchor CONFIGURE_RTEMS_INIT_TASKS_TABLE
* In case this configuration option is defined, then exactly one Classic API
* initialization task is configured.
@@ -1046,9 +1113,9 @@
* * ``CONFIGURE_RTEMS_INIT_TASKS_TABLE``,
- * * #CONFIGURE_POSIX_INIT_THREAD_TABLE, or
+ * * @ref CONFIGURE_POSIX_INIT_THREAD_TABLE, or
- * * #CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
+ * * @ref CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
* otherwise a compile time error in the configuration file will occur.
* @endparblock
@@ -1076,6 +1143,8 @@
+ * @anchor CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
* In case this configuration option is defined, then **no** Clock Driver is
@@ -1092,11 +1161,11 @@
* The application shall define exactly one of the following configuration
* options
- * * #CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER,
+ * * @ref CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER,
* * ``CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER``, or
- * * #CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER,
+ * * @ref CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER,
* @endparblock
@@ -1108,6 +1177,8 @@
+ * @anchor CONFIGURE_APPLICATION_EXTRA_DRIVERS
* The value of this configuration option is used to initialize the Device
* Driver Table.
@@ -1123,8 +1194,8 @@
* The value of this configuration option is placed after the entries of other
* device driver configuration options.
- * See #CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS for an alternative placement
- * of application device driver initializers.
+ * See @ref CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS for an alternative
+ * placement of application device driver initializers.
* @endparblock
#define CONFIGURE_APPLICATION_EXTRA_DRIVERS
@@ -1134,6 +1205,8 @@
+ * @anchor CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
* In case this configuration option is defined, then the ATA Driver is
@@ -1156,6 +1229,8 @@
+ * @anchor CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
* In case this configuration option is defined, then the Clock Driver is
@@ -1173,9 +1248,9 @@
* * ``CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER``,
- * * #CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER, or
+ * * @ref CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER, or
* @endparblock
@@ -1187,6 +1262,8 @@
+ * @anchor CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
* In case this configuration option is defined, then the Console Driver is
@@ -1207,9 +1284,9 @@
* * ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER``,
- * * #CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER, and
+ * * @ref CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER, and
- * * #CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
+ * * @ref CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
* @endparblock
@@ -1221,6 +1298,8 @@
+ * @anchor CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
* In case this configuration option is defined, then the Frame Buffer Driver
* is initialized during system initialization.
@@ -1244,6 +1323,8 @@
+ * @anchor CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
* In case this configuration option is defined, then the IDE Driver is
@@ -1266,6 +1347,8 @@
+ * @anchor CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
* In case this configuration option is defined, then the ``/dev/null`` Driver
@@ -1283,6 +1366,8 @@
+ * @anchor CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
* In case this configuration option is defined, then the Real-Time Clock
* Driver is initialized during system initialization.
@@ -1306,6 +1391,8 @@
+ * @anchor CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
* In case this configuration option is defined, then the Simple Console Driver
@@ -1328,11 +1415,11 @@
* The
- * * #CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER,
+ * * @ref CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER,
* * ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER``, and
* @endparblock
@@ -1344,6 +1431,8 @@
+ * @anchor CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
* In case this configuration option is defined, then the Simple Task Console
@@ -1375,9 +1464,9 @@
* The
* * ``CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER``
@@ -1391,6 +1480,8 @@
+ * @anchor CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
* In case this configuration option is defined, then the Stub Driver is
@@ -1409,6 +1500,8 @@
+ * @anchor CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
* In case this configuration option is defined, then the Benchmark Timer
@@ -1424,9 +1517,9 @@
* options
* * ``CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER``,
@@ -1440,6 +1533,8 @@
+ * @anchor CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
* In case this configuration option is defined, then the Watchdog Driver is
@@ -1463,6 +1558,8 @@
+ * @anchor CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
* In case this configuration option is defined, then the ``/dev/zero`` Driver
@@ -1480,6 +1577,8 @@
+ * @anchor CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
* Driver Table.
@@ -1496,7 +1595,7 @@
* by #CONFIGURE_BSP_PREREQUISITE_DRIVERS and before all other device driver
* configuration options.
- * See #CONFIGURE_APPLICATION_EXTRA_DRIVERS for an alternative placement of
+ * See @ref CONFIGURE_APPLICATION_EXTRA_DRIVERS for an alternative placement of
* application device driver initializers.
* @endparblock
@@ -1507,6 +1606,8 @@
+ * @anchor CONFIGURE_ATA_DRIVER_TASK_PRIORITY
* The value of this configuration option defines the ATA task priority.
@@ -1518,8 +1619,8 @@
* configuration.
* @par Notes
- * This configuration option is only evaluated if the configuration option
- * #CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER is defined.
+ * This configuration option is only evaluated if the configuration option @ref
+ * CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER is defined.
#define CONFIGURE_ATA_DRIVER_TASK_PRIORITY
@@ -1528,6 +1629,8 @@
+ * @anchor CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
* In case this configuration option is defined, then the machine exception to
* POSIX signal mapping is configured during system initialization.
@@ -1551,6 +1654,8 @@
+ * @anchor CONFIGURE_MAXIMUM_DRIVERS
* The value of this configuration option defines the number of device drivers.
@@ -1559,40 +1664,40 @@
* configured device drivers configured using the following configuration
* options:
- * * #CONFIGURE_APPLICATION_EXTRA_DRIVERS
+ * * @ref CONFIGURE_APPLICATION_EXTRA_DRIVERS
- * * #CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
+ * * @ref CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
- * * #CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
+ * * @ref CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
- * * #CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
+ * * @ref CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
- * * #CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+ * * @ref CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
- * * #CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
+ * * @ref CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
- * * #CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
+ * * @ref CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
- * * #CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
+ * * @ref CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
- * * #CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
+ * * @ref CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
- * * #CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
+ * * @ref CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
- * * #CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
+ * * @ref CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
- * If the #CONFIGURE_DISABLE_BSP_SETTINGS configuration option is not defined
- * and the BSP provides #CONFIGURE_BSP_PREREQUISITE_DRIVERS, then the
+ * If the @ref CONFIGURE_DISABLE_BSP_SETTINGS configuration option is not
+ * defined and the BSP provides #CONFIGURE_BSP_PREREQUISITE_DRIVERS, then the
* BSP-provided prerequisite device drivers are also taken into account.
* @endparblock
@@ -1638,11 +1743,13 @@
+ * @anchor CONFIGURE_RECORD_EXTENSIONS_ENABLED
* In case
* * this configuration option is defined
- * * and #CONFIGURE_RECORD_PER_PROCESSOR_ITEMS is properly defined,
+ * * and @ref CONFIGURE_RECORD_PER_PROCESSOR_ITEMS is properly defined,
* then the event record extensions are enabled.
@@ -1661,13 +1768,15 @@
+ * @anchor CONFIGURE_RECORD_FATAL_DUMP_BASE64
* In case
- * * and #CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB is undefined,
+ * * and @ref CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB is undefined,
* then the event records are dumped in Base64 encoding in a fatal error
* extension (see <a
@@ -1688,11 +1797,13 @@
+ * @anchor CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
* In case
* then the event records are compressed by zlib and dumped in Base64 encoding
* in a fatal error extension (see <a
@@ -1714,11 +1825,13 @@
+ * @anchor CONFIGURE_RECORD_INTERRUPTS_ENABLED
* In case
* then the interrupt event recording is enabled.
@@ -1737,6 +1850,8 @@
+ * @anchor CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
* The value of this configuration option defines the event record item count
* per processor.
@@ -1762,7 +1877,7 @@
* @par Notes
* The event record buffers are statically allocated for each configured
- * processor (#CONFIGURE_MAXIMUM_PROCESSORS). If the value of this
+ * processor (@ref CONFIGURE_MAXIMUM_PROCESSORS). If the value of this
* configuration option is zero, then nothing is allocated.
#define CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
@@ -1801,6 +1916,8 @@
+ * @anchor CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
* If this configuration option is defined, then POSIX timers may not be
* created to use the CLOCK_REALTIME. Per POSIX, this is allowed behavior but
* per the FACE Technical Standard, it is not. Using POSIX timers based on
@@ -1828,44 +1945,44 @@
* This section describes configuration options related to filesytems. By
* default, the In-Memory Filesystem (IMFS) is used as the base filesystem
* (also known as root filesystem). In order to save some memory for your
- * application, you can disable the filesystem support with the
- * #CONFIGURE_APPLICATION_DISABLE_FILESYSTEM configuration option.
+ * application, you can disable the filesystem support with the @ref
+ * CONFIGURE_APPLICATION_DISABLE_FILESYSTEM configuration option.
* Alternatively, you can strip down the features of the base filesystem with
- * the #CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM and
- * #CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM configuration options. These three
+ * the @ref CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM and @ref
+ * CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM configuration options. These three
* configuration options are mutually exclusive. They are intended for an
* advanced application configuration.
* Features of the IMFS can be disabled and enabled with the following
* configuration options:
- * * #CONFIGURE_IMFS_DISABLE_CHMOD
+ * * @ref CONFIGURE_IMFS_DISABLE_CHMOD
- * * #CONFIGURE_IMFS_DISABLE_CHOWN
+ * * @ref CONFIGURE_IMFS_DISABLE_CHOWN
- * * #CONFIGURE_IMFS_DISABLE_LINK
+ * * @ref CONFIGURE_IMFS_DISABLE_LINK
- * * #CONFIGURE_IMFS_DISABLE_MKNOD
+ * * @ref CONFIGURE_IMFS_DISABLE_MKNOD
- * * #CONFIGURE_IMFS_DISABLE_MKNOD_FILE
+ * * @ref CONFIGURE_IMFS_DISABLE_MKNOD_FILE
- * * #CONFIGURE_IMFS_DISABLE_MOUNT
+ * * @ref CONFIGURE_IMFS_DISABLE_MOUNT
- * * #CONFIGURE_IMFS_DISABLE_READDIR
+ * * @ref CONFIGURE_IMFS_DISABLE_READDIR
- * * #CONFIGURE_IMFS_DISABLE_READLINK
+ * * @ref CONFIGURE_IMFS_DISABLE_READLINK
- * * #CONFIGURE_IMFS_DISABLE_RENAME
+ * * @ref CONFIGURE_IMFS_DISABLE_RENAME
- * * #CONFIGURE_IMFS_DISABLE_RMNOD
+ * * @ref CONFIGURE_IMFS_DISABLE_RMNOD
- * * #CONFIGURE_IMFS_DISABLE_SYMLINK
+ * * @ref CONFIGURE_IMFS_DISABLE_SYMLINK
- * * #CONFIGURE_IMFS_DISABLE_UNMOUNT
+ * * @ref CONFIGURE_IMFS_DISABLE_UNMOUNT
- * * #CONFIGURE_IMFS_DISABLE_UTIME
+ * * @ref CONFIGURE_IMFS_DISABLE_UTIME
- * * #CONFIGURE_IMFS_ENABLE_MKFIFO
+ * * @ref CONFIGURE_IMFS_ENABLE_MKFIFO
@@ -1875,6 +1992,8 @@
+ * @anchor CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
* In case this configuration option is defined, then **no base filesystem** is
* initialized during system initialization and **no filesystems** are
* configured.
@@ -1895,22 +2014,24 @@
+ * @anchor CONFIGURE_FILESYSTEM_ALL
* In case this configuration option is defined, then the following
* configuration options will be defined as well
- * * #CONFIGURE_FILESYSTEM_DOSFS,
+ * * @ref CONFIGURE_FILESYSTEM_DOSFS,
- * * #CONFIGURE_FILESYSTEM_FTPFS,
+ * * @ref CONFIGURE_FILESYSTEM_FTPFS,
- * * #CONFIGURE_FILESYSTEM_IMFS,
+ * * @ref CONFIGURE_FILESYSTEM_IMFS,
- * * #CONFIGURE_FILESYSTEM_JFFS2,
+ * * @ref CONFIGURE_FILESYSTEM_JFFS2,
- * * #CONFIGURE_FILESYSTEM_NFS,
+ * * @ref CONFIGURE_FILESYSTEM_NFS,
- * * #CONFIGURE_FILESYSTEM_RFS, and
+ * * @ref CONFIGURE_FILESYSTEM_RFS, and
- * * #CONFIGURE_FILESYSTEM_TFTPFS.
+ * * @ref CONFIGURE_FILESYSTEM_TFTPFS.
* @par Default Configuration
* If this configuration option is undefined, then the described feature is not
@@ -1923,6 +2044,8 @@
+ * @anchor CONFIGURE_FILESYSTEM_DOSFS
* In case this configuration option is defined, then the DOS (FAT) filesystem
* is registered, so that instances of this filesystem can be mounted by the
* application.
@@ -1932,8 +2055,8 @@
* enabled.
* @par Notes
- * This filesystem requires a Block Device Cache configuration, see
- * #CONFIGURE_APPLICATION_NEEDS_LIBBLOCK.
+ * This filesystem requires a Block Device Cache configuration, see @ref
+ * CONFIGURE_APPLICATION_NEEDS_LIBBLOCK.
#define CONFIGURE_FILESYSTEM_DOSFS
@@ -1942,6 +2065,8 @@
+ * @anchor CONFIGURE_FILESYSTEM_FTPFS
* In case this configuration option is defined, then the FTP filesystem (FTP
* client) is registered, so that instances of this filesystem can be mounted
* by the application.
@@ -1957,6 +2082,8 @@
+ * @anchor CONFIGURE_FILESYSTEM_IMFS
* In case this configuration option is defined, then the In-Memory Filesystem
* (IMFS) is registered, so that instances of this filesystem can be mounted by
* the application.
@@ -1978,6 +2105,8 @@
+ * @anchor CONFIGURE_FILESYSTEM_JFFS2
* In case this configuration option is defined, then the JFFS2 filesystem is
* registered, so that instances of this filesystem can be mounted by the
* application.
@@ -1993,6 +2122,8 @@
+ * @anchor CONFIGURE_FILESYSTEM_NFS
* In case this configuration option is defined, then the Network Filesystem
* (NFS) client is registered, so that instances of this filesystem can be
* mounted by the application.
@@ -2008,6 +2139,8 @@
+ * @anchor CONFIGURE_FILESYSTEM_RFS
* In case this configuration option is defined, then the RTEMS Filesystem
* (RFS) is registered, so that instances of this filesystem can be mounted by
* the application.
@@ -2017,8 +2150,8 @@
* enabled.
* @par Notes
#define CONFIGURE_FILESYSTEM_RFS
@@ -2027,6 +2160,8 @@
+ * @anchor CONFIGURE_FILESYSTEM_TFTPFS
* In case this configuration option is defined, then the TFTP filesystem (TFTP
@@ -2042,6 +2177,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_CHMOD
* In case this configuration option is defined, then the root IMFS does not
* support changing the mode of files (no support for chmod()).
@@ -2056,6 +2193,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_CHOWN
* support changing the ownership of files (no support for chown()).
@@ -2070,6 +2209,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_LINK
* support hard links (no support for link()).
@@ -2084,6 +2225,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_MKNOD
* support making files (no support for mknod()).
@@ -2098,6 +2241,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
* support making device files.
@@ -2112,6 +2257,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_MKNOD_FILE
* support making regular files.
@@ -2126,6 +2273,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_MOUNT
* support mounting other filesystems (no support for mount()).
@@ -2140,6 +2289,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_READDIR
* support reading directories (no support for readdir()). It is still
* possible to open files in a directory.
@@ -2155,6 +2306,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_READLINK
* support reading symbolic links (no support for readlink()).
@@ -2169,6 +2322,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_RENAME
* support renaming files (no support for rename()).
@@ -2183,6 +2338,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_RMNOD
* support removing files (no support for rmnod()).
@@ -2197,6 +2354,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_SYMLINK
* support creating symbolic links (no support for symlink()).
@@ -2211,6 +2370,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_UNMOUNT
* support unmounting other filesystems (no support for unmount()).
@@ -2225,6 +2386,8 @@
+ * @anchor CONFIGURE_IMFS_DISABLE_UTIME
* support changing file times (no support for utime()).
@@ -2239,6 +2402,8 @@
+ * @anchor CONFIGURE_IMFS_ENABLE_MKFIFO
* In case this configuration option is defined, then the root IMFS supports
* making FIFOs.
@@ -2253,6 +2418,8 @@
+ * @anchor CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
* The value of this configuration option defines the block size for in-memory
* files managed by the IMFS.
@@ -2301,6 +2468,8 @@
+ * @anchor CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
* In case this configuration option is defined, then an IMFS with a reduced
* feature set will be the base filesystem (also known as root filesystem).
@@ -2313,29 +2482,29 @@
- * * #CONFIGURE_IMFS_DISABLE_CHMOD,
+ * * @ref CONFIGURE_IMFS_DISABLE_CHMOD,
- * * #CONFIGURE_IMFS_DISABLE_CHOWN,
+ * * @ref CONFIGURE_IMFS_DISABLE_CHOWN,
- * * #CONFIGURE_IMFS_DISABLE_LINK,
+ * * @ref CONFIGURE_IMFS_DISABLE_LINK,
- * * #CONFIGURE_IMFS_DISABLE_MKNOD_FILE,
+ * * @ref CONFIGURE_IMFS_DISABLE_MKNOD_FILE,
- * * #CONFIGURE_IMFS_DISABLE_MOUNT,
+ * * @ref CONFIGURE_IMFS_DISABLE_MOUNT,
- * * #CONFIGURE_IMFS_DISABLE_READDIR,
+ * * @ref CONFIGURE_IMFS_DISABLE_READDIR,
- * * #CONFIGURE_IMFS_DISABLE_READLINK,
+ * * @ref CONFIGURE_IMFS_DISABLE_READLINK,
- * * #CONFIGURE_IMFS_DISABLE_RENAME,
+ * * @ref CONFIGURE_IMFS_DISABLE_RENAME,
- * * #CONFIGURE_IMFS_DISABLE_RMNOD,
+ * * @ref CONFIGURE_IMFS_DISABLE_RMNOD,
- * * #CONFIGURE_IMFS_DISABLE_SYMLINK,
+ * * @ref CONFIGURE_IMFS_DISABLE_SYMLINK,
- * * #CONFIGURE_IMFS_DISABLE_UTIME, and
+ * * @ref CONFIGURE_IMFS_DISABLE_UTIME, and
- * * #CONFIGURE_IMFS_DISABLE_UNMOUNT.
+ * * @ref CONFIGURE_IMFS_DISABLE_UNMOUNT.
* In addition, a simplified path evaluation is enabled. It allows only a look
* up of absolute paths.
@@ -2352,6 +2521,8 @@
+ * @anchor CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
@@ -2364,21 +2535,21 @@
* @endparblock
#define CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
@@ -2403,6 +2574,8 @@
+ * @anchor CONFIGURE_DIRTY_MEMORY
* In case this configuration option is defined, then the memory areas used for
* the RTEMS Workspace and the C Program Heap are dirtied with a ``0xCF`` byte
* pattern during system initialization.
@@ -2415,11 +2588,11 @@
* @parblock
* Dirtying memory can add significantly to system initialization time. It may
* assist in finding code that incorrectly assumes the contents of free memory
- * areas is cleared to zero during system initialization. In case
- * #CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is also defined, then the memory is
+ * areas is cleared to zero during system initialization. In case @ref
+ * CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is also defined, then the memory is
* first dirtied and then zeroed.
- * See also #CONFIGURE_MALLOC_DIRTY.
+ * See also @ref CONFIGURE_MALLOC_DIRTY.
* @endparblock
#define CONFIGURE_DIRTY_MEMORY
@@ -2429,17 +2602,19 @@
+ * @anchor CONFIGURE_DISABLE_BSP_SETTINGS
* In case this configuration option is defined, then the optional BSP provided
* settings listed below are disabled.
* The optional BSP provided default values for the following application
* configuration options are disabled:
- * * #CONFIGURE_IDLE_TASK_BODY
+ * * @ref CONFIGURE_IDLE_TASK_BODY
- * * #CONFIGURE_IDLE_TASK_STACK_SIZE
+ * * @ref CONFIGURE_IDLE_TASK_STACK_SIZE
- * * #CONFIGURE_INTERRUPT_STACK_SIZE
+ * * @ref CONFIGURE_INTERRUPT_STACK_SIZE
* The optional BSP provided initial extension set is disabled (see initial
* extension sets). The optional BSP provided prerequisite IO device drivers
@@ -2460,6 +2635,8 @@
+ * @anchor CONFIGURE_DISABLE_NEWLIB_REENTRANCY
* In case this configuration option is defined, then the Newlib reentrancy
* support per thread is disabled and a global reentrancy structure is used.
@@ -2480,6 +2657,8 @@
+ * @anchor CONFIGURE_EXECUTIVE_RAM_SIZE
* The value of this configuration option defines the RTEMS Workspace size in
* bytes.
@@ -2514,6 +2693,8 @@
+ * @anchor CONFIGURE_EXTRA_TASK_STACKS
* The value of this configuration option defines the number of bytes the
* applications wishes to add to the task stack requirements calculated by
* ``<rtems/confdefs.h>``.
@@ -2546,6 +2727,8 @@
+ * @anchor CONFIGURE_INITIAL_EXTENSIONS
* The value of this configuration option is used to initialize the table of
* initial user extensions.
@@ -2568,14 +2751,16 @@
+ * @anchor CONFIGURE_INTERRUPT_STACK_SIZE
* The value of this configuration option defines the size of an interrupt
* stack in bytes.
- * and #BSP_INTERRUPT_STACK_SIZE is provided by the BSP, then the default value
- * is defined by #BSP_INTERRUPT_STACK_SIZE, otherwise the default value is
- * #CPU_STACK_MINIMUM_SIZE.
+ * defined and #BSP_INTERRUPT_STACK_SIZE is provided by the BSP, then the
+ * default value is defined by #BSP_INTERRUPT_STACK_SIZE, otherwise the default
+ * value is #CPU_STACK_MINIMUM_SIZE.
* @par Constraints
* @parblock
@@ -2595,8 +2780,8 @@
* @par Notes
* @parblock
- * There is one interrupt stack available for each configured processor
- * (#CONFIGURE_MAXIMUM_PROCESSORS). The interrupt stack areas are statically
+ * There is one interrupt stack available for each configured processor (@ref
+ * CONFIGURE_MAXIMUM_PROCESSORS). The interrupt stack areas are statically
* allocated in a special linker section (``.rtemsstack.interrupt``). The
* placement of this linker section is BSP-specific.
@@ -2604,12 +2789,12 @@
* to perform the sequential system initialization before the multithreading is
* started.
- * The interrupt stacks are covered by the stack checker, see
- * #CONFIGURE_STACK_CHECKER_ENABLED. However, using a too small interrupt
- * stack size may still result in undefined behaviour.
+ * The interrupt stacks are covered by the stack checker, see @ref
+ * CONFIGURE_STACK_CHECKER_ENABLED. However, using a too small interrupt stack
+ * size may still result in undefined behaviour.
- * In releases before RTEMS 5.1 the default value was
- * #CONFIGURE_MINIMUM_TASK_STACK_SIZE instead of #CPU_STACK_MINIMUM_SIZE.
+ * In releases before RTEMS 5.1 the default value was @ref
+ * CONFIGURE_MINIMUM_TASK_STACK_SIZE instead of #CPU_STACK_MINIMUM_SIZE.
* @endparblock
#define CONFIGURE_INTERRUPT_STACK_SIZE
@@ -2619,6 +2804,8 @@
+ * @anchor CONFIGURE_MALLOC_DIRTY
* In case this configuration option is defined, then each memory area returned
* by C Program Heap allocator functions such as malloc() is dirtied with a
* ``0xCF`` byte pattern before it is handed over to the application.
@@ -2629,8 +2816,8 @@
* @par Notes
* The dirtying performed by this option is carried out for each successful
- * memory allocation from the C Program Heap in contrast to
- * #CONFIGURE_DIRTY_MEMORY which dirties the memory only once during the system
+ * memory allocation from the C Program Heap in contrast to @ref
+ * CONFIGURE_DIRTY_MEMORY which dirties the memory only once during the system
* initialization.
#define CONFIGURE_MALLOC_DIRTY
@@ -2640,6 +2827,8 @@
+ * @anchor CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
* The value of this configuration option defines the maximum number of file
* like objects that can be concurrently open.
@@ -2672,6 +2861,8 @@
+ * @anchor CONFIGURE_MAXIMUM_PROCESSORS
* processors an application intends to use. The number of actually available
* processors depends on the hardware and may be less. It is recommended to
@@ -2709,6 +2900,8 @@
+ * @anchor CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
* If the value of this configuration option is greater than zero, then it
* defines the maximum thread-local storage size, otherwise the thread-local
* storage size is defined by the linker depending on the thread-local storage
@@ -2757,6 +2950,8 @@
+ * @anchor CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
* The value of this configuration option defines the maximum thread name size
* including the terminating ``NUL`` character.
@@ -2796,6 +2991,8 @@
+ * @anchor CONFIGURE_MEMORY_OVERHEAD
* The value of this configuration option defines the number of kilobytes the
* application wishes to add to the RTEMS Workspace size calculated by
@@ -2824,8 +3021,8 @@
* This configuration option should only be used when it is suspected that a
* bug in ``<rtems/confdefs.h>`` has resulted in an underestimation. Typically
* the memory allocation will be too low when an application does not account
- * for all message queue buffers or task stacks, see
- * #CONFIGURE_MESSAGE_BUFFER_MEMORY.
+ * for all message queue buffers or task stacks, see @ref
+ * CONFIGURE_MESSAGE_BUFFER_MEMORY.
#define CONFIGURE_MEMORY_OVERHEAD
@@ -2834,6 +3031,8 @@
+ * @anchor CONFIGURE_MESSAGE_BUFFER_MEMORY
* The value of this configuration option defines the number of bytes reserved
* for message queue buffers in the RTEMS Workspace.
@@ -2859,8 +3058,8 @@
* @par Notes
* @parblock
- * The configuration options #CONFIGURE_MAXIMUM_MESSAGE_QUEUES and
- * #CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES define only how many message queues
+ * The configuration options @ref CONFIGURE_MAXIMUM_MESSAGE_QUEUES and @ref
+ * CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES define only how many message queues
* can be created by the application. The memory for the message buffers is
* configured by this option. For each message queue you have to reserve some
* memory for the message buffers. The size depends on the maximum number of
@@ -2912,6 +3111,8 @@
+ * @anchor CONFIGURE_MICROSECONDS_PER_TICK
* The value of this configuration option defines the length of time in
* microseconds between clock ticks (clock tick quantum).
@@ -2949,7 +3150,7 @@
* @par Notes
* @parblock
* This configuration option has no impact if the Clock Driver is not
- * configured, see #CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
+ * configured, see @ref CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
* There may be Clock Driver specific limits on the resolution or maximum value
* of a clock tick quantum.
@@ -2962,6 +3163,8 @@
+ * @anchor CONFIGURE_MINIMUM_TASK_STACK_SIZE
* The value of this configuration option defines the minimum stack size in
* bytes for every user task or thread in the system.
@@ -2985,7 +3188,7 @@
* @parblock
* Adjusting this parameter should be done with caution. Examining the actual
* stack usage using the stack checker usage reporting facility is recommended
- * (see also #CONFIGURE_STACK_CHECKER_ENABLED).
+ * (see also @ref CONFIGURE_STACK_CHECKER_ENABLED).
* This parameter can be used to lower the minimum from that recommended. This
* can be used in low memory systems to reduce memory consumption for stacks.
@@ -2997,11 +3200,11 @@
* overflow without performing analysis on actual consumption.
* By default, this configuration parameter defines also the minimum stack size
- * of POSIX threads. This can be changed with the
- * #CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE configuration option.
+ * of POSIX threads. This can be changed with the @ref
+ * CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE configuration option.
* In releases before RTEMS 5.1 the ``CONFIGURE_MINIMUM_TASK_STACK_SIZE`` was
- * used to define the default value of #CONFIGURE_INTERRUPT_STACK_SIZE.
+ * used to define the default value of @ref CONFIGURE_INTERRUPT_STACK_SIZE.
* @endparblock
#define CONFIGURE_MINIMUM_TASK_STACK_SIZE
@@ -3011,6 +3214,8 @@
+ * @anchor CONFIGURE_STACK_CHECKER_ENABLED
* In case this configuration option is defined, then the stack checker is
* enabled.
@@ -3034,6 +3239,8 @@
+ * @anchor CONFIGURE_TICKS_PER_TIMESLICE
* The value of this configuration option defines the length of the timeslice
* quantum in ticks for each task.
@@ -3053,7 +3260,7 @@
* @par Notes
#define CONFIGURE_TICKS_PER_TIMESLICE
@@ -3062,6 +3269,8 @@
+ * @anchor CONFIGURE_UNIFIED_WORK_AREAS
* In case this configuration option is defined, then the RTEMS Workspace and
* the C Program Heap will be one pool of memory.
@@ -3089,7 +3298,9 @@
- * If #CONFIGURE_UNLIMITED_OBJECTS is defined, then the value of this
+ * @anchor CONFIGURE_UNLIMITED_ALLOCATION_SIZE
+ * If @ref CONFIGURE_UNLIMITED_OBJECTS is defined, then the value of this
* configuration option defines the default objects maximum of all object
* classes supporting <a
@@ -3119,6 +3330,8 @@
+ * @anchor CONFIGURE_UNLIMITED_OBJECTS
* In case this configuration option is defined, then unlimited objects are
* used by default.
@@ -3128,14 +3341,14 @@
* @par Notes
* @parblock
- * When using unlimited objects, it is common practice to also specify
- * #CONFIGURE_UNIFIED_WORK_AREAS so the system operates with a single pool of
+ * When using unlimited objects, it is common practice to also specify @ref
+ * CONFIGURE_UNIFIED_WORK_AREAS so the system operates with a single pool of
* memory for both RTEMS Workspace and C Program Heap.
* This option does not override an explicit configuration for a particular
* object class by the user.
- * See also #CONFIGURE_UNLIMITED_ALLOCATION_SIZE.
+ * See also @ref CONFIGURE_UNLIMITED_ALLOCATION_SIZE.
* @endparblock
#define CONFIGURE_UNLIMITED_OBJECTS
@@ -3145,6 +3358,8 @@
+ * @anchor CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION
* In case this configuration option is defined, then the system initialization
* is verbose.
@@ -3163,6 +3378,8 @@
+ * @anchor CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
* the RTEMS Workspace and the C Program Heap are zeroed with a ``0x00`` byte
@@ -3174,7 +3391,7 @@
* @par Notes
* Zeroing memory can add significantly to the system initialization time. It
* is not necessary for RTEMS but is often assumed by support libraries. In
- * case #CONFIGURE_DIRTY_MEMORY is also defined, then the memory is first
+ * case @ref CONFIGURE_DIRTY_MEMORY is also defined, then the memory is first
* dirtied and then zeroed.
#define CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
@@ -3198,12 +3415,14 @@
+ * @anchor CONFIGURE_IDLE_TASK_BODY
* The value of this configuration option initializes the IDLE thread body.
- * and #BSP_IDLE_TASK_BODY is provided by the BSP, then the default value is
- * defined by #BSP_IDLE_TASK_BODY, otherwise the default value is
+ * defined and #BSP_IDLE_TASK_BODY is provided by the BSP, then the default
+ * value is defined by #BSP_IDLE_TASK_BODY, otherwise the default value is
* ``_CPU_Thread_Idle_body``.
* @par Constraints
@@ -3217,7 +3436,7 @@
* exists.
* IDLE threads can be used to initialize the application, see configuration
- * option #CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION.
+ * option @ref CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION.
* The BSP may have knowledge of the specific CPU model, system controller
* logic, and peripheral buses, so a BSP-specific IDLE task may be capable of
@@ -3232,6 +3451,8 @@
+ * @anchor CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
* This configuration option is defined to indicate that the user has
* configured **no** user initialization tasks or threads and that the user
* provided IDLE task will perform application initialization and then
@@ -3251,15 +3472,15 @@
* The IDLE task shall run at the lowest priority of all tasks in the system.
* If this configuration option is defined, then it is mandatory to configure a
- * user IDLE task with the #CONFIGURE_IDLE_TASK_BODY configuration option,
+ * user IDLE task with the @ref CONFIGURE_IDLE_TASK_BODY configuration option,
* options
- * * #CONFIGURE_RTEMS_INIT_TASKS_TABLE,
+ * * @ref CONFIGURE_RTEMS_INIT_TASKS_TABLE,
* * ``CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION``
@@ -3273,14 +3494,17 @@
+ * @anchor CONFIGURE_IDLE_TASK_STACK_SIZE
* The value of this configuration option defines the task stack size for an
* IDLE task.
- * and #BSP_IDLE_TASK_STACK_SIZE is provided by the BSP, then the default value
- * is defined by #BSP_IDLE_TASK_STACK_SIZE, otherwise the default value is
- * defined by the #CONFIGURE_MINIMUM_TASK_STACK_SIZE configuration option.
+ * defined and #BSP_IDLE_TASK_STACK_SIZE is provided by the BSP, then the
+ * default value is defined by #BSP_IDLE_TASK_STACK_SIZE, otherwise the default
+ * value is defined by the @ref CONFIGURE_MINIMUM_TASK_STACK_SIZE configuration
+ * option.
* @par Constraints
* @parblock
@@ -3297,7 +3521,7 @@
* @par Notes
* In SMP configurations, there is one IDLE task per configured processor, see
- * #CONFIGURE_MAXIMUM_PROCESSORS.
+ * @ref CONFIGURE_MAXIMUM_PROCESSORS.
#define CONFIGURE_IDLE_TASK_STACK_SIZE
@@ -3306,6 +3530,8 @@
+ * @anchor CONFIGURE_IDLE_TASK_STORAGE_SIZE
* If this configuration option is specified, then the task storage areas for
* the IDLE tasks are statically allocated by <rtems/confdefs.h>. The value of
* this configuration option defines the size in bytes of the task storage area
@@ -3317,8 +3543,8 @@
* Workspace or through a custom IDLE task stack allocator.
* @par Constraints
- * The value of the configuration option shall be greater than or equal to
- * #CONFIGURE_IDLE_TASK_STACK_SIZE.
+ * The value of the configuration option shall be greater than or equal to @ref
+ * CONFIGURE_IDLE_TASK_STACK_SIZE.
* @par Notes
* @parblock
@@ -3328,15 +3554,15 @@
* task storage areas. The task storage area contains the task stack, the
* thread-local storage, and the floating-point context on architectures with a
* separate floating-point context. The size of the thread-local storage area
- * is defined at link time or by the
- * #CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE configuration option. You have
+ * is defined at link time or by the @ref
+ * CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE configuration option. You have
* to estimate the actual thread-local storage size if you want to use this
* configuration option. If the IDLE task stack size would be less than the
- * value defined by the #CONFIGURE_IDLE_TASK_STACK_SIZE configuration option,
- * for example because the thread-local storage size is larger than expected,
- * then the system terminates with the INTERNAL_ERROR_CORE fatal source and the
- * INTERNAL_ERROR_IDLE_THREAD_STACK_TOO_SMALL fatal code during system
- * initialization.
+ * value defined by the @ref CONFIGURE_IDLE_TASK_STACK_SIZE configuration
+ * option, for example because the thread-local storage size is larger than
+ * expected, then the system terminates with the INTERNAL_ERROR_CORE fatal
+ * source and the INTERNAL_ERROR_IDLE_THREAD_STACK_TOO_SMALL fatal code during
+ * system initialization.
* The value of this configuration option is passed to
* RTEMS_TASK_STORAGE_SIZE() by <rtems/confdefs.h> to determine the actual size
@@ -3347,7 +3573,7 @@
* * ``CONFIGURE_IDLE_TASK_STORAGE_SIZE``, and
- * * #CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE
+ * * @ref CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE
* @endparblock
@@ -3368,8 +3594,8 @@
* options are only used if RTEMS was built when the multiprocessing build
* configuration option is enabled. The multiprocessing configuration is
* distinct from the SMP configuration. Additionally, this class of
- * configuration options are only applicable if the configuration option
- * #CONFIGURE_MP_APPLICATION is defined. The multiprocessing (MPCI) support
+ * configuration options are only applicable if the configuration option @ref
+ * CONFIGURE_MP_APPLICATION is defined. The multiprocessing (MPCI) support
* must not be confused with the SMP support.
@@ -3380,9 +3606,11 @@
+ * @anchor CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
- * applications wishes to add to the MPCI task stack on top of
+ * applications wishes to add to the MPCI task stack on top of @ref
+ * CONFIGURE_MINIMUM_TASK_STACK_SIZE.
* The default value is 0.
@@ -3404,8 +3632,8 @@
* @endparblock
* @par Notes
- * This configuration option is only evaluated if #CONFIGURE_MP_APPLICATION is
- * defined.
+ * This configuration option is only evaluated if @ref CONFIGURE_MP_APPLICATION
+ * is defined.
#define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
@@ -3414,6 +3642,8 @@
+ * @anchor CONFIGURE_MP_APPLICATION
* This configuration option is defined to indicate that the application
* intends to be part of a multiprocessing configuration. Additional
* configuration options are assumed to be provided.
@@ -3435,6 +3665,8 @@
+ * @anchor CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
* concurrently active global objects in a multiprocessor system.
@@ -3457,8 +3689,8 @@
* This value corresponds to the total number of objects which can be created
* with the #RTEMS_GLOBAL attribute.
- * defined.
+ * is defined.
* @endparblock
#define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
@@ -3468,6 +3700,8 @@
+ * @anchor CONFIGURE_MP_MAXIMUM_NODES
* The value of this configuration option defines the maximum number of nodes
* in a multiprocessor system.
@@ -3486,8 +3720,8 @@
* @endparblock
* @par Notes
- * defined.
+ * is defined.
#define CONFIGURE_MP_MAXIMUM_NODES
@@ -3496,6 +3730,8 @@
+ * @anchor CONFIGURE_MP_MAXIMUM_PROXIES
* concurrently active thread/task proxies on this node in a multiprocessor
* system.
@@ -3521,8 +3757,8 @@
* remote tasks/threads which can be blocked on objects on this node, see <a
* href="https://docs.rtems.org/branches/master/c-user/multiprocessing.html#proxies">Proxies</a>.
- * defined.
+ * is defined.
* @endparblock
#define CONFIGURE_MP_MAXIMUM_PROXIES
@@ -3532,6 +3768,8 @@
+ * @anchor CONFIGURE_MP_MPCI_TABLE_POINTER
* The value of this configuration option initializes the MPCI Configuration
* Table.
@@ -3548,8 +3786,8 @@
* Multiprocessor System assuming the BSP provides the proper set of supporting
* methods.
- * defined.
+ * is defined.
* @endparblock
#define CONFIGURE_MP_MPCI_TABLE_POINTER
@@ -3559,6 +3797,8 @@
+ * @anchor CONFIGURE_MP_NODE_NUMBER
* The value of this configuration option defines the node number of this node
@@ -3583,8 +3823,8 @@
* ``NODE_NUMBER`` set to different values. The test programs behave
* differently based upon their node number.
- * defined.
+ * is defined.
* @endparblock
#define CONFIGURE_MP_NODE_NUMBER
@@ -3611,6 +3851,8 @@
+ * @anchor CONFIGURE_MAXIMUM_POSIX_KEYS
* The value of this configuration option defines the maximum number of POSIX
* API Keys that can be concurrently active.
@@ -3649,12 +3891,14 @@
+ * @anchor CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
* The value of this configuration option defines the maximum number of key
* value pairs used by POSIX API Keys that can be concurrently active.
- * The default value is #CONFIGURE_MAXIMUM_POSIX_KEYS * (
- * #CONFIGURE_MAXIMUM_TASKS + #CONFIGURE_MAXIMUM_POSIX_THREADS ).
+ * The default value is @ref CONFIGURE_MAXIMUM_POSIX_KEYS * ( @ref
+ * CONFIGURE_MAXIMUM_TASKS + @ref CONFIGURE_MAXIMUM_POSIX_THREADS ).
* @par Constraints
* @parblock
@@ -3694,6 +3938,8 @@
+ * @anchor CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
@@ -3729,7 +3975,7 @@
#define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
@@ -3738,6 +3984,8 @@
+ * @anchor CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
* API Queued Signals that can be concurrently active.
@@ -3781,6 +4029,8 @@
+ * @anchor CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
* API Named Semaphores that can be concurrently active.
@@ -3830,6 +4080,8 @@
+ * @anchor CONFIGURE_MAXIMUM_POSIX_SHMS
* API Shared Memory objects that can be concurrently active.
@@ -3873,6 +4125,8 @@
+ * @anchor CONFIGURE_MAXIMUM_POSIX_THREADS
* API Threads that can be concurrently active.
@@ -3907,12 +4161,12 @@
* This calculations for the required memory in the RTEMS Workspace for threads
* assume that each thread has a minimum stack size and has floating point
- * used to specify thread stack requirements **above** the minimum size
+ * is used to specify thread stack requirements **above** the minimum size
* required.
- * The maximum number of Classic API Tasks is specified by
+ * The maximum number of Classic API Tasks is specified by @ref
* All POSIX threads have floating point enabled.
* @endparblock
@@ -3924,6 +4178,8 @@
+ * @anchor CONFIGURE_MAXIMUM_POSIX_TIMERS
@@ -3972,12 +4228,14 @@
+ * @anchor CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
* bytes for every POSIX thread in the system.
- * The default value is two times the value of
+ * The default value is two times the value of @ref
* @par Constraints
* @parblock
@@ -4015,6 +4273,8 @@
+ * @anchor CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
* POSIX API initialization thread.
@@ -4036,18 +4296,20 @@
+ * @anchor CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
* The value of this configuration option defines the thread stack size of the
- * The default value is #CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE.
+ * The default value is @ref CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE.
* @par Constraints
* @parblock
@@ -4062,6 +4324,8 @@
+ * @anchor CONFIGURE_POSIX_INIT_THREAD_TABLE
* In case this configuration option is defined, then exactly one POSIX
* initialization thread is configured.
@@ -4074,11 +4338,11 @@
* options
* * ``CONFIGURE_POSIX_INIT_THREAD_TABLE``, or
* @endparblock
@@ -4104,8 +4368,8 @@
* By default, the <a
* href="https://docs.rtems.org/branches/master/c-user/scheduling-concepts/uniprocessor-schedulers.html#deterministic-priority-scheduler">Deterministic
* Priority Scheduler</a> algorithm is used in uniprocessor configurations. In
- * case SMP is enabled and the configured maximum processors
- * (#CONFIGURE_MAXIMUM_PROCESSORS) is greater than one, then the <a
+ * case SMP is enabled and the configured maximum processors (@ref
+ * CONFIGURE_MAXIMUM_PROCESSORS) is greater than one, then the <a
* href="https://docs.rtems.org/branches/master/c-user/scheduling-concepts/smp-schedulers.html#earliest-deadline-first-smp-scheduler">Earliest
* Deadline First SMP Scheduler</a> is selected as the default scheduler
* algorithm.
@@ -4128,11 +4392,13 @@
+ * @anchor CONFIGURE_CBS_MAXIMUM_SERVERS
* The value of this configuration option defines the maximum number Constant
* Bandwidth Servers that can be concurrently active.
- * The default value is #CONFIGURE_MAXIMUM_TASKS.
+ * The default value is @ref CONFIGURE_MAXIMUM_TASKS.
* @par Constraints
* @parblock
@@ -4150,8 +4416,8 @@
* @endparblock
* @par Notes
- * #CONFIGURE_SCHEDULER_CBS is defined.
+ * CONFIGURE_SCHEDULER_CBS is defined.
#define CONFIGURE_CBS_MAXIMUM_SERVERS
@@ -4160,23 +4426,25 @@
+ * @anchor CONFIGURE_MAXIMUM_PRIORITY
* For the following schedulers
* * <a
* Priority Scheduler</a>, which is the default in uniprocessor
- * configurations and can be configured through the
- * #CONFIGURE_SCHEDULER_PRIORITY configuration option,
+ * configurations and can be configured through the @ref
+ * CONFIGURE_SCHEDULER_PRIORITY configuration option,
* * <a
* href="https://docs.rtems.org/branches/master/c-user/scheduling-concepts/smp-schedulers.html#deterministic-priority-smp-scheduler">Deterministic
- * Priority SMP Scheduler</a> which can be configured through the
- * #CONFIGURE_SCHEDULER_PRIORITY_SMP configuration option, and
+ * Priority SMP Scheduler</a> which can be configured through the @ref
+ * CONFIGURE_SCHEDULER_PRIORITY_SMP configuration option, and
* * <a
* href="https://docs.rtems.org/branches/master/c-user/scheduling-concepts/smp-schedulers.html#arbitrary-processor-affinity-priority-smp-scheduler">Arbitrary
* Processor Affinity Priority SMP Scheduler</a> which can be configured
- * through the #CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP configuration
+ * through the @ref CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP configuration
* option
* this configuration option specifies the maximum numeric priority of any task
@@ -4218,6 +4486,8 @@
+ * @anchor CONFIGURE_SCHEDULER_ASSIGNMENTS
* The value of this configuration option is used to initialize the initial
* scheduler to processor assignments.
@@ -4237,7 +4507,7 @@
* * ``RTEMS_SCHEDULER_ASSIGN_NO_SCHEDULER``
* The ``scheduler_index`` macro parameter shall be a valid index of the
- * scheduler table defined by the #CONFIGURE_SCHEDULER_TABLE_ENTRIES
+ * scheduler table defined by the @ref CONFIGURE_SCHEDULER_TABLE_ENTRIES
* The ``attributes`` macro parameter shall be set to exactly one of the
@@ -4247,8 +4517,8 @@
* * ``RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL``
- * * The value of the configuration option shall be a list of exactly
- * #CONFIGURE_MAXIMUM_PROCESSORS elements.
+ * * The value of the configuration option shall be a list of exactly @ref
+ * CONFIGURE_MAXIMUM_PROCESSORS elements.
* @endparblock
* @par Notes
@@ -4268,6 +4538,8 @@
+ * @anchor CONFIGURE_SCHEDULER_CBS
* In case this configuration option is defined, then the <a
* href="https://docs.rtems.org/branches/master/c-user/scheduling-concepts/uniprocessor-schedulers.html#constant-bandwidth-server-scheduling-cbs">Constant
* Bandwidth Server Scheduling (CBS)</a> algorithm is made available to the
@@ -4295,6 +4567,8 @@
+ * @anchor CONFIGURE_SCHEDULER_EDF
* href="https://docs.rtems.org/branches/master/c-user/scheduling-concepts/uniprocessor-schedulers.html#earliest-deadline-first-scheduler">Earliest
* Deadline First Scheduler</a> algorithm is made available to the application.
@@ -4321,6 +4595,8 @@
+ * @anchor CONFIGURE_SCHEDULER_EDF_SMP
* Deadline First SMP Scheduler</a> algorithm is made available to the
@@ -4343,8 +4619,8 @@
* Scheduler Configuration</a> is present, then it is used as the scheduler for
* up to 32 processors.
- * This scheduler algorithm is the default in SMP configurations if
- * #CONFIGURE_MAXIMUM_PROCESSORS is greater than one.
+ * This scheduler algorithm is the default in SMP configurations if @ref
+ * CONFIGURE_MAXIMUM_PROCESSORS is greater than one.
* @endparblock
#define CONFIGURE_SCHEDULER_EDF_SMP
@@ -4354,6 +4630,8 @@
+ * @anchor CONFIGURE_SCHEDULER_NAME
* The value of this configuration option defines the name of the default
* scheduler.
@@ -4415,6 +4693,8 @@
+ * @anchor CONFIGURE_SCHEDULER_PRIORITY
* Priority Scheduler</a> algorithm is made available to the application.
@@ -4433,11 +4713,11 @@
* exactly one processor.
- * This scheduler algorithm is the default when #CONFIGURE_MAXIMUM_PROCESSORS
- * is exactly one.
+ * This scheduler algorithm is the default when @ref
+ * CONFIGURE_MAXIMUM_PROCESSORS is exactly one.
- * The memory allocated for this scheduler depends on the
- * #CONFIGURE_MAXIMUM_PRIORITY configuration option.
+ * The memory allocated for this scheduler depends on the @ref
+ * CONFIGURE_MAXIMUM_PRIORITY configuration option.
* @endparblock
#define CONFIGURE_SCHEDULER_PRIORITY
@@ -4447,6 +4727,8 @@
+ * @anchor CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
* Processor Affinity Priority SMP Scheduler</a> algorithm is made available to
@@ -4469,8 +4751,8 @@
* @endparblock
#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
@@ -4480,6 +4762,8 @@
+ * @anchor CONFIGURE_SCHEDULER_PRIORITY_SMP
* Priority SMP Scheduler</a> algorithm is made available to the application.
@@ -4501,8 +4785,8 @@
* @endparblock
#define CONFIGURE_SCHEDULER_PRIORITY_SMP
@@ -4512,6 +4796,8 @@
+ * @anchor CONFIGURE_SCHEDULER_SIMPLE
* href="https://docs.rtems.org/branches/master/c-user/scheduling-concepts/uniprocessor-schedulers.html#simple-priority-scheduler">Simple
@@ -4538,6 +4824,8 @@
+ * @anchor CONFIGURE_SCHEDULER_SIMPLE_SMP
* href="https://docs.rtems.org/branches/master/c-user/scheduling-concepts/smp-schedulers.html#simple-priority-smp-scheduler">Simple
@@ -4567,6 +4855,8 @@
+ * @anchor CONFIGURE_SCHEDULER_STRONG_APA
* In case this configuration option is defined, then the Strong APA algorithm
* is made available to the application.
@@ -4592,6 +4882,8 @@
+ * @anchor CONFIGURE_SCHEDULER_TABLE_ENTRIES
* configured schedulers.
@@ -4655,6 +4947,8 @@
+ * @anchor CONFIGURE_SCHEDULER_USER
* In case this configuration option is defined, then the user shall provide a
* scheduler algorithm to the application.
@@ -4716,6 +5010,8 @@
+ * @anchor CONFIGURE_TASK_STACK_ALLOCATOR
* The value of this configuration option initializes the stack allocator
* allocate handler.
@@ -4732,11 +5028,11 @@
* A correctly configured system shall configure the following to be
* consistent:
- * * #CONFIGURE_TASK_STACK_ALLOCATOR_INIT
+ * * @ref CONFIGURE_TASK_STACK_ALLOCATOR_INIT
* * ``CONFIGURE_TASK_STACK_ALLOCATOR``
- * * #CONFIGURE_TASK_STACK_DEALLOCATOR
+ * * @ref CONFIGURE_TASK_STACK_DEALLOCATOR
* @endparblock
#define CONFIGURE_TASK_STACK_ALLOCATOR
@@ -4746,6 +5042,8 @@
+ * @anchor CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
* In case this configuration option is defined, then the system is informed
* that the task stack allocator does not use the RTEMS Workspace.
@@ -4755,7 +5053,7 @@
* @par Notes
* This configuration option may be used if a custom task stack allocator is
- * configured, see #CONFIGURE_TASK_STACK_ALLOCATOR.
+ * configured, see @ref CONFIGURE_TASK_STACK_ALLOCATOR.
#define CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
@@ -4764,6 +5062,8 @@
+ * @anchor CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE
* The value of this configuration option is the address for the stack
* allocator allocate handler used to allocate the task storage area of each
* IDLE task.
@@ -4798,7 +5098,7 @@
* The
- * * #CONFIGURE_IDLE_TASK_STORAGE_SIZE, and
+ * * @ref CONFIGURE_IDLE_TASK_STORAGE_SIZE, and
* * ``CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE``
@@ -4812,6 +5112,8 @@
+ * @anchor CONFIGURE_TASK_STACK_ALLOCATOR_INIT
* initialization handler.
@@ -4831,9 +5133,9 @@
* * ``CONFIGURE_TASK_STACK_ALLOCATOR_INIT``
* @endparblock
#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT
@@ -4843,6 +5145,8 @@
+ * @anchor CONFIGURE_TASK_STACK_DEALLOCATOR
* deallocate handler.
@@ -4859,9 +5163,9 @@
* consistent:
* * ``CONFIGURE_TASK_STACK_DEALLOCATOR``
* @endparblock
@@ -4873,6 +5177,8 @@
+ * @anchor CONFIGURE_TASK_STACK_FROM_ALLOCATOR
* The value of this configuration option is used to calculate the task stack
* space size.
@@ -4888,7 +5194,7 @@
* @par Notes
#define CONFIGURE_TASK_STACK_FROM_ALLOCATOR
diff --git a/cpukit/include/rtems/bspIo.h b/cpukit/include/rtems/bspIo.h
index b8a48e8237..442346b64a 100644
--- a/cpukit/include/rtems/bspIo.h
+++ b/cpukit/include/rtems/bspIo.h
@@ -78,7 +78,7 @@ extern "C" {
* The directives may be used to print debug and test information. The kernel
* character input/output support should work even if no Console Driver is
- * configured, see #CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER. The kernel
+ * configured, see @ref CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER. The kernel
* character input and output device is provided by the BSP. Applications may
* change the device.
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 3d51fd6b5d..74b95deb7f 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -152,8 +152,8 @@ extern "C" {
* RTEMS Workspace for this application, otherwise false.
* @par Notes
- * The setting is defined by the
- * #CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE application configuration
+ * The setting is defined by the @ref
+ * CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE application configuration
* option.
* @par Constraints
@@ -353,7 +353,7 @@ const char *rtems_get_version_string( void );
* during system initialization for this application, otherwise false.
* @par Notes
- * The setting is defined by the #CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
+ * The setting is defined by the @ref CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
* application configuration option.
* @par Constraints
@@ -377,8 +377,8 @@ const char *rtems_get_version_string( void );
* @return Returns the IDLE task stack size in bytes of this application.
* @par Notes
- * The IDLE task stack size is defined by the #CONFIGURE_IDLE_TASK_STACK_SIZE
- * application configuration option.
+ * The IDLE task stack size is defined by the @ref
+ * CONFIGURE_IDLE_TASK_STACK_SIZE application configuration option.
* @par Constraints
* @parblock
@@ -401,8 +401,8 @@ const char *rtems_get_version_string( void );
* @return Returns the IDLE task body of this application.
* @par Notes
- * The IDLE task body is defined by the #CONFIGURE_IDLE_TASK_BODY application
- * configuration option.
+ * The IDLE task body is defined by the @ref CONFIGURE_IDLE_TASK_BODY
+ * application configuration option.
* @par Constraints
* @parblock
@@ -425,8 +425,8 @@ const char *rtems_get_version_string( void );
* @return Returns the interrupt stack size in bytes of this application.
* @par Notes
- * The interrupt stack size is defined by the #CONFIGURE_INTERRUPT_STACK_SIZE
+ * The interrupt stack size is defined by the @ref
+ * CONFIGURE_INTERRUPT_STACK_SIZE application configuration option.
* @par Constraints
* @parblock
@@ -452,7 +452,7 @@ const char *rtems_get_version_string( void );
* configured for this application.
* @par Notes
- * The resource number is defined by the #CONFIGURE_MAXIMUM_USER_EXTENSIONS
+ * The resource number is defined by the @ref CONFIGURE_MAXIMUM_USER_EXTENSIONS
* application configuration option. See also rtems_resource_is_unlimited()
* and rtems_resource_maximum_per_allocation().
@@ -482,7 +482,7 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
* @parblock
* The actual number of processors available to the application is returned by
* rtems_scheduler_get_processor_maximum() which less than or equal to the
- * configured maximum number of processors (#CONFIGURE_MAXIMUM_PROCESSORS).
+ * configured maximum number of processors (@ref CONFIGURE_MAXIMUM_PROCESSORS).
* In uniprocessor configurations, this macro is a compile time constant which
* evaluates to one.
@@ -512,8 +512,8 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
* this application.
* @par Notes
- * The number of microseconds per clock tick is defined by the
- * #CONFIGURE_MICROSECONDS_PER_TICK application configuration option.
+ * The number of microseconds per clock tick is defined by the @ref
+ * CONFIGURE_MICROSECONDS_PER_TICK application configuration option.
* @par Constraints
* @parblock
@@ -539,8 +539,8 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
* this application.
* @par Notes
- * The number of milliseconds per clock tick is defined by the
+ * The number of milliseconds per clock tick is defined by the @ref
* @par Constraints
* @parblock
@@ -566,8 +566,8 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
* this application.
* @par Notes
- * The number of nanoseconds per clock tick is defined by the
+ * The number of nanoseconds per clock tick is defined by the @ref
* @par Constraints
* @parblock
@@ -593,8 +593,8 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
* application.
* @par Notes
- * The number of initial extensions is defined by the
- * #CONFIGURE_INITIAL_EXTENSIONS application configuration option and related
+ * The number of initial extensions is defined by the @ref
+ * CONFIGURE_INITIAL_EXTENSIONS application configuration option and related
* options.
* @par Constraints
@@ -621,8 +621,8 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
* stack of each IDLE task configured for this application.
* @par Notes
- * The task stack allocator allocate hook for idle tasks is defined by the
- * #CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE application configuration option.
+ * The task stack allocator allocate hook for idle tasks is defined by the @ref
+ * CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE application configuration option.
* @par Constraints
* @parblock
@@ -648,8 +648,8 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
* application.
* @par Notes
- * The task stack allocator allocate hook is defined by the
- * #CONFIGURE_TASK_STACK_ALLOCATOR application configuration option.
+ * The task stack allocator allocate hook is defined by the @ref
+ * CONFIGURE_TASK_STACK_ALLOCATOR application configuration option.
* @par Constraints
* @parblock
@@ -674,8 +674,8 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
* this application.
* @par Notes
- * The task stack allocator initialization hook is defined by the
- * #CONFIGURE_TASK_STACK_ALLOCATOR_INIT application configuration option.
+ * The task stack allocator initialization hook is defined by the @ref
+ * CONFIGURE_TASK_STACK_ALLOCATOR_INIT application configuration option.
* @par Constraints
* @parblock
@@ -701,8 +701,8 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
* application.
* @par Notes
- * The task stack allocator free hook is defined by the
- * #CONFIGURE_TASK_STACK_DEALLOCATOR application configuration option.
+ * The task stack allocator free hook is defined by the @ref
+ * CONFIGURE_TASK_STACK_DEALLOCATOR application configuration option.
* @par Constraints
* @parblock
@@ -726,8 +726,8 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
* application.
* @par Notes
- * The clock ticks per timeslice is defined by the
- * #CONFIGURE_TICKS_PER_TIMESLICE application configuration option.
+ * The clock ticks per timeslice is defined by the @ref
+ * CONFIGURE_TICKS_PER_TIMESLICE application configuration option.
* @par Constraints
* @parblock
@@ -753,7 +753,7 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
* configured to be unified for this application, otherwise false.
* @par Notes
- * The setting is defined by the #CONFIGURE_UNIFIED_WORK_AREAS application
+ * The setting is defined by the @ref CONFIGURE_UNIFIED_WORK_AREAS application
* @par Constraints
diff --git a/cpukit/include/rtems/extension.h b/cpukit/include/rtems/extension.h
index 0117a41b8a..5f9c09db06 100644
--- a/cpukit/include/rtems/extension.h
+++ b/cpukit/include/rtems/extension.h
@@ -140,7 +140,7 @@ rtems_status_code rtems_extension_delete( rtems_id id );
* may be in an undefined and corrupt state.
* It is recommended to register fatal extensions through initial extension
- * sets, see #CONFIGURE_INITIAL_EXTENSIONS.
+ * sets, see @ref CONFIGURE_INITIAL_EXTENSIONS.
* @endparblock
typedef User_extensions_fatal_extension rtems_fatal_extension;
@@ -230,7 +230,7 @@ rtems_status_code rtems_extension_ident( rtems_name name, rtems_id *id );
* @ingroup RTEMSAPIClassicUserExt
* @brief The extensions table contains a set of extensions which may be
- * registered in the system through the #CONFIGURE_INITIAL_EXTENSIONS
+ * registered in the system through the @ref CONFIGURE_INITIAL_EXTENSIONS
* application configuration option or the rtems_extension_create()
* directive.
@@ -271,8 +271,8 @@ typedef User_extensions_Table rtems_extensions_table;
* @retval ::RTEMS_TOO_MANY There was no inactive object available to create an
* extension set. The number of extension sets available to the application
- * is configured through the #CONFIGURE_MAXIMUM_USER_EXTENSIONS application
+ * is configured through the @ref CONFIGURE_MAXIMUM_USER_EXTENSIONS
* @par Notes
* @parblock
@@ -286,8 +286,8 @@ typedef User_extensions_Table rtems_extensions_table;
* are invoked upon the next system event supporting an extension.
* An alternative to dynamically created extension sets are initial extensions,
- * see #CONFIGURE_INITIAL_EXTENSIONS. Initial extensions are recommended for
- * extension sets which provide a fatal error extension.
+ * see @ref CONFIGURE_INITIAL_EXTENSIONS. Initial extensions are recommended
+ * for extension sets which provide a fatal error extension.
* For control and maintenance of the extension set, RTEMS allocates a ESCB
* from the local ESCB free pool and initializes it.
@@ -306,8 +306,8 @@ typedef User_extensions_Table rtems_extensions_table;
* cause the calling task to be preempted.
* * The number of extension sets available to the application is configured
- * through the #CONFIGURE_MAXIMUM_USER_EXTENSIONS application configuration
- * option.
+ * through the @ref CONFIGURE_MAXIMUM_USER_EXTENSIONS application
+ * configuration option.
* @endparblock
rtems_status_code rtems_extension_create(
diff --git a/cpukit/include/rtems/io.h b/cpukit/include/rtems/io.h
index 181da9fe4f..cdb3a5b902 100644
--- a/cpukit/include/rtems/io.h
+++ b/cpukit/include/rtems/io.h
@@ -98,7 +98,7 @@ typedef rtems_status_code rtems_device_driver;
* @par Notes
* The major number of a device is determined by rtems_io_register_driver() and
- * the application configuration (see #CONFIGURE_MAXIMUM_DRIVERS) .
+ * the application configuration (see @ref CONFIGURE_MAXIMUM_DRIVERS) .
typedef uint32_t rtems_device_major_number;
@@ -207,7 +207,7 @@ typedef struct {
* @retval ::RTEMS_INVALID_ADDRESS The device driver address table was empty.
* @retval ::RTEMS_INVALID_NUMBER The device major number of the device was out
- * of range, see #CONFIGURE_MAXIMUM_DRIVERS.
+ * of range, see @ref CONFIGURE_MAXIMUM_DRIVERS.
* @retval ::RTEMS_TOO_MANY The system was unable to obtain a device major
* number.
diff --git a/cpukit/include/rtems/rtems/barrier.h b/cpukit/include/rtems/rtems/barrier.h
index 348610d886..d713930b1d 100644
--- a/cpukit/include/rtems/rtems/barrier.h
+++ b/cpukit/include/rtems/rtems/barrier.h
@@ -137,7 +137,7 @@ extern "C" {
* barrier. The number of barriers available to the application is
- * configured through the #CONFIGURE_MAXIMUM_BARRIERS application
+ * configured through the @ref CONFIGURE_MAXIMUM_BARRIERS application
* @par Notes
@@ -157,7 +157,7 @@ extern "C" {
* * The number of barriers available to the application is configured through
- * the #CONFIGURE_MAXIMUM_BARRIERS application configuration option.
+ * the @ref CONFIGURE_MAXIMUM_BARRIERS application configuration option.
* * Where the object class corresponding to the directive is configured to use
* unlimited objects, the directive may allocate memory from the RTEMS
diff --git a/cpukit/include/rtems/rtems/clock.h b/cpukit/include/rtems/rtems/clock.h
index 2f541d46a2..3dff28e3d9 100644
--- a/cpukit/include/rtems/rtems/clock.h
+++ b/cpukit/include/rtems/rtems/clock.h
@@ -116,8 +116,8 @@ struct bintime;
* before 2100-01-01:00:00.000000000Z. The latest valid time of day accepted
* by the POSIX clock_settime() is 2400-01-01T00:00:00.999999999Z.
- * The specified time is based on the configured clock tick rate, see the
+ * The specified time is based on the configured clock tick rate, see the @ref
* Setting the time forward will fire all CLOCK_REALTIME timers which are
* scheduled at a time point before or at the time set by the directive. This
@@ -853,8 +853,8 @@ rtems_status_code rtems_clock_get_seconds_since_epoch(
* application.
* @par Notes
- * The number of clock ticks per second is defined indirectly by the
- * #CONFIGURE_MICROSECONDS_PER_TICK configuration option.
+ * The number of clock ticks per second is defined indirectly by the @ref
+ * CONFIGURE_MICROSECONDS_PER_TICK configuration option.
* @par Constraints
* @parblock
diff --git a/cpukit/include/rtems/rtems/config.h b/cpukit/include/rtems/rtems/config.h
index 4a6e6c8e2e..dd9d1436b1 100644
--- a/cpukit/include/rtems/rtems/config.h
+++ b/cpukit/include/rtems/rtems/config.h
@@ -80,7 +80,7 @@ typedef struct {
* @brief This member contains the maximum number of Classic API Tasks
- * See #CONFIGURE_MAXIMUM_TASKS.
+ * See @ref CONFIGURE_MAXIMUM_TASKS.
uint32_t maximum_tasks;
@@ -94,7 +94,7 @@ typedef struct {
* @brief This member contains the maximum number of Classic API Timers
- * See #CONFIGURE_MAXIMUM_TIMERS.
+ * See @ref CONFIGURE_MAXIMUM_TIMERS.
uint32_t maximum_timers;
@@ -102,7 +102,7 @@ typedef struct {
* @brief This member contains the maximum number of Classic API Semaphores
- * See #CONFIGURE_MAXIMUM_SEMAPHORES.
+ * See @ref CONFIGURE_MAXIMUM_SEMAPHORES.
uint32_t maximum_semaphores;
@@ -110,7 +110,7 @@ typedef struct {
* @brief This member contains the maximum number of Classic API Message Queues
- * See #CONFIGURE_MAXIMUM_MESSAGE_QUEUES.
+ * See @ref CONFIGURE_MAXIMUM_MESSAGE_QUEUES.
uint32_t maximum_message_queues;
@@ -118,7 +118,7 @@ typedef struct {
* @brief This member contains the maximum number of Classic API Partitions
- * See #CONFIGURE_MAXIMUM_PARTITIONS.
+ * See @ref CONFIGURE_MAXIMUM_PARTITIONS.
uint32_t maximum_partitions;
@@ -126,7 +126,7 @@ typedef struct {
* @brief This member contains the maximum number of Classic API Regions
- * See #CONFIGURE_MAXIMUM_REGIONS.
+ * See @ref CONFIGURE_MAXIMUM_REGIONS.
uint32_t maximum_regions;
@@ -134,7 +134,7 @@ typedef struct {
* @brief This member contains the maximum number of Classic API Dual-Ported
* Memories configured for this application.
- * See #CONFIGURE_MAXIMUM_PORTS.
+ * See @ref CONFIGURE_MAXIMUM_PORTS.
uint32_t maximum_ports;
@@ -142,7 +142,7 @@ typedef struct {
* @brief This member contains the maximum number of Classic API Rate Monotonic
* Periods configured for this application.
- * See #CONFIGURE_MAXIMUM_PERIODS.
+ * See @ref CONFIGURE_MAXIMUM_PERIODS.
uint32_t maximum_periods;
@@ -150,7 +150,7 @@ typedef struct {
* @brief This member contains the maximum number of Classic API Barriers
- * See #CONFIGURE_MAXIMUM_BARRIERS.
+ * See @ref CONFIGURE_MAXIMUM_BARRIERS.
uint32_t maximum_barriers;
@@ -158,7 +158,7 @@ typedef struct {
* @brief This member contains the number of Classic API Initialization Tasks
- * See #CONFIGURE_RTEMS_INIT_TASKS_TABLE.
+ * See @ref CONFIGURE_RTEMS_INIT_TASKS_TABLE.
uint32_t number_of_initialization_tasks;
@@ -166,7 +166,7 @@ typedef struct {
* @brief This member contains the pointer to Classic API Initialization Tasks
* Table of this application.
const rtems_initialization_tasks_table *User_initialization_tasks_table;
} rtems_api_configuration_table;
@@ -183,7 +183,7 @@ typedef struct {
* @par Notes
- * The resource number is defined by the #CONFIGURE_MAXIMUM_BARRIERS
+ * The resource number is defined by the @ref CONFIGURE_MAXIMUM_BARRIERS
@@ -210,7 +210,7 @@ uint32_t rtems_configuration_get_maximum_barriers( void );
* @par Notes
- * The resource number is defined by the #CONFIGURE_MAXIMUM_MESSAGE_QUEUES
+ * The resource number is defined by the @ref CONFIGURE_MAXIMUM_MESSAGE_QUEUES
@@ -237,7 +237,7 @@ uint32_t rtems_configuration_get_maximum_message_queues( void );
* @par Notes
- * The resource number is defined by the #CONFIGURE_MAXIMUM_PARTITIONS
+ * The resource number is defined by the @ref CONFIGURE_MAXIMUM_PARTITIONS
@@ -264,9 +264,9 @@ uint32_t rtems_configuration_get_maximum_partitions( void );
* @par Notes
- * The resource number is defined by the #CONFIGURE_MAXIMUM_PERIODS application
- * configuration option. See also rtems_resource_is_unlimited() and
- * rtems_resource_maximum_per_allocation().
+ * The resource number is defined by the @ref CONFIGURE_MAXIMUM_PERIODS
+ * application configuration option. See also rtems_resource_is_unlimited()
+ * and rtems_resource_maximum_per_allocation().
* @par Constraints
* @parblock
@@ -291,9 +291,9 @@ uint32_t rtems_configuration_get_maximum_periods( void );
* @par Notes
- * The resource number is defined by the #CONFIGURE_MAXIMUM_PORTS application
+ * The resource number is defined by the @ref CONFIGURE_MAXIMUM_PORTS
* @par Constraints
* @parblock
@@ -318,9 +318,9 @@ uint32_t rtems_configuration_get_maximum_ports( void );
* @par Notes
- * The resource number is defined by the #CONFIGURE_MAXIMUM_REGIONS application
+ * The resource number is defined by the @ref CONFIGURE_MAXIMUM_REGIONS
* @par Constraints
* @parblock
@@ -345,7 +345,7 @@ uint32_t rtems_configuration_get_maximum_regions( void );
* @par Notes
- * The resource number is defined by the #CONFIGURE_MAXIMUM_SEMAPHORES
+ * The resource number is defined by the @ref CONFIGURE_MAXIMUM_SEMAPHORES
@@ -372,9 +372,9 @@ uint32_t rtems_configuration_get_maximum_semaphores( void );
* @par Notes
- * The resource number is defined by the #CONFIGURE_MAXIMUM_TASKS application
+ * The resource number is defined by the @ref CONFIGURE_MAXIMUM_TASKS
* @par Constraints
* @parblock
@@ -399,9 +399,9 @@ uint32_t rtems_configuration_get_maximum_tasks( void );
* @par Notes
- * The resource number is defined by the #CONFIGURE_MAXIMUM_TIMERS application
+ * The resource number is defined by the @ref CONFIGURE_MAXIMUM_TIMERS
* @par Constraints
* @parblock
diff --git a/cpukit/include/rtems/rtems/dpmem.h b/cpukit/include/rtems/rtems/dpmem.h
index 855ea3ddc6..48fbf9f9f3 100644
--- a/cpukit/include/rtems/rtems/dpmem.h
+++ b/cpukit/include/rtems/rtems/dpmem.h
@@ -114,7 +114,7 @@ extern "C" {
* port. The number of port available to the application is configured
- * through the #CONFIGURE_MAXIMUM_PORTS application configuration option.
+ * through the @ref CONFIGURE_MAXIMUM_PORTS application configuration option.
* @par Notes
* @parblock
@@ -138,7 +138,7 @@ extern "C" {
* * The number of ports available to the application is configured through the
- * #CONFIGURE_MAXIMUM_PORTS application configuration option.
+ * @ref CONFIGURE_MAXIMUM_PORTS application configuration option.
diff --git a/cpukit/include/rtems/rtems/message.h b/cpukit/include/rtems/rtems/message.h
index 4f2bb69500..a7575b81e2 100644
--- a/cpukit/include/rtems/rtems/message.h
+++ b/cpukit/include/rtems/rtems/message.h
@@ -212,14 +212,14 @@ typedef struct {
* message queue. The number of message queue available to the application
- * is configured through the #CONFIGURE_MAXIMUM_MESSAGE_QUEUES application
+ * is configured through the @ref CONFIGURE_MAXIMUM_MESSAGE_QUEUES
* @retval ::RTEMS_TOO_MANY In multiprocessing configurations, there was no
* inactive global object available to create a global message queue. The
* number of global objects available to the application is configured
- * through the #CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS application configuration
- * option.
+ * through the @ref CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS application
* @retval ::RTEMS_INVALID_NUMBER The product of ``count`` and
* ``max_message_size`` is greater than the maximum storage size.
@@ -260,16 +260,16 @@ typedef struct {
* message to remote nodes. This may preempt the calling task.
* * The number of message queues available to the application is configured
- * through the #CONFIGURE_MAXIMUM_MESSAGE_QUEUES application configuration
- * option.
+ * through the @ref CONFIGURE_MAXIMUM_MESSAGE_QUEUES application
* Workspace.
* * The number of global objects available to the application is configured
- * option.
* @endparblock
rtems_status_code rtems_message_queue_create(
@@ -342,8 +342,8 @@ rtems_status_code rtems_message_queue_create(
* runtime memory allocators. This can simplify the application architecture
* as well as any analysis that may be required.
- * The value for #CONFIGURE_MESSAGE_BUFFER_MEMORY should not include memory for
- * message queues constructed by rtems_message_queue_construct().
+ * The value for @ref CONFIGURE_MESSAGE_BUFFER_MEMORY should not include memory
+ * for message queues constructed by rtems_message_queue_construct().
* @endparblock
* @par Constraints
@@ -362,16 +362,16 @@ rtems_status_code rtems_message_queue_create(
- * option.
* Workspace.
- * option.
* @endparblock
rtems_status_code rtems_message_queue_construct(
diff --git a/cpukit/include/rtems/rtems/part.h b/cpukit/include/rtems/rtems/part.h
index 10091b48f4..f127fb8347 100644
--- a/cpukit/include/rtems/rtems/part.h
+++ b/cpukit/include/rtems/rtems/part.h
@@ -168,13 +168,13 @@ extern "C" {
* partition. The number of partitions available to the application is
- * configured through the #CONFIGURE_MAXIMUM_PARTITIONS application
+ * configured through the @ref CONFIGURE_MAXIMUM_PARTITIONS application
* inactive global object available to create a global semaphore. The number
* of global objects available to the application is configured through the
- * #CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS application configuration option.
+ * @ref CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS application configuration option.
* @par Notes
* @parblock
@@ -220,7 +220,7 @@ extern "C" {
* * The number of partitions available to the application is configured
- * through the #CONFIGURE_MAXIMUM_PARTITIONS application configuration
+ * through the @ref CONFIGURE_MAXIMUM_PARTITIONS application configuration
* option.
@@ -228,8 +228,8 @@ extern "C" {
* Workspace.
- * option.
* @endparblock
rtems_status_code rtems_partition_create(
diff --git a/cpukit/include/rtems/rtems/ratemon.h b/cpukit/include/rtems/rtems/ratemon.h
index 7c789a204b..1408b862f4 100644
--- a/cpukit/include/rtems/rtems/ratemon.h
+++ b/cpukit/include/rtems/rtems/ratemon.h
@@ -245,7 +245,8 @@ struct rtems_printer;
* period. The number of periods available to the application is configured
- * through the #CONFIGURE_MAXIMUM_PERIODS application configuration option.
+ * through the @ref CONFIGURE_MAXIMUM_PERIODS application configuration
+ * option.
* @par Notes
* @parblock
@@ -269,7 +270,7 @@ struct rtems_printer;
* * The number of periods available to the application is configured through
- * the #CONFIGURE_MAXIMUM_PERIODS application configuration option.
+ * the @ref CONFIGURE_MAXIMUM_PERIODS application configuration option.
diff --git a/cpukit/include/rtems/rtems/region.h b/cpukit/include/rtems/rtems/region.h
index 94a8d7008f..6cbc95d9bd 100644
--- a/cpukit/include/rtems/rtems/region.h
+++ b/cpukit/include/rtems/rtems/region.h
@@ -195,7 +195,8 @@ rtems_status_code rtems_region_get_segment_size(
* region. The number of regions available to the application is configured
- * through the #CONFIGURE_MAXIMUM_REGIONS application configuration option.
+ * through the @ref CONFIGURE_MAXIMUM_REGIONS application configuration
+ * option.
* @retval ::RTEMS_INVALID_SIZE The ``page_size`` parameter was invalid.
@@ -219,7 +220,7 @@ rtems_status_code rtems_region_get_segment_size(
* * The number of regions available to the application is configured through
- * the #CONFIGURE_MAXIMUM_REGIONS application configuration option.
+ * the @ref CONFIGURE_MAXIMUM_REGIONS application configuration option.
diff --git a/cpukit/include/rtems/rtems/scheduler.h b/cpukit/include/rtems/rtems/scheduler.h
index 8bd041558f..a582662000 100644
--- a/cpukit/include/rtems/rtems/scheduler.h
+++ b/cpukit/include/rtems/rtems/scheduler.h
@@ -383,8 +383,8 @@ uint32_t rtems_scheduler_get_processor( void );
* Where the system was built with SMP support enabled, this directive returns
* the minimum of the processors (physically or virtually) available at the
- * target and the configured processor maximum (see
- * #CONFIGURE_MAXIMUM_PROCESSORS). Not all processors in the range from
+ * target and the configured processor maximum (see @ref
+ * CONFIGURE_MAXIMUM_PROCESSORS). Not all processors in the range from
* processor index zero to the last processor index (which is the processor
* maximum minus one) may be configured to be used by a scheduler or may be
* online (online processors have a scheduler assigned).
diff --git a/cpukit/include/rtems/rtems/sem.h b/cpukit/include/rtems/rtems/sem.h
index 31156b5e43..2729438f97 100644
--- a/cpukit/include/rtems/rtems/sem.h
+++ b/cpukit/include/rtems/rtems/sem.h
@@ -203,13 +203,13 @@ extern "C" {
* semaphore. The number of semaphores available to the application is
- * configured through the #CONFIGURE_MAXIMUM_SEMAPHORES application
+ * configured through the @ref CONFIGURE_MAXIMUM_SEMAPHORES application
* @retval ::RTEMS_INVALID_PRIORITY The ``priority_ceiling`` parameter was
* invalid.
@@ -243,7 +243,7 @@ extern "C" {
* * The number of semaphores available to the application is configured
- * through the #CONFIGURE_MAXIMUM_SEMAPHORES application configuration
+ * through the @ref CONFIGURE_MAXIMUM_SEMAPHORES application configuration
* option.
@@ -251,8 +251,8 @@ extern "C" {
* Workspace.
- * option.
* @endparblock
rtems_status_code rtems_semaphore_create(
diff --git a/cpukit/include/rtems/rtems/support.h b/cpukit/include/rtems/rtems/support.h
index 356e29739b..69cda32048 100644
--- a/cpukit/include/rtems/rtems/support.h
+++ b/cpukit/include/rtems/rtems/support.h
@@ -115,8 +115,8 @@ static inline bool rtems_is_name_valid( rtems_name name )
* value.
* @par Notes
- * The number of clock ticks per second is defined by the
+ * The number of clock ticks per second is defined by the @ref
* @par Constraints
* @parblock
@@ -166,8 +166,8 @@ static inline bool rtems_is_name_valid( rtems_name name )
* @return Returns the number of clock ticks for the milliseconds value.
* @par Notes
* @par Constraints
* @parblock
diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
index 6d643b7fbe..f28b464ec6 100644
--- a/cpukit/include/rtems/rtems/tasks.h
+++ b/cpukit/include/rtems/rtems/tasks.h
@@ -160,8 +160,8 @@ typedef struct {
* alignment of an application executable.
* The application may configure the maximum thread-local storage size for all
- * threads explicitly through the #CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
+ * threads explicitly through the @ref
size_t maximum_thread_local_storage_size;
@@ -325,8 +325,8 @@ rtems_task_priority _RTEMS_Maximum_priority( void );
* risk of blown stacks for most user applications. Using this constant when
* specifying the task stack size, indicates that the stack size will be at
* least RTEMS_MINIMUM_STACK_SIZE bytes in size. If the user configured
- * minimum stack size (see #CONFIGURE_MINIMUM_TASK_STACK_SIZE) is larger than
- * the recommended minimum, then it will be used.
+ * minimum stack size (see @ref CONFIGURE_MINIMUM_TASK_STACK_SIZE) is larger
+ * than the recommended minimum, then it will be used.
#define RTEMS_MINIMUM_STACK_SIZE STACK_MINIMUM_SIZE
@@ -454,8 +454,8 @@ typedef bool( *rtems_task_visitor )( rtems_tcb *, void * );
* The **stack size** of the task is specified in ``stack_size``. If the
* requested stack size is less than the configured minimum stack size, then
* RTEMS will use the configured minimum as the stack size for this task. The
- * configured minimum stack size is defined by the
- * #CONFIGURE_MINIMUM_TASK_STACK_SIZE application configuration option. In
+ * configured minimum stack size is defined by the @ref
+ * CONFIGURE_MINIMUM_TASK_STACK_SIZE application configuration option. In
* addition to being able to specify the task stack size as a integer, there
* are two constants which may be specified:
@@ -583,12 +583,12 @@ typedef bool( *rtems_task_visitor )( rtems_tcb *, void * );
* task. The number of tasks available to the application is configured
- * through the #CONFIGURE_MAXIMUM_TASKS application configuration option.
+ * through the @ref CONFIGURE_MAXIMUM_TASKS application configuration option.
* inactive global object available to create a global task. The number of
- * global objects available to the application is configured through the
+ * global objects available to the application is configured through the @ref
+ * CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS application configuration option.
* @retval ::RTEMS_UNSATISFIED There was not enough memory to allocate the task
* storage area. The task storage area contains the task stack, the
@@ -615,7 +615,7 @@ typedef bool( *rtems_task_visitor )( rtems_tcb *, void * );
* The task stack size shall account for an target processor dependent
* interrupt stack frame which may be placed on the stack of the interrupted
* task while servicing an interrupt. The stack checker may be used to monitor
- * the stack usage, see #CONFIGURE_STACK_CHECKER_ENABLED.
+ * the stack usage, see @ref CONFIGURE_STACK_CHECKER_ENABLED.
* For control and maintenance of the task, RTEMS allocates a TCB from the
* local TCB free pool and initializes it.
@@ -644,15 +644,15 @@ typedef bool( *rtems_task_visitor )( rtems_tcb *, void * );
* * The number of tasks available to the application is configured through the
- * #CONFIGURE_MAXIMUM_TASKS application configuration option.
+ * @ref CONFIGURE_MAXIMUM_TASKS application configuration option.
* Workspace.
- * option.
* @endparblock
rtems_status_code rtems_task_create(
@@ -690,12 +690,13 @@ rtems_status_code rtems_task_create(
* @retval ::RTEMS_INVALID_SIZE The thread-local storage size is greater than
* the maximum thread-local storage size specified in the task configuration.
* The thread-local storage size is determined by the thread-local variables
- * used by the application and #CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE.
+ * used by the application and @ref
+ * CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE.
* @retval ::RTEMS_INVALID_SIZE The task storage area was too small to provide
- * a task stack of the configured minimum size, see
- * #CONFIGURE_MINIMUM_TASK_STACK_SIZE. The task storage area contains the
- * task stack, the thread-local storage, and the floating-point context on
+ * a task stack of the configured minimum size, see @ref
+ * CONFIGURE_MINIMUM_TASK_STACK_SIZE. The task storage area contains the task
+ * stack, the thread-local storage, and the floating-point context on
* architectures with a separate floating-point context.
* @retval ::RTEMS_TOO_MANY There was no inactive task object available to
@@ -736,11 +737,11 @@ rtems_status_code rtems_task_create(
* The stack space estimate done by <rtems/confdefs.h> assumes that all tasks
* are created by rtems_task_create(). The estimate can be adjusted to take
- * user-provided task storage areas into account through the
- * #CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE application
+ * user-provided task storage areas into account through the @ref
+ * CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE application configuration
+ * option.
- * The #CONFIGURE_MAXIMUM_TASKS should include tasks constructed by
+ * The @ref CONFIGURE_MAXIMUM_TASKS should include tasks constructed by
* rtems_task_construct().
* @endparblock
@@ -760,15 +761,15 @@ rtems_status_code rtems_task_create(
* Workspace.
- * option.
* @endparblock
rtems_status_code rtems_task_construct(
diff --git a/cpukit/include/rtems/rtems/timer.h b/cpukit/include/rtems/rtems/timer.h
index 0f13c04bda..658d2517c1 100644
--- a/cpukit/include/rtems/rtems/timer.h
+++ b/cpukit/include/rtems/rtems/timer.h
@@ -284,7 +284,8 @@ typedef rtems_timer_service_routine ( *rtems_timer_service_routine_entry )( rtem
* timer. The number of timers available to the application is configured
- * through the #CONFIGURE_MAXIMUM_TIMERS application configuration option.
+ * through the @ref CONFIGURE_MAXIMUM_TIMERS application configuration
+ * option.
* @par Notes
* @parblock
@@ -308,7 +309,7 @@ typedef rtems_timer_service_routine ( *rtems_timer_service_routine_entry )( rtem
* * The number of timers available to the application is configured through
- * the #CONFIGURE_MAXIMUM_TIMERS application configuration option.
+ * the @ref CONFIGURE_MAXIMUM_TIMERS application configuration option.
@@ -600,7 +601,7 @@ rtems_status_code rtems_timer_fire_when(
* * The directive may be called from within task context.
2.35.3
