[PATCH] doxygen: Document CONFIGURE_INIT
Thu Feb 9 15:47:56 UTC 2023
 cpukit/doxygen/appl-config.h | 11 +++++++++++
 1 file changed, 11 insertions(+)
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index 5dc84824da..fb071f07d4 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -50,6 +50,17 @@
  * @ingroup RTEMSAPI
+/* Generated from spec:/acfg/if/init */
+ * @brief This define enables the generation of the application configuration.
+ * While ``CONFIGURE_INIT`` is defined, when ${header-confdefs:/name} is
+ * included, the application configuration is generated according to the
+ * application configuration options provided by the user.
+#define CONFIGURE_INIT
 /* Generated from spec:/acfg/if/group-bdbuf */
2.35.3
